And enjoy you all will, it is absolutely superb
Well done Br3tt, a stunning config, the best I've ever seen for F2K
this is by far the greatest config i have ever seen. keep up the great job Brett
The config is really great. Only thing that I noticed is that I'm missing buttons and lots of them.
Btw wouldn't it be better if you used %appdir%/foobar2000/ instead of C:/Program Files/foobar2000? Simply because Windows names the program folder differently in every language.
Wanted to drop a quick thank you br3tt, and this is a really great config:)
You need to put the folder called curacao in the images folder in the Foobar main folder, so C:\Program Files\foobar2000\Images\curacao
Thanks Br3tt!
just read help files available on my site before asking question, all is explain (i hope).
%appdir% not supported
thanx to you and everybody that enjoy it
This thing is great no problems in setting it up which is a good start the only problem is when switching to MilkDrop for the AVS I get The plugin crashed during initialization.
Sorry to disappoint but I'm not that dumb. The image folder is present. Well actually it's in C:\Programme\foobar2000\... since I'm using the German version of XP. But I changed the path (changed the foo_path definition to C:/Programme/foobar2000/) in PSS so I hope that would solve this problem.
I guess this isn't a Vista x64 friendly theme? I follow the instructions and when I click to play a song it immediately crashes.
not a curacao issue, but shpeck issue, be sure that your version of milkdrop is compatible with the version of your Shpeck component !
Looks really pretty, and it was incredibly easy to set up, really well done on that. It's kind of annoying that you have to create a playlist to view all of your music though, kinda defeats the purpose of having a library. There are no ultra customizable media library viewers though, so it seems to be the only solution.
Another thing, how do you get that exact visualization up? I have milkdrop 2 installed, don't know how to pick a particular vis though.
Cheers!
You should be using Milkdrop 2.0e really, what version do you have?
components make vista x64 crash, not the config dude.
foo_path variable have to be changed in many other panel in the config, i'll list them tomorrow.
bye
I zipped up my complete Plugins folder which has got the latest versions of Milkdrop 2 and 8,606 presets (literally )
It's about 65MB RAR'd down to 17MB, if anyone wants it... http://rapidshare.de/files/40889036/Plugins.rar.html (http://rapidshare.de/files/40889036/Plugins.rar.html)
Downloading....
Thanks for another fine work.
bye
I just noticed. I changed it in a ton of different places. A hell of a lot of work. Especially if you have to do it frequently :\.
Looks great though once it's done.
Not sure if I'll keep it. Ibiza doesn't look as fancy but is easier to get working under my circumstances.
A shame that it's not possible to put a master setting for album, artist and foobar paths and let all parts of the config grab them from there.
which components would that be then? how would I figure out which one(s) it could be?
Is it possible to have all the unfocused groups collapsed like in Ibiza? Makes scrolling through the playlist a lot faster.
it is an option of the component ELPlaylist, just enter its settings, behaviour tab ...
I get this a few times now after playing music.....I did a clean install and now it seems to be working fine except for the below crash that occurs. DEP keeps closing foobar2000 down....I tried to exclude it and Vista tells me this program needs DEP and I can't exclude it.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 62A3FAD4h
Access violation, operation: write, address: 62A3FAD4h
Call path not available.
Code bytes (62A3FAD4h):
62A3FA94h: 00 00 00 00 00 00 00 00 00 00 00 00 6C D8 B8 A0
62A3FAA4h: 88 27 1E 08 00 00 00 00 37 00 00 00 08 00 00 00
62A3FAB4h: A8 FA A3 62 D4 FA A3 62 04 00 00 00 13 00 00 00
62A3FAC4h: 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00
62A3FAD4h: 8B F7 B8 D8 F1 B6 5F 50 B8 CC FA A3 62 5B DD 00
62A3FAE4h: DD 1B C3 00 00 00 00 40 00 00 00 00 00 00 00 40
62A3FAF4h: 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 40
62A3FB04h: 00 00 00 00 00 00 00 40 8B F7 B8 90 94 A7 5F 50
Stack (090FEB3Ch):
090FEB1Ch: 00000000 00000000 00000000 00000000
090FEB2Ch: 00000000 00000000 00000000 00000000
090FEB3Ch: 04A6F970 00000000 04A914E0 090FEB70
090FEB4Ch: 090FEB60 04A91508 00000368 7EFA6000
090FEB5Ch: 62A3FAD4 00000000 04A914E0 00000000
090FEB6Ch: 04A91508 090FED94 04A6DCB2 62A3FAD4
090FEB7Ch: 1670F0E8 04A725A8 62A3FAB0 090FF368
090FEB8Ch: 00000034 04A871B0 00000000 00000000
090FEB9Ch: 00000000 0000FFFF 00000000 00000000
090FEBACh: FB14BC00 00004004 00000000 00000000
090FEBBCh: D1F9DAEA 00004002 00000000 00000000
090FEBCCh: 00000000 00000000 00000000 00000000
090FEBDCh: 00000000 00000000 00000000 1670F0E8
090FEBECh: 00000000 00000000 00000000 00000000
090FEBFCh: 00000000 00000000 00000000 00000000
090FEC0Ch: 00000000 00000000 00000000 00000000
090FEC1Ch: 00000000 00000000 00000000 00000000
090FEC2Ch: 00000000 00000000 00000000 00000000
090FEC3Ch: 00000000 00000000 00000000 00000000
090FEC4Ch: 00000000 00000000 00000000 00000000
Registers:
EAX: 62A3FAD4, EBX: 04A91520, ECX: 7EFA6000, EDX: 00000368
ESI: 04A914E0, EDI: 04A91520, EBP: 090FEB70, ESP: 090FEB3C
Unable to identify crash location
Loaded modules:
foobar2000 loaded at 00F50000h - 01089000h
ntdll loaded at 77780000h - 778E0000h
kernel32 loaded at 75B50000h - 75C60000h
COMCTL32 loaded at 74A30000h - 74BCE000h
msvcrt loaded at 772C0000h - 7736A000h
ADVAPI32 loaded at 76060000h - 76126000h
RPCRT4 loaded at 76210000h - 76300000h
Secur32 loaded at 75930000h - 75990000h
GDI32 loaded at 75AC0000h - 75B50000h
USER32 loaded at 75E30000h - 75F00000h
SHLWAPI loaded at 75F00000h - 75F58000h
SHELL32 loaded at 76470000h - 76F7F000h
ole32 loaded at 76310000h - 76454000h
shared loaded at 10000000h - 1002A000h
UxTheme loaded at 74030000h - 740B0000h
COMDLG32 loaded at 75D20000h - 75D93000h
IMM32 loaded at 77380000h - 773E0000h
MSCTF loaded at 75F90000h - 76058000h
LPK loaded at 76130000h - 76139000h
USP10 loaded at 76140000h - 761BD000h
wl_hook loaded at 00E40000h - 00EF5000h
AM30400 loaded at 00AA0000h - 00AAC000h
ws2_32 loaded at 75C60000h - 75C8D000h
NSI loaded at 76460000h - 76466000h
foo_uie_elplaylist loaded at 02650000h - 026B7000h
gdiplus loaded at 719B0000h - 71B5B000h
foo_freedb2 loaded at 00F10000h - 00F50000h
foo_uie_wsh_panel loaded at 74890000h - 748BF000h
OLEAUT32 loaded at 770A0000h - 7712D000h
foo_uie_vis_channel_spectrum loaded at 025D0000h - 0260D000h
MSIMG32 loaded at 73140000h - 73145000h
WINMM loaded at 73840000h - 73872000h
OLEACC loaded at 73800000h - 73839000h
foo_menu_addons loaded at 02730000h - 0278D000h
libmmd loaded at 02FD0000h - 03281000h
MSVCR80 loaded at 74280000h - 7431B000h
foo_vis_shpeck loaded at 74860000h - 7488A000h
MSVCR90 loaded at 73330000h - 733D3000h
foo_playback_custom loaded at 02B00000h - 02B45000h
WINSPOOL loaded at 74480000h - 744C2000h
foo_lastfm_radio loaded at 02C10000h - 02C56000h
foo_ui_std loaded at 036F0000h - 037C4000h
foo_uie_panel_splitter loaded at 02C80000h - 02CCF000h
foo_rgscan loaded at 02D70000h - 02DCB000h
foo_albumlist loaded at 02E50000h - 02EBB000h
foo_converter loaded at 03390000h - 033FC000h
foo_uie_quicksearch loaded at 03400000h - 03446000h
foo_skip loaded at 75740000h - 7574C000h
foo_dsp_std loaded at 039F0000h - 03A38000h
foo_uie_graphical_browser loaded at 74720000h - 747B4000h
foo_cdda loaded at 03A90000h - 03AD1000h
foo_uie_trackinfo_mod loaded at 03AE0000h - 03B36000h
MSVCP80 loaded at 74320000h - 743A7000h
foo_input_std loaded at 03E20000h - 03F5C000h
foo_ui_columns loaded at 04060000h - 04192000h
foo_unpack loaded at 03570000h - 0359D000h
foo_fileops loaded at 03D80000h - 03DC6000h
foo_run loaded at 03DD0000h - 03DFE000h
foo_abx loaded at 043D0000h - 04401000h
foo_uie_lyrics loaded at 04470000h - 044CC000h
WININET loaded at 76F80000h - 77050000h
Normaliz loaded at 77370000h - 77373000h
iertutil loaded at 77050000h - 77095000h
mscms loaded at 70830000h - 70892000h
USERENV loaded at 757A0000h - 757BE000h
icm32 loaded at 716F0000h - 71728000h
SXS loaded at 71610000h - 7166F000h
CLBCatQ loaded at 75C90000h - 75D14000h
jscript loaded at 69DE0000h - 69E5D000h
rsaenh loaded at 73E00000h - 73E3B000h
vis_avs loaded at 04A40000h - 04ABB000h
DDRAW loaded at 70740000h - 70825000h
DCIMAN32 loaded at 71830000h - 71836000h
SETUPAPI loaded at 77130000h - 772BA000h
dwmapi loaded at 74430000h - 7443C000h
MSVFW32 loaded at 74800000h - 74823000h
AVIFIL32 loaded at 74840000h - 74859000h
MSACM32 loaded at 73280000h - 73294000h
sud loaded at 69C00000h - 69D2E000h
ADVPACK loaded at 747D0000h - 747FE000h
VERSION loaded at 75790000h - 75798000h
PROPSYS loaded at 72C50000h - 72D0B000h
DUser loaded at 6B640000h - 6B670000h
AddBorder loaded at 05C80000h - 05C86000h
colormap loaded at 05C90000h - 05C9A000h
convolution loaded at 072E0000h - 072F0000h
fyrewurx loaded at 072F0000h - 07304000h
multifilter loaded at 07310000h - 07316000h
texer loaded at 07320000h - 07327000h
texer2 loaded at 07350000h - 0735B000h
atiumdag loaded at 68C70000h - 69022000h
atiumdva loaded at 680E0000h - 6852F000h
browseui loaded at 69E60000h - 69FA6000h
tiptsf loaded at 6CD50000h - 6CDB0000h
apphelp loaded at 74CD0000h - 74CFC000h
urlmon loaded at 75990000h - 75AB9000h
DSOUND loaded at 69D70000h - 69DE0000h
POWRPROF loaded at 74700000h - 7471A000h
MMDevApi loaded at 732D0000h - 732F7000h
WINTRUST loaded at 74940000h - 7496D000h
CRYPT32 loaded at 740B0000h - 741A1000h
MSASN1 loaded at 749C0000h - 749D2000h
imagehlp loaded at 75F60000h - 75F89000h
AUDIOSES loaded at 732A0000h - 732C1000h
audioeng loaded at 71840000h - 718A6000h
PSAPI loaded at 76300000h - 76307000h
AVRT loaded at 73A00000h - 73A07000h
actxprxy loaded at 6CCF0000h - 6CD43000h
c_is2022 loaded at 75750000h - 75756000h
c_iscii loaded at 756F0000h - 756F6000h
c_g18030 loaded at 69FC0000h - 69FFA000h
dbghelp loaded at 71B70000h - 71C4C000h
Stack dump analysis:
Address: 04A6F970h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A914E0h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00011D60h)
Address: 04A6DCB2h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A725A8h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A871B0h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00007A30h)
Address: 04A850F6h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00005976h)
Address: 04A871D0h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00007A50h)
Address: 04A73E97h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 00E5DC9Ah, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00EEB8E0h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 777BD032h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlInterlockedFlushSList" (+000000E9h)
Address: 00ED0D68h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 01000414h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00ED0D98h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00E5EA5Ah, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00E562E9h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00EEB3A8h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 03000003h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0002D6C7h)
Address: 777AFA88h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlTryEnterCriticalSection" (+000004F2h)
Address: 777D3081h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlAllocateHeap" (+00000162h)
Address: 77832926h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "wcstombs" (+0000007Ah)
Address: 00ED12B8h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00E6BC4Ah, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 777AF26Ch, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlDeactivateActivationContextUnsafeFast" (+0000BBD0h)
Address: 04A75BB4h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A871E8h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00007A68h)
Address: 707B5067h, location: "DDRAW", loaded at 70740000h - 70825000h
Symbol: "GetSurfaceFromDC" (+00038E18h)
Address: 7074DA25h, location: "DDRAW", loaded at 70740000h - 70825000h
Symbol: "DirectDrawCreate" (+00004480h)
Address: 04A7E11Ch, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A8F8D8h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00010158h)
Address: 777A35C0h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlLeaveCriticalSection" (+00000000h)
Address: 04A7FECFh, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+0000074Fh)
Address: 02FFF9F8h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0002D0BCh)
Address: 02FFFB00h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0002D1C4h)
Address: 01060602h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00FF0000h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 03040B0Eh, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0006E1D2h)
Address: 01010504h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 03060F0Fh, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0008E5D3h)
Address: 01060603h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 010603FEh, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00F8F7FFh, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00FFFE05h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 03020206h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0004D8CAh)
Address: 010100FBh, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 01030505h, location: "foobar2000", loaded at 00F50000h - 01089000h
Version info:
foobar2000 v0.9.6 beta 5
UNICODE
Windows 6.0
Additional info:
WSH Panel (uie) 0.7.2 (foo_uie_wsh_panel)
Converter 1.2 (foo_converter)
Shpeck - Winamp vis plugins wrapper 0.2.4 (foo_vis_shpeck)
File Operations 2.1.1 (foo_fileops)
foobar2000 core 0.9.6 beta 5 (Core)
Menu Addons 0.4 (Intel SSE) (foo_menu_addons)
ZIP/GZIP reader 1.0 (foo_unpack)
Run services 0.3.4 (foo_run)
Graphical Browser rev015 (foo_uie_graphical_browser)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
Playback Statistics Custom 1.4.3 (foo_playback_custom)
Album List 4.3 (foo_albumlist)
Columns UI 0.3.5.1 (foo_ui_columns)
Panel Stack Splitter 0.3.6.2(alpha) (foo_uie_panel_splitter)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] (foo_uie_trackinfo_mod)
Skip Track 1.0.0 (foo_skip)
Channel Spectrum panel 0.17.2 (foo_uie_vis_channel_spectrum)
Default User Interface 0.9.5 (foo_ui_std)
Last.fm Radio 0.5 (foo_lastfm_radio)
ReplayGain Scanner 2.0.8 (foo_rgscan)
freedb Tagger 0.6 (foo_freedb2)
Standard Input Array 1.0 (foo_input_std)
CD Audio Decoder 2.1.3 (foo_cdda)
Lyric Show Panel 0.3.3.4 [Nov 11 2008 - 19:42:37] (foo_uie_lyrics)
ELPlaylist 0.6.3.0(beta) (foo_uie_elplaylist)
RAR reader 1.1 (foo_unpack)
ABX Comparator 1.3.3 (foo_abx)
Standard DSP Array 1.0 (foo_dsp_std)
another crash
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 3EC3E38Ch
Access violation, operation: write, address: 3EC3E38Ch
Code bytes (3EC3E38Ch):
3EC3E34Ch: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3EC3E35Ch: 00 00 00 00 1D A2 DB 84 76 B0 9A 08 00 00 00 00
3EC3E36Ch: 2F 00 00 00 08 00 00 00 68 E3 C3 3E 8C E3 C3 3E
3EC3E37Ch: 0E 00 00 00 13 00 00 00 00 00 00 00 00 00 00 00
3EC3E38Ch: 8B F7 B8 60 EB 31 23 50 B8 60 7F B2 04 5B DD 00
3EC3E39Ch: DD 1B C3 E3 C3 3E B8 E3 C3 3E 05 00 00 00 B8 C4
3EC3E3ACh: E3 C2 3E 05 00 00 00 B8 58 E8 31 23 10 00 00 00
3EC3E3BCh: B8 58 E8 31 23 50 B8 C4 E3 C2 3E 5B DD 00 DD 1B
Stack (08FEE9E8h):
08FEE9C8h: 00000000 00000000 00000000 00000000
08FEE9D8h: 00000000 00000000 00000000 00000000
08FEE9E8h: 04AEF970 00000001 04B114E0 08FEEA1C
08FEE9F8h: 08FEEA0C 04B11508 00000F04 7EFA6000
08FEEA08h: 3EC3E38C 00000001 04B114E0 00000000
08FEEA18h: 04B11508 08FEEC40 04AEDCB2 3EC3E38C
08FEEA28h: 18332FB8 04AF25BF 3EC3E370 08FEF214
08FEEA38h: 00000034 04B071B0 00000000 00000000
08FEEA48h: 00000000 00000000 00000000 00000000
08FEEA58h: 00000000 00000000 00000000 00000000
08FEEA68h: 00000000 00000000 00000000 00000000
08FEEA78h: 00000000 00000000 00000000 00000000
08FEEA88h: 00000000 00000000 00000000 18332FB8
08FEEA98h: 00000000 00000000 00000000 00000000
08FEEAA8h: 00000000 00000000 00000000 00000000
08FEEAB8h: 00000000 00000000 00000000 00000000
08FEEAC8h: 00000000 00000000 00000000 00000000
08FEEAD8h: 00000000 00000000 00000000 00000000
08FEEAE8h: 00000000 00000000 00000000 00000000
08FEEAF8h: 00000000 00000000 00000000 00000000
Registers:
EAX: 3EC3E38C, EBX: 04B11520, ECX: 7EFA6000, EDX: 00000F04
ESI: 04B114E0, EDI: 04B11520, EBP: 08FEEA1C, ESP: 08FEE9E8
Loaded modules:
wl_hook loaded at 00070000h - 00125000h
AM30400 loaded at 001F0000h - 001FC000h
foo_cdda loaded at 00CC0000h - 00D01000h
foo_run loaded at 00E20000h - 00E4E000h
foo_uie_graphical_browser loaded at 74780000h - 74814000h
foo_freedb2 loaded at 00E70000h - 00EB0000h
foo_menu_addons loaded at 02910000h - 0296D000h
libmmd loaded at 02D30000h - 02FE1000h
foo_uie_lyrics loaded at 02C70000h - 02CCC000h
foo_abx loaded at 00F10000h - 00F41000h
foo_uie_elplaylist loaded at 03230000h - 03297000h
foo_uie_vis_channel_spectrum loaded at 032C0000h - 032FD000h
foo_input_std loaded at 03750000h - 0388C000h
foo_fileops loaded at 03300000h - 03346000h
foo_converter loaded at 03420000h - 0348C000h
foo_lastfm_radio loaded at 03350000h - 03396000h
foo_rgscan loaded at 03490000h - 034EB000h
foo_uie_panel_splitter loaded at 039D0000h - 03A1F000h
foo_ui_columns loaded at 03CD0000h - 03E02000h
foo_uie_quicksearch loaded at 03A20000h - 03A66000h
foo_uie_trackinfo_mod loaded at 03F80000h - 03FD6000h
foo_ui_std loaded at 042E0000h - 043B4000h
foo_albumlist loaded at 03FE0000h - 0404B000h
foo_dsp_std loaded at 03F20000h - 03F68000h
foo_playback_custom loaded at 04060000h - 040A5000h
foo_unpack loaded at 03990000h - 039BD000h
vis_avs loaded at 04AC0000h - 04B3B000h
MSVFW32 loaded at 74830000h - 74853000h
AVIFIL32 loaded at 74760000h - 74779000h
ADVPACK loaded at 74730000h - 7475E000h
convolution loaded at 07360000h - 07370000h
fyrewurx loaded at 07370000h - 07384000h
multifilter loaded at 07390000h - 07396000h
texer loaded at 073B0000h - 073B7000h
texer2 loaded at 073C0000h - 073CB000h
atiumdag loaded at 68170000h - 68522000h
atiumdva loaded at 68BE0000h - 6902F000h
DSOUND loaded at 746C0000h - 74730000h
POWRPROF loaded at 69FE0000h - 69FFA000h
Address: 04AEF970h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B114E0h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AEDCB2h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AF25BFh, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B071B0h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B050F6h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B071D0h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AF3E97h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 0008DC9Ah, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0011B8E0h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 00100D68h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 00100D98h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0008EA5Ah, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 000862E9h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0011B3A8h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 001012B8h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0009BC4Ah, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 00100008h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 04AF5BB4h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B071E8h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AFFECFh, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Version info:
UNICODE
Windows 6.0
Additional info:
Hmmm, I changed all the foo_path and pictures path but I don't get Track Info and artist picture working. :/
Nevertheless Curacao looks really really great, but it's less practical for me.
