Hydrogenaudio Forums
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: remiamy on 2019-03-09 00:13:32
Title: Shuffle tracks of album A, then shuffle tracks of album B, etc.
Post by: remiamy on 2019-03-09 00:13:32
Hello !
I love Foobar, but there's one thing I can't figure how to do :
I have a playlist with all 10 albums. I would like to listen to all tracks of album 1 played in a shuffled order, then to all tracks of another album (choosen randomly, let's say album 6) in a shuffled order, etc.
Some players (like Poweramp) offer that option, but Foobar is so much better on other sides that I don't considering switching. Is there a way to do this in Foobar ?
Thank you very much !
Rémi
Title: Re: Shuffle tracks of album A, then shuffle tracks of album B, etc.
Post by: lvqcl on 2019-03-09 07:51:56
You can change your playlist:
1) Edit -> Sort -> Randomize
2) Edit -> Sort -> Sort by... -> type %album% and press Enter
Post by: remiamy on 2019-03-09 11:27:17
Hi lvqcl,
This helps, but it's not exactly what I'm asking :)
I've done what you've written and it absolutely makes it for once. But my question is : is there a way to automatize this, so that whenever I listen to a playlist, with the "Shuffle (albums)" options, it plays all albums with each album getting its tracks shuffled ?
Your solution implies that I do this every time I want to listen to a playlist, and do it again if I don't want the tracks the same order as the last time.
I know I'm picky. I guess you're picky when you love music :)
Post by: remiamy on 2019-03-14 11:23:47
Hello,
No one can help on this ?
Thanks,
Rémi
Post by: Daeron on 2019-03-14 16:06:39
What you want isn't possible as far as I know, that's why lvqcl gave you the closest approximation.
Post by: Simon_ Thunder on 2019-03-15 23:05:47
Hello,
Thanks,
Rémi
Well.
I try to help you but it takes some time how to figure out this request.
Post by: Simon_ Thunder on 2019-03-16 18:29:10
You can do this only if you
1.Create 10 playlists (one album for playlist)
2. Configure:
A. foo uie exlorer(fast creates playlists)  - https://hydrogenaud.io/index.php/topic,34207.0.html
B. foo scheduler(jumping to nex playlist when all track are played in album A) - https://www.foobar2000.org/components/view/foo_scheduler
C. foo removeplayed (remove played tracks)  - https://hydrogenaud.io/index.php/topic,50312.0.html
or foo playlist attributes (remove played tracks) - https://hydrogenaud.io/index.php/topic,73783.0.html
