WSH Biography Text, Album Info, Picture. www.last.fm
language - left mouse double click on the text (or main menu or menu properties to set);
font size - shif + mouse wheel on the text;
move text - press left mouse button on the text and move;
previous, next img. - mouse wheel on the img;
selsect artist or album img. - left mouse double click on the img (order by most popular or release date - menu);
img. interval setting - shift + mouse wheel on the img;
Thank you @kgena_ua :)
Thank you , always use your script!
glad to be useful
а можно скрипт паправит так, штоб с начала брал инфо с поля REMIXED BY, а потом (если инфо нет) уже с ALBUM ARTIST ?
мне как то правилнее если у песни дапустим ABBA (remix от TIESTO) паказывал дискографию TIESTO
Violation TOS #10 (https://hydrogenaud.io/index.php/topic,3974.html#post_tos10). You must post in English.
sorry, can you delete my message (i translate with google) ?
Is it possible to adjust the script so that at the beginning it will be taken info from the REMIXED field, then (if there is no information) from the ALBUM ARTIST field?
It seems to me more logical, for example: the song ABBA remixed TIESTO, so better that the TIESTO discography is displayed.
THANK YOU for answer.
Biography, Albums, Similar artist info. www.last.fm
version 06102017
language - left mouse (or left mouse + Shift) double click on the text (main menu or menu properties to set);
font size - Shif + mouse wheel on the text or text header (menu properties to set);
hide text - mouse mbtn dblclk on the text header;
select artist, albums or similar artisr info - left mouse double click on the img (main menu);
img. interval setting - Shift + mouse wheel on the img;
for advanced settings see menu properties.
The script is not compatible with the previous version, saved data must be deleted/
thanks, super :)
Thank you. Works perfect.
@kgena_ua can't get album-review
(old bio-tool gets album-review)
language: english
changed to album: most popular or release date - nothing found
i'm using foo_jscript-panel 1.3.0 and
your tool 06102917
please have a look at it,
thx
@lender1257,
I think you have not deleted the old data from the folder " ...\tmp_Biography".
(do not delete folder "_download")
this is a complete fresh installation of your tool
my settings:
http://de.tinypic.com/r/2450im8/9
http://de.tinypic.com/r/30x9bns/9
I'll check it at home
hi
can you please also implement a remap-field for %artist%?
owing to different spellings
thx
@lender1257
I do not even know. I checked it with foo_jscript_panel-v1.3.0.
Works good
https://www.youtube.com/edit?o=U&video_id=0ChIIlRaiXE (https://www.youtube.com/edit?o=U&video_id=0ChIIlRaiXE)
hi
thanks for checking.
in the video your script shows in line 1811 "var btn=WshShell ... Foobar 2000 ..."
in my downloaded script (version: 06102017 feature: v1.4) there isn't such a line
my script ends with line 1786
if i change to "similar artists" always "text not found"
any idea what i have done wrong or did i grab the wrong sript ?
@kgena_ua error found; it was my mistake, changed parameter "download limit" to zero
i thought concerned pics only
script works
feature request: album-review of playing %album%
remap-field %artist%
thx
All right, the script ends on line 1786.
I additionally wrote a function for deleting empty folders and testing it now.
hi
are you planning to expand your script like wrote in post #18 ?
@lender1257,
You mean to add a search for an %artist% - %album% that is playing or currently selected
hi
kgena_ua
yeah, double-click on panel changes from "bio %artist%" to "album-review %artist% + %album%" and reverse.
if not possible, then an extra script
first, a way to overwrite %artist% (remap %artist%) would be very good. with this you could correct different spellings.
thx
Hi
kgena_ua,
Thank you very much. I have used this script,It is very helpful to get the music's information.
But it has some little problems:
1)It omit some special charactors,like as "*,/,.". It will be much better to change these charactors to '_'.
2) It cann't fetch the playing music's album cover.(Not the artist's pop album)
3) When you change the music quckily,it will get wrong images.(settings:prefer now plaing)
4) It will be much better if it can set these parameters: the dowloaded image path(default: tmp_Biography) ; the artist's images's suffix(_?_images);the album's images(eg.: $if(%album artist%,%album artist% - %album%,%filename_ext%)
Could you please fix these problems? I find this script is the best than others so far.
Have a good day!
@kgena_ua
really great script !!!
if you include "album review" in the context menu, please change in properties,"default img path" to "default img path bio" and allow a new path for "album review" (default img path album review).
so that 2 different images can be displayed if nothing is found.
thx
@kgena_ua
thx
lender1257, thanks.
