Hydrogenaudio Forums
Hosted Forums => foobar2000 => Development - (fb2k) => Topic started by: foosion on 2006-03-24 11:51:48
Title: Developer Tutorials
Post by: foosion on 2006-03-24 11:51:48
The following is a list of the known tutorials for componet developers for foobar2000 0.9.
SDK readme
Not a real tutorial, but nevertheless a required read.
Included in the SDK.
General Component Tutorial
This tutorial explains how to use some of the commonly used features with an emphasis on general purpose features. The tutorial does not show how to create an input, output or DSP component.
Download (http://foosion.foobar2000.org/0.9/tutorials/#general)
DSP Component Tutorial
This tutorial explains how to implement a DSP service - either with presets or without.Download (http://foosion.foobar2000.org/0.9/tutorials/#dsp)
Post by: Synthetic Soul on 2006-03-24 12:33:01
Good work again foosion.
The comments are superb.
Is it dumb of me to point out that, once you have closed the window, it won't come back again?
Post by: foosion on 2006-03-24 12:41:04
No, I think you have found I bug there. I'll try to confirm (and fix) this later.
Post by: foosion on 2006-03-24 14:12:06
Post by: Eric on 2006-03-26 15:27:52
I am new on this part of the forum. Since I am using Foobar for 2 years, I would like to have a look of a development process.
But what are the requirements ?
I have downloaded and installed
- Visual C++ 2005 Express edition
- Foobar2000 SDK
- and now, these tutorials.
I have seen that foo_tutorial1 solution need to have the projects of the SDK of the same directory level (meaning extracting the foo_ in "foobar2000" directory created by the SDK), each foobar2000_*  is now loaded, but some projects are still missing: "components", "librairies" and "sdk".
Do I need the .NET SDK for that?
Other topic: is the database model documented? What kind of DB it is?
Post by: foosion on 2006-03-26 17:54:41
- Foobar2000 SDK
You also need the Windows Platform SDK.
Those are not projects, but "solution folders"; in other words, they are merely a means to organize projects in a VS solution.
Post by: TrNSZ on 2006-03-31 03:49:00
[deleted]
Post by: mixcherry on 2006-03-31 22:30:54
What is preventing Peter from releasing source code for such plugins as Autoplaylist Manager or Playback Statistics?... That would help me a lot on my way to become The Plugin Developer  And, as far as I remember, there were a lot more sample plugins included in 0.8.3 SDK. Where have they gone?...
Post by: the_LefthAND on 2006-04-01 00:00:19
i'm a newbie in developing foobar plugin, and always I find people that use only Visual C++ to develop and compile foobar2000 plugin. What about using Mingw-32? Do somebody use it to compile foobar2000 plugins?
Bye,
the_lefThAND.
Post by: TrNSZ on 2006-04-01 03:57:57
[deleted]
Post by: foosion on 2006-04-01 10:56:53
GCC is not currently capable of compiling the source code due to bugs and missing C++ features.  Hopefully this situation will change one day.[a href="index.php?act=findpost&pid=377703"][{POST_SNAPBACK}][/a]
You will also need C++ ABI compatibility with Microsoft's compilers, not only for the vtable but also for C++ exceptions.
However, you should be aware that Microsoft Visual Studio Express and the required Platform SDK are both free downloads from Microsoft, for now.[a href="index.php?act=findpost&pid=377703"][{POST_SNAPBACK}][/a]
The Platform SDK has been free for quite some time; it contains the toolchain (including an optimizing compiler) and all the header files and stuff you need to produce Windows binaries.
Note that ATL or MFC are only available with the non-Express versions of Visual Studio; (some) resource editors are also missing in the Expresss version, in particular the dialog editor. Nonetheless, the resource compiler is included with the Platform SDK.
Post by: the_LefthAND on 2006-04-01 12:47:07
I didn't know these limits of gcc, so i will try to use visual c++ express.
Post by: andrei5008 on 2006-06-09 14:02:29
is there any way to have the projects for Visual Studio 2003? Unfortuanatelly, VS2003 and VS 2005 can coexist peacefully on the same OS, and I really need 2003.
