Hydrogenaudio Forums
Hosted Forums => foobar2000 => Uploads - (fb2k) => Topic started by: fismineur on 2011-02-22 00:47:42
Title: foo_flv
Post by: fismineur on 2011-02-22 00:47:42
Allows you to play Flash Video (.FLV) files on foobar2000.
This currently supports PCM, MP3, and AAC audio codecs.
Download Flash Video Decoder 0.9.0: [attachment=6371:foo_flv_090.zip]
Title: foo_flv
Post by: fismineur on 2011-02-25 23:55:50
Flash Video Decoder 0.9.1: [attachment=6377:foo_flv_091.zip]
Title: foo_flv
Post by: fismineur on 2011-03-01 02:54:50
Flash Video Decoder 0.9.2: [attachment=6380:foo_flv_092.zip]
Title: foo_flv
Post by: fismineur on 2011-03-14 00:11:03
Flash Video Decoder 0.9.3: [attachment=6401:foo_flv_093.zip]
Title: foo_flv
Post by: fismineur on 2011-03-24 02:03:51
Flash Video Decoder 0.9.4: [attachment=6408:foo_flv_094.zip]
Title: foo_flv
Post by: fismineur on 2011-05-21 12:08:56
Flash Video Decoder 0.9.5: [attachment=6517:foo_flv_095.zip]
Title: foo_flv
Post by: doublehd on 2011-10-02 14:47:40
thank you so much for the plugin,it works on my V1.1.8
Title: foo_flv
Post by: hungcuonga7 on 2011-12-14 11:13:32
Thank you very much
This component work in fb 1.1.10
Title: foo_flv
Post by: a2621379 on 2011-12-14 11:15:17
Thank you
Title: foo_flv
Post by: devcon on 2012-04-26 13:16:49
  • Minor performance improvements.
thank you so much
Title: foo_flv
Post by: Porcus on 2012-04-26 17:18:08
Dang. Didn't know this existed. Well since I have learned to reencapsulate into mp4, I will go on doing that ...
Title: foo_flv
Post by: hgx on 2012-07-01 14:43:53
Thank you.
This plugin is very userfull.
but it not work with ".f4v" Extension file.
i wish you can fix it at next update.
Title: foo_flv
Post by: 80T on 2012-12-21 11:52:15
I've been looking for this for a long time. Big THX fismineur (http://www.hydrogenaudio.org/forums/index.php?showuser=88370)
I was losing faith that such plugin will be ever made for foobar2k...
Now I can listen all my music in foobar Woot!
Title: foo_flv
Post by: hungcuonga7 on 2012-12-23 14:31:47
not work on foobar2000 v1.2 beta 2
Title: foo_flv
Post by: lvqcl on 2012-12-24 18:11:24
And it seems that it doesn't work correctly with HE-AAC encoded audio tracks.
Title: foo_flv
Post by: Porcus on 2012-12-24 22:23:44
Another two reasons to extract the streams and reencapsulate them in .mp4 or .m4a.
(Is there any downside to this unless you depend on having the precise original file? Assuming that the streams fit the MP4 container, that is? (Could foo_flv play those which cannot?))
Title: foo_flv
Post by: fismineur on 2012-12-29 02:38:59
Discussion thread:
http://www.hydrogenaudio.org/forums/index....showtopic=87021 (http://www.hydrogenaudio.org/forums/index.php?showtopic=87021)
Title: foo_flv
Post by: fismineur on 2012-12-29 02:50:39
Flash Video Decoder 0.9.6: [attachment=7267:foo_flv_096.zip]
Title: foo_flv
Post by: hungcuonga7 on 2012-12-29 04:14:12
Thanks for update
Title: foo_flv
Post by: antonyb on 2013-02-14 11:07:18
I downloaded the file, it tells me that it is damaged, why?
Title: foo_flv
Post by: EpicForever on 2013-03-12 19:41:52
Just redownload it. If problem persist use other browser (IE if you are normally using FF or other way round).
BTW:
Thank you fismineur for this component so much. When combined with Converter component it allows to do everything with audio from YT...
Title: foo_flv
Post by: antonyb on 2013-03-12 20:14:47
BTW:
Thank you, I already got it.
