Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: WilB on 2016-01-21 18:38:59
Title: Library Tree Discussion
Post by: WilB on 2016-01-21 18:38:59
LIBRARY TREE
Library tree is a JScript media library viewer.
REQUIREMENT
JScript Panel. The version required and any requirement changes will be kept up to date in the latest download link location.
INSTALLATION
Add a JScript Panel to the layout in the usual way. Click the JScript panel (or right click and choose configure) to open the editor. Use the tools button to import the Library Tree script
FEATURES
Fast and lightweight script
Compatible with default user interface (DUI) & columns user interface (CUI).
Supports transparency (requires CUI & panel stack splitter or similar).
Customisable media library views. Use // to separate name & | to separate branches. Existing views can be edited or new ones added in panel properties.
Multi-value tag support. Use %<field>% syntax for fields to be split, e.g. %<genre>%.
Accurate filter & search: text and queries (e.g. artist HAS beatles). These give the same results as DUI album list filter. All give sorted results so that query sort operations are N/A. Search and filter can be hidden.
Filtering is done before the tree is populated, enabling the tree to comprise different sub-populations of the library. Filters also offer quick access to commonly used queries. Filters are customisable in panel properties. Use // to separate name from query. Existing filters can be edited or new ones added.
Search finds items in the populated tree.
Smooth scrolling.
Discrete scrollbar; can be resized / hidden. Mouse wheel: page or standard 3 line scrolling (page = default; change in panel properties).
Colours and fonts: set in foobar2000 preferences for DUI or CUI.
Font size: set with DUI or CUI list font. Or use mouse-over with CTRL + mouse wheel to zoom the font size (resets if UI list font size changed). Filter can be zoomed independently.
Extra custom colour options are in panel properties: presets for auto fade & blending of colours used by filter & lines plus ability to set all colours individually.
Customisable node symbols: windows themed or font symbol. Colour of custom nodes can be configured.
Keystroke "jump" search.
Arrow key navigation + ctrl & shift selection.
Mouse middle button > adds to playlist.
Full context menu on right click.
Panel properties has further options, e.g. display settings for  "All Music" node, item counts, alternating row stripes, tooltips, auto-collapse, margin, tree indent, autoplay, auto fit (autofit stops clipping of text in the bottom row).
Access panel properties by right click > options.
Always check near to the end of this thread for the latest download link.
(http://i.imgur.com/BKTnT9r.png)
Library Tree 0.3 (https://hydrogenaud.io/index.php/topic,110938.msg914837.html#new)
Title: Re: Library Tree Discussion
Post by: MrMonkey on 2016-01-22 13:49:15
I got this error after loading the script:
JScript Panel (Library Tree v0.3 by Wilb): Microsoft JScript runtime error:
'symb' is null or not an object
File: <main>
Line: 618, Col: 21
I'm using foobar2000 1.3.9, Library Tree 0.3, JScript Panel 1.1.1 on Win 7 x64.  Columns UI is my interface.
Post by: Frame on 2016-01-22 20:41:29
Thank you for this library viewer. Best of the best. :3
I have 2 suggestions:
1. 'Drag and drop' feature. Maybe an option to switch between the current behavior and a 'classic' behavior: click or double click on folder title (genre/artist/album) for expand/collapse a tree, middle click or drag and drop - add to playlist. It's kinda difficult to click small 'collapse/expand' buttons. Also now it's impossible to create (I mean the easy way) complex playlists, when you add 5 albums and then decide to add a 6th album between 3rd and 4th. If drag and drop is impossible to implement, then just 'classic' behavior will be enough.
2. The second option for items counting.  It will be great if numbers in brackets can show correspondingly the number of sub-folders (artists) in genre folders, the number of albums in artist folders and the number of songs in album folders.
(https://i.imgur.com/TyuqG3V.png)
Post by: Coreda on 2016-01-22 22:21:33
Curious which component the Youtube Source context menu is from, seen in the screenshots. Does it search Youtube for the selected track?
Post by: marc2003 on 2016-01-22 22:29:53
It looks like the script is using windows theming options but you're using windows classic??
Post by: MrMonkey on 2016-01-23 00:39:55
Yup.  Hmmm... so I'll have to play with the script to remove the theming options. Thanks.
Post by: WilB on 2016-01-26 17:40:10
New Version: Library Tree 0.4
@ MrMonkey & Frame. Thanks for the feedback. Regarding item counts, I prefer these to sub-item counts.
@ Coreda. The YouTube source context menu item is from the foo_youtube plug-in (https://hydrogenaud.io/index.php/topic,104379.0.html)
CHANGELOG
- Removed dependence on windows theme options.
- Added double click expand and collapse.
- Corrected a few minor draw issues.
Library Tree  0.4 (https://hydrogenaud.io/index.php/topic,110938.msg915088.html#new)
Post by: widerock on 2016-01-26 19:00:13
Is it possible not to list the music files in library tree panel?
I usually play foobar on 'album'/'directory' base which means that I don't need to see the listed files.
I know that I don't see the files if I don't click the last (+). But, it would be great if there is an option.
Post by: Frame on 2016-01-26 19:20:28
WilB, thank you for the update. Unfortunately, it's impossible to use double click, because the playlist autofills every time I click on a folder/album/artist title. Or did I miss an option to disable the 'autofill' feature?
Post by: blaxima on 2016-01-27 05:47:44
Thank you for sharing.
Auto play on send works half way though. When using the context menu to send, the song will play but double clicking on a song will only send it to the playlist.
Post by: WilB on 2016-01-28 13:05:16
@ Widerock Added option to panel properties "Node: Show Tracks": true / false.
@ Frame The double click expand/collapse action works identically to dui and cui album list, i.e. these also auto-fill. To avoid auto-fill, expand/collapse by clicking the node. Either way, to achieve what I think you want, use middle-click to add items in the order you want (if the playlist already contains items, use left click for the first addition). Middle click action is enhanced in 0.5, so please update. Double click expand/collapse action now needs to be set in panel properties (see below).
@ Blaxima Added option to panel properties to configure DblClick Action: Expand/Collapse or Send&Play (default) to achieve what you want.
Library Tree 0.5 (https://hydrogenaud.io/index.php/topic,110938.msg915163.html#new)
Post by: widerock on 2016-01-28 13:48:21
Thank you for the implementation.
Post by: blaxima on 2016-01-28 14:12:02
Thank you
Is is possible to have double click open directories and then send and play once it reaches a song rather than one or the other?
Post by: dreadroach on 2016-01-28 14:41:19
Is it possible to add drag & drop feature? I really miss that, so i'm stuck using standard albumlist.. but everything else is great, looks great and lots of options.
Post by: marc2003 on 2016-01-29 10:47:43
That's not possible due to limitations of the component. You can drag/drop in to it but not out.
Post by: Axonn on 2016-01-29 16:23:24
Hey :). Do you guys have a clue why I have this issue when using Library Tree? I have latest version of everything (installed everything today). Only thing I changed is to do some customization in my Foobar columns in the playlist.
I attached an image with the error:
JScript Panel (Library Tree v0.1 by Wilb): JavaScript runtime error:
Unable to get property 'Count' of undefined or null reference
File: <main>
Line: 322, Col: 29
Post by: MachineHead on 2016-01-29 16:43:56
Library Tree v0.1 is not the most recent. Check forum upload for latest,
Post by: Axonn on 2016-01-29 17:10:07
Ouch! Whoops! :D. You're right. Thank you. I don't know how come I ended up with that one!
I installed the new one (0.5) and this time no errors.
However... it doesn't show anything either :(. I did go into options and set it to use the "Process" playlist that you can see in my previous screenshot but it's still empty. I get the same behavior from the JS Smooth Browser too... hmm. Any clue why?
Post by: marc2003 on 2016-01-29 17:12:13
Have you configured foobar to monitor your music folders?
File>Preferences>Media library
Post by: Axonn on 2016-01-29 17:16:03
Aaaaaaaaaaaaaaah :D. Nope. I did it now :D.
Finally I get it!!! I thought that it will show stuff in that panel BASED ON what playlist I set, but it was completely the opposite way hahaha. The playlist you set is the playlist where IT PUTS the selection.
You guys are awesome, thank you so much for the fast answers! :)
Post by: WilB on 2016-01-30 18:41:49
New Version: Library Tree 0.6
Mouse double click action now offers choice of expand/collapse, play (default) or expand&play/collapse as requested by blaxima
Library Tree now reports if the media library is not configured or if nothing is found by search/filter
Various minor refinements
Library Tree 0.6 (https://hydrogenaud.io/index.php/topic,110938.msg915286.html#new)
Post by: blaxima on 2016-01-30 20:19:52
Thank you very much, but this is not what I meant. I was hoping it would act the same way browsing on your computer would. If you double click on a folder it continues on to sub-folders until it gets to a file, then it opens the file you select/double click. As it is now, it just plays the first file right away while I make my way through the sub-folders trying to get to track 6.
I do appreciate the effort though
Post by: WilB on 2016-01-30 23:05:37
New Version: Library Tree 0.7
Oh, I think I understand what you mean now. It seems a good idea and I have hopefully implemented it correctly.
CHANGELOG
Mouse double click action. Now offers choice of play (default) or explorer style (expand/collapse if branch else play)
Library Tree 0.7 (https://hydrogenaud.io/index.php/topic,110938.msg915297.html#new)
Post by: blaxima on 2016-01-30 23:45:07
CHANGELOG
Yes! This is what I wanted and it seems to be working well
Thanks again
Post by: Axonn on 2016-02-01 08:26:06
Very nice to see such an active developer! :). Good job brother!
Post by: jazzthieve on 2016-02-27 11:06:53
This is a very nice component and compared to the other Library Tree component it offers more options and flexibility. However with large libraries (100.000+) it isn't really that lightweight. Yes it browses really fast but it takes over 4 sec to repopulate which freezes the entire foobar. This can make foobar sometimes "hang" for 3 times with each song (at the start/end of a song, in the middle when the play count is updatet and when I rate a song).
Setting Node: Show Tracks to false doesn't make a difference. It also increases ram usage on foobar significantly by about 15% and with each repopulation it spikes the cpu to 90%-100% for a short moment.
I'm running this library tree component next to the old library tree component for comparison with very similar query patterns (a bit confusing to use the same name of an older and very similar component). The older component doesn't exhibit this hanging behavior.
Post by: WilB on 2016-02-27 13:28:33
I tested on ~28,000 library. Most views for me up date in 0.2 - 0.25 seconds. DUI album list is a bit faster on my system, taking about 2/3 the time, but not a huge difference. CPU usage with JScript Library Tree only rises slightly and briefly for me to 4% on repopulation. The script doesn't use the on_playback_new_track or on_playback_stop callbacks etc & so shouldn't do anything when a track starts or ends. Indeed in tests I couldn't see any issues on start/end. Playback statistics doesn’t normally update then either. May be you are auto-modifying track tags at start/end or something similar that provides the repopulation trigger. I tried repopulating multiple times, but I couldn't see any sustained increase in RAM usage. The script is coded to free memory of unwanted items. But I would confirm that JScript Library Tree does use some RAM, up to ~ 40 MB on my set up, which is trivial compared to the xx GB available on my system.
In contrast, when I used to use Ssenna's foo_uie_library tree albeit on XP I had many more problems with 100% cpu usage on start up for ~30 secs or longer as it was compiling queries. If you find foo_uie_library tree suits your workflow better then continue using that.
I believe JScript panel runs most stuff in the main thread. It is possible to make a small adjustment to the code in JScript Library Tree to stop it repopulating when playback statistics update part-way through a track or in response to any changes to existing library items (e.g. shift + right click > options > configure, then comment out line 1138 by putting // at start of line), such that it just populates on start up. Other than that, I don't think I can do anything to significantly change the behaviour.
HTH
Post by: jazzthieve on 2016-02-27 15:48:45
It is to be expected that with very large libraries loading (repopulating) would get slow. The older library tree component reacts in a similar fashion if I were to make patterns which searches the entire library so I avoid that. This seems to be handled somewhat differently with your component. Let me illustrate with an example.
When using no filter:
%genre%|%album%|%title%
on the old Library tree this will load the entire library making in very slow and almost unusable which is the same with the new library tree.
This however:
%genre%|%album%
On the old component this will not load the entire library. It only sees the album title as one single entry while the new library tree will still seem to take into account all %title% tracks belonging to the album even if it's not asked since reaction time is exactly the same whether I use %genre%|%album% or %genre%|%album%|%title%.
It's only when I define a filter (across all used filters) narrow enough so that it doesn't load too many files that it's workable.
Post by: fabiospark on 2016-02-27 20:33:02
Is there a way to get rid of the "options" dialog that appears with the right click
and go directly to the subsequent  one where one can choose a showing pattern?
Post by: Isabelxxx on 2016-03-21 00:31:35
Is there some way to adjust the Item Counter to count (immediate)nodes within branch instead of total items? (like default library)
+ACDC (3)
+Album1 (11)
+Album2 (11)
+Album3 (11)
Currently it reports
+ACDC (33)
+Album1 (11)
+Album2 (11)
+Album3 (11)
Btw branching within $if() and similar expressions seems to be broken, while that is allowed in the default library view.
For ex:
$if(%artist%,%artist%|%genre%, %genre%)
Is not being executed properly.
Post by: Just_Addict on 2016-04-02 13:48:27
I ran into a fatal bug with the non-configurable "View Folder Structure" option, causing FB2K to lockup hard.
Given the following folder structure:
topfolder
    +artistfolder
        +<loads of media files>
        +album folder
        +album folder
        +album folder
If there's folders with this layout, Library Tree refuses to fold these open. and won't go deeper than the artist folder.
The only way it will open the branch to show the sub folders is by moving all of the separate media files within the Artist folder to a subfolder on the same level as the albums.
But, if I do this with FB2K still running, (folder not active or selected in Library Tree), then FB2K will lock up hard and max out CPU usage.
Since this is a situation that exists throughout my library, I've discontinued the use and reverted back to the original album list, (also because I am missing both the subcount on sublevels and the conditional branching...)
EDIT: Further experimenting reveals this is related to the setting "Node: Show Tracks" which I have turned off by default exactly because of the library structure and because items should show in list views and not in tree views
PS. In case of wondering why going back to the original Album list, well the main reason is that it allows conditional branching and because of this I can recreate the folder structure browsing exactly as wanted, (i.e. showing just folders and no tracks, but sadly without the subcount on the lowest level)
Post by: WilB on 2016-04-15 16:28:41
New Version: Library Tree 0.8
CHANGELOG
Improved right click action
Added option in panel properties to set library sync method:
   Auto > full automatic syncing with media library as before [default].
   Initialisation only > syncs with media library on start up & changing library view [manual refresh becomes available]).
Some efficiency improvements to tree population (mostly ~10-20%) and also to the handling of library changes.
Some functionality improvement when show tracks is disabled in edge case scenarios.
Some other points have already been answered in this thread or the accompanying uploads thread.
Library Tree 0.8 (https://hydrogenaud.io/index.php/topic,110938.msg920386.html#new)
Post by: Qwghlm on 2016-05-04 19:04:12
WilB, thank you for the wonderful and powerful script.
Is it foo_jscript_panel core problem/limitation as in UTF-8 (without BOM) encoded cue-files a have something like this:
Blood Axis & Les Joyaux de la Princesse — Absinthine (D'AprГЁs Emile Duhem)
and correct encoding i can get only by using UTF-8-BOM
Blood Axis & Les Joyaux de la Princesse — Absinthine (D'Après Emile Duhem)
P.S. by default i use UTF-8 (without BOM) and Notepad++ editor
Post by: xiaNaix on 2016-05-07 23:11:23
Does this support if statements so I can stop Various Artists discs from being sorted by date?  With the old Playlist Organizer tree view plugin I was using this command.
