Look what I found today
fooTube (http://pnnceo.blog.fc2.com/blog-entry-94.html)
Together with foo_run (http://www.hydrogenaudio.org/forums/index.php?showtopic=45223) it's exactly what you're looking for
Maybe I was not exactly enough inn my starting poast.
But what I was meaning is that I want to search in foobar and get a list of hits.
Clicking on it will add it to the playlist or starts playing the song within foobar.
Not in an external Window.
Well that is as good as it gets. Foobar plays flv's with the right plugin, but only audio and you cannot search from there.
I'm happy just not having to use the browser to search for files in YT.
thank you for recomending my tool Emerelle.
jPatton then i recomend you This (http://pnnceo.blog.fc2.com/blog-entry-95.html)
At this introduction page, using this tool with foo_run
but you can use by WSH Panel mod or something like that
URL-Encordeding is needed to search Video on youtube.
[blockquote]
ex.if you want to search "apple cooking",
youtube URL with Search query have to be "http://www.youtube.com/results?search_query=apple+cooking"
you need to change " "(space) to "+"
[/blockquote]
For like me Japanese user and other multibyte-character language users,
URL-Encoding is big problem, so i made a tool to handle that.
[blockquote]
ex.if i want to search "
林檎"(林檎 means apple),
youtube URL with Search query have to be "http://www.youtube.com/results?search_query=%E6%9E%97%E6%AA%8E"
i need to change "林檎" to "%E6%9E%97%E6%AA%8E"
[/blockquote]
Using this tool you dont have to care about it.
I made footube version3.00beta (http://pnnceo.blog.fc2.com/blog-entry-213.html) note open external window.
This is BETA version and may have some bugs.
.NET FrameWork4 needed
WSH Panel Mod needed
(http://img513.imageshack.us/img513/8692/59509455.png)
(http://img408.imageshack.us/img408/7607/62983604.png)
I release footube which is work with WSH Panel Mod
Please try it!
Get it from here(English & Japanese explanation post) (http://pnnceo.blog.fc2.com/blog-entry-219.html)
(http://img809.imageshack.us/img809/1489/image1438.png)
(http://img267.imageshack.us/img267/2572/62229596.png)
Introduction Viedo on Youtube (http://www.youtube.com/watch?v=q-1rS377aSY)
Using WSH stdin/out and C# Form aplication's console.write/read,
i can made external aplication strongly coordinate operation with foobar2000.
var WshShell = new ActiveXObject("WScript.Shell");
var exe = "footube.exe";
var delay = 5000;
var oExec = WshShell.Exec(exe+" "+window.ID+" "+delay);
var timer = window.CreateTimerInterval(delay+100);
var stat = 1;
var pipe = 0;
var mes_templ = "###############################\n"
mes_templ += "Message From fooTubeScript Host\n"
mes_templ += "###############################\n";
var bar_templ = "-------------------------------\n"
function on_playback_new_track(metadb){
if (stat == 1 && pipe == 1)
try
oExec.StdIn.WriteLine(fb.TitleFormat("%title%").Eval(true));
catch(e)
fb.trace(mes_templ+"pipe had been closed");
stat = 0;
pipe = 0;
function on_timer(timer_id){
window.KillTimer(timer);
var dt = new Date();
var start = dt.getMilliseconds();
fb.trace(mes_templ+"initialization pipe conection...");
if (stat)
dt = new Date();
fb.trace("Send SYN to footube.exe");
oExec.StdIn.WriteLine("SYN");
if(oExec.StdOut.ReadLine() == "SYN")
fb.trace("Recieve SYN from footube.exe\nSend ACK to footube.exe");
oExec.StdIn.WriteLine("ACK");
fb.trace("Recive TEST Message from footube.exe");
pipe = 1;
fb.trace("\""+oExec.StdOut.ReadLine()+"\"");
var end = dt.getMilliseconds();
fb.trace((end-start)+"ms took to pipe conection establishment\n"+bar_templ);
else
fb.trace("Error : Cannot Recieve SYN from footube.exe\n"+bar_templ);
stat = 0;
pipe = 0;
(http://img28.imageshack.us/img28/952/foobarunderwater.png)
Have a nice music life with foobar2000, and many thanks to WSH Panel Mod and foobar2000 author!
2012-02-16
NEW script for footube
I wonder when i listen to net-radio and music changed, on_playback_new_track is not called.
so using regexp, if RAW PATH include "http://",make timer and check if music has changed.
and other changes in detail.
learn detail (http://pnnceo.blog.fc2.com/blog-entry-230.html)
var delay = 3000;
var timer = window.CreateTimerInterval(delay+3000);
var stat = true;
var pipe = false;
var net_radio = false;
var net_radio_tit = "";
var cmd2pipe = "";
var mes_templ = "###############################\n";
mes_templ += "Message From fooTubeScript Host\n";
var bar_templ = "-------------------------------\n";
function sendMes2pipe(cmd2pipe)
try
oExec.StdIn.WriteLine(cmd2pipe);
catch(e)
killAll();
function killAll()
stat = false;
pipe = false;
net_radio = false;
function checkBeforSend()
if (stat && pipe)
sendMes2pipe(fb.TitleFormat("%title%").Eval(true));
var url = new RegExp("http://", "i");
if(fb.TitleFormat("%_path_raw%").Eval(true).match(url))
net_radio = true;
net_radio_tit = fb.TitleFormat("%title%").Eval(true);
timer = window.CreateTimerInterval(6000);
else
net_radio = false;
checkBeforSend();
if (net_radio)
if (net_radio_tit != fb.TitleFormat("%title%").Eval(true))
sendMes2pipe(net_radio_tit);
else if (stat && pipe == false)
dt = new Date();
pipe = true;
if ((end - start) <= 0)
fb.trace((end+1000-start)+"ms took to pipe conection establishment\n"+bar_templ);
else
checkBeforSend();
else
killAll();
and I am a student so there are many other things to do.
so I make footube open sourced.please modify it by yourself
footube version3.6 with c# code (http://pnnceo.blog.fc2.com/blog-entry-239.html)
working link for footube: https://skydrive.live.com/?cid=1984874fe7d5...AGeAqFbqPPpnMm4 (https://skydrive.live.com/?cid=1984874fe7d57ae7&id=1984874FE7D57AE7!140&authkey=!AGeAqFbqPPpnMm4)
GiveMe9 ,can you make this for opera browser?
Something that will put opera aplication in foobar?
Can somebody post a nice tut about this component?
I think it works great, when it works.
I get an xml error and footube crashes (version 3.05 stable)
This is old ,don't think it'll work but there is better component for this now:
click (http://www.hydrogenaud.io/forums/index.php?showtopic=104379)
You may wanna look into these too
Foobar Youtube Radio (http://www.hydrogenaud.io/forums/index.php?showtopic=105108)
Youtube Track Manager (http://www.hydrogenaud.io/forums/index.php?showtopic=105522)
