Hydrogenaudio Forums
Lossless Audio Compression => WavPack => Topic started by: bryant on 2013-05-28 00:30:16
Title: WavPack 4.70.0 beta version available
Post by: bryant on 2013-05-28 00:30:16
The beta release of WavPack 4.70 is available and assuming no bugs are found or last-minute changes suggested, this is essentially final. The impetus for this release was to incorporate some bug fixes that had accumulated since 2009, but I decided to also include a few new features that I had been thinking about.
The most interesting new feature is the ability for the wavpack command-line executable to accept existing wavpack files as input (i.e., transcoding). This allows users to easily change the settings of files in their lossless collection, or convert from older WavPack versions. The process copies all tag information from the source, and even allows modification of the tags. Temp files are also used now when overwriting and a verify option has been added, so it's possible to safely do transcoding in-place (although this is a beta version, so be careful!)
Note that care should be taken when transcoding to and from lossy files, and lossy to lossless transcoding is not allowed.
This release should generate identical files to the previous release (other than changes from bug fixes) and the performance should be similar (excepting differences from compiler revisions). I also built 64-bit versions for Windows, but they actually perform slightly worse than the 32-bit versions (at least on my system) so I'm not sure how useful they are or whether they will make it to the final release...any opinions?
New features:
Bug fixes:
Windows features ported to Linux:
Updated manual (http://www.wavpack.com/wavpack_doc_470.html)
Windows 32-bit executables (http://www.wavpack.com/wavpack-4.70.0-beta-x86.zip)
Windows 64-bit executables (http://www.wavpack.com/wavpack-4.70.0-beta-x64.zip)
Linux distro (http://www.wavpack.com/wavpack-4.70.0-beta.tar.bz2)
Thanks in advance for any testing and/or suggestions!
Post by: skamp on 2013-05-28 11:00:09
Thanks! Works great, the memcpy() bug is gone indeed.
Post by: Mr_Rabid_Teddybear on 2013-05-28 16:26:45
Thanks for this!
BTW. I see that FreeBSD has one patch on wavpack 4.60.1. It's to make it build with clang. I don't know if this holds any interest. Clang is being used more now here and there...
http://svnweb.freebsd.org/ports/head/audio...amp;view=markup (http://svnweb.freebsd.org/ports/head/audio/wavpack/files/patch-src__wavpack_local.h?revision=304164&view=markup)
Post by: chi on 2013-05-28 18:30:43
Oh right, Debian has two small patches as well: http://patch-tracker.debian.org/package/wavpack/4.60.1-3 (http://patch-tracker.debian.org/package/wavpack/4.60.1-3)
Post by: bryant on 2013-05-29 06:37:30
Thanks for the patches! I had one of the Debians (the largefile, because they sent it to the mailing list) but not the other one or the Clang one. I'll get them in.
Post by: skamp on 2013-05-29 10:57:45
The WavPack package on Arch Linux is orphaned, so here's my PKGBUILD (https://wiki.archlinux.org/index.php/PKGBUILD) for version 4.70.0-beta:
pkgname=wavpack
pkgver=4.70.0b
pkgrel=1
pkgdesc="Audio compression format with lossless, lossy, and hybrid compression modes"
arch=('i686' 'x86_64')
url="http://www.wavpack.com/"
license=('custom')
depends=('glibc')
options=('!libtool')
source=("http://www.wavpack.com/${pkgname}-4.70.0-beta.tar.bz2")
md5sums=('5405ff4fd021059059b334962e218fb7')
build() {
  cd ${srcdir}/${pkgname}-4.70.0
    export CFLAGS="${CFLAGS/-O2/-O3}"
    export CXXFLAGS="$CFLAGS"
  ./configure --prefix=/usr --enable-mmx --disable-static
  make
package() {
  make DESTDIR=${pkgdir} install
With the PKGBUILD file in the current directory, type "makepkg -c" to build the package, then "sudo pacman -U <package>" to install.
Post by: skamp on 2013-06-10 11:29:36
I have corrected the Arch Linux PKGBUILD in order to comply with packaging rules, and have it accepted by the automatic package submission code on AUR (you can find it here: https://aur.archlinux.org/packages/wavpack-beta/ (https://aur.archlinux.org/packages/wavpack-beta/)). Basically I renamed the package from "wavpack" to "wavpack-beta", and added the appropriate "provides" and "conflict" variables. This release will be short-lived, it is only meant to allow easy installation of the beta version, until 4.70.0 final is released (which will be available in the usual "extra" repository, via pacman
Here's a local copy of the new PKGBUILD:
pkgname=wavpack-beta
pkgver=4.70.0
pkgrel=3
license=('custom')
depends=('glibc')
provides=('wavpack=4.70.0')
conflicts=('wavpack')
source=('http://www.wavpack.com/wavpack-4.70.0-beta.tar.bz2')
build() {
cd ${srcdir}/${pkgname/-beta/}-${pkgver}
# export CFLAGS="${CFLAGS/-O1/-O3}"
# export CFLAGS="${CFLAGS/-O2/-O3}"
# export CXXFLAGS="$CFLAGS"
make
package() {
# the current archive does not contain a license file
Post by: Mr_Rabid_Teddybear on 2013-06-11 14:24:23
OK. A couple of insignificant nitpickings before the final *nix tarball... (of whom you are probably already aware)
  - Remember to put back a license.txt and/or COPYING so the distros and vendors don't get uneasy...
