Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: kjoonlee on 2007-10-27 09:41:43
Title: foo_rg_trn
Post by: kjoonlee on 2007-10-27 09:41:43
Replaygain override (http://www.acc.umu.se/~zao/foobar2000/) (foo_rg_trn), configureable at Preferences | Playback | Replaygain override.
(See Frank Bicking's original post for screenshot, please.)
This plugin was previously linked from:
http://www.hydrogenaudio.org/forums/index....showtopic=48223 (http://www.hydrogenaudio.org/forums/index.php?showtopic=48223)
http://www.hydrogenaudio.org/forums/index....showtopic=57523 (http://www.hydrogenaudio.org/forums/index.php?showtopic=57523)
Is there any chance it will get support for 0.9.5's random order?
Title: foo_rg_trn
Post by: reil on 2007-10-27 16:23:27
it shows up on mine.
Title: foo_rg_trn
Post by: cristox on 2007-10-27 16:50:53
here too
Title: foo_rg_trn
Post by: mrinferno on 2007-10-27 18:21:54
yip, me too.
Title: foo_rg_trn
Post by: Zao on 2007-10-27 20:03:30
Heh, I didn't think there were anyone else than TrN that thought that the plugin was a good idea.
The current issue with it is that the last shuffle is not listed in the settings, due to Random pushing them shuffles down a step.
I went over my source when 0.9.5 beta 1 was released and I could not find any harmful effects of this, just the aforementioned mislabeling and missing order.
I'll fix this bug soon and make a post here when I do.
Title: foo_rg_trn
Post by: Zao on 2007-10-27 21:20:05
There we go, 0.1.2 should work fine in both 0.9.5 and 0.9.4.x.
The override settings may be displaced when upgrading, but since there's a brand new shiny mode, you probably want to adjust them anyway.
My plugins (http://www.acc.umu.se/~zao/foobar2000/)
foo_rg_trn-0.1.2.zip (http://www.acc.umu.se/~zao/foobar2000/foo_rg_trn-0.1.2.zip)
foo_rg_trn-changelog.txt (http://www.acc.umu.se/~zao/foobar2000/foo_rg_trn-changelog.txt)
Title: foo_rg_trn
Post by: Seldaek on 2007-10-27 21:20:48
Thanks once again for this Zao.
Title: foo_rg_trn
Post by: mrinferno on 2007-10-27 21:31:27
ah, just updated and now i see what was happening, thanks for the update!
Title: foo_rg_trn
Post by: kjoonlee on 2007-10-28 09:34:29
Thank you!
Title: foo_rg_trn
Post by: Valery_Kondakoff on 2008-06-26 10:23:26
Thank you!
Works well on FB2K 0.9.5.4b2. Thank you for very useful plugin!
Title: foo_rg_trn
Post by: Sounds Blast on 2008-06-26 22:33:45
DOES NOT WORK FOR ME ON, FB2K 0.9.5.4b2 It loads but i hear no difference. I set default replay gain to none, and selected the replaceable override to my desire with no difference. Still too loud, went back to default replay gain setup and works correctly. So, am i doing something wrong or did you just load the .dll and said it worked fine, because it dont work for me yet.
Edit: seems to be working now, had to restart to reset the playback setting, and i had to keep my playback settings in the default replay gain playback set. Pretty nice plugin.
Title: foo_rg_trn
Post by: Zao on 2008-07-27 09:45:38
You had me scared there that I might have to dig into the horrible ball of mud the source code for the plugin is. Good to hear that you got it working.
Title: foo_rg_trn
Post by: Sounds Blast on 2008-07-29 23:29:00
yep, works great. thanks for this very USEFUL plugin  Just had to re-set my play back options for the plugin to make the changes that i made. ( really it's a one time set up and you are good to go, thanks to all those option you enabled us to choose from.
Title: foo_rg_trn
Post by: Zao on 2010-01-13 23:11:03
For the half dozen users this component has: it's now updated to the new preferences page system of 1.0 in 0.1.3.
Component download page (http://www.foobar2000.org/components/view/foo_rg_trn)
Title: foo_rg_trn
Post by: Hamallainen on 2010-01-13 23:30:31
I find it very useful.
Title: foo_rg_trn
Post by: Scidd0w on 2010-01-14 13:46:39
Thank you very much Zao!
Although I don't see the settings page that often, it's more of a set it and forget it component, I do find this component very usefull.
(I'm still hoping for a something similar component for the standard crossfader dsp!)
