Hydrogenaudio Forums
Lossless Audio Compression => WavPack => Topic started by: OrthographicCube on 2017-10-09 01:43:32
Title: When Converting Files Using Pipe (Foobar / XMPLay / etc.)
Post by: OrthographicCube on 2017-10-09 01:43:32
Back then, I tried to convert files to WavPack using Foobar2000 but I find that files are created while converting then the files disappear after conversion, making Foobar2000 report the conversion as failed.
So I discovered why this happens.
1. I used a custom command line for encoding
2. I didn't use -i
3. I used -v
If you encounter the same problem, just:
1. Use -i
2. Do not use -v
That fixed the problem :D
Just posting in case someone else is having the same problems as me.
Title: Re: When Converting Files Using Pipe (Foobar / XMPLay / etc.)
Post by: bryant on 2017-10-11 04:03:56
Thanks for posting this...I remember when you reported that issue and I forgot to follow up on it!
I am aware of the requirement for -i when using pipes, so that is not new. However, the -v issue is new. Perhaps there is a timeout in Foobar that is expiring before the verification is complete (because the verification does not start until all the audio has been sent). Anyway, I will check into that when I get a chance and see if I can figure it out. Thanks again!
