Hydrogenaudio Forums
CD-R and Audio Hardware => CD Hardware/Software => Topic started by: KaiStone on 2019-04-03 18:51:29
Title: Yamaha CRW-F1 and AccurateRip Offset
Post by: KaiStone on 2019-04-03 18:51:29
Software: EAC 1.3 & dBpoweramp 16.1
Hardware: Yamaha CRW-F1E (1.0g) & TSSTcorp TS-H653Z (HD00)
Burning Software: Nero 7 & ImgBurn
It has been long ago since the last time I ripped a CD with EAC, but Iam still familiar with it. The first time setup EAC with my F1, I pay most attention on AccurateRip Offset calculation.
As usual, I insert a Accurate Key CD and waiting for the result +733. But EAC shows a notice that Offset miss-matched and the result now is +739  :o I insert some more CDs but it's still the same +739 all the time.
It happens also with the H653Z drive. The offset should be +6 but it's now +12. Why does it always have a margin exactly 6 samples? Those CDs burned by Yamaha F1.
I burn some new CDs (same source, same NRG, same FLAC) by H653Z. This time EAC shows correct result as AccurateRip databases, Yamaha F1 is +733 and H653Z is +6.
Iam so confused. I even re-burn a CD with Yamaha F1 again but every CDs come from F1 leads to wrong offset results with exactly +6 samples margin. It happens both while I burn with or without A.M.Q.R.
Anyone could explain me this situation?
And what offset should I use?
Or should I use +739 for CDs from Yamaha F1 and +733 for CDs from H653Z?
Title: Re: Yamaha CRW-F1 and AccurateRip Offset
Post by: korth on 2019-04-03 22:32:25
The Yamaha CRW-F1E = +733 & TSSTcorp TS-H653Z = +6 for the 'read offset correction'.
The AccurateRip Key Disc should be a factory CD not a burned CDR for proper detection. Many drives also require you to know the 'Write Sample Offset' to burn the audio data in the same position as a factory CD.
You can use a CDR to find the 'write sample offset' once you know 'read offset correction'.
https://web.archive.org/web/20080613155140/http://www.digital-inn.de/exact-audio-copy-english/36668-read-write-offset-correction-what-proper-settings.html
A CDR created with the Yamaha CRW-F1E giving +739 as a combined read/write offset would mean the 'write sample offset' would be +6.
+739 - +733 = +6
which would match this database (scroll down to see search result)
https://www.daefeatures.co.uk/search?model=CRW-F1E&c2=All&manufacturer=0&overread=All&accurate_stream=All&caching=All&htoa=All
Post by: KaiStone on 2019-04-04 09:21:34
+739 - +733 = +6
That's exactly what I was thinking, but 1 thing is not clear here is Nero 7 and ImgBurn not be able to burn with Write Sample Offset. I did write an Offset Test CD with EAC, and it shows the result +727, quite understandable.
I know "The AccurateRip Key Disc should be a factory CD not a burned CDR for proper detection". So in my situation, as I burned a lot of CDs from NRG with Yamaha CRW-F1, what Read Offset should I use, +733 or +739?
Post by: korth on 2019-04-04 12:35:30
Post by: KaiStone on 2019-04-04 12:42:58
I mean even in this specific situation, while all CDs from F1 have +6 offset margin?
Post by: korth on 2019-04-04 13:52:23
I'm not going to suggest using an incorrect value for the 'read sample offset correction'. You can use a 'combined read/write sample offset correction value' when ripping a CDR created using the same drive without write correction. AccurateRip will be disabled but you can verify the rip with CUETools.
Post by: KaiStone on 2019-04-04 14:53:04
Ya that's what Iam going to do now. Unfortunately these CDs come from NRG so I cannot burn them with EAC using Write Offset Correction, and have to do copy with Combined Read/Write Offset.
Thanks for your help.
Post by: Mao-0X on 2019-07-06 14:48:55
CRW-F1's Read sample offset correction is "+703" and Write samples offset is "+36".
It was a big accident of influence.
https://hydrogenaud.io/index.php/topic,50301.0.html
Post by: korth on 2019-07-06 16:38:26
TOS#5 (https://hydrogenaud.io/index.php/topic,3974.html#post_tos5)
This topic was discussing AccurateRip compatible read sample offset correction. For AccurateRip compatibility, the correction values need to be calibrated to the adopted reference. Your proposed values are not. http://wiki.hydrogenaud.io/index.php?title=AccurateRip#Offset_accuracy
Topic closed.