I tried to do build the projects manually, but unfortunatelly the tutorial give some compile error that doesn;t appear on 2005.
Post by: Florian on 2006-06-09 14:23:39
The foobar2000 0.9 SDK is only available for Visual Studio 2005. There is also a freely available Express edition.
Post by: Moitah on 2006-07-17 06:55:16
Any idea why the DSP tutorial won't compile for me?  I'm using the 2006-06-22 SDK and get this error:
c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\dsp.h(321) : error C2259: 'service_impl_t<T>' : cannot instantiate abstract class
        with
            T=dsp_tutorial_nopreset
        due to following members:
        'void dsp_impl_base_t<t_baseclass>::on_endoftrack(foobar2000_io::abort_callback &)' : is abstract
        with
            t_baseclass=dsp_v2
        c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\dsp.h(121) : see declaration of 'dsp_impl_base_t<t_baseclass>::on_endoftrack'
        with
            t_baseclass=dsp_v2
        'void dsp_impl_base_t<t_baseclass>::on_endofplayback(foobar2000_io::abort_callback &)' : is abstract
        with
            t_baseclass=dsp_v2
        c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\dsp.h(127) : see declaration of 'dsp_impl_base_t<t_baseclass>::on_endofplayback'
        with
            t_baseclass=dsp_v2
        'bool dsp_impl_base_t<t_baseclass>::on_chunk(audio_chunk *,foobar2000_io::abort_callback &)' : is abstract
        with
            t_baseclass=dsp_v2
        c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\dsp.h(133) : see declaration of 'dsp_impl_base_t<t_baseclass>::on_chunk'
        with
            t_baseclass=dsp_v2
        c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\dsp.h(318) : while compiling class template member function 'bool dsp_entry_impl_nopreset_t<T>::instantiate(service_ptr_t<dsp> &,const dsp_preset &)'
        with
        c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\service.h(406) : see reference to class template instantiation 'dsp_entry_impl_nopreset_t<T>' being compiled
        with
        c:\stuff\code\foobar2000 sdk 0.9.2\foobar2000\sdk\dsp.h(372) : see reference to class template instantiation 'service_factory_single_t<T>' being compiled
        with
            T=dsp_entry_impl_nopreset_t<dsp_tutorial_nopreset>
        .\foo_dsp_tutorial.cpp(133) : see reference to class template instantiation 'dsp_factory_nopreset_t<T>' being compiled
        with
If I comment out these lines in the tutorial:
static dsp_factory_nopreset_t<dsp_tutorial_nopreset> foo_dsp_tutorial_nopreset;
static dsp_factory_t<dsp_tutorial> foo_dsp_tutorial;
Everything compiles fine.  But I kind of need those 2 lines .
Post by: Moitah on 2006-07-17 22:03:33
Nevermind, I got it (a few things need to be changed in the tutorial to make it compatible with the latest SDK).
Post by: andrei5008 on 2006-08-09 16:07:12
What about some documentation of the API? There are a lot of classes and functions, but except the these tutorials, there's no other inspiration source.
At least some DOXYGEN generated API summary.
Post by: Zastai on 2006-10-23 15:21:39
2003 & 2005 can work on same machine just fine - 2005 sets up explorer so that it opens solutions/projects with the same version that was used to create them.  Just be sure to install 2003 first.
Post by: AndyCar on 2006-11-16 18:23:00
Moitah, could you please explain what did you do to the DSP tutorial to make it compile fine with the latest SDK?
Post by: Spirit_of_the_ocean on 2006-11-27 16:10:34
I have one question: I want to modify the window in step 2 to see if  I understand at least a bit of what is in this tutorial.
I have Visual C++ Express 2005 Edition: How can I create a dll?
I am shure I read it in this somewhere in devellopers section but I can't find it anymore.