Title: foo_rg_trn
Post by: Squeller on 2010-01-14 13:57:32
Thank you! I think there are more than a half dozen users. 7 maybe
Title: foo_rg_trn
Post by: Zao on 2010-01-14 13:58:21
If I were to do that (which I do not currently), I would do it much like my eqsplit component.
That component is a DSP that contains several Equalizer DSPs. It splits the audio into several channels, feeds it through the respective equalizer and re-merges it again.
A conditional crossfader would remember the current playback order and bypass the contained crossfader DSP when appropriate.
Title: foo_rg_trn
Post by: seigert on 2010-01-14 14:03:08
7 maybe
...or even 8!
Title: foo_rg_trn
Post by: Scidd0w on 2010-01-14 14:44:23
Sounds like the perfect solution for me!
Title: foo_rg_trn
Post by: gob on 2010-01-15 07:33:57
Thanks Zao. I'm using it here too =]
Title: foo_rg_trn
Post by: _stranger_ on 2010-01-15 10:26:38
Same here. Keep this plugin up.
Thank you very much!
Title: foo_rg_trn
Post by: Reflection on 2010-04-10 23:48:03
Thanks, this is exactly what I needed
I usually listen in Shuffle Tracks or Shuffle Album mode... this works perfectly!
Title: foo_rg_trn
Post by: edwardar on 2010-04-11 08:31:23
Great plugin! I'm always forgetting to switch replaygain mode back to album from track after using shuffle!
Title: foo_rg_trn
Post by: Porcus on 2012-01-13 11:47:48
Feature suggestion: choose track mode or album mode based on path pattern.
(I'd like to choose track mode for my various artists folders.)
Title: foo_rg_trn
Post by: EpicForever on 2014-01-29 21:26:47
I am reviving this old topic because it is not the first time when I doubt if this plugin works. But this time I have clear evidence.
My default RG behavior is "track mode" and "apply gain and prevent clipping according to peak". But in RG Override dialog I have set that when I listen to my music in "Repeat (Playlist)" mode, then RG should be working in "album mode". This is not happening. Listening to my brand new Discogs purchase - Robert Henke's "Floating.Point" have revealed this permanently. I have set order to "Repeat (Playlist)". When "Chowning Island" ends and "Plankton" begins, then volume suddenly drops down - because "Plankton" is simply louder at certain points and thus it has smaller track RG values... Is it possible that this plugin will be repaired to still work in foobar 1.2.9 or newer?
Title: foo_rg_trn
Post by: Avi on 2014-06-23 16:15:06
It is not working for me either. When I change the value in the main RG option, I can see the waveforms adjust. When I make the changes with the radio buttons, nothing happens.
Title: foo_rg_trn
Post by: Zao on 2014-06-23 19:27:32
Fun fact - this forum unsubscribes you silently from threads that have been stalled for a year.
It's possible that the mechanism used to request replaygain mode changes is different, or an additional commit step would have helped.
It would also have helped if someone approached me with these problems instead of just venting in a thread and assuming I'm ignoring it for half a year.
Title: foo_rg_trn
Post by: Zao on 2014-06-24 23:46:01
Avi: This component assumes it's the only one messing with the global RG settings. It re-applies the radio buttons whenever the playback mode changes. If you change the global settings, it will not be aware of this and not apply the right one.
It will also assume that the settings left since last shutdown are the ones that are in place when starting up, so if you've got something else messing with this then, you're also doomed.
I don't know how to reproduce your problems as the descriptions and tracks mentioned are out of my reach. Does this keep happening with a vanilla installation without any weird script-based UIs and bells and whistles?
I'm trying to get familiar with the code again, but I see nothing out of the ordinary at all, nor am I aware of anything in foobar2000 that would change how something as fundamental as playlist events would be handled.
I need some proper steps to reproduce, preferably in a clean environment. State your assumptions and actions.
Title: foo_rg_trn
Post by: RiCON on 2014-09-29 17:04:14
I did notice a volume change from track to track when RG was supposed to be using album info instead of track.
I can confirm it's because I was changing the global RG settings without changing playback order.
Title: foo_rg_trn
Post by: ChronoSphere on 2015-02-26 16:29:49
Just ran into the same issue. If I have RG set to "none" in foobar's output config, none is applied even though foo_rg_trn is set to album mode. Same other playback/gain modes.
Title: foo_rg_trn
Post by: ChronoSphere on 2015-02-27 00:18:20
Err, scratch that, it's actually working for me. For some reason I've set one mode to "none" and forgot about it...