Very nice work Br3tt.
It seems you will need Shpeck 0.3.0 Beta 2 to use Milkdrop 2.0e now the problem being it does not dock into the space it just floats in it's own window how do I change that?
Close it, right click the AVS panel and select Milkdrop 2 to auto start, then close Foobar and open it again and it should be docked in the window. Double clicking it makes it go full screen and double click again puts it back in Curacao. Also you can right click on the Back/Forward buttons on the edge of the AVS window and select appearance, then turn off the titlebar to get rid of the top white bar
You can also go into Splitter settings and choose which of the windows (ALB, ART, AVS, INFO) you want to be open when Foobar starts, I have AVS as my default window
Mmmm you got a diagram on where you need to click to edit the splitter setting for the AVS? Also this thing will not sit where I tell it lol
--Edit--
Defaulted the plugin now does as it's told.
Scrap that got it sorted.
I disabled DEP on my Vista x64 and for the moment everything seems to be ok, I just wish someone could figure out which plugin is triggering DEP to kill foobar2000 process.
Another issue I see is at the top where you can click on a letter of the alphabet to jump to that part of the playlist, when I start foobar it shows as a white bar, and only after I mess around with the 3 setting button on the top left area of the program do the letters appear again.
before: http://img122.imageshack.us/img122/6623/11...08192420ld7.jpg (http://img122.imageshack.us/img122/6623/11222008192420ld7.jpg)
after: http://img386.imageshack.us/img386/5061/11...08192603ne7.jpg (http://img386.imageshack.us/img386/5061/11222008192603ne7.jpg)
Just installed Curacao and... it really looks amazing!! I really like the fact that you can have graphical browser, album art, lyrics, etc.. in the same view. The properties, open folder 'buttons' are also very helpful.
Is there a way to change the size of the playlist switcher drop-down panel? It's too small to show all my playlists with lenght, size. I like to switch playlists pretty often - is it possible to assign a hotkey to show/hide this panel?
Support for the official playback-statistics component would make Curacao the config best ever!
thx work great
a short comment/suggestion add some real tutorials to your site
like how to
- config the elplaylist
- add buttons, hide/show panels in pss
- config the gp
- damn the wsh
- etc.
some real examples now I've to read me to japanese readme files and to find some real helpful post in forums
Really nice config Br3tt as always^^
I have the same problem
it is just a floating window
I follow your advice but it is still a floating window and in foobar it says that only one Milk drop can be launch so it just desactivate the one in foobar and let the window works.
Go to MilkDrop 2.0e Configure-> Uncheck FullScreen and Desktop Mode, check Integrate with winamp skin. I think the problem will be solved.
(http://img357.imageshack.us/img357/3025/1123200815006pmce3.jpg)
(http://img376.imageshack.us/img376/7518/1123200814935pmoi0.jpg)
(http://img338.imageshack.us/img338/8048/1123200820458pmrq4.jpg)
Thanks it was indeed the option integrate with winamp skin
thanks a lot
I love this but since I use XP x64, my folder is named "Program Files (x86)". So, many of the buttons aren't showing.
Looks hot though. Thanks.
Edit: I figured it out. Path changed in the splitter settings. All is well.
I installed winamp and foobar in c:\program files and I am running Vista x64 and so far no side effects other than the "bug" I reported earlier about the alphabetical little menu thing at the top showing up as a white bar until I mess with the 3 buttons on the top left section of the window and they it appears ok.
(http://i3.6.cn/cvbnm/9a/e0/7e/8a7d9c243e34a195bfb02ade04fd5e52.jpg)
plz add chronflow again
Can you tell me where to switch it off? I have the same problem
This is a cool config here.. thanks for your great work again!
I have just some suggestions...
a) Artist path. Maybe to help others setting up the path you could add this additional version to the Z:/artist path as a comment: $puts(artist.path,$replace($replace(%path%,$directory(%path%),),%filename_ext%,*.jpg))
It checks for any jpg in the parent folder of an album.
b) foo_path. Is there no way to put that as one global variable somewhere/somehow /in an ini-file or whatever). It's a little bit tough to find all instances of the variable definition...
c) Did you take a look at the "mouseover"-function of ELplaylist? Would be very cool if you implemented it somehow, i.e. when you move the mouse over the group header, there could be some additional info with a picture of the artist or whatever..
d) Any chance to make the uppermost line with the "breadcrumb" now playing track a little bit more interactive? Thought it would be cool to use the seperate entries as a filter for example. When you click on the artist name all songs by that artist are listed in a new playlist.
Thanks again!
Additionnal help file (image) added on my website
here is the direct link, i have indicated panels that contain the foo_path variable that you may have to change
direct link: http://br3tt.free.fr/files/help.png (http://br3tt.free.fr/files/help.png)
Curaçao gets Daily Deviation reward on DeviantART, congratulations Br3tt
Thank you very much Br3tt for this configuration! Its really very good but i miss the album list panel...also is there a way to make scrolling in playlist and graphical browser smoother?
A small request: for tracks in the playlist, please display
playcounter (maybe as a superscript similar to ibiza)
if the file is queued (like in default ui)
if present, the mood-hearts
Thank you very much!
yep, i'll add this
sweet
how are selected DAILY DEVIATION ? only autorized persons can feature them ?
Can you make random default wallpaper whenever foobar start? Thanks you very much!
Here’s a tip for getting the best Artist Art for Curacao, something I’ve learnt through using this for over a month…
Curacao works best with large widescreen art displayed as its background. Very often it’s hard to find good Artist pics in this format, but there is actually a huge source of them out there already, Band Wallpaper pics. This normally means that a fan has spent hours finding the best pics of their favourite band and then converted them into 1024 x 768 Wallpaper images, which are just perfect for Curacao
So go to Google images and search for Led Zeppelin Wallpaper for example and see what I mean
Or even better, convert the new Google Artist Art search button to do it for you, just go into Run Services in F2K Preferences and change the Google Artist Photo path to
http://images.google.com/images?hl=en&q=$replace(%artist% Wallpaper,' ','+')&btnG=Recherche+d%27images&gbv=2
Hope that helps some of you
small bug report - the button for ahead 10 sec has an action of foobar reload
great config, thank you
Yup, very strange, it re-starts F2K. It was working fine in earlier builds
my fault, i fix it immedialty
So, any workaround for smoother scrolling in the playlist?
done, archive file updated un deviant art and my website too.
it is smooth for me, try another PC or defaultUI interface
try scrolling a web page in a web browser like firefox and then scrolling the playlist...you will see what i mean...is it possible to make it so smooth or not? I don't blame you for that i'm just curious..
you can not compare scrolling smooth between applications !! notepad is the best at that lol
so to reply about curaçao, : NO
I found a workaround...its better when i deactivate the transparency!
Yes, [link] (http://help.deviantart.com/18/)
ok, thanx
but no sense for Curaçao where transparency is the main interest !
I can't even load the Curacao config file, because I get this error after copying over the needed components:
Failed to load DLL: foo_vis_shpeck.dll
Reason: The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail.
Failed to load DLL: foo_skip.dll
Any ideas?
Thanks...
I just did a google search for Vista disable DEP (I think I spelled out DEP) and found the following site
http://www.vistax64.com/tutorials/120778-d...le-disable.html (http://www.vistax64.com/tutorials/120778-dep-enable-disable.html)
Just make sure you got a good firewall and antivirus I guess.
Any ideas?
Thanks...
You need Microsoft Visual C++ 2008 Redistributable Package (http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf).
http://img243.imageshack.us/img243/8425/11...08111103ej2.jpg (http://img243.imageshack.us/img243/8425/11232008111103ej2.jpg)
any ideas on fixing that falstaff? when foobar starts the little alphabet deal at the top is all white. If I click one of the 3 buttons on the side (?, 1, 2) then it will fix it.
Any ideas?
Thanks...
Thanks! It worked perfectly!
Br3tt,
Thanks for releasing this great config! I really like the style and how adaptable it is.
I had a couple questions. Is there a setting to make the playlist remember where it last was when open/closing foobar? If i close foobar, the playlist goes back to the beginning. I realize this is probably a ELPlaylist setting, but am not sure where to find it.
There are times when just opening foobar for the first time that the buttons are missing. Also, the A-Z strip at the top starts out white until i click the min/max button on the lyrics panel.
Thanks again!
How to add a album to a created playlist in curação... I dont find a away
Tanks
Tanks
you mean sending track (an album why not ) to a specific playlist ?
for this, i use foo_utils.dll, download it (find it before ) it adds a context menu Edit Other that bring these features ...
bye
Br3tt,
Thanks again!
when you restart foobar, position in playlist is lost, right, but foobar remember what is the last played song, just click PLAY button to be positionning well
You can resume playback on foobar startup too, go to Prefs, Playback at bottom, check resume playback after restart will show it fine
I thought i'd share this with anyone interested. Want to display for example: The Animals, to Animals, The
Here is how, right click on the El playlist, Go To Settings, Then go to Group Header tab, Scroll down untill you see
////////// Group Info ////////// directly under that you'll have to change 2 items. The Highlighted section in "yellow" is the default, and replace that part with the part in "light blue" code:
$drawtext($swapprefix(%artist%)
(http://xs233.xs.to/xs233/08470/--fbset2830.png.xs.jpg) (http://xs233.xs.to/xs233/08470/--fbset2830.png) (http://xs233.xs.to/xs233/08470/--fbset870.png.xs.jpg) (http://xs233.xs.to/xs233/08470/--fbset870.png)
edit: fixed a small spelling error.
edit2: You may need to go in to ELP Settings --> 'Grouping' tab, 'Sort format' box, and paste this code:
$swapprefix(%album artist%) - %date% - %album% - %discnumber% - %tracknumber% - %title%
Feel free to custom sort it however you'd like, whatever your needs may be.
Normally I use $stripprefix instead but I've noticed that if you use an Auto playlist with 'force sorted' ticked then it does not work. The other frustration is that if you use $swapprefix or $stripprefix then use the 'T' to search it pics up THE rather than second words starting with T, any way to stop that?
Unfortunately, this proves much to heavy for my gig. ELPlaylist loaded with all my library is too slow to browse comfortably. 'Tis sad you've dropped Album List altogether.
You basically need to change from %artist% to $stripprefix(%artist%) everywhere you're sorting, so you can force sort your autoplaylist by that, and sort your graphical browsers (album pics, artist pics, and artist initial above the playlist) by it as well. That way the initials bar takes the letter A from The Artist, rather than T.
I had an idea for a plugin, although I'm not sure if it's possible, and the more I think about it the less I think it'll work. Basically you'd have some central place where you can specify what to sort by when you want to display a list of things, it would make life easier as you'd just need to specify what to display and you wouldn't have to copy sort patterns to a bunch of different places. Not sure how feasible it is though.
Nope, still not searching correctly when using the T button, but I've noticed another problem too, you can not search in ELP by typing letters anymore, I thought it was a problem with the latest version of ELP but it is working fine in IBIZA still. Weird...
Sadly, I'm finding the same problem on my machine, which I consider to still be top-of-the-line. I think it's a really nice config, but I'll be sticking with Ibiza, unless something dramatic changes with Curacao. I miss Album List too!
lol ibiza is a good choice too, i oblige nobody to use Curacao
I think ELPL searches based on %el_group_format%, so you might need to set it to group by your sort string as well. There is a setting under behaviour to turn on and off find as you type, maybe it's off in Curacao?
Yeah, I'm really loving Ibiza! Will there still be development continuing on it, or is it the final now?
Thanks for your hard work... you're making fb2k better for a lot of people!
Wow...amazing config. One of the best, most feature-rich yet. Only one issue: at the top of the window, I have two buttons for Google ("Google Artist Photo" or "Google Album Cover") and one for last.fm ("A custom last.fm station"), but the only problem is that those buttons have a black background while they should match the blue-ish gray you've set. Any idea what could cause this or how to fix it?
If you're talking about the Hover Over Image, "when you hover your mouse over the buttons" this is perfectly normal, "no problem with it" correct color.
Nope, it's a black background no matter what. When I hover I see that the buttons appear to depress, but I the background is black whether I hover or not.
Another problem I'm having that I haven't had with any previous configs: I can't reorder tracks by dragging. When I do click and drag, a little line comes up that indicates where the song would go, but when I release the mouse button nothing happens.
maybe you are in an auto-playlist with forced sort option ticked ?
Well, I do hope Falstasff will consider returning to the classical album list enabled interfaces in future. This all-library-loaded concept is somewhat questionable to me in terms of usability.
Please, take this as a piece of constructive criticism.
Browsing all your music the way it's implemented in this configuratuion is opposite to true usability. See: you have a global list.
First, the global list (given that it's all collapsed) consists of elements (boxes) with album art on the left and album artist and album title on the right (one above the other). That is, navigating through the list searching for a particular item the first thing a user (given he or she is not Asian or otherwise used to RTL layouts) sees is album art. Which, being a tiny 54px wide, is way too small to be really helpful in easily locating neither the album (even on lower display resolutions) nor (obviously) the artist, but nevertheless it occupies the most significant leftmost position in a line, where properly most important info should be located. So, in terms of search usability (not "eye-candiness") an album art like that is redundant and disturbing. Which it needn't have been, if only it could scale with the screen resolution (and possibly window size too) to keep a reasonable size.
Secondly, the whole config is coded to provide an artist title sorted list. Which is perhaps debatable. But let it be. Even if I agree to browse my library forcedly sorted by album artist, I (and I suppose most of the users) rarely listen to complete discographies. They listen to albums. So it's the albums they ultimately search for. But the first text line (and the first really helpful informative element) a user always sees is album artist's name, being topmost. Why? A user is looking for a particular album title, but the first thing that leaps to the eye (apart from album art) is album artist rather than album title. A piece of information, once the user gets to the artist in question, becomes absolutely redundant to the search. And to make things evem worse, it is aligned at the middle of the box, so that album title is not only below album artist, but lies at the bottom line of the box.
Which produces a sorry picture: of the three main potentially informative elements the single most and really important one - the album title - is placed in the least significant lower right position after two redundant and insignificant elements. That is absolutely contrary to true usabiliy. A user searching for an album, having located the artist in question, must then browse the list deliverately filtering two out of each three informative elements, and for no apparent reason. Which is to my eyes pure redundancy and info pollution. Which is non at all inevitable, just take a look at classical text list interfaces: once an intermediate category (say, album artist) is located, further information (sorted by other categories like album title) is presented without innecessary repetition of the higher catery (like in Windows Explorer, for example). And your way of presenting this is almost like an Explorer where each file name is forcedly preceded by a folder name. In my opinion, there is no way in of getting rid of this redundant repetition unless you rething the whole layout enabling a classical selective list browsing interface.
Thirdly, the whole library is made selectively accessible through an alphabetical index on top and a graphical album art index below. The alphabetical one fails to index non-latin characters, to begin with. But even having neglected many non-English speaking users (and those who simply listen to foreign music, too), it is still far from usability dealing with purely Latin character content, because picking a letter gets the list centered on the first artist name beginning with that letter. Centered, that is, there are lots of irrelevant lines in the upper half of the list which a user must skip to get to the artist in question, located at the center of the screen. It seemed to me a common practice to place the object of a link of such kind in the beginning (that is, top) of the output area, not its center, because the beginning is always clearly marked by edges, lines, borders, whatever (that is, the eye immediately knows where to focus), while the center is ambiguous with confusingly similar elements above and below and no reference point to focus attention to. It is almost like browsing a document, hitting page down and then trying to find where the beginning of that new page is! It is most stupid for a program to let it scroll half page instead of full page. All the more, it would have been most logical to produce the object of the link (the artist) right below the linking object itself (the alphabetical) index!
And the graphical album art list panel is, as I've already said, too small to be of real help. Plus, the shadowing effect forther reduces the legibility of these already not conspicuous enough pictures. While it is praisable that it tries to stay in sync with the current position in the main list, it does so by placing the selected album at the rightmost end of its line of covers! So it is a complete jumble: picking a letter from the alphabetic index on top you get the object placed in the center of the playlist and in the rightmost corner of the graphical cover list. While it would have been equally most logical to place it leftmost (and topmost in the main playlist panel), allowing the user to further navigate through the albums easily (from top to bottom in the playlist and from left to right in the graphical cover browser panel, making full use of both areas' space).
Once again, please, try to take this as a piece of constructive criticism.
Well i have some thoughts too about Curacao:
first: It needs an album list panel for sure!
second: Some details in the playlist make it difficult to read compared to the wonderful Ibiza and Kung foo! (well, i don't expect from Br3tt to do these changes though..he made the most difficult parts) So i changed these details in my Foobar:
(http://img401.imageshack.us/img401/3487/curacaoko4.th.jpg) (http://img401.imageshack.us/my.php?image=curacaoko4.jpg)(http://img401.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
Everyone can do changes like these by his own...Also i agree that album art is just eye candy with so small graphics...
