Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: kgena_ua on 2017-09-22 10:36:51
Title: Biography Text, Album Info, Picture. www.last.fm
Post by: kgena_ua on 2017-09-22 10:36:51
WSH Biography Text, Album Info, Picture. www.last.fm
language - left mouse double click on the text (or main menu or menu properties to set);
font size - shif + mouse wheel on the text;
move text - press left mouse button on the text and move;
previous, next img. - mouse wheel on the img;
selsect artist or album img. - left mouse double click on the img  (order by most popular or release date - menu);
img. interval setting - shift + mouse wheel on the img;
Title: Re: Biography Text, Album Info, Picture. www.last.fm
Post by: musikomaniak on 2017-09-22 12:12:55
Thank you @kgena_ua  :)
Post by: 西门浪子哥 on 2017-09-23 01:54:35
Thank you , always use your script!
Post by: kgena_ua on 2017-09-23 16:59:22
glad to be useful
Post by: ADDVOiCE on 2017-10-06 10:21:04
а можно скрипт паправит так, штоб с начала брал инфо с поля REMIXED BY, а потом (если инфо нет) уже с ALBUM ARTIST ?
мне как то правилнее если у песни дапустим ABBA (remix от TIESTO) паказывал дискографию TIESTO
Post by: jazzthieve on 2017-10-06 11:40:55
Violation TOS  #10 (https://hydrogenaud.io/index.php/topic,3974.html#post_tos10). You must post in English.
Post by: ADDVOiCE on 2017-10-07 10:25:31
sorry, can you delete my message (i translate with google) ?
Post by: ADDVOiCE on 2017-10-07 10:30:28
Is it possible to adjust the script so that at the beginning it will be taken info from the REMIXED field, then (if there is no information) from the ALBUM ARTIST field?
It seems to me more logical, for example: the song ABBA remixed TIESTO, so better that the TIESTO discography is displayed.
THANK YOU for answer.
Post by: kgena_ua on 2017-10-09 10:39:27
Biography, Albums, Similar artist info. www.last.fm
version 06102017
language - left mouse (or left mouse + Shift)  double click on the text  (main menu or menu properties to set);
font size - Shif + mouse wheel on the text or text header (menu properties to set);
hide text - mouse mbtn dblclk on the text header;
select artist, albums or similar artisr info - left mouse double click on the img  (main menu);
img. interval setting - Shift + mouse wheel on the img;
for advanced settings see menu properties.
The script is not compatible with the previous version, saved data must be deleted/
Post by: ADDVOiCE on 2017-10-09 19:29:25
thanks, super :)
Post by: musikomaniak on 2017-10-10 14:48:10
Thank you. Works perfect.
Post by: lender1257 on 2017-10-11 07:41:52
@kgena_ua
can't get album-review
(old bio-tool gets album-review)
language: english
changed to album: most popular or release date - nothing found
i'm using foo_jscript-panel 1.3.0 and
your tool 06102917
please have a look at it,
thx
Post by: kgena_ua on 2017-10-11 09:09:50
@lender1257,
I think you have not deleted the old data from the folder " ...\tmp_Biography".
(do not delete folder "_download")
Post by: lender1257 on 2017-10-11 09:30:25
this is a complete fresh installation of your tool
my settings:
http://de.tinypic.com/r/2450im8/9
http://de.tinypic.com/r/30x9bns/9
Post by: kgena_ua on 2017-10-11 10:39:38
I'll check it at home
Post by: lender1257 on 2017-10-11 12:55:36
hi
can you please also implement a remap-field for %artist%?
owing to different spellings
thx
Post by: kgena_ua on 2017-10-11 18:15:49
@lender1257
I do not even know. I checked it with foo_jscript_panel-v1.3.0.
Works good
Spoiler (click to show/hide)
Post by: lender1257 on 2017-10-12 06:38:13
hi
thanks for checking.
in the video your script shows in line 1811 "var btn=WshShell ... Foobar 2000 ..."
in my downloaded script (version: 06102017 feature: v1.4) there isn't such a line
my script ends with line 1786
if i change to "similar artists" always "text not found"
any idea what i have done wrong or did i grab the wrong sript ?
Post by: lender1257 on 2017-10-13 07:25:33
@kgena_ua
error found; it was my mistake, changed parameter "download limit" to zero
                   i thought concerned pics only
script works
feature request: album-review of playing %album%
                         remap-field %artist%
thx
Post by: kgena_ua on 2017-10-16 13:59:04
All right, the script ends on line 1786.
I additionally wrote a function for deleting empty folders and testing it now.