%genre%|$if($strcmp(%album artist%,'Various Artists'),[%album artist% ]|['' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
,%album artist%|%date% - %album%|[%discnumber%.][%tracknumber%. ][%track artist% - ]%title%)
Post by: Qwghlm on 2016-05-09 11:43:48
xiaNaix, i think you cannot use level separation inside $if-statements
You should do something like this:
%genre%|[%album artist% ]|$if($strcmp(%album artist%,'Various Artists'),%album%,%date% - %album%)|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
or check %album artist% state on each level
Post by: xiaNaix on 2016-05-09 19:22:55
Post by: Axioma1 on 2016-05-16 16:01:46
Hi WilB,
A few days ago, I have created a thread about your script: https://hydrogenaud.io/index.php/topic,111807.0.html
I really think your script is pretty great and very beautiful in comparison with album list panel but for my personal use it has some weaknesses.
As I said, I like to use filters playlist or album list panel playlist as a queue, unfortunately I can't do that with your script because it re-organizes the playlist in alphabetical order every time I add another track or album.
Also, I can't change the double-click action to add to current playlist (like album list panel) or add to active playlist (like filters), so it forces me to use Legacy Commands.
If you could only add options to by pass this auto sort in alphabetical order behavior and change the double-click action, your script would be GOAT.
Do you think you could make that kind of upgrade?
Post by: WilB on 2016-05-20 11:36:27
New Version: Library Tree 0.9
CHANGELOG
ADD: option to panel properties to disable use of the default playlist (Library View) as the target for left and/or middle mouse button actions. When disabled the current playlist is used instead. When configuring, ensure the comma "," separators are retained.
FIX: corrected the behaviour of the context menu "Send to Current Playlist" and "Add to Current Playlist" actions.
@Qwghlm As far as I am aware the available JScript panel methods for getting and evaluating the library and then drawing the text do not have options for checking or setting the encoding. It is possible to detect and set the codepage in JScript panel when it reads text files from disc, but that's not what's happening here since foobar2000 is reading the files into the library, and the JScript panel is obtaining the library info from foobar2000.
@Axioma1. I have made a few adjustments. Either alt + left button click, mouse middle click or the context menu can be used to add tracks to the playlist without sorting. For the mouse actions the target playlist can be set as above as either the default library view or the current playlist. Adding tracks with control + left button click retains the sorting ability. I am reluctant to add the double click action "add to current playlist", since the single click actions occur first, which can result in unexpected behaviour. So in my view it's better to map the action to a different mouse button or use a key modifier on the single left button click as implemented.
HTH
Library Tree 0.9 (https://hydrogenaud.io/index.php/topic,110938.msg922553.html#new)
Post by: Axioma1 on 2016-05-23 09:02:01
Nice! Thank you!
Post by: eddy_stylez on 2016-06-06 00:45:44
@WilB This is probably one of the most beautiful looking library tree view scripts I've seen so far. It's flawless for me except one thing that is bugging me. The playlist sorting on folder structure view. It's currently using foobar's default %path_sort% setting. Other plugins are linked directly to foobars default %path_sort% setting, but it seems like you hardcoded it into the script somewhere. I'd like to change it to %artist% - %date% - %path_sort% if possible. Having it set like this sorts my playlist view by artist > album date.
Post by: seriousstas on 2016-06-29 12:41:26
I use the View by Folder Structure
How can I see only the folders adding for such? :
(http://rgho.st/7pY49dnM2/image.png) (http://rgho.st/7pY49dnM2.view)
(http://rgho.st/8cfgCLn4Q/image.png) (http://rgho.st/8cfgCLn4Q.view)
(http://rgho.st/6TWW26jh9/image.png) (http://rgho.st/6TWW26jh9.view)
Post by: Alwazn on 2016-07-10 06:03:40
Hi WilB,
I agree with eddy_stylez, this is probably the most beautiful library tree, thank you for all your work.
I just have a slight request for you, do you think you could easily add another option in the context menu? I think an "Insert to playlist" or "Insert into current playlist" option would make the script even better.
Personally, I have huge EsPlaylists I do organize them by genre or by taste and I lost a lot of time because JScript Panel doesn’t allow drag & drop. I'm probably not the only who has this little issue.
Post by: WilB on 2016-09-04 17:14:11
New Version: Library Tree 1.0
CHANGELOG
Added "Playlist: Custom Sort" option to panel properties. If left blank tracks are sent to playlists in the tree order (as before). If an entry is present (use titleformatting), tracks are sent to playlists according to the specified sort order. Example sort: %album artist%|%date%|%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%. Some playlist viewers such as EsPlaylist have options to force-sort playlists which will override the send order
Added "Insert in Current Playlist" to context menu. If a playlist item has focus tracks are inserted before the item
@seriousstas
Like DUI album list, common folders are not displayed. The library tree folder view should display the same as DUI album list
Library Tree 1.0 (https://hydrogenaud.io/index.php/topic,110938.msg927729.html#new)
Post by: Falstaff on 2016-09-04 20:41:53
@WilB
Thank you for delivering to us the best jscript panel ever imho, still updated thru 1.0, keep the good work  ;)
Post by: WilB on 2016-10-18 00:15:34
^ Thanks for the compliments...
New Version: Library Tree 1.1
CHANGELOG
Fixed a draw issue in folder view
Library Tree 1.1 (https://hydrogenaud.io/index.php/topic,110938.msg929672.html#new)
Post by: always.beta on 2016-10-18 14:27:21
When there is a text in the search bar, select the text and then paste new text. The result is that there are more than one text in the search bar. Can you fix it? Replace old text with new text.
Post by: seriousstas on 2016-10-18 21:01:02
Add please zoom (or resizing) for Node. Convenient for the touch - panels. Thank you! :
(http://i.piccy.info/i9/8ab8f67ed644c0cab17b0f5b938a3297/1476820639/22653/1080699/2016_10_18_22_56_02_500.jpg) (http://piccy.info/view3/10411865/2b725263bd5fc567a67e81b4d177ca21/)(http://i.piccy.info/a3/2016-10-18-19-57/i9-10411865/500x309-r/i.gif) (http://i.piccy.info/a3c/2016-10-18-19-57/i9-10411865/500x309-r)
Post by: TheQwertiest on 2016-10-20 10:05:48
Hey @WilB! Thanks for the great script, have been using it from the first release =)
One suggestion though, could you add autofill toggle? I.e. with autofill enabled(current behaviour) when you click on the element it automatically fills the playlist, when autofill is disabled playlist will be filled only on left double-click.
I've made a dirty fix for myself, but I think this feature be useful to other user as well.
The code responsible for autofill is here -
populate.lbtn_dn:
     if (v.k(2))
          this.load(item.item, true, true, false, false, alt_lbtn_pl, false);
     else
          if (v.k(1)) this.load(item.item, true, true, false, true, lbtn_pl, false);
     else
          if (v.k(0)) this.load(this.sel_items, true, false, false, true, lbtn_pl, false);
     else
          this.load(item.item, true, false, false, true, lbtn_pl, false);
To remove autofill and add double-click fill you have to put this code to populate.lbtn_dblclk after check_ix if block.
Post by: WilB on 2016-11-01 13:04:32
I have dealt with most issues raised here and in the associated uploads thread. However, there are a couple of outstanding points before I wish to release a new version:
@seriosstas: Add to Current Playlist  - add always just in  "Library view". I can't reproduce this. The menu item "Add to Current Playlist" added to the current playlist as expected. MiddleBtn click & alt + left button click also worked as expected. Panel properties has "Playlist Use..." where you can set whether the button actions use the current or library view playlist. If this doesn't solve your issue then please post precise instructions on how to reproduce. Please also ensure you're using the latest release
@TheQwertiest: The left button single click seems to work the same way as DUI album list; i.e. with both library tree & album list the playlist is populated on single click. I don't see the advantage of having to use an extra click (double click) to accomplish this, but maybe I am missing something... It would also mean that single click would do nothing upon clicking on a name unless set otherwise. Bear in mind that if single click was set to do something else, that action would also run on double click, which may lead to unwanted events. Anyway, for me to consider it further, please provide convincing arguments as to why you want the double click option, why single click isn't suitable, what benefit double click offers and if added whether you want any other actions also triggered, such as starting playback
Post by: du22y on 2016-11-01 21:16:43
@WilB
HI !
I want to apologize in advance for my English.
But I will try to explain the problem. I hope that you will understand what I mean.
The problem appears when you select the folders by pressing Ctrl and left mouse click and deselect unnecessary folders that I have already been selected, and then ADD(insert) the selected folders to the playlist.
I made a little video on the test foobar in order that you could see and reproduce the problem.
In the video I show you how it works in your two scripts, the latest version 1.1 and 0.8 modified for my needs.
Video (https://drive.google.com/file/d/0B60qIBsIiUkgRnBCVlJfUXJkdzg/view?usp=sharing)
(Select folders, deselect not needed folders then add to playlist.)
All of the selected folders remain in the array, and when deselected, not removed from the array, and in playlist added all that was previously selected.
Is it possible to remove a previously selected folders from the array when adding to playlist ?
For me, this is the only problem that prevents normal use of the script.
Everything else works perfectly.
Thank you so much for your work  ;) .
Post by: seriousstas on 2016-11-01 21:47:15
Library v 1.1 & JS Smooth Playlist
For example, I create a new - with the name "My new playlist," and make it active.
  If  send folder through the menu Add to Current Playlist, instead of adding to the Current ( "My new playlist"),
  the addition will always be in the "Library view"
Insert in Current Playlist - work correctly .
Post by: WilB on 2016-11-02 12:58:00
^ I still can't reproduce & so the issue is unconfirmed. I tried by creating a new playlist in both sim_playlist manager and JS Smooth Playlist, activated the playlist and used the library tree menu "Add to Current Playlist". Items were always correctly added to the new playlist. I've repeated it many times without issue, on two different foobar2000 set-ups. I assume you don't inadvertently left click first, which may activate library view resulting in "Add to Current Playlist" then using that playlist...
@du22y I can reproduce that issue & believe I have fixed it in my version. The fix should be in the next release
Post by: du22y on 2016-11-03 00:31:59
@WilB
Awesome !
Thank you for your hard work  ;) .
Post by: seriousstas on 2016-11-04 01:32:16
I still can not reproduce & so the issue is unconfirmed
:-[  I all the same used in the old version ...
  @version "1.1" all is well
and this please:
1 .If turn on "All Music" and collapse the tree -
list disappears.
Hope for the "Node" is a decision on the size of the change  +  and  - icon :
Post by: sstavross on 2016-11-04 12:39:07
Hi!
Thank you for your excellent script! It is very usefull!
Only one question : Can we use it for other playlists except from music library?  Lets say I want your script to list my "Chopin playlist" with all the items I have in this particular list. Is this possible?
Post by: WilB on 2016-11-04 18:43:51
@seriousstas: I had already fixed/implemented those (and point raised by always.beta) in my version
@sstavross: It's a library viewer and so doesn't read data from playlists
However, you can type, e.g. "Chopin" without the quotes in the search box, to have a tree view of the tracks
Or you can create a filter for the library that's permanently available, e.g. use query "Chopin" without quotes. Such a filter would work like an autoplaylist for "Chopin" since its updated when the library content changes + offering the advantage of a tree view of the contents
Post by: WilB on 2016-11-04 22:53:05
New Version: Library Tree 1.2
CHANGELOG
Added configurable "Node: Size" & "Scroll: Smooth Scroll Level..." that may help touch device users (panel properties)
Improved interaction with playlist, especially when using Ctrl key
Fixed Allmusic node collapse regression
Fixed search paste issue with long search text
Library Tree 1.2 (https://hydrogenaud.io/index.php/topic,110938.msg930482.html#new)
Post by: seriousstas on 2016-11-06 18:00:25
Thank you so much !
"Node: Size" - I would hope to change the icon size, and not just distance.
  that may help touch device users.
  For work on a touch device - moving playlist should be a mouse with holding down the left button.
"_PROPERTY: Touch control" in "JS Smooth Playlist"  Then it emulates the movement of a finger.
Post by: iAlienator on 2016-11-12 14:15:48
Hi, really enjoying the library tree script so far myself.
There is one small thing I noticed while playing around it a bit more, and it is that the mouse scrolling behaves in a bit weird way when more elements are collapsed. So instead it scrolling the default amount (usually 3 lines at a time) down, it scrolls by some really big amount at a time. And it only happens when the nodes in the tree are collapsed outwards, while on the root level the mouse scroll is completely fine.
edit: actually it doesn't seem to be fine even on root level, but more to do with how much of the tree is on the view and how much is not. So when the visible area gets small enough the scroll seems to broke and scroll way more than it should on single scroll up/down.
Post by: WilB on 2016-11-12 16:29:44
I couldn't reproduce any scrolling issues & no one else has reported any. By default the script uses "Page Scroll" and so will scroll by a large amount, depending on the info to be displayed etc. You can set "Scroll - Mouse Wheel: Page Scroll" to false in panel properties for standard 3 line scrolling. I hope that helps.
Post by: seriousstas on 2016-11-12 16:40:32
WilB
I use   symb_style = 1  to zoom icons tree :
https://www.youtube.com/watch?v=wf4xUcOacnQ
Thank you for the excellent library !
Post by: iAlienator on 2016-11-12 16:56:30
Oh I never noticed that page scroll option there, would have probably checked that if I had any idea there was option for it. So anyways thanks for the info, that did indeed solve the scroll issue I was having.
Post by: TheQwertiest on 2016-11-18 16:29:27
Well, it's my attempt to make foobar behave more Winamp-escque =)
My usage scenario is quite simple - I use Library Tree as 'file' browser (Library View PL is used as a simple playlist, that is populated only via double-click or manual addition). I.e. I can freely move through directories\playlists and etc without worrying, that my playlists might be emptied or changed. That's why I want to avoid 'send to playlist' via single LMB click.
Your script is the only one that I could 'force' to behave like that (+ it's stylish and suits my foobar's theme), so I was hoping, that it would be possible to implement it as a build-in feature, as to avoid patching it manually every release.
Yeah, forgot about that... I guess it might be impossible to implement my request while retaining all the other functionality without changing a lot of code :\
Post by: condenado on 2017-01-13 12:36:04
Hi TheQwertiest, could you share the complete code with singleclick autofill disabled? I can't make it with your past instructions, Thanks!
Post by: WilB on 2017-01-13 15:46:59
@TheQwertiest & @condenado
Just to confirm that I had already added the ability to disable single click auto-fill in my copy. When single-click auto-fill is disabled, the playlist will be only be filled on left double-click or manually.
There will be a new a release shortly incorporating this feature, when I have finalised a request from always.beta...
HTH
Post by: condenado on 2017-01-13 17:09:08
HTH
Perfect!! I'll be waiting. Thanks WilB.
Post by: always.beta on 2017-01-15 14:45:28
I am glad to hear you say that you are adding a feature I want. Thanks WilB. Can you share a modified version? Its appearance (scroll bar) is similar to Br3tt’s JSS~.
Post by: colagen on 2017-01-21 15:32:04
This component is greatn thank you
A suggestion : For each node, can you make the whole line clickable instead of just the text ? maybe it can expand the node when the mouse click is before the node's text, and it can send to playlist when the click is on the node's text, or after the node text.
It will make the script a little more intuitive to use.
Post by: colagen on 2017-01-28 13:37:33
It's okey, i managed to update the script myself. One last thing which would be great is to expand the nodes which match the search string, when performing a search. I tried to do it also, but it require a good understanding of the code, and probably significant changes, so i gave up.
Post by: WilB on 2017-02-05 22:45:38
@collagen I have added the requested features and they will be in the next release.
@always.beta Your requests will also be in the next release.
Post by: WilB on 2017-02-11 17:19:13
New Version: Library Tree 1.3 (https://hydrogenaud.io/index.php/topic,110938.msg935524.html#new)
CHANGELOG
ADD: Ability to disable single-click auto-fill of the playlist. When disabled, the playlist can be filled manually, from the menu, or on double click. Set in panel properties; "Text Single-Click: AutoFill Playlist" and adjust "Text Double-Click" according to taste.
ADD: "Expand" (right click menu): fully expands node (N/A for large nodes).