Br3tt thanks so much for this brilliant configuration! Please accept with a positive way our comments...until now almost everything i wanted to be changed was changed by me...but there are some core elements like a bigger playlists browser and configurable list not only for artists but also for albums etc... and most of all an album list panel! Its very basic IMO!
With Curacao, IBIZA and KUNG FOO you have 3 different solutions to the same 'problem' Each offers different ways to do things and each uses a totally distinct and different approach. Ultimately they should be regarded as frameworks to be personalized in any way you feel fit to suit your own needs, just choose which one is closest for you then use it as it is accepting the few features that don't quite suit you, or modify it to fit you 100%. One size can never fit all
Yes you are right!...well, except the album list...its a basic element that could be added as a secondary mini panel at the left or together with the other lists etc..hmmm..i may try to do it...! anyway!
Well, I tend to disagree with elenhil and pacman. I'm very happy, that Br3tt has not included Album list. I have come to the conclusion that for me, file browsers like facets or album list are unneccessary because:
I have plenty of autoplaylists to which I'm listening most of the time (like new songs, top songs, songs never played,etc..) and if I want to listen to some specific tunes, quicksearch is my best friend.
Very very impressive job Falstaff! I miss info and statistics though :/
I will stick with Ibiza so I hope you won't stop updating it
The Library Playback Statistics in Curacao is awesome.
Hi there, newbie here but not so new to foobar. After using Ibiza for a while I'm very excited about Curaçao. I got it set up the way I like it except for one thing.
I'm on a 24" wide screen monitor at 1920x1200. At that resolution the album cover seems too small. So I decided to change it from 310x310 to 500x500. Except I run into problems with the album info and rating. I can't seem to find it in the splitter settings how to change the position. Any help is very much apreciated.
310x310 original:
(http://img83.imageshack.us/img83/4073/foobarcuracao1cg2.th.jpg) (http://img83.imageshack.us/my.php?image=foobarcuracao1cg2.jpg)(http://img83.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
500x500 changed:
(http://img82.imageshack.us/img82/8717/foobarcuracao2mw7.th.jpg) (http://img82.imageshack.us/my.php?image=foobarcuracao2mw7.jpg)(http://img82.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
[a href="http://img401.imageshack.us/my.php?image=curacaoko4.jpg" target="_blank"]
i can't make everybody please, it's before a config for my needs .. after a config for sharing
Good news, i have optimized the ELPlaylist scrolling, very faster and smoother in next release (will be 1.1)
thanx for this constructive mind
but i'll not change my config, i like it like this, it fit perfectly my needs and tastes
Regards
310x310 original:
[a href="http://img83.imageshack.us/my.php?image=foobarcuracao1cg2.jpg" target="_blank"]
the only way i see
Thank you very much Falstaff
thanx
Just to say tanks, great config, good work.
(http://www.hdd.pt//thumbs/1113877884.jpg) (http://www.hdd.pt/imagens/1113877884.jpg)
one hug from Portugal
Unbelievable...every time i look inside Br3tt's code i see even more genious management of variables etc...very smart way of thinking because this way its easier to mod it too! With 2 very simple changes i managed to put a big album list instead of the second "artist list"...great!
can you post a screenshot? I was going to ask if there was anyone who could add the album list panel because graphical browser seems to not like something on my AMD Phenom Quad Core, ATI Radeon 3800HD Series system and Falstaff says its nothing he can do and that plugin isn't maintained anymore which sucks. The only way I see to deal with albums is the little alphabet deal at the top and thats my problem if you see screenshots I have posted in earlier posts. Anyway I guess my only option is the album list panel but I know ZERO about messing with codes and stuff LOL.
Should I understand it like you do not want to acknowledge even the most obvious blunders? Like "centering" the graphical cover browser panel on the rightmost album, forcing the user to scroll each time he or she wants to see the next one (it's almost like a table of contents in an e-book, where you click on a chapter link but get it starting at the bottom of the page, not on top, forcing you to scroll down to read everything beyond its title). These are not regular whinings like "I want this or that eye-candy added", these are objective defects.
It's more than OK to see your errors, man. That would help make a true developer of you. Learn on your errors and think about other people. That's what makes Apple interfaces outstanding.
Sorry to (possibly) sound paternalizing.
lol I'm impressed with my hyperskills, I've managed to combine curacao and ibiza and now I''m having difficult times choosing what config to use
Looks not as shiny as I'd like to, but I'm glad anyway
[a href="http://funkyimg.com/viewer.php?img=/2/463/103/curacao.jpg" target="_blank"]
"centering" the graphical cover browser panel on the rightmost album => not way to do this, so before saying i don't want, learn about how components works
"objective defects" ==> they are only for some people, like i said, i do not have tsame tastes as yours, and to reply to this : "Learn on your errors and think about other people" if you were here more often, you should know that i often take remarks and optimization in consideration and help as often i can.
"It's more than OK to see your errors, man. That would help make a true developer of you" ==> same as above, i code since i'm twelve and coding is my job for many years now ..., so i know what an error is when i make one, and i fix it ... when possible of course (cf. first point about "centering" ...)
Regards,
PS : if you known me better (as Mr Pacaman for example), you should know that to make please some user, i'll surely add this Album list panel in time ... but not the priority for this week.
Very nice.
Great config, thanks for sharing it with us
Falstaff,
All right, I was wrong to suggest the "centering" issue was your blunder, I take my words back. Still the issue of redundant information in this layout remains.
Rest assured, it's not your coding skills that I question, but your commitment to usability (which is not about satisfying a particular user by adding a certain feature). Usability is objective (and you may have noticed that I've given you logical basis for my ctiticism, which does not get disproved simply by someone saying it "looks" OK for him). Patterns of info significance distribution for left to right readers is objective. Text vs. graphics significance is objective. Object size recognizability dependance is objective (though, of course, somewhat variable).
P.S. And remeber - the difference between a coder and a developer lies in whether one codes primarily for oneself only (and is satisfied by simply "I like it like this") or for the others (and thus binds oneself by far higher standards). Keep up the good work and don't get descouraged by my criticism!
Hi Elenhil,
I'm by job some kind of proffesional critic of critics. So you are pointing out some constructive critics about usability, but your critic lacks itself of usability. I'm not a coder nor a developper not have interest in knowing if what you are saying could be right or not, but the way you present it is quite inoperant. Some suggestions:
1 - try to correct by yourself the layout and show it, "would not it be better this way, friend?"
2 - If you don't know how to code or develop, try to ask: "hey friend, how can I get the things this way"?
3 - If -and only if- you don't receive an answer with these approachs, you can start to think about making assumptions about the philosophy of the coder.
4 - If you have some hints on philosophy about coding and developing, you'll be able to expose them and be heard positively after some positive interaction. Say, "oh, thanks for your answer, now I understand. I'm tired of developers that don't hear people... etc etc".
Quite paternalizing but older enough,
Rozzo
Ps. Thanks Falstaff, Curaçao works fine here and i like it a lot.
Falstaff,
elenhil, there really are better ways to get what you want in life, you need to learn a little psychology...
But I think it's important to understand the underlying motivation here, Falstaff designs configs for HIMSELF that he then graciously shares with us, he's not begging anyone to use them or looking for approval. To repeat what I said yesterday, one size can never fit all, and with the 3 configs that Falstaff has done I'm pretty sure that at least ONE of them must be close enough for you to either use as-is or modify to your own requirements. And if you do not like it as it is but you do not have the ability to modify it yourself then you can hardly blame Falstaff for that, can you? He does take constructive criticism and suggestions on board and many ideas do make it into later builds, but that doesn't mean he's going to make lots of basic changes just because one user thinks that it isn't working exactly as he'd like it to
It might be a good time for you to learn some titleformatting
Br3tt, there's a little mistake with ratings. The captions are not right (1 star - megahit, 5 stars - average, etc)
Chill out guys! There is no need to put posts like "you should do this or that...". Br3tt gives us so many great configurations and his coding is brilliant because if you take a look you will find a way to mod it easily..
Personally I pointed here some "lacks" but it was basically for telling my opinion. I found the way to "patch" the config like i want it, in about an hour...(ok you must know some basic things about Foobar configs and programming, but its never too late to learn and its easy if you are observant)
Here is a dirty and quick way of replacing a graphical browser (artist list) with album list panel until Br3tt make his update... (sorry if i make a mistake, i did it quickly and it worked, so i don't care if its 100% right) Don't forget to put the album list panel in your components folder first!
Step 1:
(http://img149.imageshack.us/img149/9400/78282513ny7.th.jpg) (http://img149.imageshack.us/my.php?image=78282513ny7.jpg)(http://img149.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
Step 2:
(http://img99.imageshack.us/img99/7238/37979954zp9.th.jpg) (http://img99.imageshack.us/my.php?image=37979954zp9.jpg)(http://img99.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
Thank you Brett for next gorgeous config !!!
Unfortunately, I couldn`t find so useful Filter panel in Curacao as in Kung-foo one (imho), like sorting by genre,artist,album and album list panel of cource
so, I use Kung-foo further, cuz it`s devilishly well done for me
but, Curacao... it has very nice look..
just would to know, are you planning to add something like this for Curacao or not ? (I meant filter panel)
Thank you.
For me, IBIZA II with a Curacao look and feel would be ideal
Hey, thats great Pacman!! I mentioned earlier that playlist switcher was too small for me. Now Ive just changed the height for the _PLAYLISTS panel like Pacman did with _PLAYLISTS2 and it works just the way I had in mind
Thanks for criticism of my criticism, guys!
I would have been glad to make a mod of this configuration implementing all of my suggestions (I do know titleformatting just enough not to be that helpless!), but I'll have to stick to my customized KUNG-FOO (for which I am grateful to Falstaff, no doubts) for obvious reasons: this layout is thoroughly designed to work the other way!
It's easy to replace Artist list with Albums list and the main playlist with one from Ibiza, KUNG-FOO or any other or custom playlist viewer layout. But that would inevitably break the alphabetic index and the graphical cover/artist browser, because, as I see it, the whole concept of Curacao's navigation is just a way of overcoming Graphical Browser's shortcomings: it is not a true media library viewer, it is a playlist panel. It cannot pass media library queries and generate playlists itself. Hence the whole library-in-an-autoplaylist concept, right, Falstaff? And neither can Album list panel (or any other media library viewer) act as a contents index of a playlist, it can only create or modify one. That's why Falstaff has used another Graphical Browser panel with its focus/follow functionality as an Artist list.
So there is no sense in taking my suggestion directly to this layout, as it would break the rest of the navigation. I have now realized that sinсe by nature this layout can take none of my suggestions, my criticism could not have been constructive
P.S. Hope no offence is taken, anyway!
P.P.S. Now, on second thoughts, one could replace GB-powered cover browser panel with a media library query capable panel like Chronflow or the alternative one (forgot its name). But that would still not be useful without dramatically increasing its size. Which in turn would make it too large to be integrated into the bottom panel (or, enlarging the panel itself, would make it occupy too much space in the window). Not to mention that it would not substitute the Artist GB panel. No, enlarging the cover browser one would have to make it a separate hidden panel. In short, as I've said, the way I see it implementing my suggestions would take a total remake of this layout.
oops, possible i will fix that in next release (v1.1)
thanx
@falstaff
Very, very, very nice work!
I was really surprised that i could load your config on my very old machine (ibiza doesn't load on it, caused by the buggy chronflow, which doesn't do it on my pc).
You know, i'm new in configuring foobar, but I'm in to work on my own config.
So i ask you, if it is allowed to use your EL Playlist configuration as "sample" (it is great for learning about using EL Playlist) for doing my own work in my config?
(I love your blinking play-arrow , although i don't need it in my config)
And in your ibiza config, there is a play.png (74*74).
May i use it too for my own config?
So there is no sense in taking my suggestion directly to this layout, as it would break the rest of the navigation. I have now realized that sin?e by nature this layout can take none of my suggestions, my criticism could not have been constructive
"That's why Falstaff has used another Graphical Browser panel with its focus/follow functionality as an Artist list." Do i tell you this?
"Hence the whole library-in-an-autoplaylist concept, right, Falstaff?" Maybe i don't understand and sorry about that, but why do you think i suggest this as a concept ? it's just a suggestion, and for your information (sic) it's only to explain to newbies how to use auto-playlists in foobar in the quick installation notes file ...
You have to know that there are other ways to generate playlists from the LIBRARY, and i use them a lot, i never (rarely) use Album list panel :
- the quicksearch toolbar
- the Search function in Library menu (queries)
PS : You can make suggestions, give your mind about the config, critics about it, panels that you want be added in it ... but please, don't tell us how we have to use foobar, because this way is offence . Thanx by advance.
Regards
@falstaff
of course
@falstaff
Thank you
for those who can't live without album list, Curaçao has not removed it :
(http://xs433.xs.to/xs433/08482/albumlist365.png)
I like Mr. Pacmans way better Falstaff LOL, looks like it was original in a way. Album List is the only way for me to use this theme easily since you say graphic browser doesn't work with my system...well it does but only after I have to click one of the 3 different view buttons on left side. Thanks
So, it was
not the intended way of navigation for Curacao?!
Well, I seriously could not suspect anyone of creating a layout where you cannot load an album using mouse only! Which it is, if you don't load the whole library into an auto-playlist first and are thus forced to use only quicksearch or library search! The strangest idea, I should say.
Please, elenhil, give it a rest.
I believe everyone has a clear picture of your opinion.
terry
Just because some people seem not to realize this:
The album list is ALWAYS available from the Library menu, whether it's in any given Columns UI config as a panel or not.
Well, in playback menu you can find all the playback functions too, but i believe that there is a reason we want them as buttons...
Curaçao v1.1a released on http://br3tt.online.fr/ (http://br3tt.online.fr/)
ChangeLog
- ELPlaylist layout optimized (30% faster than v1.0a version !! smooth scrolling)
- New code for volume button (more realistic, thanx to T.P. Wang on H.A.)
- Better background image support
- Added play_counter info in playlist (end of the title track)
- New group header in playlist
- Tweaks
This is a very nice build, love the new header
thanks for the update:) playlist is quicker now, nice looking header
Thank you sooo much!!!
Thank you, The new header is indeed awesome.
this's great,I love you to br3tt!
(http://xs433.xs.to/xs433/08482/2008-11-26_104846876.jpg.xs.jpg) (http://xs.to/xs.php?h=xs433&d=08482&f=2008-11-26_104846876.jpg)
1.1 is more ugly than 1.1
information of album is cumbersome
Thank you very much for the new version! The best thing is, my library playlist used to take 4 secs to open, now its down to 1 sec! I also love the playcount in playlists and the new size of the top right panels!
I played around a bit with those panels and tried some new configurations containing queue manager and ibiza track info.
(http://img81.imageshack.us/img81/7343/curacaopanelszf0.th.jpg) (http://img81.imageshack.us/my.php?image=curacaopanelszf0.jpg)
Hey, how can we reset the playcounter?
how come this happening to me everytime i start foobar .... where the A,B,C,D etc should be ther's just a white box ? .. any ideas .... it worked just fine with the previous version of Curaçao
(http://img204.imageshack.us/img204/5355/97076998nf6.th.jpg) (http://img204.imageshack.us/my.php?image=97076998nf6.jpg)
Right click on track -> Properties-> Tab MetaDate -> edit Tag <PLAY_COUNTER>
Does anyone know the name of Milkdrop 's preset which is used in this image?
(http://xs233.xs.to/xs233/08482/preview_1.1a693.png)
Falstaff,
This is your best layout yet! Thank you very much.
There are two things that are problematic. I see that one has been brought up before. When using the letters along the top to move within the playlist, the "T" button goes to the first "T" in the 'album artist', which for me is "The All-American Rejects". The problem is this artist is actually in the "A" section. I still can't figure out where this needs to be changed. I have tried all sorts of things within the settings.
The second thing deals with the playback stats and lyrics. It would be good to make a note for all that these are being automatically added as tags to the actual track. This is something that I personally do not want to have done, rather I would have them stored in the custom database (for playback) or files (for lyrics). I know those changes can be made by me, but with everything from the downloads those options were set for automatic tagging. Just wanted to point it out.
Thanks again...love the config! Beautiful work.
Hi Falstaff,
is there some way of hiding the playlist, so that one gets only the album art/track info/lyrics on the left panel, and only the background albumart on the right side panel? I think it would be fine, some playlist show/hide command, to have a more graphical/less graphical interface.
Ys
Rozzo
Hi Falstaff,
Ys
Rozzo
Look at the top right corner of now playing panel...there is a button with a magnifier symbol...press it!
[/quote]
[/quote]
Woow, yes, that's the thing!!! Thansk!!!
Ys
Rozzo
Falstaff
when trying to load the 'curacao_1.1a.fcl' file I get this message:
'Need newer foo_ui_columns'.
Weird because I use the version from your website.
hah I've just wanted to ask the same question
i would tell you if only i known how to see the name of the active vis ?!
anybody knows (special key to display its name ?)
...i would tell you if only i known how to see the name of the active vis ?!
F1 gives you the full menu, F4 gives you the preset title
It's better if you double click the AVS panel to make Milkdrop run full screen
Geiss - Blur Mix 3 thanx for the tip Mike!
