HydrogenAudio
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: zeremy on 2017-02-19 18:13:49
Title: R2YS a script for reddit
Post by: zeremy on 2017-02-19 18:13:49
/*Disclaimer
 *The usage of this script must comply with the Reddit API Terms of Use
 *https://www.reddit.com/wiki/api
 *I will not be responsible for any modifications of the script made by the end users that do not comply with the terms.
 *Credits:
 *Original concept (Subreddit to YouTube Source Bookmarklet) from https://gist.github.com/akaleeroy/b3de63c46ee43d413913
 *Description:
 *Search subreddits for youtube/vimeo/spotify url's and create a playlist within foobar2000.
 *Required components:
 *JScript Panel (http://www.foobar2000.org/components/view/foo_jscript_panel) and
 *Youtube Source (http://fy.3dyd.com/download/)
 *foo_input_spotify (https://github.com/stengerh/foo_input_spotify) Spotify support for foobar2000. Requires a Spotify premium account.
 *Optional components:
 *m-tags (http://www.foobar2000.org/components/view/foo_tags)
 *Installation:
 *Create an empty jscript panel and import the script.
 *Modify the script with your oauth2 credentials / or add them in the jscript panel properties.
 *username and password are your reddit credentials.
 *You must authorize with your account @ https://www.reddit.com/prefs/apps/ as your personal script to get your client_id  and client_secret keys.
 *See https://github.com/reddit/reddit/wiki/OAuth2 , https://github.com/reddit/reddit/wiki/OAuth2-Quick-Start-Example
 * example:
 * var username = window.GetProperty("Reddit.username", "redditusername");
 * var password = window.GetProperty("Reddit.password", "redditpassword");
 * var client_id = window.GetProperty("Reddit.client_id", "redditclientid");
 * var client_secret = window.GetProperty("Reddit.client_secret", "redditsecret");
(http://i.imgur.com/kNFGjyv.png)
Title: Re: R2YS a script for reddit
Post by: onirwai on 2017-03-07 20:43:36
Tried it, works, thanks!  8)
Post by: zeremy on 2017-03-08 09:35:42
Version 0.0.2
ADDED:  Search by query.
ADDED:  Visit Reddit comments for current playing item
CHANGE: Made Spotify optional component
Post by: onirwai on 2017-10-19 16:30:27
Script no longer works nowadays. I get this:
(https://i.imgur.com/kGN21XT.png)
Reloading or fiddling with the config doesn't help.
Post by: zeremy on 2017-10-19 17:27:35
It it still working  with JScript Panel v.1.3.0
Can you provide an output from the console panel where it crashes?
Post by: onirwai on 2017-10-19 20:56:58
Same version here. Something else was wrong with my config, because another JScript panel crashes too (YouTube Track Manager).
Found the relevant log info:
JScript Panel: This component requires your system has IE9 or later installed.
So the solution is to install Internet Explorer 9 or later.
Post by: zeremy on 2017-10-19 21:17:45
The breaking changes for v 1.3.0 are described here:
https://github.com/19379/foo-jscript-panel/wiki/Breaking-Changes
You can downgrade to v1.2.4 if you wish.
https://hydrogenaud.io/index.php/topic,110499.msg945412.html#msg945412
Post by: kgena_ua on 2017-10-21 19:25:24
@zeremy,
great job
Post by: onirwai on 2018-02-12 23:29:36
@zeremy
foo_jscript_panel (https://github.com/marc2k3/foo_jscript_panel) introduced breaking changes in v2.0.0 (https://github.com/marc2k3/foo_jscript_panel/wiki/Breaking-Changes#v200) that require updating your script:
fb.Trace has been removed and replaced with a native console.log method so you'll need to do a simple find/replace in all your scripts. It takes multiple arguments as before.
window.GetColorCUI -> window.GetColourCUI
window.GetColorDUI -> window.GetColourDUI
Post by: zeremy on 2018-02-13 17:49:10
Updated to Jscript Panel v2+
Post by: MojoBass on 2018-02-17 07:06:05
Some hints for installation for the 'non-experts':
- foo_input_spotify or a Spotify Premium Account is not required
- to get the reddit credentials:
     - register at reddit to get username and password
     - to get client_id and client_secret:
          - click here: https://www.reddit.com/prefs/apps/ (https://www.reddit.com/prefs/apps/)
          - in the template fill any name at the field 'Name'
          - check 'script'
          - Type any description
          - leave 'about url' blank
          - at 'redirect url' type 'http://107.0.0.1:65010/authorize_callback'  (that did at least work for me, don't ask me why)
          - then confirm and you see something like this:
              (https://camo.githubusercontent.com/d53f92cd85d1279a239444acee25179e8e6d8bb5/687474703a2f2f692e696d6775722e636f6d2f65326b4f5231612e706e67)
            - the red underline string is the client_secret, the string 'p-jcoL...' right to the app icon on top of the page is the client_id
            - then include username, password, client_id, client_secret in the header of the js code as described by zeremy
- when first using the code the script crashed. Fix: I had to create the folder media\r2ys manually in my foobar directory (using portable installation)
- then the plugin worked great  :)
- in my skin the panel appeared to be white text on white background (referring only to status message, left-click reddit functions worked well). Fix: underlying PSS with black background and click 'pseudo-transparent' in the js panel
And then: enjoy ;D Thanks to zeremy!
Post by: onirwai on 2018-02-17 10:06:47
I didn't have the media folder in fb.ProfilePath and it errored when it was supposed to create it with
objFSO.CreateFolder(path);:
Microsoft JScript runtime error:
Path not found
Problem was solved by creating the media folder manually in shell:AppData\foobar2000\
I uncommented //gr.FillSolidRect(0, 0, ww, wh, g_backcolor); as well because the background was white and you couldn't see the text.
Post by: zeremy on 2018-02-19 14:09:39
v.0.0.4
+Fix path creation
+Fix colours
thanks @MojoBass @onirwai for reporting.
Post by: MojoBass on 2018-03-03 06:36:06
After the first shot where I had no problems to connect to reddit, I wanted to change my password (as I did not want to ues one of my 'good' passwords here). Old clident id with new pwd did not work, so I generated a new script and new client id and secret. However, since then I am not able to connect, not even with a fully new login at reddit (new email, new user,...). Any hints?
Post by: zeremy on 2018-03-03 11:31:16
Try clearing the panel's properties and reload.
Right click the panel > Select Properties > Press the clear button > Apply.
Post by: MojoBass on 2018-03-04 05:33:01
Thanks very much!! Now works again perfect! (can't explain why I didn't even look into the properties.....)
Post by: onirwai on 2020-05-27 19:08:57
To get it to work with JScript v2.3+:
Fix utils.CheckComponent(..) calls to only take first parameter
 utils.CheckComponent(name) (boolean)
The previously optional "is_dll" parameter was removed in v2.3.0.
The filename is now always checked (equivalent to "is_dll" being true).
Example:
console.log(utils.CheckComponent("foo_playcount"));