  - Update the ChangeLog
  - Update the README
I could spot VS 2005 -> 2008. Maybe mention --enable-man for *nix.
Maybe also mention dependencies to build on *nix in there? Is it something like this...?
Dependencies to run:
  libiconv
Dependencies to build:
  bzip2 (to extract)
  pkg-config
  libtool
Dependencies to build manpages (is it this....?)
  xsltproc
  docbook-xml
  docbook-xsl
  - Add yourself to AUTHORS...?
Post by: bryant on 2013-06-13 19:20:53
Thanks for these! I knew to update the changelog of course (I always do that last), but I had forgotten about manually putting the license in there, and I should update the README.
edit: faulty keyboard!
Post by: sluggy on 2013-06-26 13:40:37
Any news of a final release of version 4.70?
Post by: lvqcl on 2013-06-26 15:03:50
4.70.0 beta for Windows hangs if the output file is NUL.
Post by: bryant on 2013-06-27 18:53:10
I'm still working on it, but I've gotten a little busy with other things. Shouldn't be long now...
Post by: bryant on 2013-06-27 18:55:34
Thanks for reporting; I have reproduced.
In the meantime a workaround is to pipe to stdout and redirect to NUL:
wavpack Track01.wav - > NUL
Post by: sluggy on 2013-06-27 23:19:17
Awesome, Looking forward to the update
Post by: eahm on 2013-07-30 05:21:55
Any news on the final stable release?
Post by: Peter on 2013-07-31 20:36:23
  • experimental, undocumented option to store float16 and float24 audio data as integers (--store-floats-as-ints)
Since it's not officially documented, I'll share my findings about such files here:
Code to determine the real wave format tag of from a WavPack context - presuming context to have been opened with OPEN_WRAPPER:
static uint32_t WavpackGetFormatTagFromWrapper(WavpackContext * wpc ) {
uint32_t bytes = WavpackGetWrapperBytes( wpc );
uint8_t * ptr = WavpackGetWrapperData( wpc ) ;
uint32_t fmtOffset = 8 + 12;
if (bytes < fmtOffset + 2) return 0;
if (memcmp(ptr, "RIFF", 4) != 0) return 0;
if (memcmp(ptr + 8, "WAVEfmt ", 8) != 0) return 0;
return (uint16_t) ptr[fmtOffset] + ((uint16_t) ptr[fmtOffset+1] << 8);
static uint32_t WavpackGetFormatTag(WavpackContext * wpc ) {
uint32_t v = WavpackGetFormatTagFromWrapper( wpc );
if (v == 0) {
if ( WavpackGetMode( wpc ) & MODE_FLOAT ) {
v = 3;
} else {
v = 1;
return v;
Please correct me if the above is wrong.
Post by: bryant on 2013-08-01 15:02:29
There are two error cases I can see. The first is if the “fmt” chunk does not come first. I don't know if that ever happens, and is not that big a deal because this code will ignore it then.
However, if an extensible header is used and the wFormatTag is 0xFFFE, then this code will fail. I would suggest changing the condition for using the WavpackGetMode() result to:
if (v == 0 || v == 0xFFFE)
Or you could change WavpackGetFormatTagFromWrapper() to return 0 for 0xFFFE. Either way, this will make sure that the only failure cases are with unsupported files.
Post by: bryant on 2013-08-03 22:09:20
Sorry for the delay on this...I've been putting out fires at my "day gig" and have been coming up to speed on Git because the WavPack repo is moving to GitHub soon.
But it's still on the radar!
Post by: DARcode on 2013-08-11 13:38:05
Found out about the new release just now, simply awesome, thanks a bunch David.
Post by: eahm on 2013-09-11 05:47:29
bryant, pardon me I am pushing again, any news on the stable release?
Post by: bryant on 2013-09-26 00:31:16
Sorry for the delay, but I am now getting ready to finalize this release (been swamped with paying work that is now complete).
The first step was migrating the sources to GitHub, which is complete: repository is here (https://github.com/dbry/WavPack).
Thanks for hanging in there!