Geiss - Blur Mix 3
It's included in the 8,606 ( ) presets I posted a couple of pages back, or if you just want this one then create a text file called Geiss - Blur Mix 3.milk and dump this lot in it
MILKDROP_PRESET_VERSION=201
PSVERSION=2
PSVERSION_WARP=2
PSVERSION_COMP=2
[preset00]
fRating=2.000000
fGammaAdj=1.0
fDecay=1.0
fVideoEchoZoom=2.0
fVideoEchoAlpha=0.0
nVideoEchoOrientation=0
nWaveMode=6
bAdditiveWaves=0
bWaveDots=0
bWaveThick=0
bModWaveAlphaByVolume=0
bMaximizeWaveColor=1
bTexWrap=1
bDarkenCenter=0
bRedBlueStereo=0
bBrighten=0
bDarken=0
bSolarize=0
bInvert=0
fWaveAlpha=100.0
fWaveScale=3.266313
fWaveSmoothing=0.207000
fWaveParam=0.0
fModWaveAlphaStart=0.750000
fModWaveAlphaEnd=0.950000
fWarpAnimSpeed=1.0
fWarpScale=1.331000
fZoomExponent=1.0
fShader=0.0
zoom=0.999710
rot=0.0
cx=0.5
cy=0.5
dx=-0.005000
dy=0.0
warp=0.000001
sx=1.0
sy=1.0
wave_r=1.0
wave_g=0.999999
wave_b=1.0
wave_x=0.5
wave_y=0.5
ob_size=0.010000
ob_r=0.0
ob_g=0.0
ob_b=0.0
ob_a=0.0
ib_size=0.010000
ib_r=0.25
ib_g=0.25
ib_b=0.25
ib_a=0.0
nMotionVectorsX=64.0
nMotionVectorsY=48.0
mv_dx=0.0
mv_dy=0.0
mv_l=0.0
mv_r=0.350000
mv_g=0.350000
mv_b=0.350000
mv_a=0.0
b1n=0.0
b2n=0.0
b3n=0.0
b1x=1.0
b2x=1.0
b3x=1.0
b1ed=0.25
wavecode_0_enabled=0
wavecode_0_samples=512
wavecode_0_sep=0
wavecode_0_bSpectrum=0
wavecode_0_bUseDots=0
wavecode_0_bDrawThick=0
wavecode_0_bAdditive=0
wavecode_0_scaling=1.0
wavecode_0_smoothing=0.5
wavecode_0_r=1.0
wavecode_0_g=1.0
wavecode_0_b=1.0
wavecode_0_a=1.0
wavecode_1_enabled=0
wavecode_1_samples=512
wavecode_1_sep=0
wavecode_1_bSpectrum=0
wavecode_1_bUseDots=0
wavecode_1_bDrawThick=0
wavecode_1_bAdditive=0
wavecode_1_scaling=1.0
wavecode_1_smoothing=0.5
wavecode_1_r=1.0
wavecode_1_g=1.0
wavecode_1_b=1.0
wavecode_1_a=1.0
wavecode_2_enabled=0
wavecode_2_samples=512
wavecode_2_sep=0
wavecode_2_bSpectrum=0
wavecode_2_bUseDots=0
wavecode_2_bDrawThick=0
wavecode_2_bAdditive=0
wavecode_2_scaling=1.0
wavecode_2_smoothing=0.5
wavecode_2_r=1.0
wavecode_2_g=1.0
wavecode_2_b=1.0
wavecode_2_a=1.0
wavecode_3_enabled=0
wavecode_3_samples=512
wavecode_3_sep=0
wavecode_3_bSpectrum=0
wavecode_3_bUseDots=0
wavecode_3_bDrawThick=0
wavecode_3_bAdditive=0
wavecode_3_scaling=1.0
wavecode_3_smoothing=0.5
wavecode_3_r=1.0
wavecode_3_g=1.0
wavecode_3_b=1.0
wavecode_3_a=1.0
shapecode_0_enabled=0
shapecode_0_sides=4
shapecode_0_additive=0
shapecode_0_thickOutline=0
shapecode_0_textured=0
shapecode_0_x=0.5
shapecode_0_y=0.5
shapecode_0_rad=0.1
shapecode_0_ang=0.0
shapecode_0_tex_ang=0.0
shapecode_0_tex_zoom=1.0
shapecode_0_r=1.0
shapecode_0_g=0.0
shapecode_0_b=0.0
shapecode_0_a=1.0
shapecode_0_r2=0.0
shapecode_0_g2=1.0
shapecode_0_b2=0.0
shapecode_0_a2=0.0
shapecode_0_border_r=1.0
shapecode_0_border_g=1.0
shapecode_0_border_b=1.0
shapecode_0_border_a=0.1
shapecode_1_enabled=0
shapecode_1_sides=4
shapecode_1_additive=0
shapecode_1_thickOutline=0
shapecode_1_textured=0
shapecode_1_x=0.5
shapecode_1_y=0.5
shapecode_1_rad=0.1
shapecode_1_ang=0.0
shapecode_1_tex_ang=0.0
shapecode_1_tex_zoom=1.0
shapecode_1_r=1.0
shapecode_1_g=0.0
shapecode_1_b=0.0
shapecode_1_a=1.0
shapecode_1_r2=0.0
shapecode_1_g2=1.0
shapecode_1_b2=0.0
shapecode_1_a2=0.0
shapecode_1_border_r=1.0
shapecode_1_border_g=1.0
shapecode_1_border_b=1.0
shapecode_1_border_a=0.1
shapecode_2_enabled=0
shapecode_2_sides=4
shapecode_2_additive=0
shapecode_2_thickOutline=0
shapecode_2_textured=0
shapecode_2_x=0.5
shapecode_2_y=0.5
shapecode_2_rad=0.1
shapecode_2_ang=0.0
shapecode_2_tex_ang=0.0
shapecode_2_tex_zoom=1.0
shapecode_2_r=1.0
shapecode_2_g=0.0
shapecode_2_b=0.0
shapecode_2_a=1.0
shapecode_2_r2=0.0
shapecode_2_g2=1.0
shapecode_2_b2=0.0
shapecode_2_a2=0.0
shapecode_2_border_r=1.0
shapecode_2_border_g=1.0
shapecode_2_border_b=1.0
shapecode_2_border_a=0.1
shapecode_3_enabled=0
shapecode_3_sides=4
shapecode_3_additive=0
shapecode_3_thickOutline=0
shapecode_3_textured=0
shapecode_3_x=0.5
shapecode_3_y=0.5
shapecode_3_rad=0.1
shapecode_3_ang=0.0
shapecode_3_tex_ang=0.0
shapecode_3_tex_zoom=1.0
shapecode_3_r=1.0
shapecode_3_g=0.0
shapecode_3_b=0.0
shapecode_3_a=1.0
shapecode_3_r2=0.0
shapecode_3_g2=1.0
shapecode_3_b2=0.0
shapecode_3_a2=0.0
shapecode_3_border_r=1.0
shapecode_3_border_g=1.0
shapecode_3_border_b=1.0
shapecode_3_border_a=0.1
per_frame_1=wave_r = wave_r + 0.350*( 0.60*sin(0.980*time) + 0.40*sin(1.047*time) );
per_frame_2=wave_g = wave_g + 0.350*( 0.60*sin(0.835*time) + 0.40*sin(1.081*time) );
per_frame_3=wave_b = wave_b + 0.350*( 0.60*sin(0.814*time) + 0.40*sin(1.011*time) );
per_frame_4=cx = cx + 0.110*( 0.60*sin(0.374*time) + 0.40*sin(0.294*time) );
per_frame_5=cy = cy + 0.110*( 0.60*sin(0.393*time) + 0.40*sin(0.223*time) );
per_frame_6=decay = decay - 0.01*equal(frame%20,0);
per_frame_7=//zoom = 1;
per_frame_8=//warp = 0;
warp_1=`shader_body
warp_2=`{
warp_3=` // sample previous frame
warp_4=` ret = tex2D( sampler_main, uv ).xyz;
warp_5=` ret += tex2D(sampler_blur2, uv).xyz*0.1;
warp_6=` ret /= 1.1;
warp_7=`
warp_8=` // darken over time
warp_9=` ret -= 0.02;//*= 0.95; //or try: ret -= 0.004;
warp_10=`}
comp_1=`shader_body
comp_2=`{
comp_3=` ret = tex2D(sampler_main, uv).xyz*1 +
comp_4=` GetBlur1(uv)*3 +
comp_5=` GetBlur2(uv)*0 +
comp_6=` GetBlur3(uv)*0 +
comp_7=` 0;
comp_8=` ret += GetBlur2( (uv-0.5)*0.333 + 0.5);
comp_9=` ret *= 1;
comp_10=`}
Need help, i download your plugin and follow every step you say on install notes and it isn't look like you have on your pictures
(http://i35.tinypic.com/2432tlh.png)
This is the near i get...not so far but there are missed stuff and i still having the original menu
To get rid of the original menu click on VIEW then untick SHOW STATUS BAR and SHOW TOOLBARS
...img...
follow every step .. really ?
extract for installation notes, first point :
1) Firstly install foobar2000 to its default location of C:\Program Files\foobar2000\
If you already have Foobar installed to any other location other than this then Curaçao WILL NOT WORK
maybe you have not take care about this important point ?
It works now really thanks... my mistake
between, very nice skins you have here!!
don't forget to install needed fonts !!
[quote name='Rozzo' date='Nov 26 2008, 09:42' post='601424']
[/quote]
[/quote]
Ys
Rozzo
[/quote]
Maybe I'm missing something, I see two magnifying glass buttons, one on the lyrics panel and one on the album art. Which panel is the now playing? Thanks!
Thanks London Mike and Falstaff. Curacao config is really great with Milkdrop!
With F8 we can edit plugin path and choice preset which is used in Milkdrop.
So bad!
I have 2 problems:
(http://img117.imageshack.us/img117/4199/91134900il9.jpg)
When I add them to my Library, I can't see: FATE OF NORNS, THE CRUSER, ONCE SENT FROM THE GOLDEN HALL in my library :| File type is mp3.
Some albums don't show in playlist and library...
(http://img241.imageshack.us/img241/4342/43844777uo4.jpg)
Another, when I start Milkdrop 2.0e, i have a message:
The plugin crashed during initialization.It's included in the 8,606 ( ) presets I posted a couple of pages back, or if you just want this one then create a text file called Geiss - Blur Mix 3.milk and dump this lot in it
It's don't show in presets list!
Ys
Rozzo
The upper one (album art) is the now playing panel...Just press the buttons and see what they do...they don't bite...
I have a couple of problems which I've been trying to resolve on my own. Without any luck.
The background image is the cover of the album currently playing.
I have my artist images in "../%artist%/%artist%.jpg"
ie. D:\Musikk\Saturnus\Saturnus.jpg
The blue button above the volume control restarts Foobar or something.
Shpeck only finds AVS, while my other (now uninstalled of course) foobar found everying (Milkdrop etc).
Any tips?
Any tips?
i explain with a video where to change artist and cover paths on my website http://br3tt.online.fr (http://br3tt.online.fr)
the blue button restart foobar, it do what it is designed for
right click on previous/next buttons around the shpeck panel give you a context menu to select which vis to start at foobar launch, just tick Milkdrop instead of AVS
I've watched that video, and I know where to change it. But I don't know what to change it to =p
Oh, I thought I saw that that was the preferences button or something, in an overview picture. Nvm then^^
And about Shpeck: It doesn't show up anything else but AVS in the preferences.
Thanks for the fast reply.
just copy nscrt.dll from winamp dir to foobar dir
Hi Falstaff!
Thanks for the cool improvements in the new version. It gets better and better...
In case you haven't ignored my idea on purpose but just have missed it..
I second that.
Falstaff, tell us please - how to edit your scripts to allow Curaçao read the artist background image directly from artist folder?
Thanks in advance for the answer.
(http://img518.imageshack.us/img518/9012/00111lj5.png)
Hi Falstaff!
"c) Did you take a look at the "mouseover"-function of ELplaylist? Would be very cool if you implemented it somehow, i.e. when you move the mouse over the group header, there could be some additional info with a picture of the artist or whatever.."
that makes me laugh, sorry
and you ??? you should because popup is coded for curacao, you just have to active it in ELPlyalist settings (mouse over) ... did you took a look at this ?
"d) Any chance to make the uppermost line with the "breadcrumb" now playing track a little bit more interactive? Thought it would be cool to use the seperate entries as a filter for example. When you click on the artist name all songs by that artist are listed in a new playlist."
could be done, why not, i think this is a good idea ... i'll see
b) foo_path. Is there no way to put that as one global variable somewhere/somehow /in an ini-file or whatever). It's a little bit tough to find all instances of the variable definition... "
an external plugin (component) is needed for handling global variables (or constants), foo_exvar can do the job, i'll see to implement this for further versions
I second that. Falstaff, tell us please - how to edit your scripts to allow Curaçao read the artist background image directly from artist folder?
read again first post :
ColumnsUI Config using Panel Stack Splitter gives Foobar2000 a kick ass look, but these configs are not recommended for newbies to Foobar2000, DefaultUI is a better choice if you don't know how to configure a component and if you don't know a little bit about titleformatting script used in Foobar
--- use at your own risk and matching your foobar capacities ---
so, i think i have given all that you need to use Curacao, excuse me but i'm not here to explain what is a path or what are the globals variables used in foobar, but as i am pleased today, here is the path to use for replacing the artist.path variable declaration
in the 4 places that my video tutorial indicate, for the
artist.path variable, just replace my default
path :
'Z:/_artists_/'%artist%'.jpg'
by :
Thank you, Falstaff and Onkel Andy!
I've changed the operators for artist.path to
$puts(artist.path,$replace($replace(%path%,$directory(%path%),),%filename_ext%,artist.jpg))
and now the artist photo shows correctly.
All fixed. Everything working. Thanks alot for the help.
Best config in ages!
Hi Br3tt..
I love your config..
It's great..
But I have a little problem..
Can I change the font in Playlist Switcher?? Current font can't show Korean artists name, so It confused me..
Thats pretty easy....
Preferences->ColumnUI Colours and Fonts->Fonts tab->Choose playlist switcher from drop-down and be happy!
For anyone that has an issue with the letter filter not going to the right spot when you click a letter (usually "T" is the worst), I was able to finally get it to work.
There are four spots with "%album artist%" that need to be changed to the same way you sort your artists. I use the following for sorting my artists:
$if($strcmp($left(%album artist%,4),The ),$right(%album artist%,$sub($len(%album artist%),4))', 'The,%album artist%)
Right click anywhere on the set of letters, and select "Settings". In the first field "Group" you will need to replace both instances of "%album artist%"
In the "Draw" section, you will also need to replace the "%album artist%" in the "$puts(ch..." and "$puts(my.char..." sections. One for each.
Thank you, that worked perfectly
Br3tt, could this go into the code permanently???
You need to replace the SORT and GROUP instances too in EL Playlist to get the same result when typing letters to search 'T' artist names
Glad I could help.
Oh, and don't forget that if you use the sort string I do, then you will also want to put it in the library sort order, as well as the "Sort" section of the Album Art viewer in the lower section.
Yip, and in the artist list drop down boxes too
Great config, everything works. But still two Questions: No problems with the images folder but the volume - circle is just not shwoing up, the "above-layer" ist missing.
Second quastion: Where to switch the font-size of the playlist switscher? Its just too small for my eyes...
Preferences -> Display -> ColumnsUI -> ... you should find it
--Ypreferences...vertical item padding? nothing happens.
Sry if im blind but i already looked in all these registers.
Think it is hidden somewhere in these CUI-settings?
@Generalverdacht
columns UI/Colours and fonts- element - choose playlist switcher - and press change
Thank you!!!
@Generalverdacht
Thanks! I was looking for that also.
I've updated foobar to the latest version (0.9.6 beta 5) some plugins don't work with it - fine. But the volume and seek bars have disappeared :/ Why? I mean powerpanels are not compatible but how you all manage to use it then?
i do not use powerpanels, they are WSH panels. beta 5 not tested yet, always under beta 4
I'm using Beta 5 with no problems, all plugins working fine
I'm having ZERO problems as well, with fb2k beta 5," foobar2000 v0.9.6beta5
You're right guys, I've checked my 1.1 and default 1.0 and there's no WSH volume and no WSH seekbar panels, could it happen because of my deletion of wsh_panels for a couple of foobar launches?
Br3tt, is it possible to copy&paste these two panels from default 1.0 or 1.1? I don't want to lose all my settings and tweaks I tried copying and pasting panels from the layout menu but then the whole setup messes up
update: solved, but tips appreciated
It's a great config UI but it doesn't quite fit well with my library of 900+ albums. Scrolling through a long list just to playback an album is very painful.
IF only I can configure it to view just a full list of the album. When I double click / single click on an album, then only will the tracklist/playlist for that album will be displayed. Kinda like in IBIZA config.
Eg:
1) I click 'D' on the list 'A-Z'.
2) Display all albums sorted alphabetically and starts with 'D'.
3) I double click on a particular album - Dancemania SPEED SFX.
4) Display the tracklist for the album.
*That way I can save time scrolling through a long list of items. Better yet there is a small album art beside all album name.
http://www.hydrogenaudio.org/forums/index....showtopic=64035 (http://www.hydrogenaudio.org/forums/index.php?showtopic=64035)
So use the letters at the top, or type them into EL Playlist, or select it from the Artist List, or collapse all the groups in EL Playlist, or use the scroll bar...
That's the beauty of Br3tt's configs, there are always several ways to do the same thing and the hardest thing is just getting used to how it all works and what the fastest way is to use the config for you. I have over 600 albums and it works fine for me
That's why someone invented the search function...
About the collapse-group/double-click stuff: Go to ELPlaylist Setting, Behaviour tab and play around a bit.
Thanks for the info but currently the letters at the top is sort by artist. How can I config it to list by album title?
Are you going to add foo_uie_albumlist support?
Thats the onliest thing I miss in your great config!
It shouldn't be that hard...you should be able to make the changes yourself, provided you know how the components work and the coding is set up.
I tried to config:
$puts(ch,$lower($left(
%album artist%,1)))
$puts(my.char,$puts(ch,$lower($left(
%album artist%,1)))$if($stricmp($get(ch),'a'),'a',...........
to
%album%,1)))
%album%,1)))$if($stricmp($get(ch),'a'),'a',...........
but the letter change to 'a' instead of following the album title.
I tried to config:
$puts(ch,$lower($left(%album artist%,1)))
$puts(my.char,$puts(ch,$lower($left(%album artist%,1)))$if($stricmp($get(ch),'a'),'a',...........
to
$puts(ch,$lower($left(%album%,1)))
$puts(my.char,$puts(ch,$lower($left(%album%,1)))$if($stricmp($get(ch),'a'),'a',...........
You need to change the %album artist% in the "Group" section too. There will be two of them. Then, you would probably want to change your sort order in the playlist, as well as the album art viewer at the bottom.
Forgive me, I am very new to foobar, I love this layout, one thing I'm having an issue with, I can't seem to get any type of background going. Mine is just plain black, all else looks good.
I looked at the tutorial about the paths for .jpg's, I use foobar to listen to online streaming music so the folder, artist, etc. .jpg doesn't work for me, also I looked at the static background tutorial, but either way I just get a black background, how can I get an image back there?