Post by: kanex on 2006-12-28 16:27:37
Post by: Moitah on 2007-01-01 22:57:19
Sorry for taking so long to respond, I didn't see this until now.  I think I just had to add an extra parameter to some functions:
virtual bool on_chunk(audio_chunk * chunk) {
becomes
virtual bool on_chunk(audio_chunk * chunk, abort_callback &) {
virtual void on_endofplayback() {
becomes
virtual void on_endofplayback(abort_callback &) {
Also I see this function in my code which isn't in the tutorial, I'm not sure if it was required to make it work or not:
virtual void on_endoftrack(abort_callback &) {
Post by: Hancoque on 2007-04-28 15:38:40
@Moitah: I added the abort_callback parameter to the two functions but I still get a compile error. It seems that the implementation of the on_endoftrack function is required as you assumed. Can you (or anyone else) tell me how this function has to be implemented in foo_dsp_tutorial.cpp? I tried but didn't get it to work.
This is the exact compile error description:
c:\foobar2000\foobar2000\sdk\dsp.h(321) : error C2259: 'service_impl_t<T>' : cannot instantiate abstract class
        with
        with
            t_baseclass=dsp_v2
        c:\foobar2000\foobar2000\sdk\dsp.h(121) : see declaration of 'dsp_impl_base_t<t_baseclass>::on_endoftrack'
        with
            t_baseclass=dsp_v2
        c:\foobar2000\foobar2000\sdk\dsp.h(318) : while compiling class template member function 'bool dsp_entry_impl_nopreset_t<T>::instantiate(service_ptr_t<dsp> &,const dsp_preset &)'
        with
        c:\foobar2000\foobar2000\sdk\service.h(413) : see reference to class template instantiation 'dsp_entry_impl_nopreset_t<T>' being compiled
        with
        c:\foobar2000\foobar2000\sdk\dsp.h(372) : see reference to class template instantiation 'service_factory_single_t<T>' being compiled
        with
        c:\foobar2000\foobar2000\foo_dsp_tutorial\foo_dsp_tutorial.cpp(133) : see reference to class template instantiation 'dsp_factory_nopreset_t<T>' being compiled
        with
Post by: Hancoque on 2007-04-29 01:00:37
It's working now. I didn't notice that I had to implement the function two times (for each class). I thought the error was still there when it was in fact a new error coming from the second class. But right after that I got new compile errors. For now I have removed the second class (with presets). The class without presets compiles without any new errors. So I finally have *something* to start with.
Post by: foosion on 2007-07-03 12:37:15
Update to foo_tutorial1. The component now queries and uses the global setting for showing keyboard shortcuts in menus. Only the on_contextmenu method in steps 3 and 4 is affected.
Before:
        // Create a menu_manager that will build the context menu.
        service_ptr_t<contextmenu_manager> cmm;
        contextmenu_manager::g_create(cmm);
        // Set up flags for contextmenu_manager::init_context.
        // Initialize menu_manager for using a context menu.
        cmm->init_context(items, contextmenu_manager::FLAG_SHOW_SHORTCUTS);
After:
        // Query setting for showing keyboard shortcuts.
        const bool show_shortcuts = config_object::g_get_data_bool_simple(standard_config_objects::bool_show_keyboard_shortcuts_in_menus, false);
        unsigned flags = show_shortcuts ? contextmenu_manager::FLAG_SHOW_SHORTCUTS : 0;
        cmm->init_context(items, flags);
Post by: Tuzz on 2007-10-14 08:43:12
I managed to compile SDK, and SDK helpers, but i have errors compiling step1:
step1.obj : error LNK2019: symbole externe non résolu __imp__RegisterClassW@4 référencé dans la fonction "public: struct HWND__ * __thiscall window_tutorial1::create(struct HWND__ *)" (?create@window_tutorial1@@QAEPAUHWND__@@PAU2@@Z)
step1.obj : error LNK2019: symbole externe non résolu __imp__LoadCursorW@8 référencé dans la fonction "public: struct HWND__ * __thiscall window_tutorial1::create(struct HWND__ *)" (?create@window_tutorial1@@QAEPAUHWND__@@PAU2@@Z)
foobar2000_sdk_helpers.lib(window_placement_helper.obj) : error LNK2001: symbole externe non résolu __imp__IsWindow@4
foobar2000_sdk_helpers.lib(window_placement_helper.obj) : error LNK2019: symbole externe non résolu __imp__GetWindowPlacement@8 référencé dans la fonction "public: bool __thiscall cfg_window_placement::read_from_window(struct HWND__ *)" (?read_from_window@cfg_window_placement@@QAE_NPAUHWND__@@@Z)
Post by: foosion on 2007-10-14 10:05:55
The missing functions are from the Win32 API. Do you use Visual C++ 2005 Express? If so, you should check that the Windows SDK (previously called Microsoft Platform SDK) is installed correctly, specifically that the library directory is set up correctly in the IDE.