ADD: "Collapse All" (right click menu).
ADD: Auto expand search results. Operates when list is refined sufficiently – see technical notes below. Default is off.  Enable in panel properties: "Search Results Auto Expand".
ADD: Improved custom node icon options, e.g. chevron arrows like >. To use, enable "Node: Custom..." in panel properties.
ADD: Improved navigation. Node selection area is bigger + nodes highlight on hover (can be disabled). Additionally, active text area can be increased by enabling "Text Whole Line Clickable" in panel properties.
ADD: Node size can now be zoomed (mouse-over > Ctrl + Alt + mouse wheel).
CHG: Zoom. Ctrl + Alt + mouse wheel are now required to zoom the font, filter and node sizes on mouse over. This is to stop ctrl selection of tracks while scrolling sometimes causing zooming.
ADD: Custom node colours (panel properties).
ADD: Customisable scrollbars (panel properties).
FIX: Minor draw issues.
Technical notes
1) The menu "Expand", and search results "Auto Expand", have default limits of 500 & 350 tracks, respectively. This is for efficiency reasons & because expanding to large lists impedes navigation. Thresholds can be changed in: "ADV.Limit..." in panel properties.
2) Availability of custom icons may depend on fonts installed. The icon font can be set in panel properties. Font symbols can be pasted in.
3) Ensure comma "," separators are retained where used in panel properties.
4) Some panel properties have changed & redundant removed (view & view filter patterns unaffected). Export panel properties, before updating, if you need a record.
Post by: WilB on 2017-02-12 18:23:57
New Version: Library Tree 1.3.1 (https://hydrogenaud.io/index.php/topic,110938.msg935555.html#new)
CHANGELOG
Fix: Draw regression
Post by: colagen on 2017-02-12 21:58:23
Thanks. Finally i did it myself on my custom library tree, but a little bit differently : on my script, when there is one node only at any level of the tree, this node is automatically expanded. Like that it work for the search results, but it also work when an artist have only one album, when you expand the node of this artist, you see directly the tracks of the album.
I added a property called autoExpendOnSingleChild, and i added the line of code below at the complete end of the function named "branch" of the object "populate".
if(br.child.length==1 && pop.autoExpandSingleChild) pop.branch(br.child[0]], false , true);
Post by: Black_Over_Bills_Mothers on 2017-02-13 18:14:19
Hi Wilb. Firstly many thanks for a great component and it keeps getting better.
I have found a small problem with the following view;
View by Genre // %<genre>%|[%band% - ]%album%|[[%discnumber%.]%tracknumber% ][%track artist% - ]%title%
As you should see I use multi-value genres.
I get a crash popup window telling me that at line 583 Col 93. 'Unable to get property 'name' of undefined or null reference.
It may be my inconsistant tagging but I wouldn't expect a crash.
Post by: WilB on 2017-02-15 21:42:07
New Version: Library Tree 1.3.2 (https://hydrogenaud.io/index.php/topic,110938.msg935692.html#new)
CHANGELOG
FIX: Regression in multi-value tag handling
Post by: GSmirnov on 2017-03-03 18:42:55
Hi. View by Folder Structure doest`n work?
Post by: WilB on 2017-03-03 20:38:07
It's working for me. I tried on main + portable install + no one else has reported issues.  I assume you have the foobar2000 media library enabled and it contains music. Bear in mind common folders aren't displayed - it should look similar to DUI album list with view by folder structure for comparison.
Post by: GSmirnov on 2017-03-03 20:56:09
Oh. Sorry, my mistake. I use WSH panel =))
Now all working!
But I'm not sure that correctly understood the last sentence. Explain in detail please, if possible with screenshots
Post by: Axonn on 2017-03-28 11:07:41
Hey :). I'm curious if there's any version of the script that has better formatting and/or comments. Right now some lines are more than 300 characters long and I keep wondering if there's something wrong I did when loading the script. It almost looks like it's generated from some other tool. If this is the way you write code, then please don't take my comment as an insult. I'm sure that you have your preferences and if that's the case, I definitely won't comment against somebody that has done such awesome work for free :). I am merely trying to browse & understand the code so that I may learn to do some JSPanel components myself.
Post by: zeremy on 2017-03-28 11:24:13
Use http://jsbeautifier.org/ on the code .will help you browse it easier.
Post by: Axonn on 2017-03-28 22:06:40
That's a pretty nice tool. Thank you! :). However, it's just a workaround. I am still wondering if the WilB has a better source somewhere. If not, I'm cool with that! :).
One more thing: do you know any other JSPanel components? Is there a repository for updated components (that work with the latest JSPanel)? I already have the "Smooth series" (br3tt). I'm trying to find more samples to look at :).
Post by: San_dr on 2017-04-12 14:34:51
Hi Wilb!
I'm not a programmer and my English is bad, but I'll try :))))
good plugin, I use it at DUI,placing it under the standard playlist. (so that the coordinate "x" they have the same), and the horizontal separation between them moving manually, if necessary. Added to the script line "window.MinHeight=55;" (this can't reduce the window to zero and forget about it.) How to change the script so that when you turn on the player folder "All Music" was curtailed and the condition "window.MaxHeight = window.MinHeight" performed? But if clicked on the "minus" button (expand) to the left of the folder "All Music", or started "the search"- then the condition "window.MaxHeight" was terminated (false) , and the window was slightly extended in height (to get noticed and could manually increase the height of the window if you want) - for example "window.Height = window.MinHeight*3" , and when you click on the "plus" sign (collapse) "All Music" again became "window.MaxHeight = window.MinHeight" (true)
thought also that it can be easier to set two values of the height of the window selected by the user, and switch between them with the button "All Music" to expand/collapse
Post by: jaysong on 2017-04-14 04:19:51
I am moving my music library to a new laptop where folder structure is changed.  I realize all those playlist files .fpl keep absolute folder structures like C:\Users\Jay\Documents\personal\foobar2000\Music library\.  I need to figure out a way to keep these file locations to be relative on the original laptop so that the new laptop can locate .cue files by a relative point.  Any ideas?  It'll be very much appreciated.
Thanks.  Jay
Post by: colagen on 2017-04-14 13:16:56
Thanks.  Jay
It seems that your issue isn't related to Library Tree Jscript. You should start a new topic, in the "general (https://hydrogenaud.io/index.php/board,27.0.html)" board
Post by: WilB on 2017-04-20 18:05:44
New Version: Library Tree 1.3.3 (https://hydrogenaud.io/index.php/topic,110938.msg938251.html#new)
CHANGELOG
ADD: Option for All Music node expand/collapse to change panel height, e.g. so library tree only occupies a small space when not actively used. In this mode, typing in search also auto-expands the panel. Enable and set expand/collapse sizes in panel properties (ADV.Height...).
If the feature is used, note the following requirements and recommendations:
  - Back-up layouts, by exporting theme files (DUI) or fcl files (CUI), in case of unwanted sizing effects that, could arise if the next point isn't implemented
  - Must be another panel above or below library tree
  - "Node: Show All Music" has to be enabled in panel properties
  - N/A if library tree is in a panel stack splitter container
Post by: San_dr on 2017-04-21 14:05:25
Thanks, WilB! Promptly fulfilled. :))
With customized Autokollapse has become much more convenient.
Post by: Lucidae on 2017-06-14 07:41:58
Thanks WilB for creating this plugin, it's made my layout much more functional.
I'm using library tree in conjunction with the jscript album art viewer - it works fine with "prefer now playing", but if I set it to "follow selected track", the artwork is not updated when the selection is changed. Is there a way around this?
Post by: marc2003 on 2017-06-14 17:39:09
There are 2 issues with what you're trying to do.
Unfortunately, my artwork panel does not update with library viewer selections, only playlist. I've updated the menu in the next version to avoid confusion. https://github.com/19379/foo-jscript-panel/commit/a102874eed63d74f8ec1dc127d7596bd623d3e6e
Secondly, this Library Tree script doesn't yet support updating the selection so even the default UI artwork panel wouldn't update. There is a way to do it with JScript Panel but it was a feature added by a previous developer when the component was under its original name of WSH panel mod. The original docs didn't really explain how to use it properly but I've just about figured it out. I need to update the docs with an example that WilB could implement in this script. I'll post back when that is done.
edit: I've drafted something here, hopefully it makes sense...
https://github.com/19379/foo-jscript-panel/blob/deb88db224a247309ad8a3a82ae33ff77d6b2e8e/component/docs/Interfaces.txt#L63L123
Post by: Blockdude on 2017-07-06 01:28:29
WilB, thanks for this component, but is there any chance of being able to filter multiple of the same item?
ie: filter only one genre from a specific artist, filtering it to match 2 genre tags (Dance and Electro), and filtering to exclude certain tags.
Post by: WilB on 2017-07-26 10:48:30
@Blockdude. If I understand you correctly, then that depends on the filter Query used. Check out the foobar2000 Query syntax.
@Black_Over_Bills_Mothers
View by Band // $if2($swapprefix([$meta(band,0)],A,The), 'Non Album')|$if($stricmp($meta(band,0),various artists),,['('%date%') '])%album%[|Disk %discnumber%]|[%tracknumber% ][%track artist% - ]%title%
Your above pattern is attempting to insert a conditional branch that the script doesn't support, as described in the documentation. It does handle the scenario by inserting a hyphen instead. The reasons for not supporting conditional branches have been discussed before (https://hydrogenaud.io/index.php/topic,110938.msg914836.html#msg914836). Essentially adding the feature would require re-writing much of the library handling in a different way, and since its running in jscript, that way would slow things down too much based on my tests.
The best patterns I quickly came up with are as follows:
View by Band // $if2($swapprefix([$meta(band,0)],A,The), 'Non Album')|$if($stricmp($meta(band,0),various artists),,['('%date%') '])%album%|[[%discnumber%.]%tracknumber% ][%track artist% - ]%title%
View by Band // $if2($swapprefix([$meta(band,0)],A,The), 'Non Album')|$if($stricmp($meta(band,0),various artists),,['('%date%') '])%album%[ - Disk %discnumber%]|[%tracknumber% ][%track artist% - ]%title%
@Lucidae & marc2003. There will be a new version shortly with library viewer selection support.
Post by: WilB on 2017-07-26 18:58:26
New Version: Library Tree 1.3.5 (https://hydrogenaud.io/index.php/topic,110938.msg942684.html#new)
CHANGELOG
ADD: Library viewer selection support (thanks to marc2003 for info). Mostly, this improves interaction with default user interface album artwork panel. Most users won't notice much difference as it already worked through playlist selection.
@Lucidae: JScript biography album art panel, when set to follow selected track (uncheck "Menu > Sources > Now Playing"), has always given the behaviour you described with default library tree settings. Default user interface album artwork panel will also now work the way you want.
Post by: WilB on 2017-07-28 11:30:20
New Version: Library Tree 1.3.6 (https://hydrogenaud.io/index.php/topic,110938.msg942792.html#new)
CHANGELOG
CHG: Re-worked library handling so that conditional branches are now supported, e.g. discnumber in example below:
View by Artist // %artist%|%album%[|Disc %discnumber%]|[%tracknumber%. ][%track artist% - ]%title%
Speed is better than previous for initialisation of most views.
Post by: Black_Over_Bills_Mothers on 2017-07-29 22:14:06
Hi WilB
Many thanks for this. I'll try it in the morning.
Post by: Black_Over_Bills_Mothers on 2017-07-30 07:54:15
Hi WilB
GREAT! It works just fine. Thank you very much for your work on this script.
Post by: Lucidae on 2017-08-02 08:11:13
CHANGELOG
Thanks for this update, exactly what I was hoping for!
I have another small request - could you add an option to change the panel edge style, so it can closer match other DUI elements?
Post by: WilB on 2017-08-02 11:38:03
Panel edge style can already be set: none, sunken or grey, in line with other components. This is controlled by JScript panel itself & not the script. To set: shift + right click Library Tree, choose configure & the "Edge Style" setting is at the bottom of the JScript Panel Configuration window.
Post by: WilB on 2017-08-24 15:47:15
New Version: Library Tree 1.3.7 (https://hydrogenaud.io/index.php/topic,110938.msg944078.html#new)
CHANGELOG: Various optimisations
Post by: miras on 2017-08-27 23:52:34
Hi WilB, I'm using your great script and I have another question.
Library Tree is a great substitute to Filter Columns UI panel and others.
But can I get a "playback playlist" behaviour? Like "Filter Results" and "Filter Results (Playback)" playlists in Filter panel?
I have been using Filter Panel + Graphical Browser + marc2003 Playlist for a long time. I lost something very obvious or Filter Panel it's only to have this two default playlist behavior? Maybe with some plugin? Thanks a lot!
Post by: WilB on 2017-08-28 12:48:04
As far as I am aware only the facets/filter style library viewers offer a separate playback playlist, which it seems has to be selected by some type of playlist manager. So I didn't get on with the way that worked.
JScript Library Tree aims to retain the playing status of the playing track in the playlist (i.e. highlighted with playing symbol) when clicking on different nodes and then returning back to clicking on a node containing the playing track.
Post by: culinko on 2017-08-29 14:09:14
Hi WilB, looks like I found another one of your great works :)
So far it does everything I would want it to, except one small thing. I wonder if I missed a setting for it somewhere. The thing is that if you have 2 group levels (2x | sign), you can expand the tree 2 times (2x plus sign) to get all the way to the individual tracks, such as in your Album Artist View. But if you have only 1 group level, such as in your Album View, there is no plus sign so you can't expand the tree to see the individual tracks at all. Is it possible to have the plus sign displayed for only 1 group leve? Thanks a lot!
Post by: WilB on 2017-08-29 17:35:17
Thanks for the report.
Unfortunately a regression has arisen in v1.3.7. If the issue affects you, then v1.3.6 is working fine, until the issue is fixed.
Post by: culinko on 2017-08-30 00:40:17
Yeah, I can confirm that the issue is no longer present in v1.3.6, so I will be using that one until it's fixed. Thanks for the advice.
Post by: culinko on 2017-08-30 15:02:37
I found one more thing which doesn't work for me, not sure if it's a bug in the Library Tree or something in Foobar. When I use the | sign to add another group level inside an if condition, the code won't work. I know the conditions work for 1 level of grouping, so title formatting seems to be supported inside both the custom sort and view patterns of your Library Tree.
E.g. this code with 1 level of grouping works:
$if($strcmp(%directoryname%,Hudba),%directoryname%,%album artist% - %album% '['%date%']')
but this code with 2 levels doesn't:
$if($strcmp(%directoryname%,Hudba),%directoryname%|[%artist% - ]%title%,%album artist% - %album% '['%date%']'|%discnumber%.%tracknumber%. [%artist% - ]%title%)
Is there anything I need to change in order to make this work? Thanks a lot, much appreciated!
Post by: WilB on 2017-09-05 15:59:46
New Version: Library Tree 1.3.8 (https://hydrogenaud.io/index.php/topic,110938.msg944563.html#new)
CHANGELOG
FIX: Regression
FIX: Certain views with conditional branches weren't displaying properly
@culinko. The issues raised should be fixed.
Post by: huggy020 on 2017-09-30 02:26:35
.........  option for items counting.  It will be great if numbers in brackets can show correspondingly the number of sub-folders (artists) in genre folders, the number of albums in artist folders and the number of songs in album folders.
+ACDC (3)
+Album1 (11)
+Album2 (11)
+Album3 (11)
+ACDC (33)
+Album1 (11)
+Album2 (11)
+Album3 (11)
Would you now consider these option in the future, for those of us who collect mainly albums instead of singles. Thanks you kindly.
Keep up the good work. This is brilliant
Post by: MojoBass on 2017-10-02 13:55:31
WilB, your JS plugins are really great!!
General question to your plugins (Library Tree, YTTM, Bio): is there a way to assign specific menu items, which are usually accessed by right mouse, to a button (eg most liked filters in the Library Tree)? If it requires specific coding, a small example would be great from where I could start create own buttons.