Also I changed the google path for large wallpapers, is there a way to get foobar to pull an image and throw it up as the background based on the artist playing?
if not, just any image will do.
thanks in advance!
also, I noticed the large panel on the left will show the artist and song from a shoutcast stream, but the playlist (i think) on the right shows a ? so when I right click run service > google, it googles ? instead of the artist name
thoughts?
all works fine when I play a mp3 located on my hard drive fyi
Another problem - Curaçao v1.1a (foobar v0.9.6 beta 5) is frequently crashing on startup when trying to load foo_uie_lyrics.dll.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00F69BF9h
Access violation, operation: read, address: 01056000h
Call path:
entry
Code bytes (00F69BF9h):
00F69BB9h: C7 8D 73 1C 8D 50 02 66 8B 08 83 C0 02 66 85 C9
00F69BC9h: 75 F5 2B C2 D1 F8 50 8B C7 E8 D9 7A FF FF 8B 5B
00F69BD9h: 30 8D 3C 5F 33 C9 66 3B 0F 75 1A 8B 54 24 10 8B
00F69BE9h: 44 24 20 03 C2 8B FF 3B F8 73 0A 83 C7 02 33 C9
00F69BF9h: 66 3B 0F 74 F2 8B 54 24 14 8B 4A 0C 85 C9 75 04
00F69C09h: 33 C0 EB 08 8B 42 14 2B C1 C1 F8 03 8B 5A 10 8B
00F69C19h: D3 2B D1 C1 FA 03 3B D0 73 2E C6 44 24 1C 00 8B
00F69C29h: 44 24 1C 8B 4C 24 1C 50 51 8D 74 24 30 BA 01 00
Stack (0012F188h):
0012F168h: 00E3DCDC 7C9C76F0 77F643DD 7C9C76F0
0012F178h: 00000004 00000000 00E3D1E8 00000000
0012F188h: 0012F308 01055350 00000000 0012F308
0012F198h: 000001C8 00FB1458 01054538 0012F200
0012F1A8h: 01055E38 000001C8 01054538 01054608
0012F1B8h: 0049DC90 0012F218 00000004 0012F22C
0012F1C8h: 00F9F690 00000001 01055350 0012F238
0012F1D8h: 00F811D8 0012F204 000001CC 0012F328
0012F1E8h: 00000BFC 0238BE6D 0012F358 AA81D745
0012F1F8h: 43A64C62 6920FEAD 39481087 00FA7F54
0012F208h: 0012F308 00000000 00000000 00FB04CC
0012F218h: 000001CC 00000000 01054F20 013F8F20
0012F228h: 0012F1E8 0012F2DC 00F9F11A 00000001
0012F238h: 0012F2E8 00F8A70F 0012F308 0012F328
0012F248h: 0041A494 0012F308 0012F328 0012FD70
0012F258h: 004E72CC 00000281 00404E97 003F64A8
0012F268h: 00000000 00000000 00000001 FFFFFFFF
0012F278h: 0045D5C1 0012FD70 004E72CC 00000281
0012F288h: 00000279 00000279 00416749 425CAB40
0012F298h: 4E345F61 40CA0DA6 ADF62381 003FA601
Registers:
EAX: 01056000, EBX: 00000041, ECX: 00000000, EDX: 000001C8
ESI: 01054554, EDI: 01056000, EBP: 0012F1D4, ESP: 0012F188
Crash location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Loaded modules:
foobar2000 loaded at 00400000h - 00539000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F56000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D4000h
ole32 loaded at 774E0000h - 7761C000h
shared loaded at 10000000h - 1002A000h
UxTheme loaded at 5AD70000h - 5ADA8000h
COMDLG32 loaded at 763B0000h - 763F9000h
mzvkbd loaded at 6D710000h - 6D723000h
PSAPI loaded at 76BF0000h - 76BFB000h
mzvkbd3 loaded at 6D730000h - 6D743000h
MSCTF loaded at 74720000h - 7476B000h
foo_dsp_std loaded at 00AE0000h - 00B28000h
foo_lastfm_radio loaded at 00B50000h - 00B96000h
foo_skip loaded at 00BC0000h - 00BCC000h
MSVCR90 loaded at 78520000h - 785C3000h
foo_converter loaded at 00BF0000h - 00C5C000h
foo_albumlist loaded at 00C80000h - 00CEB000h
foo_uie_elplaylist loaded at 00D10000h - 00D77000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_run loaded at 00DB0000h - 00DDE000h
foo_input_std loaded at 00E00000h - 00F3C000h
foo_uie_lyrics loaded at 00F60000h - 00FBC000h
WINMM loaded at 76B40000h - 76B6D000h
WININET loaded at 771B0000h - 77256000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_uie_graphical_browser loaded at 01060000h - 010F4000h
MSIMG32 loaded at 76380000h - 76385000h
IMM32 loaded at 76390000h - 763AD000h
foo_ui_columns loaded at 01120000h - 01252000h
foo_unpack loaded at 01280000h - 012AD000h
foo_out_asio loaded at 012D0000h - 01307000h
foo_ui_std loaded at 01330000h - 01404000h
foo_freedb2 loaded at 01430000h - 01470000h
foo_uie_quicksearch loaded at 01490000h - 014D6000h
foo_input_monkey loaded at 01500000h - 01545000h
foo_uie_wsh_panel loaded at 01570000h - 0159F000h
foo_menu_addons loaded at 016E0000h - 0173D000h
libmmd loaded at 01750000h - 01A01000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_dts loaded at 01A30000h - 01B0B000h
foo_cdda loaded at 01B30000h - 01B71000h
foo_playback_custom loaded at 01BA0000h - 01BE5000h
WINSPOOL loaded at 73000000h - 73026000h
foo_uie_trackinfo_mod loaded at 01C30000h - 01C86000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
foo_rgscan loaded at 01CA0000h - 01CFB000h
foo_fileops loaded at 01D20000h - 01D66000h
foo_ac3 loaded at 01D90000h - 01DBF000h
foo_vis_shpeck-0.3.0-beta-2 loaded at 01DE0000h - 01E2D000h
foo_uie_panel_splitter loaded at 01E50000h - 01E9F000h
foo_abx loaded at 01EC0000h - 01EF1000h
foo_uie_vis_channel_spectrum loaded at 01F20000h - 01F5D000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
VERSION loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 00FB1458h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 0049DC90h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00F9F690h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 00F811D8h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 00FA7F54h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 00FB04CCh, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 013F8F20h, location: "foo_ui_std", loaded at 01330000h - 01404000h
Address: 00F9F11Ah, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 00F8A70Fh, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 0041A494h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E72CCh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00404E97h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 0045D5C1h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00416749h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DC898h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E8CD4h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C6156h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00F60000h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 00FB01F4h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBC000h
Address: 004DC888h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DC360h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004179A2h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D8D5Fh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 01AB59B2h, location: "foo_dts", loaded at 01A30000h - 01B0B000h
Address: 01764ACEh, location: "libmmd", loaded at 01750000h - 01A01000h
Symbol: "_csqrtq_f90" (+00012192h)
Address: 01244385h, location: "foo_ui_columns", loaded at 01120000h - 01252000h
Address: 776058C0h, location: "ole32", loaded at 774E0000h - 7761C000h
Address: 00503200h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DD454h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00503220h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C8F30h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00439642h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E8CF0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 004B58F3h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AFF80h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004B3D48h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 1000258Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 004DF4B8h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CA13Bh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00439A52h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE141h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE13Bh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D0B64h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CEE50h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE14Fh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CA32Bh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AFB6Ah, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00E3D0B8h, location: "foo_input_std", loaded at 00E00000h - 00F3C000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004AFBD5h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 00539000h
Version info:
foobar2000 v0.9.6 beta 5
UNICODE
Windows 5.1
I've tried several versions of lyrics plugin, but to no avail. Any ideas?
Illegal operation:
Call path:
entry
Stack (0012F188h):
Registers:
Loaded modules:
Version info:
UNICODE
Windows 5.1
I have exactly the same problem and changing to earlier versions of foo_uie_lyrics does not help, but it seems to happen when I first change to a new build, if I am just using Curacao in a normal way it never happens. It's a very strange problem
how to do if i want the AVS panel to be shown directly when foobar is started ?
can't find it in the splitter settings .....
Once again, kickass config Br3tt. Can't wait to see what you come up with the next time
Splitter settings
Info setting, tick HIDE PANEL ON STARTUP
Shpeck setting, untick HIDE PANEL ON STARTUP
Splitter settings
thanks.... i didn't see that ... lol
Question:
How to make "Track info mod" not to show on startup ? (hide panel on startup in splitter settings doesn't work)
Okay - this is slightly off topic but still relevant and I'm completely stumped.
Does anyone know how to get these Vis working without installing Winamp? I don't have Winamp installed and have no desire to install it - which is the reason I use foobar in the first place.
I've downloaded London Mike's viz zip and that's as far as I can get without crashing foobar
Help.
Plz.
Ah, you have the wrong version of
er......
Something, I forget, but that version of Milkdrop needs the correct version of something or other...
Blast knows what I mean
You need the latest version of foo_vis_shpeck.dll which is 0.3.0 Beta 2 you will also need to rename the file to foo_vis_shpeck.dll as it's named something diffrent.
http://yirkha.fud.cz/progs/foobar2000/foo_....3.0-beta-2.dll (http://yirkha.fud.cz/progs/foobar2000/foo_vis_shpeck-0.3.0-beta-2.dll)
how do i change the milk drop preset to Geiss - Blur Mix 3? I have read through the thread, but i haven't been able to figure it out.
BACKSPACE: return to previous preset
SPACE: transition to next preset
H: instant Hard cut (to next preset)
R: toggle random (vs. sequential) preset traversal
L: load a specific preset (invokes the 'Load' menu)
+/-: rate current preset (better/worse)
scroll lock: lock/unlock current preset
(keyboard light on means preset is locked)
(prevents random switch to new preset)
A: aggregate preset - loads a random preset,
steals the warp shader from a different random preset,
and steals the composite shader from a third random preset.
D: cycle between various lock-states for the warp and
composite shaders. When one of these shaders is locked,
loading a new preset will load everything *except* the
locked shaders, creating a mix between the two presets.
So I can change the preset to something I want, but is it even possible with Milkdrop2 to make a preset the default? Every time I exit fb2k, when I run fb2k again, Milkdrop2 wants to go back to the same preset it originally started with, not the one I locked previously.
good question, short of removing all but the preset you want I'd like to know if that's possible too. I can lock it with scroll lock but upon restart its back to random.
thanks
Thanks for the great plugin and community support for this skin. Been replacing it with my previous custom theme
I do have a kinda question which I think I can't do it.
How can I resize the popup box size according to the content of the EL Playlist (Popup Track) of a certain song. It poses a problem as each song has various amount of details (id2tag). In other words, how to render the image that uses a dynamic height size? I'm not concerned about dynamic width as my computer width is kinda small.
Eg:
For a song that has a huge amount of details, I would like it to display as the following: (using dynamic height calculated by a certain formula)
|Album:
|Artist:
|Catalog:
Instead of the following (which uses elplaylist height which is fixed)
|Album:
|Artist:
|Catalog:
EL Playlist (Popup Background)// Background //
$puts(foo_path,%__FOO_PATH__%)
$puts(deb,1)
$puts(ind,5)
$puts(width,240)
$imageabs(0,0,%el_width%,%el_height%,$get(foo_path)'images/'%__CONFIG_NAME__%'/bg/popup.png',nokeepaspect,,250)
// $gradientrect(6,$add($get(deb),1),$sub($get(width),11),$add(4,$mul(20,$get(ind))), 030-030-030-220, 100-100-110-100, vertical)
// $fillroundrect(5,$get(deb),$sub($get(width),9),$add(6,$mul(20,$get(ind))),5,5,050-050-050-135,000-000-000-000,)
// $drawroundrect(6,$add($get(deb),1),$sub($get(width),12),$add(3,$mul(20,$get(ind))),3,3,000-000-000-000,225-225-225-080,)
// $gradientrect(6,$add($get(deb),11),$sub($get(width),11),$sub($add(2,$mul(20,$get(ind))),10), 000-000-000-000, 120-120-130-240, vertical)
// $drawrect(7,$add(4,$mul(20,$get(ind))),$sub($get(width),13),1,120-120-130-240,,)
// $drawrect(8,$add(5,$mul(20,$get(ind))),$sub($get(width),15),1,120-120-130-240,,)
// Cover //
$puts(art_path,%__PHOTO_PATH__%)
$puts(art_size,93)
//$imageabs($sub($get(width),$add($get(art_size),10)),8,$get(art_size),$get(art_size),$get(art_path),,)
EL Playlist (I add more custom details for the song)$setcoordinate(1)
//////Track Info/////
//$puts(head,$rgb(192,192,192))
$font(Arial,8,bold) $drawstring($get(head)%tracknumber% - %title%,12,$add(12,$mul(%el_item_index%,20)),$sub(%el_width%,6),%el_height%,255-255-255,nowrap elipchar)
$font(Arial,8,bold)
$ifequal(%el_item_count%,1,$drawstring($crlf()$get(head)Album: %album%$if(%genre%,$crlf()Genre: %genre%)$if(%publisher%,$crlf()Publisher: %publisher%)$if(%catalog%,$crlf()Catalog: %catalog%)$if(%released_date%,$crlf()Released Date: %released_date%)$crlf()$crlf()Bitrate: %bitrate% Kbit/s$crlf()Codec: %codec%$crlf()Compression: $get(info)$div(1411,%__bitrate%).$substr($muldiv(1411,100,%__bitrate%),2,3):1 '('$get(info)$muldiv(%__bitrate%,100,1411)$get(anno)'%)'$crlf()Channels: $get(info)$if($stricmp($codec(),MP3),$get(space2)$caps(%__mp3_stereo_mode%),$if(%__channels%,$ifgreater(%__channels%,1,Stereo,Mono),'?'))$if(%__samplerate%,$crlf()Samplerate: $get(info)$div(%__samplerate%,1000).$substr(%__samplerate%,3,3) KHz)$crlf()Filesize: $div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2) $get(anno)'MB'$crlf()$crlf()----------------------------------------------------------------------------------------------------------$crlf()$if(%artist%,$crlf()Artist: $crlf()%artist%$crlf())$if(%original artist%,$crlf()Original Artist: %original artist%)$if(%composer%,$crlf()Composer: $crlf()%composer%$crlf())$if(%band%,$crlf()Band: $crlf()%band%$crlf())$if(%conductor%,$crlf()Conductor: $crlf()%conductor%$crlf())$if(%arranger%,$crlf()Arranger: $crlf()%arranger%$crlf())$if(%vocal%,$crlf()Vocal: $crlf()%vocal%$crlf())$if(%writer%,$crlf()Lyricist: $crlf()%writer%$crlf())$if(%remixed by%,$crlf()Remix: $crlf()%remixed by%$crlf())$if(%engineer%,$crlf()Engineer: $crlf()%engineer%$crlf())$if(%encoded by%,$crlf()Encoder: $crlf()%encoded by%$crlf()),11,38,$sub(%el_width%,12),%el_height%,192-192-192,nowrap elipchar),)
* Some hints that I think need to be done:
1) Calculate and get the dynamic value for the height in Popup(Track). The value of the height is somewhat determined by the number of lines from the last info?
2) Get and used the dynamic value obtained on 1 and use it in Popup(Background) to render the image height.
I guess this question should be posted in the ELPlaylist thread and not here. Anyhow, there are two functions called $gettextwidth and $gettextheight. The problem is that the last one only checks the height of a single text line. But at least adapting the width of the popup would be easy (although u're not interested in that *g*)..
Example:
$puts(width,$add(40,$gettextwidth(%artist% - %album% - %tracknumber% - %title%,Arial,8,bold)))
I'm hoping to get some info on the height, too. But as the background is drawn before the track-info this will be tough stuff, I guess.
Okay - did this, renamed new dll and removed the old dll.
Now all I get is the option to select the "Winamp" as default or switch to custom location but seeing as it doesn't detect Winamp the option to select any folder is greyed out. Refresh list (regardless of what I put in the default folder) just draws a blank.
Based on the info from the shpeck page, you need to hold the SHIFT key while pressing the "..." button. This will allow you to type a custom path.
Can the author somehow add some features in this great skin?
An icon that will displayed next to the playcounter on ELPlaylist when there is [Lyric] tab embedded inside the song?
[img=http://img366.imageshack.us/img366/2249/screenhunter10dec011211oy4.th.jpg] (http://img366.imageshack.us/my.php?image=screenhunter10dec011211oy4.jpg)
Hello everyone
This seems to be a great job, but this config do not work on my foobar... Ibiza and Kung-Foo config work very well, but this one doesn't. When I launch the application, I have this error message :
Failed to load DLL: foo_menu_addons.dll
Reason: Cette application n'a pas pu démarrer car la configuration de l'application est incorrecte. Réinstaller l'application pourrait résoudre ce problème.
I've search on the internet, but did not find any clue...
Can someone help me ?
http://www.megaupload.com/?d=7PGIWXXY (http://www.megaupload.com/?d=7PGIWXXY)
that is version 0.4 SSE that I have. Authors website seems to be gone and looks like his account is banned.
why not
why not
Hopefully there'll be an update on it.
What should I configure so that whenever I click on a letter on the menu [A-Z] the playlist will only display album for that letter. I already changing %album artist% to %album% on the setting for the menu.
Currently what it did was when I click a letter, say M, the playlist will show the album starting with M at the center. Other non-M letter album is still displayed.
Second question:
How can I enable the sorting method (preset default) as default every time I click an album from the album panel list for ELPlaylist to sort by album title alphabetically (some album didn't sort by that way). Now I need to right click the option every time I choose an album group/genre. I already change the Group and Sort method of ELPlaylist to %album%.
Second question:
Go to the "Edit" menu of fb2k, and select "Sort", and then you can either use one of the main options, or use "Sort By" and create your own. Also, in fb2k's preferences you need to go to the "General" section and change the sort order there. Yes, it is a bit of a pain, but that should cover your problem.
I use this for sorting my library:
$if($strcmp($left(%album artist%,4),The ),$right(%album artist%,$sub($len(%album artist%),4))', 'The,%album artist%) - %album% - %codec% - $num(%tracknumber%,2)
Also, your playlist you are using is probably locked, which is why it will only highlight the letter of the alphabet you choose, rather than show only the letter you choose.
EDIT: Actually, even my unlocked playlist still just highlights, doesn't really filter. Hmmmm...
why not
It's a nice idea.. but that brings another idea to my mind: what about automatically switching the lyrics-panel between lyrics and let's say an info-panel with details about the songs or whatever based on the existence of a lyrics-tag.. ? Something like that could also be done for the artwork-panel.
Don't know if it's really that cool when the interface changes somehow but it may be a cool feature
Second question:
Thanks for the info. Changing the sort option to %album% in General tab really works.
You did mentioned about locked playlist, but I can't see such feature?
Btw, here's what I manage to come out so far after using and modifying this great skin for 2 days:
(http://img171.imageshack.us/img171/9383/screenhunter01dec020009om6.th.gif) (http://img171.imageshack.us/my.php?image=screenhunter01dec020009om6.gif)
D.Sync, good job I've been working on this too, could you please post your code here or in the pm?
I was also thinking about those buttons (at the bottom, arrows), it would be nice to choose between different infos on this tab by pressing them.
offtop: jeez, why are you all so keen to upload ur images to imageshack :/
Perhaps it is because the Graphical Browser component that is used for the alphabetic index is not a media library viewer, but simply a playlist panel? So it cannot create playlists (like one with only album titles starting with a particular letter).
Actually, I was just able to test something that I thought of earlier...but had been AFK. If you right-click on the alphabet section, and pull up the settings and select the "Other" tab, you can make a change to the behavior when using "Single-Click" or "Double-Click", etc. If you change the "Single-Click" behavior from "default" to "send to playlist[replace]" and either use the setting for the playlist name below or change it to whatever you want. After saving those changes, whenever you select a letter above the playlist view, it will now only show artists (or albums if you go that route) from the letter you choose, not just focus. Also, you can move from letter to letter without having to go back to your full music library.
EDIT: I should have waited after testing something else. If you stay in that list when you close fb2k, when you reopen, your alphabet will only have the letter for the group displayed. You would then need to go back to your full library list to get the full view again.
EDIT #2: The point above is remedied by going to the "File" menu, then go to "Startup Playlist" and select the full library list. At least that is what I have done. Now, everything is perfect. Love this config!
why not
I second that, I have a large collection of classic and instrumental music which obviously don't have any lyrics. So most of the time I don't need the lyrics panel. Having something that will display all the details of a track would be more interesting then "no lyrics found".
Great, Great, upload Br3tt, thanks alot.
Quick noob question that i have never got around too. Whats the best way to go about changing the titlebar style? Mine is still basically the default and it sticks out like a sore thumb. Any help is appreciated.