I'm thinking about reviewing the album. The idea is interesting.
My problem is my English. Basically, I understand, but the subtleties
@kgena_ua i've sent you a mail
There were some changes on the LastFM website.
Biography & Albums & Similar artist info. www.last.fm
version "15122017
for wsh panel mod and jscript panel
language - left mouse (or left mouse + Shift) double click on the text (main menu or menu properties to set - select en,it,zh,de,pl,pt,ru,tr,fr,sv,ja);
for advanced settings see menu properties;
added: background transparency under the text - Ctrl + mouse wheel on the text.
over all wishes I work
@kgena_ua hi
version 171215 crashes on both panels (jscript + wsh)
(http://[IMG]http://i63.tinypic.com/210x348.jpg)[/img]
no one else has this problem?
Am I doing something wrong?
Hi.
Unable to create folder "tmp_Biography" - permision denied.
hi kgena_ua
no chance to get version 15.12.2017 running
updating from old to new script --> crash
new installation:
i have deleted jscript- and wsh-panel totally; deleted tmp_Biography
inserted jscript-panel new with script from 15.12.2017 --> crash, same error as described.
when i delete tmp_biography and i start foobar without playing music (stop), tmp_biography and the bio of the last played %artist% will be allocated automatically.
hope you can help
@kgena_ua i have found an error in your script 15.12.2017
changed it, and now new version is doing fine
changed red marked field from old to new
@kgena_ua another crash with version 15.12.2017
field "priny" not defined; line 1613 - at a change of the %artist%
could it be that this should be "print" ???
please have a look on it
thanks
@kgena_ua
thanks
lender1257, this is not a mistake, it's my inattention. Thanks.
hi kgena-ua
I assume it's print. (I don't know this programming language.)
I like your script very much.
what i'm missing is a remap-field for %artist% in properties.
this field should be very long and fillable with titleformatting script. so that every user can enter what he wants.
I myself have almost 800 different %artist% and last-fm doesn't always save as I do it.
the result should then be used to search as %artist%.
I hope you can make this possible. then the script would be perfect, for me.
best regards
@kgena_ua another please:
please include a refresh-function in your script. (delete folder and new download)
to fix download-errors
thanks
"Biography & Albums & Similar artist info. www.last.fm"
version "18022018"
Added: review of playing or selected album.
language - left mouse (or left mouse + Shift) double click on the text (main menu to set);
select artist, albums (most popular and release date), similar artisr or album info - left mouse double click on the img (main menu);
The script is not compatible with the previous version, saved data must be deleted.
hi kgena_ua
really great work; all works perfect
thanks
are you planning to install the other features i've posted ?
this is for you - for great work
this is for you
Thank.
this field should be very long and fillable with titleformatting script. so that every user can enter what he wants.........
if I understand correctly you want to be able to, for example through a dialog box, enter the name of the artist.
hi
1) maybe in properties a new line named "remap artist". (very large)
in this field i will enter with titleformatting script, all changes of my %artist%-tags, so last.fm will find the text.
if "remap-field" not is space search with this new "remap-field" as %artist%, in all other cases with %artist%.
for example:
$if($or($strcmp(%artist%,'ALLMAN BROTHERS BAND'),$strcmp(%artist%,'ALAN PARSONS PROJECT'),$insert(%artist%,'THE ',0),),)$replace(%artist%,'CHRIS FARLOWE & THE HILL','CHRIS FARLOWE WITH THE HILL')$replace(%artist%,'YUSUF','CAT STEVENS')
means:
my tag result in remap-field (should be like in last.fm)
ALLMAN BROTHERS BAND THE ALLMAN BROTHERS BAND
ALAN PARSONS PROJECT THE ALAN PARSONS PROJECT
CHRIS FARLOWE & THE HILL CHRIS FARLOWE WITH THE HILL
YUSUF CAT STEVENS
2) refresh function (maybe under "delete empty folders")
thx
for example:
means:
thanks I understood
hi
maybe remap %album% (i don't use it) could be useful for other people
thx
if it will be so
script - no download possible
lender1257 ,
whitch script - no download possible
I'm sorry, I thought you already finished it.
input line is ok.
thx
"Biography, Albums, Similar and title artist info. www.last.fm"
version "030322018"
Added:
review of playing or selected album;
menu item "Refresh" (default is false, see menu Properties);
remap artist (menu Properties);
"img border thickness" (menu Properties).
select artist, albums (most popular or release date), similar artist, album or title info - left mouse double click on the img (main menu);
Added:
My mistake
Added:
review of playing or selected title;
hello kgena_ua
thank you very much
all works perfect
you're great
thx a lot
lender1257,
glad to be useful
version "030322018"
for jscript panel v2.0.6
hello kgena_ua
thank you very much
all works perfect
you're great
thx a lot
I work fine with foo_uie_wsh_panel_mod 1.56
good!
hi kgena_ua
bio: searching for THE V.I.P.'s (availabe in english last.fm) but script founds: THE VIP's (= false artist)
can you please make a correction.
thx
Hi.