Thanks very much,
MojoBass
Post by: WilB on 2017-10-05 19:20:54
New Version: Library Tree 1.3.9 (https://hydrogenaud.io/index.php/topic,110938.msg945843.html#new)
CHANGELOG
ADD: Improved sorting of multi-value items sent to playlist. As before a custom sort can also be used.
CHG: Node Item Count. Either sub-items counts or track counts (as before) can now be displayed. Set preference in panel properties.
ADD: Menu item (shift + right click) to batch create m-TAGS. Runs m-TAGS creator. Follow instructions on menu item. See documentation for full info.
@mojobass It's possible to create buttons in the script, by adding more onto the button_manger object. If you mean elsewhere then notify (search interfaces for notify) might be able to be used to communicate with another JScript panel containing the buttons, but I don't think it would work if the buttons were elsewhere.
Post by: huggy020 on 2017-10-07 04:24:52
CHANGELOG
thank you
Post by: MojoBass on 2017-10-07 05:32:15
Thank you very much for this Info. I will look into it (but not too sure if I am able to do adaptions in the buttom_manager...).
Post by: novaca on 2017-10-09 09:36:28
I also thank you for the sub-items counts...
I really think it's more useful than track counts.
Post by: musikomaniak on 2017-11-10 10:07:50
I did not find where to increase font size.
I use Ctrl + Alt + mouse wheel, but it's not very practical.
I'd like something like SEGOE semibold 10.
Post by: MojoBass on 2017-11-11 05:01:42
In Panel Properties put '_CUSTOM COLOURS/FONTS: USE' to 'True', then you can change the font at '_Custom.Font (Name, Size, Style [0-4])'.
Post by: musikomaniak on 2017-11-11 07:51:47
Thank you very much MojoBass.
I was changing font without putting "True" to CUSTOM COLOURS/FONTS: USE' !  :)
Post by: always.beta on 2017-11-12 01:49:41
Search: ALL I WANT FOR, crash. But search: All i want for, not crash.
JScript Panel (Library Tree v1.3.9 by WilB)
JavaScript 运行时错误:
File: <main>
Line: 992, Col: 58
Post by: marc2003 on 2017-11-12 11:05:36
Well you can't use uppercase ALL because it has a special meaning in queries that returns everything. If you use double quotes around it then it's fine.
"ALL I WANT FOR"
But the script should have the fb.GetQueryItems function inside a try/catch statement to prevent errors (https://github.com/19379/foo-jscript-panel/blob/931e07797f107c317f03c8d1664dd118d006aba6/foo_jscript_panel/docs/Interfaces.txt#L216L224).
Post by: always.beta on 2017-11-12 11:37:35
Thank you.
Post by: WilB on 2017-11-15 12:54:54
New Version: Library Tree 1.3.9.1 (https://hydrogenaud.io/index.php/topic,110938.new.html#new)
CHANGELOG
FIX: Regression related to query syntax help.
FIX: Missing try/catch with one of the fb.GetQueryItems functions.
Post by: Tropoje on 2017-11-18 08:52:02
@WilB
This is fantastic. Thank you very much for your hard work with this component.
Is it possible to set the cover of the currently playing track as a background of Library Tree ? I looked in settings but maybe I missed something.
Post by: novaca on 2017-11-26 12:24:21
Is there a way to change the color of "Item Counts" (numbers in brackets) other than text?
I think that then it would be clearer.
Post by: eNforcer on 2017-12-06 23:21:58
What an amazing script, I'm loving it!
Post by: zoumbro on 2017-12-07 07:20:18
Library tree is so far one of the best feature of foobar. I am trying to customise my settings to my needs however due to my luck of knowledge I need some help.
I always use view by Folder Stucture.  In Filter option i would like to have an option o Most Played Folders in sort descending. I quess it has to be done smg with the aggregation of folder tracks
Post by: WilB on 2017-12-24 12:13:24
@Tropoje & novaca. The requested features should be in the next release.
@zoumbro. The aggregation methodology of the type you require isn't supported. The filter uses foobar2000 query syntax and AFAIK that doesn't support it either.
Post by: fabiospark on 2018-01-04 20:59:18
Is it possible to have the views list as a view?
I mean, I'd like to have all the views always visible together
without having to use the right click, like the old Playlist Tree
or the PLT mod called Library Tree.
This is what I mean.
(https://image.ibb.co/jRUwBb/PLT_mod_Library_Tree_multiview.png) (https://ibb.co/fCr9Wb)
Post by: WilB on 2018-01-05 11:57:49
Nope.
Post by: WilB on 2018-01-24 18:27:27
New Version: Library Tree 1.3.9.2 (https://hydrogenaud.io/index.php/topic,110938.msg951758.html#new)
CHANGELOG
ADD: Themes: dark, blend & light ("right click > menu > theme").
ADD: Option to set current cover as background ("right click > menu > theme"). Cover opacity & auto-fill can be set in panel properties ("Cover...").
ADD: Configurable root name. Choice of "All Music" or view name, e.g. "Artists", "All Genres" etc. Enable in panel properties "Node: Root..." and set view names as required. To show  number of artists etc, set "Node: Item Counts" to show "Sub-Items" [panel properties].
ADD: "Tree: Remember State" [panel properties]. Remembers expanded nodes, search & selection state etc on closing / opening foobar2000. Default is enabled.
ADD: "_Custom.Colour Item Counts" [panel properties].
FIX: Compatibility with JScript Panel v2.0.1.
Post by: always.beta on 2018-01-25 03:07:50
Did you forget to change it?
Post by: Tropoje on 2018-01-25 07:35:14
@WilB First of all, thank you very much for your work.
I love your "Library Tree". New options work as expected.
THANKS
Post by: TheQwertiest on 2018-01-25 09:11:17
@WilB : So many changes, but the version bump is so small.. I wonder what it takes to bump a 'major' version :P
Post by: WilB on 2018-01-27 17:51:30
@always.beta
I can't reproduce that with the new version (1.3.9.2). Nothing should have changed for those items & all's working well on my test set-ups. All panel properties does is initially read the settings from the script, and those ones are identical to before. The settings are retained unless edited by the user. Try resetting the affected panel properties by deleting them.
Post by: Black_Over_Bills_Mothers on 2018-01-28 10:04:15
Crash
Hi WilB I'm using version 1.3.9.2 and getting
'undefined' is null or not an object
File: <main>
Line: 558, Col: 221
When I use a view;
View by Band // $swapprefix(%<band>%,A,The)|$if($stricmp($meta(band,0),various artists),,['('%date%') '])%album%[ '('%disctitle%')'][|Disk %discnumber%]|[%tracknumber% ][%track artist% - ]%title%
It seems to be the multi-value band tag that is causing it. If I use $meta(band,0) all is okay - but I don't get entries for the other values in the tag.
Post by: WilB on 2018-01-28 17:06:42
@Black_Over_Bills_Mothers. Thanks for the report. The issue seems to occur when running the script with the JScript engine. Under the 'chakra' engine the issue disappeared for me. Incidentally, note that in your example, $swapprefix applies to the whole str content. $swapprefix(%<field>%) doesn't split the values and apply $swapprefix to each. Any string manipulation function that removes a part of a string or inserts a substring by position is generally unsafe (http://wiki.hydrogenaud.io/index.php?title=Foobar2000:Titleformat_Album_List) in multi-value branching expressions.
All users of Library Tree 1.3.9.2 should ensure that the 'Chakra' script engine is used (requires IE9 or later) - select in the JScript panel configuration window (https://github.com/marc2k3/foo_jscript_panel/wiki/Configuration-Window)  (shift + right click).
If updating to JScript panel 2.0.1, existing panels will default to the JScript engine and so the 'chakra' engine has to be set.
Post by: Black_Over_Bills_Mothers on 2018-01-29 09:52:34
@WilB Thanks for the reply, it now works. However as you point out $swapprefix(%<band>%,A,The) doesn't actually work as I had intended. It now splits the muli-value tag band correctly but doesn't do anything with the prefix, they are ignored. Not nice.
Since this seems to be a limitation with foobar core/ColumnsUI I probably don't stand much chance of getting this fixed! So it occurs to me that it could be done within the JScript code itself. Just a thought!...
As usual thanks for your continued efforts on this panel, I couldn't do without it now.
Post by: eNforcer on 2018-02-20 00:13:22
Looking for a bit of help, I'm trying to sort my albums by year (old to new) but I keep messing it up.
Here's my filter:
Brad // %artist%|%album% $if(%date%,'['[%date%]']')|$if(%discnumber%,[Disc %discnumber%|%tracknumber%_%title%],[%tracknumber%_%title%])
(https://i.imgur.com/QcjM28J.png)
Post by: WilB on 2018-02-21 11:55:06
Sorting is by the view pattern. So the date has to be in front of the album. Try:
Brad // %artist%|['['%date%']' ]%album%|$if(%discnumber%,[Disc %discnumber%|%tracknumber%_%title%],[%tracknumber%_%title%])
I might add a $nodisplay{sort} parameter that can be used in the pattern. It will enable extra sorting without display of the sort item. Then you could just use that, and keep the displayed date after the album.
Post by: Black_Over_Bills_Mothers on 2018-02-21 12:20:16
@WilB
Sounds like a great idea. Could I use this to display in descending date order ie latest album first?
Post by: WilB on 2018-02-21 13:09:52
Yes. It all seems to be working on my copy & should be in the next release.
Post by: culinko on 2018-03-09 23:30:44
Found a small issue with Library Tree. I have the border of the panel hidden but when I switch to another song or play/pause the current one, the border of the panel flashes for a split second most of the time. It also happens when switching from another panel (e.g. Biography) to Library Tree. The easiest way to reproduce it is to spam play/pause for the current song with the panel open. For some reason I couldn't capture it on screenshot, though.
Title: Re: Library Tree Discussion
Post by: WilB on 2018-03-10 00:41:44
I couldn't see the issue using DUI or CUI with panel stack splitter.
Are using panel stack splitter? A flashing panel/border sounds as though it might be a panel stack splitter artefact. PSS usually re-runs all it's code on play & pause & on panel change as panel sizes alter. You have to be careful how to set up PSS layouts so they work cleanly. So if using PSS please ensure its not due to the construction of the layout, as it may have nothing to do with the Library Tree.  Fiddling around with positioning methods like $movepanel, custom background color (behaviour tab), use of $showpanel & force layout if it's in PSS may help.
If the issue persists which border do you mean? I don't understand how you see it flashing if it's hidden??? To try & reproduce I would need more info on the set-up, DUI vs CUI, exactly what the container is, e.g. PSS etc. May be a screenshot of the layout would help.
Post by: culinko on 2018-03-10 02:58:36
I am using Columns UI with PSS. Interestingly enough, this issue doesn't happen with the Biography script even though the PSS script for the background is literally the same for both:
$drawrect(0,0,%_width%,%_height%,$get_ps_global(bg.color),$get_ps_global(bg.color),)
If I check Forced Layout the panel is just blank.
I managed to record it with Fraps and uploaded the video to YouTube: https://www.youtube.com/watch?v=CVkfSB-1mig . You can use 0.25 speed and see how the border briefly flashes when switching to the next song.
Edit: I managed to crash the panel by right clicking in a specific spot somewhere on the top edge of the panel: https://i.imgur.com/KyAGSx2.png. My mouse cursor was exactly at the upper left edge of the right click dialogue. Reloading the panel fixes the error. I am not sure if it's a bug in Library Tree or in JScript panel. The error is the following:
Error: JScript Panel v2.0.6 (Library Tree v1.3.9.2 by WilB)
Unable to get property 'rbtn_up' of undefined or null reference
File: <main>
Line: 1411, Col: 85
Post by: WilB on 2018-03-10 11:17:46
The appearing borders seem as though they due to the default 5px PSS padding. I believe the issue is the way the layout is constructed and how PSS redraws on track change, etc. This doesn't look like an issue with library tree to me?
To test if it really is a library tree issue, try exporting the layout as an fcl file so you have a back-up. Then shift+right click library tree > configure. Choose tools > reset to default. You should then see the default JScript panel layout. If the problem persists then its not due to library tree.
It looks to me like the layouts drawing the panel twice: one time a bit smaller so the borders show. As a workaround reducing the padding to 0 may remove the issue. I suspect there is something different in how the bio panel is sized & positioned in PSS vs the method used for the library tree panel. There are several ways of positioning panels in PSS. Try exactly duplicating the method used for bio with library tree.
The other issue should be fixed for the next release.
HTH
Post by: culinko on 2018-03-11 15:07:56
Thank you so much, I managed to resolve the issue! Here's what I did in case someone else encounters a similar issue:
First I verified that it's not a Library Tree issue by resetting the JScript panel as you suggested and the issue still persisted. Then I removed the 5px padding from the panel which fixed the issue. However, the JScript panel with the Biography script also has 5px padding, so it had to be something else. Then I compared the settings for all PSS panels that I have and there were some inconsistencies in the behavior tab (custom background color, pseudo transparency, keep aspect ratio, enable per second checkmarks). After enabling "custom background color" and setting it to the color I use, the issue disappeared!
Again, thank you so much for the pointers, knowing where to dig does really help a lot :)
Post by: WilB on 2018-03-26 13:07:31
New Version: Library Tree 1.4 (https://hydrogenaud.io/index.php/topic,110938.msg954814.html#new)
CHANGELOG
ADD: Drag & drop (thanks to TheQwertiest & marc2k3).
CHG: Efficiency improvements due to implementation of new changes to JScript panel (thanks to marc2k3).
- faster initialization (typically 1.2-2X faster, depending on view)
- faster updates to tree when media library changes (typically 3-1000X faster depending on nature of update)
- much improved handling of tag-like database triggers (foo_playcount etc) that frequently call on_library_items_changed
ADD: Copy command to context menu + keyboard shortcut (CTRL+C) for copying items. Copied tree items can be pasted in playlists or other components. Thanks again to marc2k3 for new features that have enabled this.
ADD: $nodisplay{sort}. For use in view pattern. Enables use of extra sorting without display of the sort item. Example:
View by artist // %artist%|$nodisplay{$sub(99999,%date%)}['['%date%']' ]%album%|$nodisplay{%tracknumber%}[%track artist% - ]%title%
Albums will be sorted by DATE, latest first, with date displayed before the album.
Tracks will be sorted by %tracknumber%; %tracknumber% isn't displayed.
ADD: Hot keys for "Add to Playlist" & "Insert in Playlist". User assignable: right click > panel properties > "Hot Key...". They're likely to work best with "Playlist Autofill" off.
CHG: Some optimisations to key stroke navigation.
FIX: Now runs under both 'Chakra' & 'JScript' script engines. Use the 'Chakra' script engine if possible (requires IE9 or later) - its faster with this script. Set in the JScript panel configuration window (shift + right click).
FIX: Regression: stackoverflow issue.
As pointed out by the TheQwertiest, the previous version should have had more of a version bump due to the number of enhancements. That is now corrected.
Post by: WilB on 2018-03-26 17:48:06
New Version: Library Tree 1.401 (https://hydrogenaud.io/index.php/topic,110938.msg954848.html#new)
FIX: Regression: selection issue
Post by: Black_Over_Bills_Mothers on 2018-03-28 10:51:09
Hi WilB
I'm not that confident with my database search syntax but I've tried the following filter;
$meta(genre,0) IS Test
and it doesn't work. But;
%genre% IS Test
does work.
Am I doing something wrong?
Post by: jazzthieve on 2018-03-28 10:58:52
Does "$meta(genre,0)" IS Test work?
Post by: Black_Over_Bills_Mothers on 2018-03-28 11:19:42
Hi jazzthieve
Yes, the addition of speech marks fixed it. Thanks or your swift reply.
Post by: WilB on 2018-04-10 18:12:20
New Version: Library Tree 1.4.02 (https://hydrogenaud.io/index.php/topic,110938.50.html#msg955694)
ADD: $swapbranchprefix. For use in view pattern and with branching expressions. Enables swapprefix to be applied to each branch created from a multi-value field (@Black_Over_Bills_Mothers).