(http://i195.photobucket.com/albums/z140/di0p7/untitled.jpg)
Actually, if you look at D.Sync's picture posted a few posts up, D.Sync changed the "..." or Info section in the lower right to show track information, rather than Br3tt's very cool "Curacao" image.
I think it might be cool to keep showing the "Curacao" image when in a stopped state, but once playback begins, perhaps show track info.
Great Foobar theme! I like it, but I have a few questions:
1. How do you get the exact visualization and info under the artist/album in the music list?
2.When I play files with this, they are edited in some way (I'm assuming the info is changed); how can I play the files without changing the original file AT ALL?
3.When you highlight a track, it plays that track next instead of the next one after the previously played song. Is there any way to disable this?
4.I can't seem to figure out how to set the number of stars to zero .
You need to make sure that the Milkdrop2 plugin and visualizations are installed, plus you need the NSCRT.dll (from Winamp) placed into the foobar2000 directory. The rest is a matter of changing settings. Some of which is discussed in this thread.
Based on the config settings and components that Br3tt includes, by default, lyrics and playback statistics are automatically added as tags. You would need to go to the settings for both components to change this.
You would need to change your playback order. Go to the "Playback" menu, go to "Order" and change it accordingly. Default plays in order of the list.
You should be able to use the rating section on the left hand side. I personally don't rate my music.
I gave you some direction on what to do, but since you are new to HA forums, you really should read this thread, as well as information specifically on foobar2000. Welcome to the forum!
As requested: (Do note that the font of the info will not change to a smaller one if you shrink foobar2k, best viewed on 1280x800 since that's the resolution of my workaround).
You'll need to have the following custom tags:
- %publisher%
- %released_date%
- %catalog%
and
- Font (Maiandra GD)
*Paste it as 'Per Second' script and enable [Per Second] as the bitrate displayed is dynamic (VBR).
$puts(config_name,'curacao')
// you may have to change the variable below :
$puts(foo_path,'C:/Program Files/foobar2000/')
//$gradientrect(0,0,%_width%,%_height%,$get(scr_color_top),$get(scr_color_bot),)
//$drawroundrect(-1,-1,$add(%_width%,1),$add(%_height%,1),3,3,50-55-50-0,0-0-0-155,)
//$puts(cover.path,$get(foo_path)'images/'$get(config_name)'/bg/wallpaper.jpg')
$puts(cover.path,$replace(%path%,%filename_ext%,)folder.jpg)
//$imageabs(0,0,%_width%,%_height%,$get(cover.path),nokeepaspect,0,20,)
//Background image
$imageabs_rc(%_width%,600,0,300,%_width%,850,0,0,$get(cover.path),nokeepaspect,,50)
//Upper round rectangle
$drawroundrect(7,12,880,20,4,4,0-0-0-100,172-172-172-100,)
//Bottom round rectangle
$drawroundrect(7,44,880,20,4,4,0-0-0-100,172-172-172-100,)
// coverlay reflect
$drawimage(1,0,$sub(%_width%,0),$add(%_height%,20),$get(foo_path)'images/'$get(config_name)'/bg/coverlay.png',nokeepaspect,,130)
// line separator 1
//$drawrect(0,25,%_width%,1,050-050-050-125,)
//$drawimage($sub($div(%_width%,2),80),3,160,58,$get(foo_path)'images/'$get(config_name)'/bg/logo.png',nokeepaspect,,)
$font(uni 05_53,6,normal)
$drawstring(>>> Song Info >>> $if(%comment%,%comment%),7,0,,,255-255-255-255,)
$drawstring($if(%play_counter%,First Played : %first_played% | Last Played : %last_played% | Played : %play_counter% times),475,0,,,222-222-222-100,)
$font(Maiandra GD,8,normal)
$put(tab.width,0)
$drawstring($if(%publisher%,Publisher : %publisher%)$if($not(%publisher%),Publisher: N/A),$put(tab.width,40),16,,,255-255-255-255)
$drawstring($if(%catalog%,Catalog : %catalog%)$if($not(%catalog%),Catalog : N/A),$put(tab.width,$add($get(tab.width),12,$gettextwidth(%publisher%,Segoe UI,8,normal),100)),16,,,255-255-255-255)
$drawstring($if(%released_date%,Released Date : %released_date%)$if($not(%released_date%),Released Date : N/A),$put(tab.width,$add($get(tab.width),10,$gettextwidth(%catalog%,Segoe UI,8,normal),100)),16,,,255-255-255-255)
$drawstring(>>> Technical Info >>>,7,33,,,255-255-255-255,)
$drawstring(Bitrate : %bitrate% Kbit/s,40,48,,,255-255-255-255)
$drawstring(Codec : %codec%,185,48,,,255-255-255-255)
$drawstring(Samplerate : $div(%__samplerate%,1000).$substr(%__samplerate%,3,3) KHz,300,48,,,255-255-255-255)
$drawstring(Channels : $if($stricmp($codec(),MP3),$get(space2)$caps(%__mp3_stereo_mode%),$if(%__channels%,$ifgreater(%__channels%,1,Stereo,Mono),'?')),460,48,,,255-255-255-255)
$drawstring(Filesize : $div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2) $get(anno)'MB',625,48,,,255-255-255-255)
//$drawtextex('v1.1a',$add($sub($div(%_width%,2),80),149),49,30,12,0-0-0,left top)
* I've been trying to figure out too, eg: change back to Curacao original background when song is not playing but I couldn't figure the function. I had tried %el_isplaying% and %ps_isplaying% but no avail. Hopefully someone can modify it.
* I choose Imageshack because it offers fast upload and doesn't require membership to upload.
Actually, if you keep the "Per Track" section as is, and then add in your code in the "Per Second" section, then it just overlays the info on the Curacao image. You could reposition so it doesn't cover up the center portion. I also wonder if %_isplaying% will work instead?
Ops, I guess I forgot to mention that I actually delete the entire code in the Per Track section for it to work.
Btw, wanna ask what function should I use to find a x position whereby it is 'n' pixels from the end of the line.
Eg:
|>>> Technical Info >>> Tag Info: [30 pixels from end]|
And how can I modify the font color?
Publisher: ABC
*I'm currently still working on the track info by adding more info. Might release a full version if my problem had been solved~
Eg:
Publisher: ABC
If you click the "List" button at the bottom of the editor window, when "Functions" is showing in the drop-down, you will find a "$drawtext" function. The options include "r-g-b". Or you should also be able to use "$puts" functions to create your own variables. Not sure about your other request.
I'll try that.
Do you know how to solve my first question in the previous post?
-> How to read a x-coordinate 'n' pixels from the total width
EDIT: The $drawtex function doesn't work effectively as I need to type the coordinate for each words I like to change color: (Why did the developer removed the $rgb function... T.T which would make things easier)
Eg:
[Red] Bitrate: [White] %bitrate%
[Red] Codec: [White] %codec%
Ok, I was just verifying that the visualization was from Milkdrop and not something else.
Lyrics are embedded into the song? Didn't know that heh, anyway to not embed them in the file? The lyrics are set to auto download and "save to configuration folder". Where is that exactly, and why is the file affected if the lyrics are saving somewhere else?
Maybe I wasn't clear, it plays in order of the list regularly, but if I wanted to browse to another section of the list and highlight another song, instead of playing down the list it skips to the highlighted song. My Order has always been on Default btw.
Yea, but I cant' seem to completely eliminate the rating, I can only get it down to one star. Does rating change the composition of the song?
Thanks for all your help and thanks for the welcome!
To remove the star rating, just click again on the previous star rating icon.
anyone know how I could replace the lyrics show with album list and still look good? Also any way to lock the shpeck milkdrop visualization so it survives a restart of the program? I lock the one I want in but when program restarts its no longer set to the one I want.
I don't think the album list can be made transparent so it wouldn't fit in with the rest of the theme.
That has nothing to do with foobar, you need to either
1. Use windowblinds
2. Patch your uxtheme.dll to allow you to use unsigned themes.
Thanks, D.Sync
oh, maybe you can help me a bit again, I'd like to replace any of your strings with the playing song elapsed percentage, but can't get "$muldiv(%_time_elapsed_seconds%,100,%_length_seconds%" to work
Thanks, D.Sync
You forgot to close the bracket:
E.g: (Add elapsed percentage beside Technical Info):
$drawstring(>>> Technical Info >>> $muldiv(%_time_elapsed_seconds%,100,%_length_seconds%
)'%',7,33,,,255-255-255-255,)
Isn't the info details already enough? For me, I enable the mouse hover feature on ELPlaylist which shows info such as Artist, Composer, Conductor, Band, etc... which involved person as their name length varies whenever I hover over a track.
Another room for improvement:
- If multiple different %artist% tag is detected in an album, a 'Various Artist' string will be displayed on EL Playlist group header instead of using the artist name for the first track
Thk for your help RavenSoft, but it still doesn't work... I don't understand !
Been working on displaying the lyric icon when a [Lyric] tag is being detected, as follows:
[a href="http://img155.imageshack.us/my.php?image=screenhunter01dec030101tv9.gif" target="_blank"]
is there anyway to turn off that whenever I click in foobar, it pauses the song for some reason
mine :
[a href="http://xs234.xs.to/xs234/08492/1.3preview917.png" target="_blank"]
song is paused when clicking the cover art only ... don't click !!!
not an image, so scrolling down the playlist is not affected
hope you'll make it as an option because some music fans who have lyrics for all of their songs don't need this
why not, easy to do with elplaylist (field definition tab in elp settings )
mine :
I like this! Looks very clean and meshes well with the rest of the layout. Can't wait to see it in my fb2k.
Hi all!
I've spent quite some time to improve the popups and also the handling of different playlists. The purpose is to have some nice infos as popus and adapt the playlist-view based on whether you want to group by albums or just list the single files.
Here is a picture that more or less describes what my setup does:
Hope everything works.. Most important thing is to change the playlist filter names so they fit to your own playlists..!
P.S.: If anyonw could help me to change the "last played date" in History-view to the date when the song was added to the playlist, that would be great! I'm using [a href="http://mry.awardspace.com/fb2k/foo_navigator.htm" target="_blank"]foo_navigator (http://img518.imageshack.us/my.php?image=foobarpopupandplaylistsbv6.jpg) to automatically add played songs to that playlist by the way that also provides extra title formating, but that doesn't seem to work in elPlaylist
Hi all!
Nice work, i like your pop-up display, i like them
I very small feature request. Can you make your config look for both jpg or png album/artist art? a few I have are in png and I'd like to leave them that way if possible. Winamp displays them fine.
Have you tried changing the extension from .png to .jpg? I do this with GIF files, call them .jpg, and they display fine, try it...
Hi Br3tt... and everybody !
i've got a question :
how can i do, if i want this...
[a href="http://img186.imageshack.us/my.php?image=anacaonagw5.jpg" target="_blank"]
Get a program called IrfanView. It is an image program, which has a nice little batch converter/renamer. Search your music for all of your PNGs, drag them into the converter window and set it to convert them to JPGs. You could do the opposite, but then you need to change the extension in all of the settings in fb2k that are looking for JPGs right now.
[a href="http://img518.imageshack.us/my.php?image=foobarpopupandplaylistsbv6.jpg" target="_blank"]
I'll try to get it work on Ibiza.
Thanks Andi
Onkel Andy, care to share the popups code only please?
Nevermind...I see what was being asked.
I have updated the popup code a little bit. Now it looks even nicer and displays icons when the song has lyrics embedded and/or album art. Additionaly I have implemented some sort of logic if you use the comment-tag for info on what soundtrack or single a track was released. Look at the code and comments...
$if($findfile(Z:\_artists_\%artist%.jpg),
$puts(artist_path,Z:\_artists_\%artist%.jpg),
$puts(artist_path,$replace($replace(%path%,$directory(%path%),),%filename_ext%,%artist%.jpg)))
$puts(config_name,%__CONFIG_NAME__%)
$puts(art_path,%__ART_PATH__%)
$puts(time_of_year,$right($substr(%last_played%,9,10),2)'. '$select($substr(%last_played%,6,7),January,February,March,April,May,June,July,August,September,October,November,December)'
'$substr(%last_played%,1,4))
$puts(time_of_day,$substr(%last_played%,12,13)$substr(%last_played%,14,16))
$puts(row.height,15)
$puts(row.width,0)
$puts(icon,0)
//If you put Information about Single or Soundtrack in your comments, this information will be displayed as Album Info!!
//To disable this behaviour, just replace the "2" by a "1"
$puts(comment,$if(%comment%,$if($or($strstr(%comment%,'Single'),$strstr(%comment%,'Soundtrack')),2,1),0) )
$if($findfile($get(artist_path)),$puts(artist_size,$ifequal(%el_item_count%,1,%__ART_SIZE__%,200)),$puts(artist_size,0))
$if($imageabs(1,1,0,0,%path%,artreader),$puts(cover_size,%__ART_SIZE__%),$puts(cover_size,0))
$puts(space,0)
$puts(deb,1)
$puts(ind,5)
$if($findfile($get(artist_path)),$imageabs(1,1,200,200,$get(artist_path),,nodisplay))
////Calculate height and width////
$if($or(%lyrics%,%unsynced lyrics%),$puts(row.width,$add($get(row.width),30)) )
$if($imageabs(1,1,0,0,%path%,artreader),$puts(row.width,$add($get(row.width),30)) )
$if(%artist%,
$puts(row.width,$gettextwidth(Artist: %artist%,Arial,9,bold))
$puts(row.height,$add($get(row.height),15)) )
$puts(row.width,$max($get(row.width),$gettextwidth('Original Artist: '%original artist%,Arial,9,bold)) )
$if(%origartist%,
$puts(row.width,$max($get(row.width),$gettextwidth('Original Artist: '%origartist%,Arial,9,bold)) )
$ifequal($get(comment),2,
$puts(row.width,$max($get(row.width),$gettextwidth('Album: '%comment%,Arial,9,bold)) )
$puts(row.height,$add($get(row.height),15)),
$if(%album%,
$puts(row.width,$max($get(row.width),$gettextwidth('Album: '%album%,Arial,9,bold)) )
$puts(row.height,$add($get(row.height),15)) ) )
$if(%title%,
$puts(row.width,$max($get(row.width),$gettextwidth('Title: '%title%,Arial,9,bold)) )
$if(%featuring%,
$puts(row.width,$max($get(row.width),$gettextwidth('Featuring: '%featuring%,Arial,9,bold)) )
$if(%remixed by%,
$puts(row.width,$max($get(row.width),$gettextwidth('Remixed by: '%remixed by%,Arial,9,bold)) )
$if(%date%,
$puts(row.width,$max($get(row.width),$gettextwidth('Year: '%date%,Arial,9,bold)) )
$if($or(%genre%,%publisher%,%bitrate%),
$puts(row.height,$add($get(row.height),18)))
$if(%genre%,
$puts(row.width,$max($get(row.width),$gettextwidth('Genre: '%genre%,Arial,9,bold)) )
$puts(row.height,$add($get(row.height),15)))
$if(%publisher%,
$puts(row.width,$max($get(row.width),$gettextwidth('Publisher: '%publisher%,Arial,9,bold)) )
$if(%bitrate%,
$if(%BPM%,
$ifequal($get(comment),1,
$puts(row.width,$max($get(row.width),$gettextwidth('Comment: '%comment%,Arial,9,bold)))
$puts(row.height,$add($get(row.height),15)),)
$if(%play_counter%,
$if(%last_played%,
$puts(tags,$add($get(tags),1))
$puts(row.width,$max($get(row.width),$gettextwidth('Last played: '$get(time_of_year)' at '$get(time_of_day),Arial,9,bold)) )
$ifequal($get(comment),1,$puts(row.height,$add($get(row.height),18)),
$if($or(%play_counter%,%last_played%),
$puts(row.height,$add($get(row.height),18)) ))
$puts(row.width,$add($get(row.width),$add(48,$max($get(artist_size),$get(cover_size)))) )
$puts(width,$max(
$add(40,$gettextwidth(%artist% - %album% - %tracknumber% - %title%,Arial,9,bold)),
$get(row.width)) )
$puts(height,$max($add($add(58,$get(space)),$add($get(cover_size),$get(artist_size))),$add($get(row.height),60)))
$puts(width,224)
$puts(height,224),
$popuphide())
// BACKGROUND //
$popupsize($get(width),$get(height))
$imageabs(0,0,$get(width),$get(height),$get(foo_path)'images/'%__CONFIG_NAME__%'/bg/popup.png',nokeepaspect,,250)
// Cover And Artist Picture//
$if($findfile($get(artist_path)),$imageabs(12,40,$get(artist_size),$get(artist_size),$get(artist_path),nokeepaspect,) $puts(space,12),)
$imageabs(12,$add($add($get(space),40),$get(artist_size)),$get(cover_size),$get(cover_size),%path%,artreader,,)
,$imageabs(12,12,$get(artist_size),$get(artist_size),$get(artist_path),,)
//////Header Info/////
$puts(header,$if(%artist%,%artist%)$if(%album%, - %album%)$if(%tracknumber%, - %tracknumber%)$if(%title%, - %title%))
$font(Arial,9,bold)
$ifequal(%el_item_count%,1,$drawstring($get(header)
,0,15,$get(width),%el_height%,255-255-255,hcenter nowrap elipchar),)
$font(Arial,9,bold)
/////Additional Track Info/////
$ifequal(%el_item_count%,1,$drawtextex(
$if(%artist%,Artist: %artist%)
$if(%origartist%,$crlf()Original Artist: %origartist%)
$ifequal($get(comment),2,$crlf()Album: %comment%,$if(%album%,$crlf()Album: %album%))
$if(%title%,$crlf()Title: %title%)
$if(%featuring%,$crlf()Featuring: %featuring%)
$if(%remixed by%,$crlf()Remix: $crlf()%remixed by%)
$if(%date%,$crlf()Year: %date%)
$if($or(%genre%,%publisher%,%bitrate%),$crlf(),)
$if(%bitrate%,$crlf()Bitrate: %bitrate% Kbit/s)
$if(%BPM%,$crlf()BPM: %BPM%)
$crlf()
$crlf()
$ifequal($get(comment),1,$crlf()Comment: %comment%,)
$if(%play_counter%,$crlf()Playcount: %play_counter%)
$if(%last_played%,$crlf()Last Played: $get(time_of_year) at $get(time_of_day) )
,$add(24,$max($get(artist_size),$get(cover_size))),40,$sub(%el_width%,12),%el_height%,192-192-192,nowrap elipchar),)
////Icons for Lyrics and Artwork////
$if($or(%lyrics%,%unsynced lyrics%),$imageabs($sub($get(width),35),38,15,15,$get(foo_path)'images/'$get(config_name)'/bt/vscrollbar_hide_on.png',,)$puts(icon,20),)
$imageabs($sub($get(width),$add($get(icon),35)),38,15,15,
$get(foo_path)'images/'$get(config_name)'/bt/artists_show_on.png',,),))
CAN ANYONE HELP? I'm looking for a way to check whether the artwork is embedded as a tag or not. The %path%,artreader is true whenever some sort of art is found, means not only when artwork is embedded
P.S.: Feel free to optimize the code and re-post it here
Curacao v1.2a is out, check http://br3tt.online.fr (http://br3tt.online.fr)
ChangeLog:
- ELPlaylist : new info added : embedded lyrics icon, track bitrate
- ELplaylist : infos like rating, lyrics icon, bitrate can be turned off in ELP settings (check the "field definition" tab)
- New file info added in Curacao mini panel in the control panel when track is playing
- Added new popup panel in the playlist header : AL button for Album list view
- better support for Last.fm radio plugin
- On track change, buttons disappear ==> fixed
- rating stars : playback statistic rating support added, now, curacao displays stars from the library info too ... (rate-engine at bottom left do not displays them because it reflects only the metadata info from file)
- bigger font in popup panels (statistics, artists list) from playlist header buttons
- Tweaks, fixs ...