Post by: lender1257 on 2017-11-22 07:09:29
hi
are you planning to expand your script like wrote in post #18 ?
Post by: kgena_ua on 2017-11-25 05:42:43
@lender1257,
You mean to add a search for an %artist% - %album%  that is playing or currently selected
Post by: lender1257 on 2017-11-25 06:49:39
hi
kgena_ua
yeah, double-click on panel changes from "bio %artist%" to "album-review %artist% + %album%" and reverse.
if not possible, then an extra script
first, a way to overwrite %artist% (remap %artist%) would be very good. with this you could correct different spellings.
thx
Post by: hikaze on 2017-11-26 13:08:46
Hi
kgena_ua,
Thank you very much. I have used this script,It is very helpful to get the music's information.
But it has some little problems:
1)It omit some special charactors,like as "*,/,.". It will be much better to change these charactors to '_'.
2) It cann't fetch the playing music's album cover.(Not the artist's pop album)
3) When you change the music quckily,it will get wrong images.(settings:prefer now plaing)
4)  It will be much better if it can set these parameters: the dowloaded image path(default: tmp_Biography) ; the artist's images's suffix(_?_images);the  album's images(eg.: $if(%album artist%,%album artist% - %album%,%filename_ext%)
Could you please fix these problems? I find this script is the best than others so far.
Have a good day!
Post by: lender1257 on 2017-11-29 08:15:32
@kgena_ua
really great script !!!
if you include "album review" in the context menu, please change in properties,"default img path" to "default img path bio" and allow a new path for "album review" (default img path album review).
so that 2 different images can be displayed if nothing is found.
thx
Post by: kgena_ua on 2017-12-02 19:20:41
@kgena_ua
thx
lender1257, thanks.
I'm thinking about reviewing the album. The idea is interesting.
My problem is my English. Basically, I understand, but the subtleties
Post by: lender1257 on 2017-12-03 16:37:22
@kgena_ua
i've sent you a mail
Post by: kgena_ua on 2017-12-28 16:04:44
There were some changes on the LastFM website.
Biography & Albums & Similar artist info. www.last.fm
version "15122017
for wsh panel mod and jscript panel
language - left mouse (or left mouse + Shift)  double click on the text  (main menu or menu properties to set - select en,it,zh,de,pl,pt,ru,tr,fr,sv,ja);
for advanced settings see menu properties;
added: background transparency under the text - Ctrl + mouse wheel on the text.
over all wishes I work
Post by: lender1257 on 2017-12-30 10:18:23
@kgena_ua
i PMed you
Post by: lender1257 on 2018-01-17 13:04:41
@kgena_ua
hi
version 171215 crashes on both panels (jscript + wsh)
(http://[IMG]http://i63.tinypic.com/210x348.jpg)[/img]
Post by: lender1257 on 2018-01-25 10:34:09
no one else has this problem?
Am I doing something wrong?
Post by: kgena_ua on 2018-01-27 09:44:33
Hi.
Unable to create folder "tmp_Biography" - permision denied.
Post by: lender1257 on 2018-01-27 10:34:01
hi kgena_ua
no chance to get version 15.12.2017 running
updating from old to new script --> crash
new installation:
i have deleted jscript- and wsh-panel totally; deleted tmp_Biography
inserted jscript-panel new with script from 15.12.2017 --> crash, same error as described.
when i delete tmp_biography and i start foobar without playing music (stop), tmp_biography and the bio of the last played %artist% will be allocated automatically.
hope you can help
Post by: lender1257 on 2018-01-27 15:10:35
@kgena_ua
i have found an error in your script 15.12.2017
changed it, and now new version is doing fine
changed red marked field from old to new
Post by: lender1257 on 2018-02-02 22:30:57
@kgena_ua
another crash with version 15.12.2017
field "priny" not defined; line 1613 - at a change of the %artist%
could it be that this should be "print" ???
please have a look on it
thanks
Post by: kgena_ua on 2018-02-07 15:16:32
@kgena_ua
thanks
lender1257, this is not a mistake, it's my inattention. Thanks.
Post by: lender1257 on 2018-02-07 16:21:26
hi kgena-ua
I assume it's print. (I don't know this programming language.)
I like your script very much.
what i'm missing is a remap-field for %artist% in properties.
this field should be very long and fillable with titleformatting script. so that every user can enter what he wants.
I myself have almost 800 different %artist% and last-fm doesn't always save as I do it.
the result should then be used to search as %artist%.