Syntax: $swapbranchprefix{%<field>%}
e.g. $swapbranchprefix{%<album artist>%}
Only change the field name. Specify prefixes to swap in panel properties: ADV.$swapbranchprefix ... (default prefixes: A + The).
ADD: Ability to set extra hot keys (@N4s7y):
- collapse all
- search (activates search if library tree has focus as that's needed for typing entries)
- search clear
User assignable: right click > panel properties > "Hot Key...". This change resets previous hot key assignments in panel properties.
*** ALWAY ENSURE COMMA "," SEPARATORS ARE RETAINED WHERE USED IN PANEL PROPERTIES ***
CHG: Optimisations: draw + sub-item counts handling.
CHG: Updated to use new "Query Syntax Help" path in foobar2000.
Post by: Black_Over_Bills_Mothers on 2018-04-17 07:45:08
@WilB
Just tried the new version and it's great! This script has everything I need to search and select from my library and it's quick. I have 169k tracks and it refreshes in less than 3 secs. I love the in-built handling of the swapprefix function - it works well.
Thank you for all your hard work on this script.
Post by: N4s7y on 2018-04-17 15:15:00
And thank you for adding those hotkeys. They work like a charm.
I'm really running out of complaints  ;)
Post by: WilB on 2018-05-04 11:11:57
@Novatic: Thanks for the info sent.
The problematical tags are multi-line, e.g.
Maria Callas, Main Artist
Angelo Mercuriali, Featured Artist, Tenor Vocals
Tullio Serafin, Featured Artist, Conductor
Orchestra del Teatro alla Scala di Milano, Featured Artist, Orchestra
Coro Del Teatro Alla Scala Di Milano, Featured Artist, Chorus
Vincenzo Bellini, Composer
That is evident from their display in track properties: "Maria Callas, Main Artist (...)" or by pasting into a text editor (NOT notepad). Incidentally, CUI album list has issues with multi-line tag display/grouping.
The best solution, which will give maximum compatibility with other things, is to remove the line breaks from the affected subset of tags. To complicate things the track properties editor doesn't actually show the line breaks and shows the lines joined without an intervening space, like you get if paste the affected tags into notepad!
Alternatively, just the first line of a multi-line tag can be displayed:
View by Artist // $fix_eol(%artist%,)|$fix_eol(%album%,)|[[%discnumber%.]%tracknumber%. ][$fix_eol(%track artist%,) - ]$fix_eol(%title%,)
Currently library tree is displaying multi-line tags with line breaks, causing the overlap you see. That will be corrected in the next release, by setting it to single line mode. That should display the whole multi-line tag as a single line replicating the whole entry seen upon clicking it in track properties. If you don't fix the tags as above & don't want to wait until the next release:
Shift+right click library tree & choose configure.
Search for:
this.lc
There's only one match in the middle of line 347.
Change it to:
this.lc = DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX | DT_END_ELLIPSIS;
Post by: TheQwertiest on 2018-05-04 13:57:40
@WilB : could you share a problematic track please? I'd like to test it and fix my scripts as well =)
Post by: WilB on 2018-05-04 18:15:09
I've sent you a pm.
Post by: Novatic on 2018-05-04 21:07:59
Many thanks for the complete answer, I fixed my tags as you described. It looks good so far.
Post by: MojoBass on 2018-05-20 09:52:43
Hallo WilB,
Is there a chance for some kind of auto-fill functionality assigned to the 'next' and 'previous' command? I'd like to listen through an album by just clicking on one of the titles and go from there by 'previous' or 'next' without selecting specific titles.
Additionally, it would be great if the currently played song would somehow be indicated in the Library Tree view (e.g. by another background color of the title text or a rectangle around the title text etc).
Another question: when using your script and the JS Smooth Browser from Br3tt/marc2k3 in one skin, in my case the panel properties of both scripts are mixed in the same list (e.g. _DISPLAY... in the Library Tree Panel Properties). Probably this is not indended - just to let you know.
Thanks for the great scripts!
Post by: WilB on 2018-05-31 23:05:14
@MojoBass. 'next' and 'previous' commands are playlist commands. I did try implementing, but, perhaps unsurprisingly, that conflicted with playlist actions. You can achieve the behaviour by using the up/down arrow keys.
It is possible to highlight the playing track and I'll try and add something for the next version unless unexpected complications arise.
To avoid properties that are mixed, clear properties before importing new scripts else properties both from the original & new script will be present. That's just how JScript panel works, unless I've misunderstood your meaning. Importing new scripts doesn't automatically clear old properties.
Post by: MojoBass on 2018-06-03 05:10:53
Hello WilB,
thanks for the hint with the arrow keys, that works well for me!
For the intended behaviour, the option 'Play on Enter or Send from Menu' should be switched on.
Post by: RuKuKi on 2018-07-10 12:26:04
Hello WilB. Thanks for your great script!
Two questions:
it it possible to set the playlist name dynamically on creating (node name) (like in default album list component) when autofill is off
and is it possible to show folders before files (View by Folder Structure)
Post by: WilB on 2018-07-11 17:43:14
1) Set playlist name dynamically. Currently you can use SHIFT + right click > utilities > send to playlist. This a foobar2000 command that can be set to not require shift in foobar2000 preferences > context menu > utilities. This offers a likely playlist name or the option of editing it (works best if files are tagged). I didn't include a "Send to new playlist" command on the main menu because it can result in creating loads of different playlists that are cumbersome to then select or manage etc when simply re-clicking the tree item is much simpler + it auto-updates when the library changes. But it could be added...
2) View by folder structure uses a foobar2000 function that analyses relative paths & that doesn't display common elements of the path to give an easier to view presentation. It's the same as used in DUI album list etc & isn't user configurable. The view you require can probably be created with title formatting. Since this would likely lack the relative path handling bit how well it works may depend on the nature of your folder structure. I'm not sure that I fully understand what you want, but the following seems to be what you're asking:
View by Folder: File // $replace($directory_path(%path%),\,|): %filename%
As the above is path-based, put $nodisplay{%subsong%} on the end if you need tracks in containers like m-TAGS or cues sorted.
There maybe other ways if you look at foobar2000 title format help + also look at that if I misunderstood you.
As is usually the case you'll likely get maximum flexibility if views are created based on file tags...
Post by: Tropoje on 2018-07-24 20:20:58
Is the "Add to Current Playlist" option ? I can not find it or I'm blind :)
Post by: WilB on 2018-07-24 22:07:24
Right click over a tree item & it should be on the menu. The menu is context sensitive & so if the click isn't over an item, view options etc are shown instead.
Post by: Tropoje on 2018-07-25 06:25:22
Of course, under the right click is this option. It's my fault because I did not express myself precisely. I was thinking about changing the behavior of the middle mouse button or changing the behavior of a double click on the selected item. Currently, I have not found such a possibility. I admit that this is a very helpful option and much faster than using the context menu  ;)
Post by: WilB on 2018-07-25 11:06:28
MiddleBtn can be set to add to the current playlist as follows.
Panel properties > Playlist Use: 0 or 1 > set: ...MiddleBtn,0
0 - uses the current playlist.
1 - uses a fixed "Playlist" that can be defined in panel properties (line above: default Library View).
Search the documentation for "Playlist:" if you need more info.
Drag n Drop is also now implemented & that can be used as well.
Post by: Tropoje on 2018-07-25 12:36:23
This is exactly what I was looking for. Works as expected  :D  Thank you very much
BTW
Where can I find documentation about "Playlist"?
Post by: WilB on 2018-07-25 12:47:44
Library Tree 1.4.0.2 Documentation.txt is included with the Library Tree download (https://hydrogenaud.io/index.php/topic,110938.50.html#msg955694).
Search it for "Playlist:" (minus quotes, but with colon) -> takes you straight to info.
Post by: MordredKLB on 2018-07-25 17:31:15
Hey WilB! I was wondering if I could have your permission to incorporate your LibraryTree into my Georgia theme. I've had a couple users ask for this functionality, so I figured I'd try and get the best :)
Post by: Tropoje on 2018-07-25 18:00:47
Oh, I forgot that the Documentation.txt file is attached to every zip file. Everything is clear to me now  ;D
Post by: WilB on 2018-07-25 19:03:15
@MordredKLB
Yes, using Library Tree in your Georgia theme is fine. Permission is granted.
Post by: seriousstas on 2018-08-08 09:28:23
@WilB
Can hope to create a new playlist in the future?
Now we have from Br3tt:
WSH Playlist Viewer 2013 - obsolete
JS Playlist - there is no support for smooth scrolling, there is no support for touch screens.
JS Smooth Playlist by Br3tt - no sorting by folders, no choice of Loved tracks (moods),
not optimized (requires a lot of resources when scrolling), design - requires the best..
Post by: mjm716 on 2018-08-23 21:25:13
Fantastic panel addition Wilb!
Just wondering if there is a way to color within formatting, either via syntax or similar to the existing:
Color control: < >    Used to dim or highlight text, currently available in playlist and status bar. There are 3 dim and 3 highlight levels, accessible by repeating color control characters.    <dim> >highlight< >>extrahighlight<<
Post by: seriousstas on 2018-08-26 09:53:39
 my task  "Add to Current Playlist" via  hotkey.
Can someone help?
Post by: elia_is_me on 2018-08-26 12:30:13
tough work, good luck.
Post by: seriousstas on 2018-08-26 13:29:56
@WilB
If there is an unused * .CUE in the folder with the tracks -
"Add to Current Playlist" from the menu works correctly. Removes this * .CUE .
But if use index hotkeys (PlaylistAdd,0,PlaylistInsert,0) - CUE duplicates files .
"They're likely to work best with playlist autofill off"
It helps ,  but sometimes duplicates are added to the list
Post by: WilB on 2018-08-26 17:39:17
@seriousstass
JScript playlist. I'm satisfied with the playlist renderers I currently use + plus coding one in JScript is a huge amount of effort. So I have no plans to produce one.
CUE files. I may not fully understand what you mean. But, perhaps you need to sort your CUE file handling so only the original music tracks or CUE are monitored as part of the library, e.g. set "Media Library\File Types" in main foobar2000 preferences or use a filter. If you have both the original music files + CUE files as part of the library then, depending on the view, its not always obvious with tree viewers like Library Tree or DUI album list, that both are present since they can sort together. It's not until you add to a playlist that you may see there is more than one copy of tracks. Add to playlist wouldn't remove CUES, it would just add what's in the selected tree item. I do a lot of testing with m_TAGS which is another container format, and I haven't seen any problems.
I checked the shortcut key commands vs the menu commands and they all worked correctly for me. I also checked the code and they're obtaining the lists in the same way. Perhaps your issue is related to the CUE file handling discussed above. Of course you also have to be sure not to assign the same hot key to "Add" and "Insert", because then both events take place.
@mjm716.
The dim & highlight syntax isn't supported.
Post by: seriousstas on 2018-08-27 11:26:13
@WilB
Thanks for the answer!
I understood ..
I use // @version "1.4.1 beta" - here autoFill does not disconnect ..? , hence the problem ..
When do you plan release 1.4.1?
This is a very big breakthrough, a modern script! , but
intel core i7 i5 is needed for normal (touch) scrolling,
or put 4x acceleration, which is not very comfortable ..
+ sorting by folders structure - necessary . Header is not beautiful)
Sometimes forget to remove the CUE - for separate tracks it is not needed,
and that's what I get in the playlist :
Spoiler (click to show/hide)
in the version
// @author "Wilb"
// @version "1.3.2"
or if  just add a folder with the CUE twice.
In version 1.4, CUE is removed, but sometimes the problem remains.
Post by: seriousstas on 2018-09-01 23:51:05
All issues - resolved .
Post by: novaca on 2018-10-08 14:11:55
@WilB
Can I find information about support for the Spider Monkey Panel somewhere (for Library Tree and Biography scripts)?
@seriousstas
I use JS Playlist and it's the best I found.
I only lose more than one grouping level (for multiple disk editions) and $rgb() tag support (in a grouping).
Otherwise, I'm happy with it.
(offtopic, but a crucial topic for me...)
Post by: WilB on 2018-10-08 15:34:22
See here. (https://hydrogenaud.io/index.php/topic,116669.msg962928.html#msg962928)
Since that post there have also been some new feature requests that need to be taken into consideration...
Post by: WilB on 2019-01-20 17:56:29
New Version: Library Tree 2.0.0 (https://hydrogenaud.io/index.php/topic,110938.50.html#msg967374)
CHANGELOG
NEW: Improved menu options (menu > options). Most key options are now on the menu, e.g. mouse & key actions, target playlists, themes, sub-item vs track counts, root node style, items to show and mode (e.g. remember tree state [expanded nodes]).
NEW: Touch Control (enable: menu > options > mode)***.
NEW: Nowplaying highlight option (enable: menu > options > show). If enabled, also adds "Show Nowplaying" to context menu.
NEW: Filter presets now support $nowplaying{%field%}, enabling filtering based on the nowplaying track, e.g.
         artist IS $nowplaying{%artist%} => tree displays tracks by nowplaying artist.
         Nowplaying views can be put in a second Library Tree panel, if required, to retain optimal access to normal views.
NEW: Invalid search expressions are now identified with a message.
CHG: Improved auto expand. Useful to auto expand search, filter & nowplaying results etc if below a certain size. Size is user-configurable. Enable & configure: menu > options > mode.
CHG: Keyboard Shortcuts: common are now inbuilt (see context menu). User configurable keyboard shortcuts have been moved to "ADV.Hot Key..." (panel properties).
CHG: Various performance enhancements, e.g. scrolling & initialisation of views (especially compared with v1.4.0.2 when first released).
CHG: Requires Spider Monkey Panel (https://hydrogenaud.io/index.php/topic,116669.0.html) - if you're unfamiliar with it, then it's based on JScript Panel but has a modern Javascript engine. Spider Monkey Panel can be run alongside JScript Panel, & so other panels can continue to run in JScript Panel if you don't have Spider Monkey Panel versions.
*** for an extra scroll experience, if you don't have a touch screen, enable touch control and drag with left mouse button down.
Updating
Panel properties will be reset as its a new panel. Export JScript panel properties or back-up layouts before updating if you want a record. Importing JScript panel properties isn't supported: panel properties have been overhauled & many key options are now on the menu.
Post by: always.beta on 2019-01-21 02:45:39
Error: Spider Monkey Panel v1.1.4 (Library Tree v2.0.0 by WilB)
tt.Activate is not a function
File: <main>
Line: 1227, Column: 20
Stack trace:
  activate_tooltip@<main>:1227:20
  Populate/this.move@<main>:1688:47
  on_mouse_move@<main>:2327:156
Post by: WilB on 2019-01-21 13:11:16
Reproduced & fixed for the next version.
Until that time note that the issue only seems to occur after enabling menu > options > show > tooltip. Even then reloading the script will remove the error and display the tooltips.
Post by: Tropoje on 2019-01-25 07:06:32
Error: Spider Monkey Panel v1.1.5 (Library Tree v2.0.0 by WilB)
assignment to undeclared variable image
File: <main>
Line: 350, Column: 233
Stack trace:
  getFbImg@<main>:350:233
  UserInterface/this.on_playback_new_track@<main>:358:121
  UserInterface/this.blurReset@<main>:353:101
  on_size@<main>:2338:73
Post by: WilB on 2019-01-25 11:49:07
New Version: Library Tree 2.0.1 (https://hydrogenaud.io/index.php/topic,110938.50.html#msg967656)
FIX: Tooltip issue.
FIX: Variable declaration.
Thanks for reporting.
Post by: Tropoje on 2019-01-25 17:55:11
@WilB
Thank you very much for your hard work. After updating, everything works like a charm  ;D
Post by: seriousstas on 2019-01-26 12:34:41
Сan wait on JScript Panel 2.2.0 ?
