Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: Boltex on 2011-08-01 22:25:06
Title: foo_lastfm_radio not working w/ my new fb2k; how to remove/deactivate?
Post by: Boltex on 2011-08-01 22:25:06
Hello. I have a layout of Ibiza and foo_lastfm_radio.dll. This component is not compatible with my fb2k in version 1.0.3. May know where in the files can manually remove the component that was not used? Because from what I know is the newest of this component is not there. So it's probably the only solution or disable it somewhere in the preferences.
Post by: Zarggg on 2011-08-02 20:40:01
I don't recall if 1.0.3 had the new components system, but if it does, just remove the component through the options. If you don't know how to do that, you should read foobar2000's documentation.
Post by: Boltex on 2011-08-02 23:22:54
I found new componet and work!
