Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: k2k on 2015-07-15 07:20:48
Title: MathAudio Headphone EQ for Foobar2000
Post by: k2k on 2015-07-15 07:20:48
(http://mathaudio.com/images/mathaudio-headphone-eq.png)
Download: mathaudio.com/download.htm (http://mathaudio.com/download.htm)
Title: Re: MathAudio Headphone EQ for Foobar2000
Post by: AndreaT on 2019-12-01 13:24:43
Hello @k2k,
I installed Headphone EQ ver 1.4.0 and I cannot hear any sweep tone (I have ASIO driver).
I also pressed the button sweep-out to check the output settings, but the button is unresponsive.
I think there is a bug somewhere.
Regards, Andrea
Post by: k2k on 2019-12-01 15:49:18
We've just fixed the problem. Please download the newest version of Headphone EQ from our web site: https://mathaudio.com/download.htm
Post by: AndreaT on 2019-12-01 17:25:48
Hello @k2k, unfortunately the link provided landed me to the download page, but the only package effectively available for download is the old 1.4.0 even if on the page there is written 1.4.1.
Please, kindly check.
Thanks and regards, Andrea
Post by: AndreaT on 2019-12-01 17:54:28
Hello @k2k, I could download the new package 1.4.1 a few minutes ago.
It is still NOT working with ASIO.
Now the Sweep Out button works but selecting any ASIO output I cannot get any output there.
It works only if I select regular embedded laptop audio loudspeaker.
Because I am using very well known, professional and solid MOTU ASIO driver, I have to suppose there is some other problem pending.
Kind regards,
Andrea
Post by: AndreaT on 2019-12-01 18:09:01
Hello @k2k, I though about and I think the best would be to have also the option to Sweep-Out directly into/to the next component present in the DSP chain.
In my headphone DSP configuration, your component is the last, but it may be not the last...
I tell you this because I am now having problem with Room EQ also ... and I am going to write to you in the appropriate thread.
Regards, Andrea
Post by: k2k on 2019-12-01 23:05:10
Kind regards,
Andrea
The Foobar2000 version of Headphone EQ can send the sweep sound to a conventional Windows driver only, not ASIO. I believe that your MOTU set includes conventional Windows drivers and you can temporarily use them to make the correction curve. After that you can use Foobar2000 to work with your ASIO drivers.
Regards, Andrea
It could be a good idea, but the Foobar2000's plug-in interface doesn't allow us to return any sound when Foobar2000 doesn't send a sound to the plug-in's input. That is why the Foobar2000 version of Headphone EQ sends the sweep sound directly to the sound card.
Post by: k2k on 2019-12-01 23:09:19
Post by: AndreaT on 2019-12-02 07:50:44
Hello K2K, thanks for the explanation. I will use your VST2 plug-in for headphone EQ testing.
Regards, Andrea
Post by: AndreaT on 2019-12-27 11:39:47
Hello @k2k, I see that a new version is up. What's new?
Did you find the solution for having signal out of ASIO?
Regards, Andrea
Post by: k2k on 2019-12-27 15:15:33
A small bug is fixed which affected the Mac version only. We use the same C++ code for all versions, so the Foobar version is updated too.
Regards, Andrea
When you click the "Sweep Out" button, Headphone EQ shows you all the available (non-ASIO) audio devices that can be used to output the sweep tone. If you use a MOTU audio interface, most probably there is a non-ASIO dirver that can be used to output the sweep tone. If you can select something like "MOTU Line Out" but the sound is absent, it is possible that another program occupies your ASIO driver at the moment and your audio interface cannot work in ASIO and non-ASIO modes simultaneously. If you use the Foobar's "ASIO Support" component, try to temporarily disable it to allow your audio interface to work in non-ASIO mode.
Post by: AndreaT on 2019-12-27 17:51:09
Thank you K2K for the info and the tip.
Regards, Andrea