I hope you can make this possible. then the script would be perfect, for me.
best regards
Post by: lender1257 on 2018-02-13 07:39:56
@kgena_ua
another please:
please include a refresh-function in your script. (delete folder and new download)
to fix download-errors
thanks
Post by: kgena_ua on 2018-02-19 08:14:17
"Biography & Albums & Similar artist info. www.last.fm"
version "18022018"
Added: review of playing or selected album.
language - left mouse (or left mouse + Shift)  double click on the text  (main menu  to set);
select artist, albums (most popular and release date), similar artisr or album info - left mouse double click on the img  (main menu);
The script is not compatible with the previous version, saved data must be deleted.
Post by: lender1257 on 2018-02-19 09:39:57
hi kgena_ua
really great work; all works perfect
thanks
are you planning to install the other features i've posted ?
this is for you - for great work
Post by: kgena_ua on 2018-02-19 14:37:08
this is for you
Thank.
this field should be very long and fillable with titleformatting script. so that every user can enter what he wants.........
if I understand correctly you want to be able to, for example through a dialog box, enter the name of the artist.
Post by: lender1257 on 2018-02-19 15:58:23
hi
1) maybe in properties a new line named "remap artist". (very large)
in this field i will enter with titleformatting script, all changes of my %artist%-tags, so last.fm will find the text.
if "remap-field" not is space search with this new "remap-field" as %artist%, in all other cases with %artist%.
for example:
$if($or($strcmp(%artist%,'ALLMAN BROTHERS BAND'),$strcmp(%artist%,'ALAN PARSONS PROJECT'),$insert(%artist%,'THE ',0),),)$replace(%artist%,'CHRIS FARLOWE & THE HILL','CHRIS FARLOWE WITH THE HILL')$replace(%artist%,'YUSUF','CAT STEVENS')
means:
my tag                                  result in remap-field (should be like in last.fm)
ALLMAN BROTHERS BAND     THE ALLMAN BROTHERS BAND
ALAN PARSONS PROJECT       THE ALAN PARSONS PROJECT
CHRIS FARLOWE & THE HILL   CHRIS FARLOWE WITH THE HILL
YUSUF                                  CAT STEVENS
2) refresh function (maybe under "delete empty folders")
thx
Post by: kgena_ua on 2018-02-20 09:04:48
for example:
means:
thanks I understood
Post by: lender1257 on 2018-02-20 12:55:10
hi
maybe remap %album% (i don't use it) could be useful for other people
thx
Post by: kgena_ua on 2018-02-25 12:00:30
if it will be so
Post by: lender1257 on 2018-02-25 13:55:54
script - no download possible
Post by: kgena_ua on 2018-02-25 14:11:02
lender1257 ,
whitch script - no download possible
Post by: lender1257 on 2018-02-25 16:33:15
I'm sorry, I thought you already finished it.
input line is ok.
thx
Post by: kgena_ua on 2018-03-03 16:37:24
"Biography, Albums, Similar and title artist info. www.last.fm"
version "030322018"
Added:
review of playing or selected album;
menu item "Refresh" (default is false, see menu Properties);
remap artist (menu Properties);
"img border thickness"  (menu Properties).
select artist, albums (most popular or release date), similar artist, album or title info - left mouse double click on the img  (main menu);
Post by: kgena_ua on 2018-03-03 17:42:29
Added:
My mistake
Added:
review of playing or selected title;
Post by: lender1257 on 2018-03-04 07:06:46
hello kgena_ua
thank you very much
all works perfect
you're great
thx a lot
Post by: kgena_ua on 2018-03-05 15:41:15
lender1257,
glad to be useful
Post by: kgena_ua on 2018-03-09 17:31:49
version "030322018"
for jscript panel v2.0.6
Post by: 西门浪子哥 on 2018-03-10 11:47:50
hello kgena_ua
thank you very much
all works perfect
you're great
thx a lot
I work fine with foo_uie_wsh_panel_mod 1.56
good!
Post by: lender1257 on 2018-03-12 12:55:36
hi kgena_ua
bio: searching for THE V.I.P.'s (availabe in english last.fm) but script founds: THE VIP's (= false artist)
can you please make a correction.
thx
Post by: kgena_ua on 2018-03-17 08:02:48
Hi.
Is it? If no give me a LastFM link
Post by: lender1257 on 2018-03-17 08:26:55
hi
yes, script finds this wrong artist
link for correct artist: https://www.last.fm/music/The+V.I.P.%27s
thx
Post by: kgena_ua on 2018-03-24 05:20:38
version "240322018"
Post by: lender1257 on 2018-03-24 05:57:54
hi kgena_ua
works perfect
thx
Post by: kgena_ua on 2018-06-17 16:26:09
version "15062018"
While only for WSH panel
Post by: kgena_ua on 2018-06-18 13:12:44
version "15062018"
for jscript panel
Post by: Sergey77 on 2018-06-18 16:55:55
Hi kgena_ua!