Post by: Tropoje on 2019-01-27 16:42:19
There was an error during some operations  :(
Error: Spider Monkey Panel v1.1.5 (Library Tree v2.0.1 by WilB)
assignment to undeclared variable en
File: <main>
Line: 1820, Column: 102
Stack trace:
  SearchLibrary/this.on_char@<main>:1820:102
  on_char@<main>:2311:91
Post by: WilB on 2019-01-27 18:18:27
New Version: Library Tree 2.0.2 (https://hydrogenaud.io/index.php/topic,110938.msg967776.html#new)
@Tropoje. Thanks for reporting. The issue should be fixed.
@seriousstas. I fixed compatibility with JSP 2.2.0 (v1.4.0.3) a while ago - it doesn't have any of the new feature set though. It can be obtained from the usual location.
I believe you were the first (https://hydrogenaud.io/index.php/topic,116669.msg962909.html#msg962909) to ask about adapting Library Tree to SMP. Porting to SMP resulted in a large number of changes and use of newer ES features that are incompatible with JSP. Back porting to JSP would therefore be a lot of effort - I don't have a direct JSP precursor to the SMP version since a bunch of new features were added during porting. I don't see the need for a JSP version either:
1) SMP can be run alongside JSP. So if you don't have SMP versions of other scripts they can continue to run in JSP.
2) A basic upgrade of JSP scripts to SMP versions in any event should only take a few minutes per script following the migration (https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/JScript-to-SpiderMonkey-migration-guide) guide. Only if you wanted to use newer ES styles and features would it be more significant undertaking.
3) Moreover, I think you use "View by Folder Structure". This loads 1.5x faster when running in SMP (v1.1.6-beta) vs JSP (v2.2.0) on my machine [GetLibraryRelativePaths used for both].
Post by: WilB on 2019-02-18 12:50:20
@AndreaT Thanks for the reports. I moved the feedback here, since Uploads section is not a proper place for discussion.
I am getting this error as I click on the top line All Music when in View by Folder Structure mode.
Error: Spider Monkey Panel v1.1.5 (Library Tree v2.0.2 by WilB)
too many arguments provided for a function call
It seems that the "apply" function has a hard coded argument limit of ~500000 in Spider Monkey Panel. So I presume you were trying to send 500000+ tracks from All Music which would give the error. I have changed the method in my copy & so it should be fixed for the next version.
out of memory
I just checked on my system and library tree has a very low memory usage. With default theme, view by folder structure, searches and even expanding every node in the tree I couldn't get it to go above a very small 3-4MB. If one of the theme backgrounds is on then the image display can result in it becoming bigger as the images change. I saw it rise to 62MB, which is still low, before the automated Spider Monkey Panel GC (garbage collection) kinked in and reduced it back down.
To check the panel memory usage, in function on_playback_new_track (~line 2332) I put the following:
console.log("window.ID:", window.ID,"window.PanelMemoryUsage",window.PanelMemoryUsage/1000000, "MB :: Library Size",lib.list.Count);
So on playing a track the memory usage is reported in the console.
Memory handling in SMP is very different to JScript panel.
SMP restricts its total memory usage by default to AFAIK the smaller of 1 GB and 25% of RAM. Note that this is the memory available to all SMP panels. So its possible for one panel to get near the memory limit and effect what's available to other panels which in turn could give an OOM.
You can increase the memory allocation in preferences>advanced>spider monkey panel>maximum heap size. Don't change anything else. Maximum value AFAIK is 25% of RAM.
I do in fact wonder if the default wouldn't simply be better as always 25% of RAM.
Post by: TheQwertiest on 2019-02-18 15:05:31
Well, I don't want a music player to eat up 8gb of my memory :D
The memory limit is set mainly to prevent unintentional memory leaks (e.g. needlessly storing too many uncompressed art images in memory). 1gb limit should be enough for the majority of usage scenarios, IMO, and then there is a `maximum heap size` configuration options for special corner cases.
PS: @AndreaT , `out of memory` error also reports the name of the panel and the memory usage of that panel, so you can locate the memory eating culprit by finding the largest RAM usage number from those error reports.
Post by: AndreaT on 2019-02-18 18:17:04
Hello WilB and TheQwertiest,
my archive has about 6200 directories and 600k records.
So, for the first problem, yes, probably the point what that. I take the opportunity to notify that the View by Folder Structure is "wrongly" reporting the number of records and not of folders (it does not mimic exactly the default Album List).
For the out of memery problem, I cannot replicate now because I already reverted back to Album List, but surely the total memory used by Foobar was not over 1.3GB because I was monitoring it with Windows resource manager. However I will try again the new release when available and I will take care to report any new crash or anomaly.
Going to the point "why willing to use the Library Tree instead of the default Album List, it is all related to these problems I have with Album List:
- my library is large and Album List integrated search is useless starving at any letter typed (this problem also is affecting Library Tree as I initially tested). I would like to have smart input allowing me first to type the patter in full and then run the search.
- Album List often gets stuck for 10-15 seconds and freezes the entire user interface.
- finally, I would like to have a more flexible search engine as Library Tree should be (not yet tested)
Thanks and regards,
Andrea
Post by: WilB on 2019-02-18 19:18:12
Thanks for the feedback.
Its actually very easy to delay the search. On line ~1835 the delay time is set to 160 (msec), and could be changed by Shift+RightClick>Configure and typing a different number, e.g. 250 to 2000 (0.25 to 2 seconds) or what works best. But I expect the default is about right for most users. I might consider adding an option to set the value in panel properties.
Regarding the number of records perhaps you're confusing sub-item counts that album list displays vs the number of tracks that library tree displays by default. If you right click on All Music in album list and open properties [ensure no search or filters are enabled], it should display the same number of items in the header bar that library tree displays next to All Music. No discrepancies have been reported: fb.GetLibraryItems provided by SMP/foobar2000 is used. It also uses the SMP/foobar2000 provided GetLibraryRelativePaths to prepare the list. I am aware that there can be minor differences in sort order with the folder structure view between the two, though.
Post by: seriousstas on 2019-02-18 20:35:28
WilB
A basic upgrade of JSP scripts to SMP versions in any event should only take a few minutes per script following the migration guide
Thnx!!
I use window.NotifyOthers to control the library with the buttons (CarPC) - now there is no time for changes..,
staying on // @version "1.4.1 beta3" )
Post by: cgooey on 2019-04-02 22:37:19
Hi WilB,
Not sure if this is an appropriate place to request features, but I'd love to see a couple of things be implemented, if possible.
The main feature I'd love to be added is some kind of auto-search similar to Quick Search Toolbar or Facets. Essentially automatically populating the playlist with matches as each character is input into the search box; emulating pressing the enter key after each character as it currently is.
Also, I'm unsure if this is working as intended, but could the handling of symbols, namely "&" when sorting be changed from working like this:
BADBADNOTGOOD & Ghostface Killah
BADBADNOTGOOD & Little Dragon
BADBADNOTGOOD
To this:
BADBADNOTGOOD
Using the word "and" in place of "&" here sorts as desired. It just seems be the non-alphanumeric symbols that sort this way.
I just now noticed something small and pretty inconsequential; when hitting the esc key while typing in the search box it adds a small backwards arrow symbol. It would be cool if hitting the esc key here would clear the search bar of text, similar to clicking the X to the left.
I would be extremely grateful if you could consider the things above, but regardless of whether you have the time or desire to implement them, I'd like to say a big thanks for making this panel. All the best.
Post by: WilB on 2019-04-03 18:54:00
Thanks for the feedback. All requests implemented + sort issue fixed in my copy!
The new features should be in the next version.
Post by: Black_Over_Bills_Mothers on 2019-04-27 08:30:17
Seeing two consecutive bands (album artists) sent to play list even though I select only one.
I'm using v2.0.2 of the script and with the following selection pattern:
View by Band //$swapbranchprefix{%<band>%}|$if($stricmp($meta(band,0),various artists),,[$nodisplay{$sub(99999,%date%)}'('%date%') '])%album%$if(%discnumber%,|Disk %discnumber%,)[ '('%disctitle%')']|[%tracknumber% ][%track artist% - ]%title%
My tracks are tagged correctly and have artist, band and album artist tags containing only one artist
An example: In the library tree I see artist123 followed by artist124 and by artist125. If I select artist123 I get a playlist containing both  artist123 and artist124 but only one album from artist124 even if artist124 has several albums.
Post by: Black_Over_Bills_Mothers on 2019-04-27 08:43:02
I noticed that I wasn't using the latest foorbar core (1.4.3). After upgrading to 1.4.4b1 all is working correccly again. Curious.
Post by: Awesomeo on 2019-05-14 22:07:33
It could use %_view%, like the album list panel has, to generate different names of playlists based on current tree view.
Post by: nikosvault on 2019-05-25 22:58:26
Is there a way to get your playlist folders (with .fpl files) to show up in the library tree next to your music file folders?
My music folder...
https://i.ibb.co/XVnZ2Sf/1.jpg
and how it shows up in Foobar with Library Tree
https://i.ibb.co/ZhjK31C/2.jpg
Post by: WilB on 2019-05-28 12:20:06
@Awesomeo. Please explain how %_view% is useful in a normal workflow scenario.
@nikosvault . Displaying playlists isn't supported. There is a dedicated component that can show playlists in a tree view called playlist organiser foo_plorg (http://www.foobar2000.org/components/view/foo_plorg).
Post by: Awesomeo on 2019-05-28 23:22:26
1. That's one of the reasons I still stick to album list panel. %_view% sends music to different playlists depending on which filter I choose (by album, by artist, by whatever): https://upload.wikimedia.org/wikibooks/ru/7/74/Foobar2000_album_list_panel.gif
I don't know what else is there to explain, I find it useful on daily basis.
2. I do have another wish, this one is probably gonna seem even weirder to you. I love $nodisplay{sort} option, but I'd love to see something similar, like $evaluateonly{} - a handle to filter by a value, but not display it. Sounds dumb, I know, but it would be the best thing for me to differentiate between same name artists. I have my library synced with musicbrainz and all of it has musibcrainz ids included. I could use them in the filter, of course, but who wants to see 128-bit UUIDs? I'd rather have them evaluated only, so that in certain cases I would see two positions for same name artists and not have them mixed up.
Post by: WilB on 2019-05-29 13:07:31
1. I've added support for %view% for the next version.
2. I've adjusted $nodisplaysort{}, so it should do what I think you want in the next version; e.g.
%artist%$nodisplay{%musicbrainz_artistid%}|... should separate artists of the same name, provided they have different mbids.
I might make grouping CASE SENSITIVE for the next version. If anyone has an opinion one way or another please let me know.
Post by: Awesomeo on 2019-05-29 21:26:27
Thanks a lot for this!
Post by: WilB on 2019-06-10 12:40:20
New Version: Library Tree 2.1.0 (https://hydrogenaud.io/index.php/topic,110938.50.html#msg972268)
NEW: Various display improvements.
   - New node styles.
   - New highlight models (menu... > options > show).
   - Scrollbar now auto-minimises by default + has new look button icons. Behaviour & look can be set as previous on options > scrollbar menu.
   - New root node options, e.g. it can now be set as a summary item, e.g. All (132 artists), and in-lined.
    - Align right option for item counts.
NEW: Quick setup: Three node styles with different highlight models.
NEW: Improved search
    - Option to auto-send search results to playlist (menu > options > search).
    - Shortcut key to clear search results: "Escape".
    - Option to require pressing enter before searching (menu > options > search).
NEW: Target playlist can be set to use view name.
CHG: Various optimisations.
FIX: Reported issues.
Credit: kudos to Ottodix for inspiration in reworking certain aspects of the display format.
Updating. A number of minor panel properties will be reset. Export panel properties before updating if you want a record of previous settings.
Fresh installs will load the new look (can be changed on the Quick setup menu). Existing installs should retain the original look, except for the updated scrollbar.
Post by: Awesomeo on 2019-06-10 16:57:01
This is perfect. Thank you!
Post by: MojoBass on 2019-06-16 07:57:46
Hello WilB,
I still very much like your script, thanks for even further develiping this!
An issue I have with 2.1.0 is the following:
Up to 2.0.2 your script showed the full 'pattern tree' (as defined in Panel Properties/pattern such as artist/album/title) with the foreground colour defined in Preferences/Display/Columns UI/Colours and fonts/Colours for 'Foreground' at 'Inactive selected items' for the currently playing title, see first and second attachment.
I liked this feature very much, as it enabled that you can select an album and then flip though the titles with 'previous' and 'next', and still the currenty played title is indicated by the above defined foreground colour for the 'inactive selected items'.
Now this feature seems to have gone (see third attachment). Any chance to get back this or a similar behaviour?
Thanks, MojoBass
Post by: wirdjos on 2019-06-18 10:58:15
Hello,
Vanilla CUI filter component uses two playlists for browsing library: Filter Results for browsing and Filter Results (Playback) for playing. Is there a way to enable such behavior in Library Tree? Right now library browsing resets next track in current queue due to using only one playlist.
Also is there a hotkey for search via Library Tree or focus on its search bar?
Post by: WilB on 2019-06-18 16:42:38
@MojoBass
I've reinstated ...Show > Nowplaying in Highlight for the next version.
@wirdjos
A separate browse playlist shouldn't really be necessary with a tree viewer??? With a tree viewer you can browse by clicking nodes & so see the tracks that way within the tree view etc. Expanding nodes doesn't send items to the playlist, and so the next track in current queue shouldn't be reset. If you find that you inadvertently click on tracks, consider setting Single Click to "Select" & Double Click to "Send to playlist". By default middle clicking tracks adds them to the current playlist, and so can be used to queue tracks.
Extra hot keys are user assignable with the Spider Monkey panel index method.
1) Set Spider Monkey panel index number (1-10) for "search" by right click... > panel properties > "ADV.Hot Key..."
2) Go to foobar2000 preferences > keyboard shortcuts & assign that Spider Monkey panel index to a key or key combination.
3) Press key(s) to activate search. This activates search provided library tree has focus as that's needed for typing entries.
Post by: MojoBass on 2019-06-19 04:52:22
@MojoBass
@WilB: Thanks very much!!
Post by: nikosvault on 2019-06-22 23:06:41
I have forgotten how to add taps at the top of the panel. Can it be done in the panel properties menu?
Post by: WilB on 2019-06-27 16:04:10
If you mean Touch Control see menu > … Options > Mode
Post by: cgooey on 2019-06-27 21:34:33
Hey WilB,
Thanks for the changes you implemented in the latest update, they're really nice.
Currently when clearing the search box by clicking the X or hitting Esc, it will select an empty playlist. Could a option be added so that when you make a search and then click on an artists name, clearing the search will then populate the playlist with the artist that was selected? When clearing search without selecting an artist it could possibly select the summary item/root node, or the currently playing playlist instead.
Here's a video of the desired feature using Facets,
https://imgur.com/3EjcwAr
Thanks again.
Post by: nikosvault on 2019-06-28 19:38:32
I was talking about the taps at the top of the JScript library tree. They are there when you first install the plugin.
Similar to like the ones you see below (now/lyrics/meta/library)....
https://blog.aquinzi.com/images/2013/foobar_tomorrow_library.png
Post by: anamorphic on 2019-06-29 12:13:46
^ They are Tabs - part of foobar DUI. Just add Tabs to your layout using Layout Editing Mode (https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Layout_Editing_Mode) and place Spider Monkey / JScript Panel inside one.
Post by: nikosvault on 2019-06-29 16:27:10
Thanks. It was driving me crazy trying to figure it out!
And I never noticed my phone did Danish auto correct on that word. lol
Although I like that bugle call.
Post by: WilB on 2019-07-10 17:40:52
New Version: Library Tree 2.1.1 (https://hydrogenaud.io/index.php/topic,110938.50.html#msg973094)
CHG: Optimised Search Clear behaviour.
CHG: Reinstated option to highlight nowplaying (menu > ... options > show).
Post by: MojoBass on 2019-07-14 08:08:20
Hi WilB,
thanks very much for nowplaying highlightning!
