Hydrogenaudio Forums
Hydrogenaudio Forum => Scientific Discussion => Topic started by: TimYork on 2003-09-10 17:35:15
Title: Stochastic Processes in Audio Processing
Post by: TimYork on 2003-09-10 17:35:15
I'm in a class called "Advanced Stochastic Processes" this semester, and we have to do a project applying the mathematics of probabilty theory to engineering in some fashion.  I was considering using audio processing for a topic.  If anyone can help me out with info or articles, it would be of great aid.  I'd hate to have to do the project on financial engineering.
Post by: Jasper on 2003-09-10 18:52:31
Why don't you do it on compression, it has a lot to do with probability (for example, the entropy of a file is calculated based on the probabilities of the different values, more or less), here are two links that deal with compression:
http://www.cs.auckland.ac.nz/~peter-f/ (http://www.cs.auckland.ac.nz/~peter-f/)
http://www.data-compression.com/lossless.html (http://www.data-compression.com/lossless.html)
But there is lots more on the subject (both online and offline).
If you want to do it about lossless audio compression you might want to have a look at a program I made together with a friend of mine, it allows you to experiment with different methods of prediction and encoding of the residual signal, and there is quite a lot of documentation (in Dutch) for it, as well as some configuration files we used to perform tests, if you need them:
http://sourceforge.net/projects/pws-sces/ (http://sourceforge.net/projects/pws-sces/)
Post by: TimYork on 2003-09-10 22:59:19
Thanks for the info.  I'll talk with the instructor tomorrow about it, and see if he thinks it's worthy of consideration.
Post by: jmvalin on 2003-09-11 08:22:06
You can try anything related to speech recognition or speaker verification/identification. It's basically one big statistical model (gaussian mixtures, HMM's, ...)