I gladly tested your component (for jscript panel), there are positive improvements.
It is making a good alternative.
Keep it up!
Regards.
Post by: kgena_ua on 2018-06-20 17:33:53
Sergey77, thanks, I like it myself
Post by: aloola on 2018-06-22 15:19:38
thanks for good work.
would you bring these options back ?
https://imgur.com/a/ohXvY3q
(https://i.imgur.com/Bf0MqMs.png)
Post by: kgena_ua on 2018-06-23 09:40:17
displayed menu items from another of my scripts - "Get Covers (Artwork) radio logos".
Post by: lender1257 on 2018-07-11 16:18:43
version "15062018"
for jscript panel
hi
script crashes when using jscript 1.3.2.2
getcolour should be getcolor (9 times)
Post by: tvenissat on 2018-08-22 03:06:36
Thank you for all of your hard work, kgena_ua. This component is one of my favorites! Also, I'm not sure where to post bug reports but I hope its alright to post the fix here. If there is no active internet connection and the biography is not cached, then a crash occurs. Here is a screenshot of the error:
The fix was to replace this line (around line 549, use control+f to search):
if (this.xmlhttp != null && this.func != null) {if (this.xmlhttp.readyState == 4) {if (this.xmlhttp.status == 200) this.func(); else {this.on_search_done_callback(artist, list, done, handles);}}}
with this line:
this.on_state_change = function() {
if (this.xmlhttp.status == 200) {
this.func();
} else {
if (this.on_search_done_callback != null) {
Now, the null check prevents the script from crashing and instead displays placeholder text. Attached are images of each event. Also, GetColour() works on the current version of JScript Panel. That error only affects older versions.
Post by: WilB on 2018-08-22 11:53:02
It seems that this report concerns JScript Biography 0.9.0.2 (https://hydrogenaud.io/index.php/topic,112913.msg952419.html#msg952419), and would have been best put in the discussion thread (https://hydrogenaud.io/index.php/topic,112914.0.html) dedicated to that. Not to worry, I'll try and fix it for the next version. However, it's not actually currently obvious to me why your fix worked, since the callback is defined (line 542) as it's sent to the master function (line 541). I couldn't seem to reproduce the issue. Anyway I'll think about it further. Line 549 in the release version is also just a "}" and not an object and so I would like to be sure that the issue occurs with the script in a completely unmodified state. Please post any further discussion here (https://hydrogenaud.io/index.php/topic,112914.0.html).
Thanks for the report.
Post by: kgena_ua on 2018-08-22 18:09:35
"22082018"
Post by: tvenissat on 2018-08-22 19:02:45
Well, this is embarrassing. I'm sorry for the inconvenience.
Post by: lender1257 on 2018-08-23 11:20:48
"22082018"
@kgena_ua
what's new in this version?
please always post your changes
thanks
Post by: kgena_ua on 2018-08-24 07:01:01
thanks
- optimization;
- added lyrics for the selected track;
- changes in the main menu (see "Menu setting");
- added external links for artists and related artists.
Post by: lender1257 on 2018-08-24 13:26:21
thanks
- optimization;
@kgena_ua
additional question:
is this script for wsh_panel_mod or
for jscript 1.3.2.2 or
for jscript 2.1.6
please also provide this information in the future if you change your script
thank you
Post by: kgena_ua on 2018-09-16 05:11:29
version "14092018"
Minor corrections and optimization .
Added:
- when viewing information about the artist, the meaning of the lines "popular this week" and "the latest releases" are clickable (double click).
The saved data (if saved) must be deleted, or use the menu item Refresh.
The Properties menu must be updated.
The script is compatible with:
- wsh_panel_mod ;
- jscript_panel (all version).
Post by: kgena_ua on 2019-01-08 17:11:16
version "30122018"
Added:
- smooth scroll.
- wsh_panel_mod ;
Post by: hikaze on 2019-02-23 13:01:33
Hello,
kgena_ua,
I have used the newest script. Could you please make some changes for more better?
1)one special character,like dot ".". It can not be changed to dot"."(keep the same).
2)It can  not set the path of the  album's images in one seperate directory.(named as %album artist% - %album%)
3) I don't need some information for XXX_the _artist_info.ini.(except:external_links,born)
I wish you make this to be the one best excellent script tool.