Post by: Tuzz on 2007-10-14 17:57:19
you're right, i've forget to modify a file
Post by: foosion on 2008-09-04 22:48:54
I've updated the DSP tutorial. It now compiles with the latest foobar2000 SDK. There is still a warning message about a deprecated dialog helper class from the SDK, I plan to get rid of that in the next version.
Post by: mccarver on 2009-06-08 19:38:42
Nevermind. Found what I was looking for
Post by: grodriguez on 2009-06-26 02:52:45
Hey guys,
Maybe this is a really newbie question but here it goes.
I compiled and tested the tutorial component but is there an easier way of making modifications to it other than:
1. Modify
2. Compile
3. Close foobar
4. Copy .dll to components folder
5. Open foobar
6. Try
Cheers
G
Post by: Yirkha on 2009-06-26 10:53:45
Set output target directory to ...\foobar2000\components directly, or add a post-build step to copy it there, and set ...\foobar2000\foobar2000.exe as debugged process in project properties. Just hit F5 (Run) to do everything automagically each time after that.
Post by: grodriguez on 2009-07-07 01:33:30
Thanks Yirkha, I'll try that ...
G
Post by: foosion on 2009-10-23 20:12:49
I've updated the DSP tutorial. There was an old bug in the dsp_tutorial_nopreset::flush() method.
Post by: sunshine_fen on 2010-02-02 06:51:46
I'm a new on this part. Recently, I want to have a look of the development process.
I have download and installed,
-VC 2005
-Windows platform SDK
And get SDK-2010-01-19.zip. But when I unzip it, I can not find the "SDK-test" solution file.
Is there anything wrong?
Post by: Yirkha on 2010-02-14 15:50:56
No, the .sln file is just not bundled with this version. Create a solution yourself and add all the projects (search for *.vcproj).
Post by: sunshine_fen on 2010-02-25 04:07:00
Thanks Yirkha!
I have another problem,
Is there any method to debug the project?
How can I see the value/state of a parameter?
Post by: Yirkha on 2010-03-01 14:04:34
Yes, see this (http://yirkha.fud.cz/tmp/496351ef.tutorial-draft.html) (but note it's old, it might fairly outdated in some other regards).
Post by: Blood HaZaRd on 2010-04-11 20:56:17
Hi Foobares  . As i'm new here and really addicted to contribute into the devolepment of foobar, i was wandering if one momber of the commity could tell me what EDI we should install (microsoft visual 6, 2003, 2005 or later ) and others related staff !!
Thank you
Post by: Blood HaZaRd on 2010-04-12 00:21:16
well, i downloaded MVS C++ Express edition 2008. and i tried to compile the foobar project but when compiling it told me to specify the name of the exec to use. COuld some one tell me or give a tuto or a little help to surpass this nooby handicap.
Post by: Girid on 2010-09-16 00:13:22
I have been developing a plugin that I finally got to a point where I would like to share it but when I switch the configuration over from debug to release in visual studio 2010, I get numerous errors for my project along the lines of "error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL':".  All of the separate components for the SDK compile fine in release mode, it is only when I try to make a component dll that I get these errors.  I have tried doing the same for the sample projects mentioned here and I get the same errors.  Has anyone seen this before or have any ideas about how I should go about fixing this?