Post by: Awesomeo on 2019-07-16 22:07:01
For the past month I've gathered a couple of wishlist items (ordered by personal priority) that I felt I could use the most. I know it's a long list and a lot to ask for, but I hope that at least some of these make sense to you and you'll consider implementing them at some point.
1. Formatting
I could really, really use the $rgb(baseline,hover,select) call. I'm not trying to turn my library tree into a christmas tree, I just need to make some subtle highlighting/dimming to discern between different tags displayed in one line. For example, under my view 'by label' I currently use {catalog number} Album Artist - Album [YYYY] · Source Media · It's a bit packed, I know, but that's where $rgb() would come in handy. This is how it looks now:
(https://i.imgur.com/BMCYxtK.png)
2. More external communication
This also concerns Spider Monkey Panel as a whole, because I saw it's got only 10 assignable indices. It would be really awesome to assign separate commands for all the views (and filters). It's not even about the hotkeys, I'd rather place a row of buttons above the filter (either via foobar toolbar or just drawn in panel stack splitter) to quickly switch between library tree views or to set up different filtering options. So essentially more robust capabilities for external interaction with the library tree.
3. Hide empty fields
CUI filter has the option to "show/hide items with empty labels". Now I have some tag fields that aren't populated for all of my library (like label or release series). So currently all the items with an empty %series% or %publisher% tag will get lumped at the top of the tree under a question mark with [1] item count. For now I've mitigated this by enclosing the whole view pattern with $if(%tag%,view pattern,'-'), but it's just a cosmetic fix.
4. Make keystrokes work locally when tree is in focus
Not sure if this is possible, but it's a little annoying issue, especially when it comes to spacebar. See, like in most players, I use spacebar as a play/pause toggle. So whenever I type some query in the library tree search field, it pauses playback in effect. It doesn't happen with foobar's library/playlist search, but yeah I assume that's because they're separate windows (?)
5. Headings / non-nodes
Ok, this one is a bit far fetched compared to the rest and it's just a whim. I just thought it would be great for the tree's clarity to introduce some kind of headings that would sort with the tree elements, but wouldn't be expandable nodes. The first place I could use these would be my 'by date' view:
(https://i.imgur.com/gtgtvbg.png)
I use decades as the top branch only to make the years view a bit tidier and clearer. But there's really no need to keep them as nodes. Sure, I could have them expanded at all times... except whenever I change the view, the state of the previous one resets.
PS
Another minor thing, there's "_Custom.Colour Frame Highlight" option but no "_Custom.Colour Frame Selected" and because of that I can't blend the selected item's frame with the bg.
Post by: WilB on 2019-07-19 12:43:02
1. Formatting. I couldn't find any tree or filter examples that offer the ability to set different colours for parts of a line, nor any case uses of your $rgb call??? The only sort of exception was facets which auto-dims text in parentheses or square brackets. There's also the highlight dim syntax (currently in DUI playlist) but I don't believe there is direct support for that in spider monkey panel.
It's actually quite complex to set different colours for different parts of a line of text. This plus the extra handling needed in various places, so all scenarios etc work, would increase the overhead. This post (https://hydrogenaud.io/index.php/topic,111060.msg961551.html#msg961551) about sums it up.
I'll consider adding something if spider monkey panel provides a direct function, e.g. a new (?) text draw function that supports the highlight dim syntax (currently in DUI playlist), or an alternative, that does all the colouring and text placement/sizing automatically, including ellipsis. This might now be possible due to enhancements in foobar2000 SDK, but I'm not sure. It would likely be generally useful.
2. External communication. Yes the current number of 10 would be rather limiting.
3. Hide empty fields. The current behaviour is the standard tree method, e.g. it's the same as DUI album list. I did try implementing, but it caused conflict with other node states. Working round the issues especially with parent nodes again adds to overhead & complicates things further. There are a couple of alternatives to consider.
Use $if2": e.g. $if2(%album%,Unknown)
Use filter: tag PRESENT; e.g. Album PRESENT // can be combined with other filters
4. Keystrokes. From the spider monkey panel documentation:
on_key_down(vkey); Note: keyboard shortcuts defined in the main preferences are always executed first and are not passed to the callback.
So essentially I can't do anything about this.
However, I did confirm that DUI album list & facets filter allow typing a space without triggering play/pause with that short cut key assignment. In spider monkey panel typing the space is completely blocked and you get play/pause. I'm not sure whether or not this could be changed in spider monkey panel.
5. Headings. "except whenever I change the view, the state of the previous one resets." That may be because "mode > auto collapse nodes" is enabled. Note that some Quick Setup options enable this mode.
6. Frame. I've added _Custom.Colour Frame Selected for the next version.
If you're inclined you may consider requesting items 1, 2 & 4 in the spider monkey panel thread.
Post by: TheQwertiest on 2019-07-19 13:11:12
1. I'll take a look whether fb2k API provides any such functionality.
2. I don't think I will change this - note that these are global, i.e. they can't be used by multiple scripts simultaneously (or more like it will trigger corresponding callback in EVERY script). Ideally there should be a different mechanism to assign global hotkeys, that could target specific scripts, but I'm not sure if it's achievable with the current fb2k API.
4. This comment means exactly what it says: SMP component does not receive a key event if it was handled by fb2k ('space' key down event in this case). So I can't pass to script (or suppress) what I don't have. You'll have to disable global 'space' shortcut if you want to use it in the scripts.
[EDIT] 4. Another alternative would be to use a popup to pass a string for searching.
Post by: Awesomeo on 2019-07-21 18:28:18
1.
Quote from: WilB
Here's what I meant:
(https://ptpimg.me/2g1yeu.png)
It all boils down to aesthetic choices, but for me it makes a huge difference in readability. Another case use would be 'releases' branch under 'album artist' - I could dim a little everything that has %release type% as single, ep etc., so that full length albums would stand out by being a bit brighter.
Quote from: WilB
Overhead for your code or for the speed of the tree on my side?
If it's the first, then sure, I understand. If it's the latter, then no worries, I don't think three or four $rgb() calls in my sub-label branch would slow down things at all:
$nodisplay{%date%}$nodisplay{%albumartistsortorder%}['{'%catalognumber%'} ']%album artist% - %album%' ['$year(%date%)']'[' ∙ '$meta(media type,0)['/'$abbr($meta(media type,1))]' ∙ ']
Honestly I've been conditionally formatting CUI playlists for years and they're all lightspeed fast even if I throw thousands of tracks at them. E.g. in my 'title' column I have recognition of extra-titular info like remix/instrumental etc. and additional highlighting of the remixer:
(https://ptpimg.me/860w1a.png)
Absolutely nothing about any CUI elements or SMP has ever been noticeably slow for me, no matter what I do (...unless I make calls to foo_customdb, but it's an old and slow extension in itself).
2.
Quote from: TheQwertiest
I.e. scripts and particular properties within them. I mean, yeah, I feel like this is probably too much, but I think you agree that a mechanism for communicating between different panels/scripts would be a massively powerful tool: I could draw a button in panel stack splitter that would access particular SMP and change the property 'SYSTEM.View By' to a given value. And vice versa, I could have any PSS element that would react to changes in a particular SMP. So maybe something like $set_smp(smp_id,property,value) and $get_smp(smp_id,property).
3.
Quote from: WilB
Yeah, pretty much what I did, except I didn't really want to see the ones with empty fields, so I made it as unobtrusive as possible by wrapping the whole view pattern in a conditional. Like, you can see in that snap from my previous post, there's just a little hyphen at the top that has no item count (I could replace it with a zero-width space too or some exotic script character that would move it to the end of the list). Setting all filters to have additional 'PRESENT' is a good idea too, thanks.
4.
Hm, not sure if I fully understand this, because both things happen at once for me: playback pauses and the library tree search field receives a space.
However I've already checked other CUI panels with typing option, like 'Typefind' or 'Youtube Source Search' and keystrokes work locally in them, they don't execute foobar's global hotkeys. So I suppose they're somehow isolated, like pop-ups?
5.
Quote from: WilB
Nope, I have it disabled. I can expand multiple nodes in, say, 'by date' view, change the view to 'by artist', then change back to 'by date' again and all the decades will be collapsed again. The panel doesn't remember tree state between views, it only remember it on closing/opening foobar.
6.
Thanks for this one!
Post by: TheQwertiest on 2019-07-22 11:28:43
[EDIT]: moved to SMP thread - https://hydrogenaud.io/index.php/topic,116669.msg973489.html#msg973489
Post by: WilB on 2019-07-27 18:13:33
@Awesomeo
Formatting. I've added the following:
$colour{normal,hover,selected}
Normal, hover & selected can either be r-g-b or a highlight or dim indicator. The latter are analogous to the DUI playlist highlight / dim method, except here they should also support hover & selected text, and I think will use +++, ++, +, -, --, ---. Either should enable setting different colours for parts of a line.
Remember tree state. I've added an option to remember tree state of all views independently (expanded nodes etc).
These should be in the next version (exact syntax of $colour might change), provided nothing unexpected arises during further testing etc.
Post by: Awesomeo on 2019-07-28 13:46:02
That's so great, thank you! This panel is heaven sent.
Post by: Awesomeo on 2019-09-20 14:06:43
Hey, I'm just wondering if you're still planning this update any time soon or whether you put this on hold for now? Sorry if I come off as nagging too much about it :(
Post by: WilB on 2019-09-20 18:34:38
There will be an update shortly with the new features indicated above (i.e. new colour handling [including setting different colours for parts of a line] and the ability to remember the tree state of all views independently etc). I was waiting to see if anything appeared in SpiderMonkey Panel v1.2.2 that was relevant to some of your other comments, and that would require attention, plus I was rather busy. But now SpiderMonkey Panel v1.2.2 is out...
Post by: TheQwertiest on 2019-09-20 20:41:56
@WilB, sorry, nothing relevant in this one =) (apart from bug fixes)
I'm planning to add new keyboard shortcut functionality, which will allow to assign global fb2k hot keys to panel specific actions, but it requires a lot of internal changes. Hopefully it will be ready for the next release.
Post by: WilB on 2019-09-25 13:20:15
New Version: Library Tree 2.1.2 (https://hydrogenaud.io/index.php?topic=110938.msg975702#new)
CHANGELOG
NEW: Option to remember tree state of all views independently (expanded nodes etc; menu > ... options > mode > Remember Tree State).
NEW: Colour options:
1) Option to set a custom colour for the selected item frame: _Custom.Colour Frame Selected (panel properties).
2) Option to set different colours for parts of a line of text:
For use in view patterns.
Normal, hover & selected can either be r-g-b or a highlight or dim indicator, e.g.
$colour{r-g-b,r-g-b,r-g-b} or $colour{-,++,+++}
Highlight & dim indicators:
- dim text
-- dimmer text
--- dimmest text
+ bright text
++ brighter text
+++ brightest text
All colours are optional: any undefined are set to default. Format, r-g-b & -/+ style, can be mixed in same $colour{} function.
Examples:
$colour{} reset all colours to defaults
$colour{255-0-0} set normal text colour to red; set hover & selected text colours to defaults since undefined
$colour{,,+++} set selected text colour to brightest; set normal & hover text colours to defaults since undefined
$colour{0-255-0,++} set normal text colour to green & hover text colour to brighter; set selected text colour to default since undefined
$colour{255-0-0,0-255-0,0-255-255} set normal, hover and selected text colours to red, green & cyan, respectively
Example pattern:
View by Artist - Album // $colour{-}%album artist%[$colour{+} - %album%][$colour{96-127-127} ∙ '['%date%']'][$colour{111-132-138} ∙ %genre%]$colour{--}|[[%discnumber%.]$colour{--,++,0-192-192}%tracknumber%. ]$colour{-,++,0-228-228}[%track artist% - ]%title%
Colours apply after the $colour code until either another $colour code is encountered or a branch point is reached (| in the view pattern).
Item counts are a special case. They don't form part of the view pattern.
   Align right: drawn separately; not controlled by $colour codes; already dimmed.
   End of text: effected by $colour codes. Use $colour{} at the end of the line [i.e. before branch point: | ]  to reset or set to a different colour if desired ($colour{--} is used in the example above).
Post by: Awesomeo on 2019-09-25 17:06:25
Thank you so much! I'm starting formatting right away.
Post by: Tropoje on 2019-09-26 18:45:30
@WilB
Perfect, Thank you :)
Post by: Tropoje on 2019-09-27 07:54:58
I don't know what the problem is, but when you hover over the song, the color does not change (in this case to yellow 255-255-0)
My test code:
Test colours // $colour{255-0-0,255-0-0,255-0-0}'('%date%')'$colour{} - %album%|%tracknumber%. $colour{255-0-0,255-255-0,0-255-255}%title%
normal
(https://i.postimg.cc/nLpQCkY7/normal.jpg)
hover
(https://i.postimg.cc/RVxKnKmM/hover.jpg)
selected
(https://i.postimg.cc/HLz85yBN/selected.jpg)
Post by: WilB on 2019-09-27 16:30:20
I tried your code sample, and it worked as expected for me, i.e. title showed in yellow on hover.
Please ensure the following is enabled: right click menu … > options > show > highlight text on hover.
Post by: Tropoje on 2019-09-27 17:14:34
Yes indeed, the option you mention about was missing. Now everything works as it should. Once again, thank you very much for your work  :)
Post by: AndreaT on 2019-09-27 20:40:23
@WilB
Hello WilB, even with this last version I am getting this error:
Error: Spider Monkey Panel v1.2.2-preview+0db3c6a4 (Library Tree v2.1.2 by WilB)
OrderByRelativePath failed:
allocation size overflow
File: <main>
Line: 542, Column: 61
Stack trace:
  Panel/this.sort@<main>:542:61
  rootNames@<main>:1205:48
  Library/this.getLibrary@<main>:1190:119
  Timers/this.lib/<@<main>:2911:115
Regards,
Andrea
Post by: WilB on 2019-09-27 22:14:16
Ever since I realised you're using a very large library I've routinely run tests on an artificially created 640,000 library.
That works fine on my pc, including with view by folder structure.
The actual error seems to be in the handleList sort: handleList.OrderByRelativePath(); I'm not sure that I have any control over what that's doing, as it's a SpiderMonkey Panel function.
So it's not clear to me whether this is actually a SpiderMonkey Panel issue, possibly related to memory handling / memory available on your device, or whether something could be optimised in the script.
@TheQwertiest - any ideas?
Post by: Awesomeo on 2019-09-29 19:43:13
Works great and it made my information-overloaded branches much more readable: https://imgur.com/a/MjqhJVJ (at least to me). Thank you again!
One thing I noticed though, is that $colour{} function doesn't work inside other functions (conditional or string). For conditionals it outputs invalid syntax error, for $replace(%some_tag%,'some_string',$colour{x-y-z}'some_string') all sorts of weird breaks happen. I suppose that's intended not to work within functions?
In the end managed to get around it mostly and it's not such a big issue, but I was just wondering, because e.g. $nodisplay{} works within functions.
Post by: WilB on 2019-09-29 23:12:17
Yes I had spotted that one & it should be fixed on my copy. I'm awaiting to see if  @TheQwertiest can help with the issue raised in posts 231 & 232, before releasing an updated version.
But the fix is very minor, and you could change it yourself if you're inclined and don't want to wait until the next version. Shift + right click > menu > configure
On line 616 replace "," with "`" (2 instances on that line)
On line 1790 similarly replace ',' with '`' (1 instance on that line)
i.e. replace the commas on those lines with backticks. Do not alter any other lines.
I tested it with conditional strings, but please confirm it works with your conditional or string scenarios, if you want to try it, else advise me if you prefer to wait until the next version.
HTH
Post by: Awesomeo on 2019-09-29 23:57:14
Yes! Works like a charm:
(https://i.imgur.com/cFMWS9x.png)
Thanks again for so quick help!
Post by: Tropoje on 2019-09-30 06:36:25
I confirm, it now works inside the function. Earlier I had to add a square bracket to make it work. Thank you for the correction, it makes operation much easier  ;D
Post by: TheQwertiest on 2019-09-30 10:13:17
@AndreaT , does this happen on SMP v1.2.1 as well? Is it consistently reproducible? How big is your library (i.e. the number of tracks)?
