Hydrogenaudio Forums
Lossless Audio Compression => FLAC => Topic started by: Thomas C. on 2018-10-09 00:17:43
Title: Cover/artwork storage?
Post by: Thomas C. on 2018-10-09 00:17:43
Are covers/artworks:
- stored as image in the *.flac files?
- not store in the file but use a reference to a file?
- does it depend on the tagging program?
Title: Re: Cover/artwork storage?
Post by: Chibisteven on 2018-10-09 06:07:30
Either one you want.
In File Positives
- Tends to be more compatible with some applications.
- Much more portable and convenient, especially with singles if you store them in different directories with each other and occasionally move them to different directories.
- It's cleaner in the directories where the files themselves are stored.
In File Negatives
- Very large images may not fit if you embed a ton of different ones (disc art, front and back covers, booklets).
- Takes more space with whole albums.
Linked Positives
- Saves space when it comes to whole albums.
- Can store a ton of different images of stuff at larger file sizes than what most files will have padding for.
Linked Negatives
- Not very portable, especially with singles if you store them in different directories with each other and occasionally move them to different directories.
- Messier in directories that store the files themselves.
Post by: Porcus on 2018-10-09 07:38:48
Not to forget: Some media players are happy to search in the same directory as the media file.
Post by: Thomas C. on 2018-10-09 11:32:55
Post by: lvqcl on 2018-10-09 16:47:20
Foobar2000 seems to look in priority for file-embedded pictures, then folder images.
There's a setting in foobar2000 Advanced preferences: Display -> Album art -> Embedded vs external.
For some files I changed with Mp3Tag, Foobar2000 didn’t seem to see the changes right away. Made me think there some caching going on?
Don't set option "preserve modification time", foobar2000 relies on this info.
Post by: j7n on 2018-10-09 17:52:38
Positive for using an image file in the same directory:
- Artwork can be easily updated later with a better quality (accurately cropped, square) without using special software or modifying audio files.
- You can tell that artwork is present, and look at it in full size using any image viewer.
few kilobytes smaller than files just ripped with "Embed album art" = false. Which makes me wonder what resulting the difference inside the file is,
New files without artwork include a small amout of padding to allow adding more metadata tags without rewritting the entire file to make room. The metaflac command line removed all padding.
Post by: Thomas C. on 2018-10-09 18:19:09
Thank you.
Why? Do you mean it uses modification date for some caching purpose? Or else?
Post by: Roseval on 2018-10-09 21:35:49
Most media players employ the same strategy.
As scanning all the audio files and reading the tags is very time consuming, they do so once and store all the tags in a database.
Next time they scan the file system for changes.
Only if a file is modified, they read the tags anew.
This is much faster of course.
By now I think you could guess what happens when you change a tag e.g. art work and suppress changing the date modified :)
Post by: Thomas C. on 2018-10-09 22:02:36
Got it.
The thing is that I don't use any kind of media library, I just use the file system.
Even on portable MP3/Flac player I do not browse things like "Artists" or "Albums" but rather "Folders",
Post by: Porcus on 2018-10-09 23:38:01
Do they? Do they store all the album art in a database? It isn't a searchable text field, so ...
Post by: kode54 on 2018-10-10 04:11:08
foobar2000 mobile has an in-memory image cache, including memory for pre-resized images for different display intents, but I don't know what desktop foobar2000 does in that regard.
Oh, and putting this out here: Remember, Windows Media Player on Windows 10 now (probably at least since 1803) defaults to only tagging in a central database, and has to be instructed to actually alter files on disk.
Post by: Roseval on 2018-10-10 10:14:45
Not necessarily in a database but the ones known to me like JRiver, MusicBee, WMP, etc do  extract the coverart and store them in a cache.
