Hydrogenaudio Forums
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: MetaPixel on 2019-07-18 22:47:01
Title: Difference/relationship between Buffer lenght and Read-ahead
Post by: MetaPixel on 2019-07-18 22:47:01
I store my music (mostly FLACs) on an external hard drive. If I leave the player paused in the middle of a song, come back minutes later and press play the song will play for a second, stop for two while the hard drive wakes up, and then resume as usual.
Both of these options were left as default on my foobar2000 installation (output > buffer length 1000ms, advanced > playback > buffering > read-ahead for local files and full file buffering up to (kB) : 0).
What are the differences/relationship between these two, and what would be the best option/course of action to prevent this behavior?
Title: Re: Difference/relationship between Buffer lenght and Read-ahead
Post by: A_Man_Eating_Duck on 2019-07-18 23:46:14
When I was using a similar set up I would just increase the output buffer length to 7000-8000ms. Increasing the buffer length will increase the amount of ram being used by foobar if that is a possible area of concern.
Post by: Rollin on 2019-07-19 22:59:55
Output buffer contains data after decoding and passing DSPs. Read-ahead buffer contains undecoded data read from file.
Post by: PleasantSounds on 2019-07-21 05:25:42
Make sure this setting is checked:
    Advanced -> Playback -> Prevent hard disk sleep while playing
Post by: MetaPixel on 2019-07-23 01:29:32
Yes, 5000ms were enough to make the problem go away. Thank you for the info.
Post by: MetaPixel on 2019-07-23 01:51:52
Wow now it makes a lot more sense, thanks for the insight.
Post by: MetaPixel on 2019-07-23 08:53:19
Enabled this a month ago, but on my experience it seems to only prevent sleep... while playing, though it seems like the appropriate behavior.