Is it? If no give me a LastFM link
hi
yes, script finds this wrong artist
link for correct artist: https://www.last.fm/music/The+V.I.P.%27s
thx
version "240322018"
hi kgena_ua
works perfect
thx
version "15062018"
While only for WSH panel
version "15062018"
for jscript panel
Hi kgena_ua!
I gladly tested your component (for jscript panel), there are positive improvements.
It is making a good alternative.
Keep it up!
Regards.
Sergey77, thanks, I like it myself
thanks for good work.
would you bring these options back ?
https://imgur.com/a/ohXvY3q
(https://i.imgur.com/Bf0MqMs.png)
displayed menu items from another of my scripts - "Get Covers (Artwork) radio logos".
version "15062018"
for jscript panel
hi
script crashes when using jscript 1.3.2.2
getcolour should be getcolor (9 times)
Thank you for all of your hard work, kgena_ua. This component is one of my favorites! Also, I'm not sure where to post bug reports but I hope its alright to post the fix here. If there is no active internet connection and the biography is not cached, then a crash occurs. Here is a screenshot of the error:
The fix was to replace this line (around line 549, use control+f to search):
if (this.xmlhttp != null && this.func != null) {if (this.xmlhttp.readyState == 4) {if (this.xmlhttp.status == 200) this.func(); else {this.on_search_done_callback(artist, list, done, handles);}}}
with this line:
this.on_state_change = function() {
if (this.xmlhttp.status == 200) {
this.func();
} else {
if (this.on_search_done_callback != null) {
Now, the null check prevents the script from crashing and instead displays placeholder text. Attached are images of each event. Also, GetColour() works on the current version of JScript Panel. That error only affects older versions.
It seems that this report concerns JScript Biography 0.9.0.2 (https://hydrogenaud.io/index.php/topic,112913.msg952419.html#msg952419), and would have been best put in the discussion thread (https://hydrogenaud.io/index.php/topic,112914.0.html) dedicated to that. Not to worry, I'll try and fix it for the next version. However, it's not actually currently obvious to me why your fix worked, since the callback is defined (line 542) as it's sent to the master function (line 541). I couldn't seem to reproduce the issue. Anyway I'll think about it further. Line 549 in the release version is also just a "}" and not an object and so I would like to be sure that the issue occurs with the script in a completely unmodified state. Please post any further discussion here (https://hydrogenaud.io/index.php/topic,112914.0.html).
Thanks for the report.
"22082018"
Well, this is embarrassing. I'm sorry for the inconvenience.
"22082018"
@kgena_ua what's new in this version?
please always post your changes
thanks
thanks
- optimization;
- added lyrics for the selected track;
- changes in the main menu (see "Menu setting");
- added external links for artists and related artists.
thanks
- optimization;
@kgena_ua additional question:
is this script for wsh_panel_mod or
for jscript 1.3.2.2 or
for jscript 2.1.6
please also provide this information in the future if you change your script
thank you
version "14092018"
Minor corrections and optimization .
Added:
- when viewing information about the artist, the meaning of the lines "popular this week" and "the latest releases" are clickable (double click).
The saved data (if saved) must be deleted, or use the menu item Refresh.
The Properties menu must be updated.
The script is compatible with:
- wsh_panel_mod ;
- jscript_panel (all version).
version "30122018"
Added:
- smooth scroll.
- wsh_panel_mod ;
Hello,
kgena_ua,
I have used the newest script. Could you please make some changes for more better?
1)one special character,like dot ".". It can not be changed to dot"."(keep the same).
2)It can not set the path of the album's images in one seperate directory.(named as %album artist% - %album%)
3) I don't need some information for XXX_the _artist_info.ini.(except:external_links,born)
I wish you make this to be the one best excellent script tool.