Right on, thanks for the updates, new features are nice
This is a great build, the modifications in ELP are fantastic, as is the addition of the Album List. A lot of people are going to be very happy I predict
Thanx!
I still haven't installed curacao, but doesn't it work with this code I took from tedgo's style.
http://www.hydrogenaudio.org/forums/index....st&p=603138 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=64035&view=findpost&p=603138)
Thanks for the update
I think each track bitrate info is useless though, that's pretty odd to have tracks at different bitrate in the same album.
Don't say that, I've been asking for this feature since early IBIZA days
I have several albums or compilations with mixed bitrate, it just shows you which ones need updating. And you can easily hide the feature if you don't like it
you can easily hide this info in elp settings
NOW (v1.2a) rating info from playback stats library are displayed as well (elplaylist, under cover panel), but NOT in the rating engine that is the rating stored in file TAG %rating% $meta(rating) if you prefer.
so it's no sense to display library rating here, only stored TAG from files, CAPICE ?
Why is it odd to have tracks with different bitrates? A variable bitrate encoding will do just that...give different bitrates for each track. Using a constant bitrate encoding, you would get the same bitrate for each file, but that isn't necessarily the best way to encode files.
Thanks for the update but I can't install it.
At the start up I get:
Failed to load DLL: foo_albumlist.dll
Reason: The specified procedure could not be found.
Even though I have the DLL in the components folder.
This pop up appeared on the other version at the start up but it didn't affect the installation. When I try to import 1.2a I get:
The layout import was aborted because the following required panels are not installed:
Album List (Then a GUID number)
Any ideas on how to sort this out?
I don't wanna feel you be pissed off, but I would tell the people that there is a possibility to rate in statistics with this button too.
I don't think there is no sense, cause like I and developers think, it's not a good idea to change files with such things.
Sorry for the note, but it was only a suggestion and not an attack.
OK, not different bitrates, but different encoding presets
When I do that, the stars just turn more transparent, but don't disappear.
I had the same problem. was missing "foo_uie_albumlist.dll". try adding that and see if it works. (curacao_1.2a)
So do not install this config, it's not for you. Thanx.
new dll needed for v1.2a : foo_uie_albumlist.dll
get it and install it.
You are acting like a prima donna.
Again, it was not an attack, only a suggestion, cause I like your configs very much.
But, nerver mind.
Wow! What a great update! My two favourite changes:
$puts(foo_path,'./') --> no need to change the path for every single panel anymore
Finally supporting Playback Statistics-ratings!
Thank you very much, Brett!
But, nerver mind.
The problem is not here, it is just that you do not understand how 3rd party plug in works and how curacao use them, i make a notice to explain why the rating engine will not reflect the library-rate but only the file-tag-rate, and you do not understand it, so, once again i will explain to you the problem and the reason of this choice:
1) if a track is rated in the library using the official playback statistics module (foo_playcount), we can use %rating% field in titleformatting and so in third party componenets.
2) if a track is rated in the music file itself, we can use %rating% too or $meta(rating) in titleformat strings (note that $meta(rating) will return nothing if track is rated only in the statisitic database)
3) to rate a track in the stats lib, we have to use right click on the track with context menu and select the right entry.
4) to rate a track in the music file itself, we have in Curacao (or ibiza ...) the rate-engine which is a simple Trackinfo_mod panel that allow this.
5) if a track is rated in both method and if we display the rate with the %rating% method, rate from the stats lib is used in priority.
6) rate-engine (a simple trackinfo_mod panel) only permits to TAG music files, not the statistic library db
So, now that things are clear for you and me, do you have a better understanding of the reason why i do not display the stats lib rate in the Trackinfo_mod panel ?
if i display the stats lib rating info in it, we cannot know where is stored the rating for the track. and if for example there is a 3 stars rating in the trackinfo_mod, if i want to rate it more or less, it will tag the music file (not the stats lib db) and it will be never displayed well in the Trackinfo_mod, because of rule 5 (seen above), and the rule 6
maybe i'll use different colors for the stars to make the difference later but for now, it works like that
You're welcome
Thanks a lot for the explanation.
I noticed for myself that if there are different ratings in Tag an Stats Lib that the Lib is prioritized and there is a "strange" behaviour.
But, point 6. is not true (in Ibiza). I can rate in trackinfo_mod panel via Stats Lib, thats what I want to say all the time.
If there is some rating in the tag and I re-rate it via stats lib, I get an window asking me for deleting the tag-rating and only store the rating in stats lib and so point 5 is also obsolete, cause I only have the Stats Lib.
The only suggestion I wanted to say is, to tell the people who prefer the Stats Lib that there is also a possibility.
I hope I didn't missunderstand you completly.
this setup is AWESOME!! thank You Br3tt!! one idea: is there any way to add special album art for streaming radio? please! (i have been trying many different codes and nothing...)
no way i know... art support with streaming need to be handled by a specific component, like last.fm radio component does (grab cover art from last.fm site that can be displayed in foobar)
@Krema+Or
I don't know how Br3tt has made his setup (i haven't installed it at the moment, i only took a look in it, to learn the handling of ELPlaylist) but in ELPlaylist I've done it with:
$if($strcmp($left(%path%,7),'http://'),
$imageabs(3,3,$sub(%el_height%,8),$sub(%el_height%,8),%__FOO_PATH__%Radio.png)
$imageabs(3,3,$sub(%el_height%,8),$sub(%el_height%,8),%__FOO_PATH__%NoCover.png)
$imageabs(3,3,$sub(%el_height%,8),$sub(%el_height%,8),%path%,artreader)
I haven't integrate it in my own skin though, because i rarely use radio in foobar and i don't know if there are no other possible conditions where the path begins with 'http://' (although I don't know any. Maybe I'm stupid, I know... )
Or did i misunderstand you?
EDIT:
Spelling.
@Krema+Or
EDIT:
Spelling.
i have misunderstood the Krema+Or question, sorry
it's easier to test the %length% for streaming radio, this one is not set for them, so instead of :
$if($strcmp($left(%path%,7),'http://'), ...
you can write :
$if($not(%length%), ...
anybody help, plz (script error)
(http://pic.ipicture.ru/uploads/081207/4347/thumbs/8ABK674FgW.jpg) (http://ipicture.ru/Gallery/Viewfull/9999962.html)
latest java installed
@falstaff
May i ask you that silly question?
In what other situation can the path begin with http://?
(I only use foobar for music on my local or connectable harddisc)
I first had tested the situation with $if(%length%,...) but thought searching for 'http://' would be probably better.
I use this string only to indicate a blinking "STREAMING" in the statusbar.
hey, this config is great, but i have just one problem. for some reason it wont show .bmp album art? i changed the folder.jpg to folder.* but that didn't work for me. any ideas?
Hey Br3tt, or anyone else,
I do not allow the lyrics plugin to automatically tag my files, instead I have it save them as a LRC file (named in the format of %artist% - %filename%.lrc). I have tried to change the ELP settings so that it will show the lyric icon when a song has the accompanying LRC file, but I haven't gotten it to work. Anyone else try this? I tried to modify the $or statement to include a $replace function similar to the ones used for artwork. But it hasn't worked. Not sure if fb2k or the plugin can look for LRC files like it can image files.
wildcard chars like * are not supported
I've found the solution of the "Failed to load DLL: foo_menu_addons.dll" problem.
I downgraded my foobar from 0.9.6 to 0.9.5, and it works perfectly.
By the way, it really is a nice piece of work Br3tt !
Thk for the work !
has to be something with your computer, but 0.9.6 works just fine with foo_menu_addons. Maybe runtimes need updating or your hardware isn't SSE. Either way it does work with 0.9.6.
He Falstaff,
thanks for your update...!
Maybe you are interested in my update, too. I've implemented some additional stuff into your most recent elPlaylist:
- nice popups for Album and Tracks
- Single/Album view: you can change sorting/grouping. So for the library the standard album-grouping makes sense, but for other playlists like history or random temp playlist a simple list of the songs without headers may make more sense.
- integration of "Comment"-Tag: some people like me tag single B-sides or rarities in the comment-tag. The info is then shown in the playlist and in the popups. Additionaly you can choose to show the specific embedded album art in the playlist.
- History playlist view with "last played" information (used with the foo_navigator plugin)
Everything is totally optional, you can switch features on or off in the standard elPlaylist setting without searching through the code. Feel free to integrate the stuff in your next release
Download (http://www.onkelandy.com/ELPlaylist_Andy.elp) and import.
Version 1.2a has some problems with the images, etc. The './' for foo_path doesn't seem to work flawlessly. I don't know whether it's because I've installed foobar as "portable".. do I have to set any system variables? The weird thing is that some images are shown and some are not..
@tedgo thx for code, i am not good enough in script language, i've been trying to insert with modified paths -it is not showing any dedicated pictures when streaming.
Br3tt could You PLEASE make it (streaming.jpg as album art) working in the next version? I hope i am not the only one who is using radio streaming in foobar. for You it is only a few lines of code - for me a black magic...
... Add it if u can.
Some fucntion in mini mod can remove: ALB, ART AVS and '...' buttons
Can u make bottom panel like a rectangle? I don't like the curve in a config with all-90*-corners
Sorry for my bad English
I love your config. BTW!!!
I still can't figure out how to edit the color of the text in the group (like in the pic at the top-the aqua-ish font) and also the extra info in the groups. (Exactly like the post above mine.
@nate911: Right click in Playlist -> Settings
Select tag 'field definition', you will see line: TXT_COLOR_GROUP, double click and change your color (RGB).
You can use MS Paint to select color you want.
Anyone have thoughts on this?
I've only noticed a couple things that don't seem to work right. I'm using a fresh 0.9.6 install following all your directions in the install setup document (and I read the overview document). By the way, if I recall correctly, you didn't mention the required fonts at all in the install documentation. Anyway:
1. I actually have a series of discs that goes in to double digits. I noticed that when displaying the disc number in the playlist, it only shows one digit for the current disc, but two digits for the number of total discs. Therefore, if you have a ten disc set, the tenth disc, for example, will show up as "(Disc 0/10)" rather than "(Disc 10/10)". I only have one set like this, so it doesn't really bother me.
2. The Preferences button doesn't seem to work for me at all. In fact, it crashes (but restarts) the foobar2000.exe application entirely. Also, CTRL+P doesn't work when I initially start foobar. It gives me a windows "exclaimation" sound but does nothing. However, after I click somewhere (anywhere) within the program (other than the title bar) CTRL+P works and continues to work until I restart foobar.
3. The two google buttons in the top right don't seem to do anything. How exactly do these work? I guessed that they would open my default browser, but perhaps they try to download album/artist art and put it in the currently playing track's folder? If so, that would explain why it doesn't work, as I already have all that art in place?
4. Is there any way for me to have the playlist disregard "The" in an artist's name? It would be much easier to use the handy letter buttons at the top for quick searching. As it stands, there are a slew of artists in the "T's" because of this.
All in all, this is a very complete, functional, and visually pleasing config. Greatly appreciated!
I guess there is a $num(blabla,1) somewhere in the code. Just change 1 to 2...?
I guess the Ctrl-P behaviour is normal at least for panel stack splitter plugin.. something has to be active that the program knows the hotkey is hit.
They just open the browser and put the correct google URL in the adress bar, that's it. Read the curacao install instructions -> you have to setup up the "Run Services" for making the buttons work.
Search this thread and you will find the solution. You have to replace the "%album artist%" by some code that was posted some paged before.
Do you know how to change the font??
Thanks..
Thanks..
Right-click anywhere in the playlist (on the album header or a song) and select "Settings". Go to the "Group Header" tab, and in the field box look for the "Text Properties" portion.
The Ctrl-P shortcut is not set as a Global, which would allow you to use it when unfocused. You could change it to a Global, BUT if you do, make sure it doesn't conflict with a normal Windows command. Shortcuts are in the Preferences.
Look for my posts in this thread, I posted the code to ignore the "The" in the %album artist%. You will also need to look at the posts after that, as there will be a few places that you will need to put this code.
I'm using this string for ELP also
But if I put this in the code for the GB (at the top of ELP) I only get the letter for the first "The" band and all of these bands will be selectedt at once.
Does anybody know how to do?
Edit: I made it. I have forgotten the grouping there. Sorry for posting before thinking.
Hello,
First of all, I'd like to thank you for this great theme you made. I want to ask a question, I'm new at this foobar-plugin thing so I hope you forgive me because of my ignorance. Nearly all of my albums have an original cover, when I select a song from an album with cover, cover appears on the background. That's a cool feature, but I felt like the background is better with no cover (grey). I searched an option for that but couldn't find it. I don't want my covers to appear on the background. Is there anyway to disable this feature?
Hello,
have you check my site ??? i explain that with a video, cannot be more clear
see the 2nd video :
http://br3tt.free.fr/tutorials/index.htm (http://br3tt.free.fr/tutorials/index.htm)
bye.
I won't even pretend to know where to find this.
This makes sense. I was also under the impression that the button above the playback time and vis spectrum was supposed to bring up foobar's preferences, but from reading more of this post I gather that it is indeed supposed to restart foobar. This must serve some purpose to Br3tt and others that I can't understand.
Thanks again. I re-read, and found the info not in the install instructions, but in the overview document. Both of them are a little out of date, but useable. Not to complain. None of this is coming to me as a right, after all, but a privilege. Thanks, again, Br3tt!
You know, I found the posts you were talking about. Specifically, kockroach's. I tried this, but it still wasn't working quite right as far as I could tell. All artists preceeded by "The" were indeed changed to their name followed by a comma and "The". And they were indeed sorted properly in the playlist view.
However, the letters at the top didn't work quite right. For example, the first artist with a "The" in my library is "The Adolescents". They were resorted in the playlist view with the "A's" and the "The" at the end of their name, but clicking on "A" in the letters at the top highlighted all "A" artists in the playlist
except for the ones that normally start with "The" such as "The Adolescents".
What's more, the letter T at the top was replaced with the first letter (alphabetically) of the first "The" artist in the list. In this example, it was "A" for "Adolescents, The". Clicking that letter highlighted every "The" artist in the list regardless of their physical location.
I'm 99% sure that I put the code that kockroach posted in all the proper areas that people mentioned. However, because others are reporting that it works, I'm assuming I missed something.
I would greatly appreciate it if someone would take the time to list each location that I need to post the "The" omission code to properly sort my playlists (and graphical browser, and wherever else it would be pertinent).Also, Onkel Andy, I downloaded and imported (through the import button in the ELPlaylist settings) your playlist sorting and popup settings. Nice work! There are only two problems I'm having that maybe you can help resolve.
1. The playlist now seems to scroll at far fewer lines at a time than it did before. Is there a way I can increase this, as I like the idea of hiding the scroll bar.
2. The popups aren't quite displaying as you intended them to. See the images below:
Album Popup (http://sites.google.com/site/diningnighthawk/Home/images/album-example.jpg?attredirects=0)
Track Popup (http://sites.google.com/site/diningnighthawk/Home/images/track-example.jpg?attredirects=0)
Thanks again for everyone's help, and especially to Br3tt for sharing his creation!
However, the letters at the top didn't work quite right. For example, the first artist with a "The" in my library is "The Adolescents". They were resorted in the playlist view with the "A's" and the "The" at the end of their name, but clicking on "A" in the letters at the top highlighted all "A" artists in the playlist except for the ones that normally start with "The" such as "The Adolescents".
I have already mentioned all of the places you would need to put that code within this thread. They aren't all in the same place, because some of it was figured out at different times. Just pull up all of my posts in this thread, and you should find everything. It isn't worthwhile to write it again. It will also take care of the Alphabetical list at the top too.
And just a quick note. Don't use the code for the actual grouping in the playlist. Only the sorting. If you do it in the grouping, you get the ", The" problem you mention.
- right click on browser / settings - for the first letter browser on top
- Group - replace in 2 places %album artist% with $stripprefix(%album artist%) - at the begining of the string
- Draw code below - replace in 2 places %album artist% with $stripprefix(%album artist%) - on line 4 and 5
- right click on browser / settings - for the artist browser on bottom
- Sort - replace %album artist% with $stripprefix(%album artist%) - at the begining of the string
- right click on browser / settings - for the album browser on bottom
- right click on playlist / settings / grouping tab
- Sort format - replace %album artist% with $stripprefix(%album artist%) - at the begining of the string
- Foobar properties
- replace %album artist% with $stripprefix(%album artist%) - on these places:
- Columns UI / Filter tab / Sort Incoming Files By
- General / Sort Incoming Files By
- Album List / Views and Album List Panel / Views - the By Artist and the By Artist/Album entries
- Open Artist List popup on top of playlist
- Group - replace %artist% with $swapprefix(%artist%) - at the begining of the string
if anyone can add more info please do
thank you
When I search an artist in library. Playlist don't soft files automatically..
I used Sort -> preset default.
I want playlist auto-sort files. Can I do it?
Sorry... I think this post have some mistake of English Grammar
Hi Br3tt,
I love curacao, surely your masterpiece.
The only thing I miss, is the option "Highlight in Playlist". Normally I doubleclick on statusbar to go to the actually played song, but I don't have statusbar in your config.
Can you integrate this feature in curacao? Maybe a button? Or a full contextmenu in layout with big cover, like right-click on lyrics-panel in layout with small cover?
I hope u understand.
Hi Br3tt,
already done Grimes !
(http://img67.imageshack.us/img67/6167/nplaying2uk3.jpg)
Another...
Heart icon is no usefull. Please make a bigger Heart show in Playlist or Cover Pannel.
Or you can change color of Loved tracks
Hey Br3tt,
Really loving your new setup here.
One thing I'm slightly curious about though. Is it possible to get the default wallpaper in /images/curacao/bg/ to display instead of cd covers or nothing, but not display instead of artist photos?
I checked your video and saw how to make it display all the time, but when there is no cd cover in the background the setup simply displays a grey background rather than the wallpaper. Perhaps I missed something, but it'd be nice to be able to use that instead of the CD cover in the background or just the grey background.
Hopefully that makes sense.
You are right, without the scroll bar that's annoying. Just go to style and change scrollbar from 1 to 0
Actually, I'm not quite sure why br3tt made the popup background like that The problem is that the transparent parts of the png just aren't displayed correctly in elPlaylist. You can use the "enable color key" and set the correct grey color to be keyed under "misc"-tab. But I'd advise to crop the picture in any photo editing tool and maybe make the round corners straight to make it look fine.
