Hydrogenaudio Forums
Lossless Audio Compression => Lossless / Other Codecs => Topic started by: JDPCC on 2020-04-15 01:33:50
Title: Unable to open item for playback (24-bit WMA Lossless decoding is broken on Wind
Post by: JDPCC on 2020-04-15 01:33:50
Running Windows 10 version 1909 OS Build 18363.778, Foobar2K 1.53, FFmpeg Decoder Wrapper 0.5.5 (FFmpeg builds 4.2.2 for ffmpeg.exe and ffprobe.exe).  Trying to implement the patch to get my 24BPS (bits per sample) WMA files to play with Foobar2K.  I get the error message when trying to play a file of this format:  "Unable to open item for playback (24-bit WMA Lossless decoding is broken on Windows 10, use foo_input_ffmpeg to decode this file):
Windows uses the same file extension (WMA) for both the 16 and 24 BPS and I don't want to use the using the FFmpeg Decoder Wrapper to decode the 16 BPS files since they play fine.  Is there a way using the FFmpeg Decoder Wrapper to identify the 24 BPS WMA files?  As far as I can tell I can only add a "WMA" file extension to the list of files to convert.
As a side note Windows Media Player, VLC Media Player,  Groove Music, and Wave Pad Sound Editor have no problem playing these files.  Foobar2K is pointing to Windows as the culprit however since the files play in other music players I am thinking it may be Foobar2K that has the problem.
Title: Re: Unable to open item for playback (24-bit WMA Lossless decoding is broken on Wind
Post by: Case on 2020-04-15 05:50:46
There isn't a way to only use ffmpeg for 24-bit WMAs.
The OS codec is blocked because it doesn't decode all files correctly. The prevention protects your data.
Post by: Rollin on 2020-04-15 12:06:10
There is way to use ffmpeg to decode 24 bit files and decode all other wma files as before. But it requires renaming files (all files can be ranamed in one go with foobar2000). Give double extension to 24 bit files, for example 24l.wma instead of wma, so all software will still see them as normal wma files. Then set up Ffmpeg decoder wrapper to decode *.24l.wma files and in Decoder priority list move Ffmpeg decoder wrapper higher than foobar2000 wma decoder. Don't forget to restart foobar2000.
Foobar2000 is pointing to Windows as the culprit because fb2k uses Windows' decoder and it is broken.
Post by: For Serious on 2020-06-26 18:51:41
If I remember correctly, Windows fixed their issue with version 1904. It just foobar2000 that has not re-enabled playback.
Post by: Case on 2020-06-26 20:21:17
You remember incorrectly. I just verified with Windows 10 version 2004 running latest updates that its built-in WMA Lossless codec can't decode problem tracks bit-perfectly.
Post by: For Serious on 2020-09-09 17:46:39
Humm okay. I guess that would explain why all my 24 bit WMA lossless files produce silent tracks when converting to wav with dBpoweramp. Oddly enough though, I can convert them to flac and then to wav as a work around.
Post by: Porcus on 2020-09-11 09:58:57
Should https://wiki.hydrogenaud.io/index.php?title=Lossless_comparison be updated when it comes to WMAL?
Software support: "Abandoned" or something.
Or throw it over to "Other" together with Shorten and Real Lossless.