:) ;D :)) :D
And 4) if the search information is empty,don't create this artist's folder.(add a property like as setting: "remap artist").Thanks. ;D
Hello, I found that "remap artist" and "Unkown Artist"(no information) can be one function.(Add a fuction button "remap"- "remap to Unkown Artist and delete the folder"(like black list)). By the way,some artists have no other language's translation.(like as no information)(It will be much better to fetch the correct language information automatily.)
hikaze,
I will think
Hi there!
@kgena_ua,
Please add the lock mode with the "lock" button on the script field window. Because sometimes a song ends (image and text change) before you have time to read the text and view the images (for example when listening to internet radio).
It would also be nice to add a mode of fixed separation of text and image excluding overlay.
Thanks for this great script!
Hi there!
@kgena_ua,
Very interesting.
As you see it. Menu item, hotkey or something else. How to call this feature. How should this work.
Conveniently if it would be the "Lock" button as shown at the picture (highlighted in red).
If the user clicks on the "Lock" button, mode is on - when the music track and the artist change, but the picture and text do not change, they remain for the previous track and artist.
If the user clicks on the "Lock" button again, mode is off and the script continues to work as usual.
Thank you!
Hello,This script took a long time to load.(more than 8s, sometimes > 30s).(Some reason is that I used 2 script in Panel.)
I think this script need to speed up the load speed.It used too many function clean(). Sorry,I don't much more ability to improve with it. I'm a new learner.
208 line:(The special characters do not need to be customized.I think that another plugins also handled it simply.)
var tmp = n.replace(/[\/\:\*\?\"<>\|\\]/g,"_");
"Biography, albums, title, similar artist info.www.last.fm."
@version "27062019"
jscript panel, wsh panel mod.
Add:
- new customizable main menu - see menu item "Main menu setting";
- lock mode - left mouse button dblclk on header_1 (artist);
- collapse / expand additional info text - popup button between header_2 and main text;
- menu item "Hisory" - view previously downloaded data if it is stored in the tmp_Biography folder (by default).
Saved data reload.
Before installation, clear variables - the "Properties" menu.
Hi! Last.fm again changed the design ... Every time it gets worse! And the photos stopped loading ...
udege,new test version you can find here
http://foobar2000.ru/forum/viewtopic.php?t=1878&p=73458#p73458 (http://foobar2000.ru/forum/viewtopic.php?t=1878&p=73458#p73458)
No update? Still "No Photo" in Biografi.
emaulana,
see previous post
hi kgne_ua
I'm using your script from 20180324 (JScript1.3.2.2) - any chance to update this too?
does your newest script have the option to disable some information?
i only want to see the artist-name and the biography; all other information in between is useless information for me
thanks
emaulana,
see previous post
Ok, it is working now. Thank u for your script bro. My Foobar2000 is look beautiful again.
@kgena_ua
sorry, I didn't read your mail well enough. the function is already inside.
thank you
@version "13072019"
Minor fixes.
"External links" work.
Added the ability to view text using the keys UP, DOWN, PAGE_UP, PAGE_DOWN, HOME, END.
LEFT and RIGHT keys to change the image.
Accordingly, the panel should be active (selected, left-click on the panel, for example).
hi kgena_ua
works perfect - great work !!
Great script. Thanks for making this.
version "24082019"
Changes in the history menu section:
- history list navigation - Mouse, Up, Down, Page Up, Page Down, End, Home keys;
- artist selection - left mouse button, Enter key;
- deleting a list item - menu, Delete key;
- delete history list - menu.
Minor changes and improvements.
Properties needs to be updated.
need your recommendations for improvements
Looks like the pulling of artist art is broken? It won't load artist art anymore for me.
I confirm.
images are no longer loaded.
Last.fm has changed its site.
version 24.08.2019
@kgena_ua new version 2019-10-26 works - thank you
http://foobar2000.ru/forum/viewtopic.php?t=1878&start=2660 (http://foobar2000.ru/forum/viewtopic.php?t=1878&start=2660)
version "07112019"
compatible with WSH panel mod and jscript panel
lender1257,
what is your opinion about the versions 26102019 and 07112019
hi kgena_ua
i don't see any difference between the two versions.
version 2019-11-07 works fine.
i leave this version installed.
@kgena_ua hello
i use version 2019-11-07
please do not write the band members in a row but each one in a line
thanks
hi kgena_ua
changes on the last.fm website
Hello i have problem like this when i put Biography .
What should i do?
hi,
i'm not sure, but i thinks it works only with jscript panel or wsh panel mod.