Post by: Yirkha on 2010-09-16 00:20:17
You have part of the projects build with debug and part with release configurations. Make sure your Release configuration reference Release .libs of other components, that you don't force /D_DEBUG options for compiler even in Release configuration etc.
Post by: Girid on 2010-09-16 18:45:03
Thanks Yirkha.  For some reason when I was switching over to release, some of the projects were switching over to the Multi-Thread libraries and some to the Multi-Thread DLL libraries.  Just switched them all to the Multi-Thread and it worked fine.
Post by: popatr on 2011-01-13 16:54:30
I have seemingly successfully compiled the general component tutorial, and loaded it into foobar:
but when I start foobar (v1.1.1) I can't see the component's main menu item.  The component is visible in the components list and can display it's simple about form.
Post by: popatr on 2011-01-25 14:56:45
Nevermind my last post, I was incorrectly looking for a preferences dialog, not a link under the view menu where I should have been looking.
Post by: Ditchbuster on 2011-07-05 22:26:46
the link seems to be broken to download the General Component Tutorial.
Post by: foosion on 2011-07-06 06:14:40
Fixed. Thanks for noticing.
Post by: Ditchbuster on 2011-07-06 16:42:30
Thanks for fixing!
Title: Re: Developer Tutorials
Post by: tipar on 2016-09-05 01:06:27
So, If I read all of this documentation I will be able to do a component from the scratch? If not, where can I look for that?
Post by: aidivn on 2016-10-18 07:25:53
I want to read REM DISCNUMBER of cue file
Post by: icepopo on 2016-12-30 19:41:34
I am having a problem with atl. I've installed the wtl and successfully compiled(and run) foo_sample. But I'm not able to make it work in a solution made from scratch. I added all the files from foo_sample to the solution, next set up the linker and added all the projects from sdk. It compiles fine, but when running in foobar I'm getting 'Internel error - one or more of the installed components have been damaged. How can I make it work?
Post by: foosion on 2016-12-30 20:12:52
Have you added the required references under "Frameworks and references"? Right click the project "Solution explorer" and choose "References...". You'll need to add at least pfc, foobar2000_component_client and foobar2000_SDK. Most projects will additionally need foobar2000_sdk_helpers and foobar2000_ATL_helpers.
I'm not entirely sure what the error message means but it sounds like the DLL might lack the proper entrypoint function. This in turn would indicate that foobar2000_component_client is not linked into the DLL.
Post by: kode54 on 2016-12-30 20:36:59
Perhaps it is a mismatched name to the component filename verification service, versus installing the component to the Application\components folder instead of Configuration\user-components\foo_component_name?
Also, that service is always a good idea if you ever care about receiving crash reports, as it can be bothersome loading minidumps where the DLLs have been renamed from your original build filenames.
Post by: icepopo on 2016-12-30 20:47:30
I wouldn't think that that service exists! Thanks for the help.
Post by: kode54 on 2016-12-30 21:24:56
VALIDATE_COMPONENT_FILENAME is the macro, it declares an implementation of the component validation service, styled to check your filename on disk. It can be expanded through more complex means to perform more thorough verification, although filename is usually all you need to care about for minidump concerns.
Post by: magicgoose on 2018-10-23 09:34:58
Is there something similar for Android version of foobar2000?
Post by: Case on 2018-10-23 11:00:56
No. Mobile versions don't support third party components. I'm pretty sure it's not even allowed, certainly not allowed for Apple Store.
Post by: magicgoose on 2018-10-24 15:16:02
There's a lot of things that Apple doesn't allow but fortunately this doesn't affect Android.
On Google Play & Android it's possible to add extra modules as separate APK files if they are published and signed by the same person. So the foobar2000 author will need to upload them in the end, but they can be developed by someone else.
Deadbeef player (Android version) used this mechanism to offer extra decoder pack as a separate APK.
Post by: lvqcl on 2018-10-24 17:30:17
So, foobar2000 author will be responsible for those 3rd party plugins made by unknown authors? Sounds like a bad idea.