Post by: Tropoje on 2019-09-30 13:03:17
Is it possible for the color to work inside the $replace function?
$if($or($strstr(%title%,feat.),$strstr(%title%,Feat.)),$replace(%title%,Feat.,$colour{128-255-0,128-255-0}feat.$colour{}),%title%[ '('$colour{128-255-0,128-255-0}feat.$colour{} %featuring%')'])
The second part of the code works (without the $replace function)
I don't know if it's possible to work around this  ::)
Title: Re: Library Tree Discussion
Post by: Awesomeo on 2019-09-30 13:42:22
@Tropoje $replace is case sensitive, but you can do it over infinite number of arguments, so just make replacements for both cases.
$if($or($strstr(%title%,feat.),$strstr(%title%,Feat.)),$replace(%title%,feat.,$colour{128-255-0,128-255-0}feat.$colour{},Feat.,$colour{128-255-0,128-255-0}Feat.$colour{}),%title%[ '('$colour{128-255-0,128-255-0}feat.$colour{} %featuring%')'])
Post by: Tropoje on 2019-09-30 14:39:06
Thank you very much for your quick reply  ;D
My goal is to always make changes Feat. (uppercase)  to feat. (lowercase). I have slightly modified your code and now it works as it should. This solves my problem  ;D  ;D  ;D
$if($or($strstr(%title%,feat.),$strstr(%title%,Feat.)),$replace(%title%,Feat.,$colour{128-255-0,128-255-0}feat.$colour{},feat.,$colour{128-255-0,128-255-0}feat.$colour{}),%title%[ '('$colour{128-255-0,128-255-0}feat.$colour{} %featuring%')'])
Post by: AndreaT on 2019-09-30 15:51:22
@TheQwertiest
Yes, with SMP 1.2.1 I had to remove Library Tree immediately, it was completely unusable. No way to "start-up" Library Tree View.
With the new SMP 1.2.2 and the new Library Tree View things are going better, At least I can have it running for a while.
My library contains about 600k records (live recordings made over 30+ years).
PS: Nothing critical for me. No hurry. I already reverted back to Album List (it is slow, but it works).
Regards, Andrea
Post by: TheQwertiest on 2019-09-30 16:06:20
@AndreaT , answered in SMP thread.
PS: @WilB , sorry for the offtopic >_<
Post by: Awesomeo on 2019-10-03 00:42:41
1. I found a minor issue: Placing $colour{} function before the first string in top branch breaks the jumpsearch. If colouring is involved in conditional or replacement functions, jumpsearch works only for the unformatted alternatives.
2. Now for another thing that I'm not really hopeful about since it looks a bit like I'm asking for the impossible:
Pairing of corresponding meta fields between separate multi-value tags
Ideally I would love to be able to couple different multi-value tags in a way that evaluated corresponding indices of both arrays in tandem. So that branching would look like this:
- $meta(tag_a,0)$nodisplay{$meta(tag_b,0)
- $meta(tag_a,1)$nodisplay{$meta(tag_b,1)
How it looks now
At this point I gave up with disambiguating those few same-named artists I have, in order not to get these mangled branchings for much more ubiquitous multi-valued artist tags.
Post by: WilB on 2019-10-03 17:50:12
Jump search & $colour: should be fixed for the next version.
Pairing of corresponding meta fields between separate multi-value tags: multi-value tags & $nodisplay.
I did spot an issue with $nodisplay not always being correctly sorted with multi-value tags. That should be fixed for the next version It may address some of the sorting issues you noticed, but not the pairing point.
Pairing: multi-tag evaluation doesn't consider the indices that would be needed for that even for the displayed item (just getting the names is enough) let alone for anything that's not displayed.
Personally I would find it rather confusing to have exactly the same named artist appearing in the list twice.
Possibilities:
1) Standard artist names. Album name, for example, can be a disambiguator, e.g.
View by Artist // %<artist>%|%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
i.e. disambiguation would be based on album name after click on artist
View by Artist - Album // %<artist>% - %album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
i.e. album name alongside artist name
2) Artist name with disambiguator, including where it appears in multi-value tags. Doesn't depend on album names being present. For example:
Muse ∙ UK
Muse ∙ US
Disambiguator could be genre, country or city of origin etc. If a unique separator is used, artist names can easily be cut at the separator if used in internet look-ups of lyrics, biographies etc, so as not to break those types of look-ups.
Seeing as you say you only have a few same-named artists, it would be simple to change the tags if you're inclined.
Post by: Awesomeo on 2019-10-03 18:09:26
Yeah, I figured this is the easiest way. Or even to make an additional %artist_disamb% tag for these few cases, where I would have the name with more info, for example with the country code like you suggested. And then the branch would simply have a structure like this $if2(%artist_disamb%,%artist%).
Thanks for help!
Post by: TheQwertiest on 2019-10-05 15:20:11
I don't think there is a need to wait for the new version of SMP, since even if this bug to be fixed, it should not impact SMP API in any way =)
Post by: Black_Over_Bills_Mothers on 2019-10-06 18:35:54
Hi
I'm seeing error as below when I use view: View by Album //$if(%album%,%album% - $meta(band,0), 'Non Album')|%title%
n is undefined
File: <main>
Line: 1683, Column: 6
Stack trace:
  branchCount/<@<main>:1683:6
  branchCount@<main>:1681:5
  Populate/this.buildTree/<@<main>:1667:156
  Populate/this.buildTree@<main>:1649:9
  Library/this.rootNodes@<main>:1276:58
  Timers/this.lib/<@<main>:2911:133
Post by: WilB on 2019-10-06 19:53:14
As I couldn't seem to reproduce, I've sent you a private message to explore what's going on.
Post by: zoumbro on 2019-10-07 05:37:22
Hi, I am facing the following problem when I start my foobar. It always crashes and I have to reload the panel to operate normally.
I am using SMP v .2.1. and Library Tree v2.1.0.
Thank you
Post by: WilB on 2019-10-07 12:51:45
@zoumbro
I'm not keen on debugging old versions of library tree because most releases have various bug fixes, possibly not always evident from the change log. I can't remember if there were any changes that might have affected this. It's also best to use the latest version of spider monkey panel.
In this particular case, it looks as though the library was updating since on_library_items_changed was called. Appearance of the abort message, I think, only has a short delay. From the stack trace, library tree was in the middle of updating the tree.
In general tree updates in response to library changes should be very rapid and occur in the background: only affected items in the tree are altered.
Aborting scripts part way through may give unpredictable results and a script error. What happens if you just let library tree continue and finish? If that's OK, perhaps choose don't ask me again & don't worry about it.
As a test I just tried changing 24,000 tags. All proceeded fine on my device in that scenario. There was no message.
Library Tree also has an option to switch off automatic syncing with the media library: panel properties: "ADV.Library Sync: Auto-0, Initialisation Only-1". If auto-syncing is off the library used by library tree will only be updated on initialisation, view change or through manual refresh on the menu.
I have seen the abort message on a number of occasions when it isn't really the script that's at fault, e.g. if windows is busy (e.g. updating) and necessary files can't be read from the hard drive in a timely way. Then scripts can stall at points difficult to predict and the message can appear.
Post by: always.beta on 2019-10-08 14:33:38
Without changing the font size, add line-height setting function?
Post by: WilB on 2019-10-08 22:24:06
See: menu … options > mode > line spacing
Enables line height to be padded as required. I think adding padding is more flexible than setting a fixed line height.
Post by: always.beta on 2019-10-09 01:44:23
This is what I want. I'm sorry, I did not find it. thank you
Post by: AndreaT on 2019-10-17 17:21:26
@WilB
File: <main>
Stack trace:
Regards,
Andrea
@WilB
Hello WilB, any news about this?
I am still having this blocking error.
Regards, Andrea
Post by: WilB on 2019-10-17 18:54:23
As far as I am aware this seems to be a bug (https://hydrogenaud.io/index.php?topic=111060.msg976016#msg976016) in spider monkey panel and outside of my control, but I am open to suggestions. I just tried again with a 642K test library & all was OK here. That particular error seems to be occurring on panel initialisation and is explicitly related to view by folder structure. So you could try a different view (if the error is locking you out you could open panel properties and find SYSTEM.View By [it's probably the last entry] and change it to 1 to set a different view).
I thought you were debugging (https://hydrogenaud.io/index.php?topic=116669.msg976066#msg976066) the issue with @TheQwertiest? It sounds as though the issue is reproducible and so it ought to be possible to resolve the cause.
HTH
Post by: AndreaT on 2019-10-19 08:03:05
Hello WilB, thanks for caring about and for the new tips.
I already notified @TheQwertiest of the problem and he promised me a debugging version of SMP that I am still waiting for...
And, moreover, he wrote that the problem was looking to be related to your script...
Now, having your new feedback, I will go back to him again.
Many thanks and kind regards, Andrea
Post by: TheQwertiest on 2019-10-22 11:08:22
I've never said such a thing though :\
The problem with `bad_alloc` in `OrderByRelativePath` is most likely a memory exhaustion problem. Theoretically, script could reduce memory usage by operating on smaller arrays or storing less data, but that would greatly increase complexity of the script.
Post by: AndreaT on 2019-10-24 20:18:11
@WilB and @TheQwertiest
Sorry for having misunderstood the matter ... I am not a developer... (:->)
Thanks for eventually find out a solution.
Library Tree is looking very nice and I would be glad to be able to use it.
Kind regards, Andrea
Post by: handleyman on 2019-10-28 09:06:01
Hi. I was using an old version of Library Tree with JS and it worked fine except that a Custom field I use %GEOGRAPHICAL% refuses to split multiple fields: some bands originate from more than one city/country, etc. The fields work fine everywhere else (they are originated in Mp3tag), and are separated by a <;>. So I just tested installed the new LT 2.1.2, but in this version, I cannot get the <Settings, View by> to save. I first tried importing an .wsp file (exported from the earlier version) and, although the new config shows in Panel Properties fine, they do not change in the options. It just shows the original config (ie: no View by Geog" shows. I then manually edited it, and it doesn't save. Is there something in the new version that I am missing? Many thanks for any help. Attached is the exported example.
Post by: WilB on 2019-10-28 09:55:15
It looks like you tried to import the JScript panel properties which isn't supported by the Spider Monkey Panel version of Library Tree (https://hydrogenaud.io/index.php?topic=111060.msg967377#msg967377). This has resulted in duplicate entries in panel properties and you changed the wrong one.
You need to clear panel properties to reset them. Then you should be able to enter, e.g.
View by Geog // %<geographical>%|[%album artist% - ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Note that geographical in the view has to use the multi-value syntax as in the example to split multi-value tags. %geographical% will not split them.
Post by: handleyman on 2019-10-28 10:47:02
Brilliant, thanks! That got the new version working, but
<View by Geog // [%<geographical>%]>
 still doesn't split the tags, as  shown in this image...
Post by: WilB on 2019-10-28 11:09:23
I think that's actually to do with foobar2000 and not library tree.
Select a track. Open the properties of the track. Select the geographical field, right-click and choose split values. When confident it's working you can select multiple tracks.
foobar2000 also has an advanced setting in preferences: display > properties dialogue > multivalue fields.
You can add GEOGRAPHICAL to the list. That seems to help when creating new multivalue geographical tags through properties, but didn't seem to cause existing to be split. For that you have to use the above method.
Post by: handleyman on 2019-10-29 10:18:22
Brilliant! Thanks to your help, I have found the reason it isn't working:
In the fields with multiple values, I have used a space after the delimiter <; > (Australia: Cairns; England: Ellesmere Port). Removing the space <(Australia: Cairns;England: Ellesmere Port)> makes the field split fine, but it looks ugly! I wonder if there is there a way to force it to read <; > instead of <;> (ie. with the following space)??? Otherwise, I'll have to re-tag them all. Although that's fairly simple with Mp3Tag, it would force re-copying of so many files during backup, as there are thousands tagged this way!
Post by: WilB on 2019-10-29 11:07:48
I tried the following with the space after the ;
View by Geog // %<geographical>% splits the tag fine and displays correctly as in the picture.
However it was necessary to run the split values command as I said in my previous post. It looks like you didn't do that????? Select a track, open properties for the track, right click the geographical tag name and run Split values.... Once you know its working correctly you can do all music in one go in a few seconds. Much easier than retagging. Also see my comment in my previous post concerning display > properties dialogue > multivalue fields.
Also Library Tree now requires FontAwesome for proper display of symbols, and from your picture it looks as though it's not installed. There's a link to it in the Library Tree download location.
HTH
Post by: handleyman on 2019-10-29 11:25:48
Thanks. I did do that, yes, to test a few and it did work. Are you saying I need to do it every file which has multiple geog tags? And what then happens to new ones I add?
Post by: WilB on 2019-10-29 11:53:24
Yes
These are all general foobar2000 handling issues and not specific to library tree. It may depend on what tagger is used. You may need to split them...
Post by: handleyman on 2019-10-29 11:55:22
Thanks for all your help.  :D
Post by: AndreaT on 2019-11-08 14:59:24
@WilB
Hello WilB, today I was finally able to run Library Tree 2.1.2 ("special version").
Thanks to @TheQwertiest new method "OrderByRelativePathV2" requiring less memory and other SMP memory tuning, now Library Tree is running ... but it eats approximately 400 MB of RAM.
So, I know, it is just a matter of time and I will run out of memory again.
At this point, I have a 1 milion dollar question for you: does it is difficult to move all the libray dBase to an external SQL mini dBase and then from the SMP/JS just query this SQL?
Post by: WilB on 2019-11-08 16:40:22
In the tests I've done library tree uses ~5 MB of memory per 10K of tracks:
library 2.5 MB + up to an extra 2.5 MB if a search returns all the library.
Values are based on using Spider Monkey Panel window.TotalMemoryUsage.
That seems quite low. But it's a question of scalability.
So:
10K library = ~5 MB
50K library = ~25 MB
100K library = ~50 MB
200K library = ~100 MB
600K library = ~300 MB
Actual values depend on complexity of patterns and could be a bit lower or higher. In the case of folder view it will depend on the depth of the folder structure and length of the folder names.
It seems your 600K library is using ~400 MB. I assume that's after searching. I wouldn't really expect it to go up much more. Spider Monkey Panel memory management has improved a lot in the more recent versions.
I don't know anything about use of SQL, so it would be a difficult task. Not sure if it would reduce memory use or not, since if it had to be read in before loading the library and doing a query it may not anyway.
Post by: WilB on 2019-11-08 18:08:25
New Version: Library Tree 2.1.3 (https://hydrogenaud.io/index.php?topic=110938.msg977222#msg977222)
NEW: $stripbranchprefix{X}. Adds ability to strip the prefix of all values in multi-value tags, e.g. $stripbranchprefix{%<artist>%}. Complements already present $swapbranchprefix{X}. Specify prefixes in panel properties: ADV.Prefixes to Strip or Swap ... (default prefixes: A + The). Note new property name. See documentation for more info.
Post by: AndreaT on 2019-11-08 19:42:58
Many thanks, @WilB, for your kind reply.
All the best, Andrea
PS: I am going to install the new Library Tree 2.1.3...(:->)
Post by: TheQwertiest on 2019-11-08 19:58:57
PS: OrderByRelativePathV2 will replace the old one in the next SMP release (and nightly as well), so there will be no need to change anything in the script.
Post by: AndreaT on 2019-11-09 18:32:40
Hello @TheQwertiest, I installed the new Library Tree 2.1.3 using the last SMP beta you gave me directly.
With this beta I was testing the V2 method, however it can have the new LT 2.1.3 running fine with it.
Does this SMP beta you gave me implements both V1 and V2 in the V2 new mode?
Or am I just very lucky?
Regards, Andrea
Post by: TheQwertiest on 2019-11-09 18:54:09
You are just lucky =)
V2 was not merged in V1 yet on any SMP version.