The script is compatible with jscript panel and wsh panel mod
When i put on jscript or wsh panel i have this same error
JScript Panel v2.3.5 (id:1902770)
Błąd kompilacji kodu JavaScript:
Błąd składni
File: <main>
Line: 3, Col: 1
const requiredVersionStr = '1.2.2'; function is_compatible(requiredVersionStr) {const requiredVersion = requiredVersionStr.split('.'), currentVersion = utils.Version.split('.'); if (currentVersion.length > 3) currentVersion.length = 3; for (let i = 0; i < currentVersion.length; ++i) if (currentVersion != requiredVersion) return currentVersion > requiredVersion; return true;} if (!is_compatible(requiredVersionStr)) fb.ShowPopupMessage(`Biography requires v${requiredVersionStr}. Current component version is v${utils.Version}.`);
works perfect with foo_jscript_panel-v1.3.2.2
later versions of jscript_panel have changed significantly
please search the web for version 1.3.2.2
thx
Hello to everyone !
I have wsh panel v1.5.6 and i try to manage it for Biography text, Album info... but always an eror message came up,
I runed also from kgena_ua ''Reply #99 – 2019-11-07 13:00:16'' and i have the same message, you can look at the file.
If someone have an idea how it can work please let me know.
Thank you!
@kgena_ua please include a remap function for album titles as well (analog remap artist)
thanks
@kgena_ua
Add menu item "remap". Now I'm testing.
@version "26052020"
Added: remap function for album titles.
Minor fixes.
great work !
remap-album function perfect.
small mistake in the context menu "remap artist" the "t" is missing
leave the previous artist-remaps as they are, or rather use the new remap-function-artist to create new ones ?
will the old remap-artist function be abandoned at some point?
can you transfer the existing remap-artists into the new editor automatically?
greetings
the old existing remap-artists data will be lost.Do not refresh "Properties"
I'll try
1. Open script "Biography..." by pressing "Comfigure..."
2. Paste at the end of the script:
// transfer_data script
var remap_data = window.GetProperty(" remap artist", "ALLMAN BROTHERS BAND:THE ALLMAN BROTHERS BAND;");
transfer_data(remap_file_path("artist"));
function transfer_data(path) {
var tmp_arr = [];
tmp_arr = remap_data.split(/[:;]/g);
try {
remap_file = fso.OpenTextFile(path, 8);
if (tmp_arr.length){
remap_file.WriteLine(tmp_arr.join("\r\n"));
remap_file.Close();
} catch(e) {};
3. Press "Apply"
4. Check file ... /tmp_Biography/_download/remap_artist.txt
5. If the transfer completed successfully, delete "transfer_data script"
5. Press "Apply".
has worked perfectly
thank you very much
@kgena_ua error at remap-album (maybe at remap-artist too)
example:
"Dark Side Of The Moon (Experince Edition)" is remaped to "Dark Side Of The Moon"
remap is ok; the correct entry is displayed.
original album "Dark Side Of The Moon" is not remaped. in remap_album.txt however "Dark Side Of The Moon" (as remaped entry) is found and now the following entry is taken as "remap". but this is the next album to be remaped. in my case "Live At Montreux 1991 (Collectors' Edition)
only the 1st entry may be searched for when comparing (never the 2nd entry)
extract from my remap_album.txt (sorry, can't upload a picture)
please correct - thanks
suggestion:
make it single-lined again, with ":" as the separator (as the old way of remap-artist but with txt-file)
i think this will do best
thanks
remap album name
better you take "::" (2 x colon) as separator
I saw that there are many albums that have ":" in them.
For example: Stay With Me: Faces Anthology
please transfer the previous data automatically into the new format
thanks
You're right
version "10062020""*" as the separator
the previous remaps (artist + album) were set to "*" (everything ok), but the remap name is not searched for. the search is for the original artist/album name. only if you do a manual remap, it works correctly.
please correct this - thanks
Hello,
thank you very much for this script. Would it be possible to disable some features? I'm interested in the (automatic) artist image download only. Or is there a separate script for this case?
Thank you in advance.
hello kgena_ua
it is possible that you include the artist-name in the album-remap so that if you have several identical album-names, the correct album will be displayed.
if the artist has already been remapped, the remapped artist-name should be used.
if possible, please sort history, artist and album.txt.
thanks
hello kgena_ua
what do you think about adapting your script for spider monkey panel ?
Hi everyone,
Is there a way to disable the ability to drag&drop the text around? It would be cool if the user could select the text instead of moving it around.