 :)   ;D  :))   :D
Post by: hikaze on 2019-02-24 02:49:49
And 4) if the search information is empty,don't create this artist's folder.(add a property like as setting:  "remap artist").Thanks. ;D
Post by: hikaze on 2019-02-24 05:45:51
Hello, I found that "remap artist" and "Unkown Artist"(no information) can be one function.(Add a fuction button "remap"- "remap to Unkown Artist and delete the folder"(like black list)). By the way,some artists have no other language's translation.(like as no information)(It will be much better to fetch the correct language information automatily.)
Post by: kgena_ua on 2019-03-30 19:33:38
hikaze,
I will think
Post by: Sergey77 on 2019-04-08 16:25:47
Hi there!
@kgena_ua,
Please add the lock mode with the "lock" button on the script field window. Because sometimes a song ends (image and text change) before you have time to read the text and view the images (for example when listening to internet radio).
It would also be nice to add a mode of fixed separation of text and image excluding overlay.
Thanks for this great script!
Post by: kgena_ua on 2019-04-18 09:43:36
Hi there!
@kgena_ua,
Very interesting.
As you see it. Menu item, hotkey or something else. How to call this feature. How should this work.
Post by: Sergey77 on 2019-04-18 16:55:50
Conveniently if it would be the "Lock" button as shown at the picture (highlighted in red).
If the user clicks on the "Lock" button, mode is on - when the music track and the artist change, but the picture and text do not change, they remain for the previous track and artist.
If the user clicks on the "Lock" button again, mode is off and the script continues to work as usual.
Thank you!
Post by: hikaze on 2019-04-20 15:18:27
Hello,This script took a long time to load.(more than 8s, sometimes > 30s).(Some reason is that I used 2 script in Panel.)
I think this script need to speed up the load speed.It used too many function clean(). Sorry,I don't much more ability to improve with it. I'm a new learner.
208 line:(The special characters do not need to be customized.I think that another plugins also handled it simply.)
var tmp = n.replace(/[\/\:\*\?\"<>\|\\]/g,"_");
Post by: kgena_ua on 2019-06-27 17:56:45
"Biography, albums, title, similar artist info.www.last.fm."
@version "27062019"
jscript panel, wsh panel mod.
Add:
- new customizable main menu - see menu item "Main menu setting";
- lock mode - left mouse button dblclk  on header_1 (artist);
- collapse / expand additional info text - popup button between header_2 and main text;
- menu item "Hisory" - view previously downloaded data if it is stored in the tmp_Biography folder (by default).
Saved data reload.
Before installation, clear variables - the "Properties" menu.
Post by: udege on 2019-07-05 21:45:10
Hi! Last.fm again changed the design ... Every time it gets worse! And the photos stopped loading ...
Post by: kgena_ua on 2019-07-07 13:38:40
udege,
new test version you can find here
http://foobar2000.ru/forum/viewtopic.php?t=1878&p=73458#p73458 (http://foobar2000.ru/forum/viewtopic.php?t=1878&p=73458#p73458)
Post by: emaulana on 2019-07-09 16:10:19
No update? Still "No Photo" in Biografi.
Post by: kgena_ua on 2019-07-10 14:08:35
emaulana,
see previous post
Post by: lender1257 on 2019-07-10 14:33:38
hi kgne_ua
I'm using your script from 20180324 (JScript1.3.2.2) - any chance to update this too?
does your newest script have the option to disable some information?
i only want to see the artist-name and the biography; all other information in between is useless information for me
thanks
Post by: emaulana on 2019-07-10 14:48:59
emaulana,
see previous post
Ok, it is working now. Thank u for your script bro. My Foobar2000 is look beautiful again.
Post by: lender1257 on 2019-07-10 19:41:59
@kgena_ua
sorry, I didn't read your mail well enough. the function is already inside.
thank you
Post by: kgena_ua on 2019-07-13 17:46:53
@version "13072019"
Minor fixes.
"External links" work.
Added the ability to view text using the keys UP, DOWN, PAGE_UP, PAGE_DOWN, HOME, END.
LEFT and RIGHT keys to change the image.
Accordingly, the panel should be active (selected, left-click on the panel, for example).
Post by: lender1257 on 2019-07-13 20:06:02
hi kgena_ua
works perfect - great work !!
Post by: hexenszene on 2019-07-14 11:06:51
Great script.  Thanks for making this.
Post by: kgena_ua on 2019-09-01 12:15:52
version "24082019"
Changes in the history menu section:
- history list navigation - Mouse, Up, Down, Page Up, Page Down, End, Home keys;
- artist selection - left mouse button, Enter key;
- deleting a list item - menu, Delete key;
- delete history list - menu.
Minor changes and improvements.
Properties needs to be updated.
Post by: kgena_ua on 2019-09-05 20:41:07
need your recommendations for improvements
