I want to remove the display of the number of tracks within brackets from all different view types, how do I accomplish this ?
AbbA (24)
Cranberries (12)
In Dire Straits (3)
to
AbbA
Cranberries
In Dire Straits
you can't do it with the default UI panel. i *think* it might be possible with the columns UI album list panel. it's also possible with library tree (http://foo2k.chottu.net/#lt) which is a replacement panel for columns UI only.
edit: you can access library tree as a popup panel from within default UI if you install columns UI and foo_popup_panels.
