Hydrogenaudio Forums
Hydrogenaudio Forum => Validated News => Topic started by: menno on 2007-03-12 09:44:29
Title: Results: 80 kbps LC AAC listening test
Post by: menno on 2007-03-12 09:44:29
Here are the final results for the IS/PNS 80 kbps LC AAC listening test:
http://www.audiocoding.com/results/image003.gif (http://www.audiocoding.com/results/image003.gif)
http://www.audiocoding.com/results/image004.gif (http://www.audiocoding.com/results/image004.gif)
Since the main reason for this test was to determine whether PNS and/or IS gives any advantage, results where only low anchor was identified were not counted.
Chunky was used with option -p 0.05 to remove results with a wrong grading.
Key, encoders used, results used and ratings are in FinalResults.zip (http://www.audiocoding.com/results/FinalResults.zip).
Results that were not used because no relevance for this test are in NotUsed.zip (http://www.audiocoding.com/results/NotUsed.zip).
Thanks to everyone who helped us with this test!
Post by: Maurits on 2007-03-12 10:57:17
So, would you conclude there is no reason to use either IS or PNS or both at bitrates as high as 80kbps in your codec?
Post by: menno on 2007-03-12 12:13:01
Yes, the results show that our current implementation of IS and PNS have no benefit over not using it. Given the cons of using these tools (read: iPod can't decode it properly) it is probably not a good idea to enable them.
Post by: Maurits on 2007-03-12 12:49:12
OK. Are you thinking of enhancing the current implementation or starting a new listening test at a lower bitrate to determine the threshold?
I agree on the cons, try to keep it LC as much as possible/desirable.
Post by: Sebastian Mares on 2007-03-12 13:48:02
Would LC even make sense at a lower bitrate?
Post by: SebastianG on 2007-03-12 14:23:56
According to FCD 14496-3 (http://sound.media.mit.edu/mpeg4/audio/documents/) IS and PNS are part of the MPEG4 "AAC low complexity" profile.
The test results are interesting. All confidence intervals overlap so you can't say for certain that one setting performs better than another. I guess it's just trading different kinds of artefacts for Ahead's current implementation. I wonder if there's room for improvement. I expected the IS / PNS tools to be more useful, actually.
Cheers!
SG
Post by: sketchy_c on 2007-03-12 14:32:05
I personally wouldn't think so especially if PS/INS cause compatibility problems.  Not even sure what players can decode LC-PS/INS but not HE.  Rockbox?
Thanks for posting the results, menno.  Glad I could help a little.
Post by: muaddib on 2007-03-12 14:57:40
Why not if you have a device which supports only LC and quality is acceptable? It is always better to have more songs on a device
Post by: spoon on 2007-03-12 19:40:38
Sort of reminds me of all those people who wanted to encode to mp3pro when it came out at 128 Kbps or above...
About the ipod, are there patent fees for decoding PNS / IS?
Post by: menno on 2007-03-13 06:59:19
Nothing extra, if you have an AAC license you can do PNS and IS, it's part of LC AAC.
Post by: Maurits on 2007-03-13 09:54:13
If it is more complex to decode it may be a battery issue.
Post by: menno on 2007-03-13 10:14:10
If it was intentional, it wouldn't sound like it does now.
Post by: Ivan Dimkovic on 2007-03-13 10:15:52
Complexity should actually decrease for IS as less MDCT data should be decoded
Same goes for PNS, too.
I wouldn't go into speculating why Apple iPod has no PNS support, but my best guess would be that it was just not tested because iTunes Encoder does not use PNS... but could be any other reason as well.
Post by: Maurits on 2007-03-13 11:42:29
Hhmm... I see.
Well, considering there is a new Apple AAC codec coming with OS X Leopard (http://www.hydrogenaudio.org/forums/index.php?showtopic=47526&st=0&p=424105&#entry424105) and native FLAC support, who knows what else they'll change in the audio department.
I am more or less expecting HE-AAC, at least for streaming playback, since iTunes is starting to lose out on more and more radio stations by not supporting it.
Post by: plonk420 on 2007-03-16 10:17:04
when you guys do the next test, throw an email my way. i can encode samples using AAC on my PS3... uses the 3gp container format, tho o_O
Post by: dannyb37 on 2007-03-20 03:29:02
Quick Answer SONY, the psp could only playback aacs in that back when!
