Hydrogenaudio Forums
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: khashayar on 2018-11-05 20:29:23
Title: [Android] Foobar2000 Music Folder
Post by: khashayar on 2018-11-05 20:29:23
Where is it?
Title: Re: [Android] Foobar2000 Music Folder
Post by: khashayar on 2018-11-07 13:25:10
Hi!
Does anyone know where the "Foobar2000 Music Folder" is?
or how can we use it?
Post by: tpijag on 2018-11-08 01:19:00
As far as I know, it is where you put your music. That is, in the settings for the library, you point/tell the library where you have placed your music files.
Post by: kode54 on 2018-11-08 02:57:31
It is a folder within the application's local storage. I'm not really sure how one goes about accessing it on Android devices.
(On iOS devices, it's accessible as the application's Documents folder, which you can access through iTunes or other software.)
Post by: khashayar on 2018-11-08 06:48:19
That's "Music on Internal Storage" Folder not "foobar2000 Music Folder", which is accessible from the devices storage "root/Music"
but I don't know any directory for the other.
Post by: zeremy on 2018-11-08 11:22:17
On my android device the Foobar2000 Music Folder is located at
ROOT/DATA/DATA/COM.FOOBAR2000.FOOBAR2000/DATA/MUSIC
Post by: khashayar on 2018-11-09 09:41:33
I couldn't find such a directory, is it there by default or you created it yourself?
the only thing I've found:
Root/Android/data/com.foobar2000.foobar2000/data
which is an empty directory.
Post by: zeremy on 2018-11-09 10:30:36
It is the application's local storage location visible only with root access.
Post by: khashayar on 2018-11-09 10:37:11
So how are we to use that?
is it considered for normal Storage of Music/Audio files?
do you use "root/Music" or "ROOT/DATA/DATA/COM.FOOBAR2000.FOOBAR2000/DATA/MUSIC" for your own Music?
why does this option exist at all?
Post by: zeremy on 2018-11-09 10:45:28
I personaly use root/Music.
If I remember correctly there is an option in TuneFusion (https://forum.dbpoweramp.com/showthread.php?39617-TuneFUSION-Release-1-Beta-Windows) to use that folder for synchronization.
Maybe @spoon can give more information.
Post by: kode54 on 2018-11-11 02:59:14
You can use foobar2000 itself to permanently download and save local copies of network links to static files, or at least I think it can do that.
Post by: zoumbro on 2019-08-09 11:07:28
Did anyone find the music folder?  I can understand why it is unaccessible