I've provided the optimized popup-background and optimized elPlaylist config (two-digit discnumber, group/sort artists with "The" and standard scrolling on my server. Just download it (http://www.onkelandy.com/ELPlaylist.zip) and put the image in the images/curacao/bg-folder.
By the way: I've implemented the same sorting- and grouping-logic as with "The.." with "DIE". As you seem to speak german this could make sense. Changes "Die Toten Hosen" to "Toten Hosen, Die" You have to apply this code in the alphabetical panel at the top:
$if($strcmp($left(%album artist%,4),The ),$right(%album artist%,$sub($len(%album artist%),4))', 'The,$if($strcmp($left(%album artist%,4),Die ),$right(%album artist%,$sub($len(%album artist%),4))', 'Die,%album artist%))
To make it easier I have also implemented the complete columnsUI-config, but u may have to install some additional plugins like bookmarks, etc. to make it load..
Thanks Dan Popescu, using Kockroach's code in those places has got everything working perfectly now!
Also, thanks for the update Onkel Andy. Can't wait to get home and try it out!
EDIT: Unfortunately, the link you provided for the ELPlaylist updates seems to be broken
Onkel, is there any special reason not to use $swapprefix(%album artist%,The,Die) ?
Is it something I'm missing?
Popups huh so why do they not show on mine then i am using 1.2a but nothing shows up.
you just have to put them available in the ELPlaylist settings (enable mouse over ...)
hi falstaff, how can i start playback for the marked track with a shortcut? even the now playing track starts with a shortcut, not the marked track...
lg frank
Br3tt,
I have some code that may be worthwhile to add into your config. I was finally able to get something to work that would recognize Lyrics stored in a file, rather than in a tag, and display your new Lyrics Icon.
In ELP settings add the following Field Definition:
DEFINITION: $findfile($replace(%path%,%filename_ext%,%artist% - %filename%.lrc))
Then in the Track List tab of the Script section, change this:
$if($or(%LYRICS%,%LYRIC%),
to this:
$if($or(%__LYRICSFILE__%,$or(%LYRICS%,%LYRIC%)),
Enjoy!
Ok thats enabled but there just grey boxes nothing like the images people have posted.
First you may have to change the path, second - if you want the popups posted in the last few pages here you gotta download my tweaked version of elPlaylist-config.
Onkel Andy,
how do you get to save additional presets in ELP settings - I don't make it. Changes are not saved and I can't rename them.
Actually.... there is not one single reason to not use the code you've provided I was just blindly copying the stuff posted here - big thanks for that hint... everything could be so easy
By the way, I changed my album artist code from this:
to this:
$stripprefix(%album artist%,the)
It works in all of the places I did the former code, plus is it more compact. I also only did "The" as I don't believe an artist like A Perfect Circle should go under P. Belongs under A. But that is my opinion.
Onkel Andy,
First change the code, then hit new, then change the name and hit "rename" afterwards. To use the presets you have to put the relevant names in the grouping tab, the option is called "associated script name"
I've updated my tweak-file This time it also has the correct link So get it while it's hot.
Download tweaked Curacao (http://www.onkelandy.com/curacao_tweaked.zip)
elPlaylist:These are the
tweaks:
-Sorting and grouping with swapprefix(The)
-Lyric-Icon also showing when LRC-File exists, not only tag
-2-digit discnumber
Additional stuff:
-Different group/sort-possibilities: change between single track listing (inkl. special treatment of "History"-playlist) or album group
-Show Album art for Single- or Soundtrackfiles in the playlist as well as relevant comment-info
-Popups completely re-designed, showing album- and artistpictures
Graphical Browser:-Sorting and grouping based on prefix "The"
-totally redesigned album/artist-browser based on Thuans great config. Features are:
display info for missing artwork, show play-icon on playing album/artist and of course.. popups
I forgot "associated script name".
Thank you Onkel Andy.
I've actual cover as background picture.
nocover.jpg is displayed, when no cover is available.
But the background is gray.
How can I display in this case nocover.jpg as background picture?
I checked that option and got the little blank box pop up. I imported OA's file and it totally changed the look unless I missed something, I want it to look like original out of the box but still have the popup thing.
You may have missed the group/sorty by option. Just sort by Album and you have the completely same look as before! You can also delete the other grouping-way in the preferences if you don't like the tracklisting. If nothing works for you, just copy the popup-code and put it in the old config.
Lieber Onkel, if I'm not missing something your script gets only folder.jpg as displayed covers. I added another variable for cover.jpg and then modified the script to display it if folder.jpg is not found.
Maybe you can do the same for your next update?
I also made all the changes for the graphical browser.
Looking at your popup I see that it also displays the comments from the tag. Only thus the window gets very large. Should it be possible to limit the display length of the comment line or to introduce a line break lets say after 20 chars?
Br3tt -> Please tell me when you don't want me to share a tweaked version of Curacao.
you can share your personnal .fcl file with no problem for me, but not a full zip with images, docs, ...
Regards
Would you mind either fixing this link or pm'ing me a new link? I'd love to fix the background problem I talked about earlier with the popups. I need those modified images. Thanks, and nice work.
I think I got it...the other issue is the popup...comes up just fine as far as the color but there is a white border on the right side and bottom and that looks like crap....any place to fill the whole popup with the same color or get rid of the white border?
Okay, so the link works now! It includes the tweaked FCL with all the tweaks mentioned above, an altered popup.png and a play-icon for the graphical browser. Have fun.
DOWNLOAD tweaked Curacao (http://www.onkelandy.com/curacao_tweaked.zip)
Done. I just cut the comment to %__commentcut__% characters right now, you can define the number of chars in the variables under field definition
Coverart is now also considering cover.jpg and directoryname.jpg. Add additional stuff in the art_path field definition.
Implemented the cover.jpg and %directoryname%.jpg check in graphical browser and splitter -> more flexible.
Some other tweaks done.
Yes, the popup looks fine now. I tweaked the GB to display not only the folder.jpg, but also cover.jpg. Same for the Splitter setting.
I have another question: the playlist grouping startup by default is by Single, how can I make it startup with
Artist Album as default?
EDIT: nevermind, the alphabet deal at the top isn't working anymore....so thats a big problem. I imported OA's altered config and elplaylist deal and popups look nice now but I need the alphabet deal at top to work! Please help someone! Thanks!
EDIT 2: got the idea to download OA's .zip config again and there were changes made so I imported both again and still the little alphabet deal at the top isn't responding no matter what I click, its just stuck at the beginning.
This is strange... I have tested it and it works.. have you tried different playlists? Maybe it's just not updating. Maybe you right-click on the alphabet at the top and go into the settings. After hitting "Okay" or "Apply" it may update..?
If that doesn't help download the zip, you only need to import the FCL, not the elp seperately.
well I only have 1 playlist
I can mouse over the letters and click them and that part looks normal but the area below doesn't move or do anything like the original
Using the original and setting it up as required its working fine. With this altered version do I still follow the original setup instructions? Or just simply import it and thats it?
*EDIT*
http://img117.imageshack.us/img117/3061/12...08172003bv1.jpg (http://img117.imageshack.us/img117/3061/12132008172003bv1.jpg)
There is a screenshot...I am playing Alice In Chains and before if I clicked any letter, in pic its M, it would jump to the M section of the playlist and I could then play other music....but as the screen shot shows I clicked M and nothing happened.
I have another question: the playlist grouping startup by default is by Single, how can I make it startup with Artist Album as default?
I'd like to know how to change this as well. Thanks.
Either download the zip file again (updated) or if that doesn't help you can just change the behaviour of the
presets under Settings / Grouping / Playlist Filter. Change "Album Artist" to disable on and put the names of playlists next to it that shouldn't use that preset. Vice versa you edit the "Single" preset to only show on specific playlists. That should change the "standard" behaviour.
As for the problem with the
top letters. Right click, choose Settings. In the "Others" tab change the "Click actions". Maybe you have to set everything to default. That worked very slowly with large playlists that's why I changed to behaviour. I assume you also have Graphical Browser rev015?
yes rev015. i set single click from none to default and it does do something now, but seems like there is a little hesitation right after the click to when it shows the corresponding letter playlist below.
is there any other plugin that can do something similar that the graphical browser does to make the alphabet deal at the top? I have a very current computer, but as you can see that plugin has a bug in it and its a damn shame its not being updated anymore. As soon as I click one of the the "Buttons" to the top left of album art ( ||||, 1, 2 ) then the alphabet will show just fine. I have noticed however that if shpeck plugin that's at the bottom isn't rendered of doesn't load right that the alphabet will show just fine. But in order to get shpeck to work right you have to close and restart foobar2000, then shpeck loads up like normal but the alphabet area is a white box.
Bad: http://img123.imageshack.us/img123/7995/12...08190024zu0.jpg (http://img123.imageshack.us/img123/7995/12132008190024zu0.jpg)
Good: http://img126.imageshack.us/img126/6092/12...08191602rk1.jpg (http://img126.imageshack.us/img126/6092/12132008191602rk1.jpg)
Right Click in Playlist > Setting... >Grouping
In [Group by]: Select Artist Album, after that, select Disable On in playlist filter
With Histtory, like Artist Album...
Last, select Single in [group by], and [enable only on] in playlist filter > OK
Whenever I play a song from a rar file, I get a pop up saying
Could not update tags (Access denied) on:
"song location here"
Is there a way to fix this?
Also, would it be possible to make some type of way to browse different picture files in folders, like, if there was 1.jpg and 2.jpg, to be able to look through them using foobar.
Yes, same problem here as RavenSoft. When I double click on a letter sometimes I get a playlist with all the same titles. When looking at the playlist the default is then called Graphical Browser and most letters of the menu are gone. When I switch back to MyPlaylist, the letters are showing again, but do not work.
An error
(http://img530.imageshack.us/img530/927/37455308tr6.jpg)
(http://img258.imageshack.us/img258/707/64676492vx5.jpg)
Sometime, cover reflex don't fade...
And at the same time the images of the buttons or ie the "play"-icon in the playlist disappear..?? I got these problems, too. Guess it's some panelstack thingy?
This two buttons don`t work when I click on them, but run services from context menu work fine.
I use foo_run 0.3.4
(http://img390.imageshack.us/img390/3050/graphic1qe3.jpg) (http://img390.imageshack.us/my.php?image=graphic1qe3.jpg)
(http://img390.imageshack.us/img390/graphic1qe3.jpg/1/w604.png) (http://g.imageshack.us/img390/graphic1qe3.jpg/1/)
Great config but I have a problem.
every time my foobar restarts some of the images are mising(including the static background image), the images will show again only by re-importing the theme!!
using the latest version and components pack from brett's site
(http://img228.imageshack.us/img228/9402/66125383ge3.png)
Well right click on a letter and go to settings. Click on Others tab and bottom left you see click actions. single click is blank, if you set it to default then it works, just doesn't seem like original version of this theme but I don't want to mess with setting my foobar up again to see.
*EDIT*
Here is a screenshot that shows the shpeck plugin not rendered/loaded correctly, and the alphabet thing at the top shows up just fine.
http://img156.imageshack.us/img156/9803/12...08123439fl6.jpg (http://img156.imageshack.us/img156/9803/12142008123439fl6.jpg)
Upon restart shpeck plugin almost always loads fine but then the alphabet deal at the top is a white box until I hit one of the three buttons at the top left corner. Is it really a bug in the graphical browser or the theme itself?
Yes, I already found it with the default item which was blank. However I also noted the blank box, but not always; furthermore sometimes the animations are not working, then when I close and restart Foo, then it mostly works.
I also don't wanna mess around with the configuration importing the original. Maybe I'll try it on my other PC.
SOLUTION FOR THE ALPHABETICAL NAVIGATOR ON TOPSo... as some of you have figured out the "default" click option takes much too long to jump to the correct space in the playlist. I have set the left mouse button for the Graphical Browser on top to "Edit/Highlight in Current Playlist". The playlist scrolls immediately to the correct position (and well, selects all entries with that letter, but see it as a feature ). The thing is - this menu entry is only available with "foo_utils (http://foosion.foobar2000.org/components/?id=utils&version=0.6.2+beta+6)". So get that plugin and rock on..
By the way, I've updated the zip-file (http://www.onkelandy.com/curacao_tweaked.zip) to fix some minor things and a problem with the artist path (somehow the parent directory wasn't found always...).
Hey br3tt,
Really great setup you have here with Curacao! I appreciate it a lot and it looks amazing. I have been using it for about a week now on my desktop and just got around to loading it on my laptop as well. Excuse me if this has been addressed earlier in this thread (I think I remember reading something about it but not sure), but is it possible to add a scroll bar to the right of the playlist? It wasn't a big deal on my desktop, but the scroll built in to my laptop touchpad is a little difficult to use with the config. I think a scroll bar could be integrated with the whole visual theme without detracting from it too much. If you can't find a way to add one that looks appealing it's not a big deal though. I will still use your plugin because I really enjoy it! Thanks
-Docnoq
*Edit: I noticed after reading through some of these posts that some users are having issues with the alphabet and buttons on the top. I wasn't having any issues on my desktop, but the first time I loaded foobar on my laptop the 5 buttons to the right of the alphabet were invisible. The main difference between my desktop and laptop is my laptop is running vista, so this leads me to believe vista is causing the issue. However, I know virtually nothing about programming, so this may not be the problem at all. Hopefully this helps you in case you look into the issue though. Thanks again!
just use this button to show/hide the playlist vertical scrollbar
(http://xs434.xs.to/xs434/08511/playlistbt787.png)
Thanks again for this Br3tt. It's really a wonderful layout. And Onkel Andy, your slight modifications make it suit me even more. Thanks for that. Everything is working perfectly now.
Hi Andy,
I tried to but I'm not so fit in scripting.
If I play an album with Various Artists the group-popup only shows the artist of the first song.
Is it possible that the group popup is showing the single artist picture of the playing song?
btw, I like your ELP-Settings very much (especially the popup thing), just modified a liitle bit for my needs.
@bubi jackson
To my knowledge it's a restriction of the group format in ELP (at the moment).
It only gets information from the first title in a group.
Ok, wasted another hour of my life.
Thx tedgo
Maybe this behaviour has changed with newer versions of ELP.
But i don't know an actual translation of the readme, which includes all 'innovations'...
No, it doesn't
That would be very nice, I only see text like this in th readme.
Columns UI—p SCPL like‚ÈPlaylist view
ƒvƒŒƒCƒŠƒXƒg‚ÌŠeƒgƒ‰ƒbƒN‚ðgroup format‚ÉÝ'肵‚½—v'f‚ŃOƒ‹[ƒsƒ"ƒO‚µ‚ăŠƒXƒg•\Ž¦‚µ‚Ü‚·B
Well I just want to give some feedback to the updated tweaks from Onkel. BTW it's more than only a slight modification. Looks good at first sight and the alphabetic letters are working as they should.IO
I appreciate the works and I'm quite satisfied with it.
Of course another question: when starting foo the first item from the group is always expanded. I would like to have it collapsed as default.
deleted
Oh, thanks Br3tt! I thought I had played with all the buttons already but I guess I missed that one.
I've converted a set of digits to blue to match the colour used for the Artist and Album in the header which I think blends in better, if you want to try them just download and unzip into your C:\Program Files\foobar2000\Images\curacao\digits\set1 folder
http://rs254.rapidshare.com/files/174029554/set1.zip (http://rs254.rapidshare.com/files/174029554/set1.zip)
Hi Andy,
The only useful thing would be to tweak the code under //Cover and Artist Picture. When you change the lines in Popup-Code to the following one:
$ifequal($get(VA),0,$if($findfile($get(artist_path)),
$imageabs(12,12,$get(artist_size),$get(artist_size),$get(artist_path),,),
$imageabs(12,12,$get(cover_size),$get(cover_size),$get(art_path),,) ),
and put this code at the top of the popup(track) tab:
$if($stricmp(%album artist%,%artist%),
$puts(VA,0)
$puts(VA,1)
the popup would work like this:
When you hover over the group header of a normal album the artist picture is shown, when available, otherwise the cover. When you hover over the header of a sampler, only the cover is shown and no artist picture from the first or any other artists
Maybe the $if($findfile.. stuff could be replaced by a simple $if2 but only maybe.. *g* bubi jackson - wanna share your additional tweaks?
Thank you Andy, it's nicer to get the cover than always the same artist.
I don't wanna klugscheissen, but hovering over the header of a normal album the noartist.cover is shown, cause you defined it so with the $puts (artist_path...).
But I have another problem.
I did a workaround with artist covers which have invalid characters in the artist name.
I put these covers in every single album folder as invalidartist.jpg and defined a constant (also for the artist wallpaper) - so this is ok, but I don't like it cause it's a lot of work.
I have read the Title Formatting Reference 5 times today to find an answer, but I don't make it.
I wanna a title formating which checks if there are invalid characters in the artist , replaces it with space and take the new filename for "%artist%.jpg".
An example: Phantom/Ghost --> Phantom Ghost -->Phantom Ghost.jpg
AC/DC becomes AC DC
Try this,
$replace(%artist%,/, ).jpg
This is mine, for graphical browser
$puts(artist.path,'F:/Artist Images/'$replace(%artist%,/,_)'.jpg')
AC/DC becomes AC_DC
Edit: too many edits
Thx sounds blast, but I want an automatic replacement for every artist with invalid characters.
I thought about to define every single exception but I wanna an automatic method. *grrrrr*
You can add more to it, $replace(%artist%,/, ,*,) etc... try that out, you can test this in the properties window of fb2k, right click the file and go to Properties, and then Right Click On The Artist name and click Fromat From Other Fields, and paste this $replace(%artist%,/, ,*,) and you can see what the name would look like, and if it matches your .jpg then click cancel so it doesn't mess your tag up. Just to preview the name is all.
Edit:, hm automated method, don't know if that's possible
This should replace all invalid characters with space:
$replace(%artist%,/, ,\, ,*, ,?, ,", ,<, ,>, ,|, ,:, )
EDIT:
" doesn't need to be replaced with space, but removed, so:
$replace(%artist%,/, ,\, ,*, ,?, ,",,<, ,>, ,|, ,:, )
Thank you very very much, Sounds Blast and Tedgo - it works perfectly.
I thought there are so much more invalid characters.
That's the punishment for being too lazy for google - ok, I'm not sure if I would have found this answer for myself.
Another question Andy,
could you tell me why popups are destroyed when I put this in the Popup(Track)?
$if($findfile(%__ART_PATH__%),
$puts(art_path,%__ART_PATH__%),
$puts(art_path,$get(foo_path)'images/'$get(config_name)'/cover/nocover.png')
I ask because if I put in your code and there is cover for a sampler, only an empty popup is shown.
a bracket is missing to close the if statement, that's all :
Thank you Br3tt - I'm blind
After putting this in Andy's Popup-Code the Nocover had been shown, but after restarting foobar nothing is shown again - I'm going crazy.
My Popup tweaks - I merged some code from Andy and Br3tt.
Two new Field Definitions
__PHOTO_PATH_ALBUMARTIST__: F:\Eigene Dateien\Eigene Bilder\Artist Cover\$replace(%album artist%,/,,?,,*,,",,<,,>,,|,,:,,).jpg
__PHOTO_PATH_ARTISTGROUPHEADER__: F:\Eigene Dateien\Eigene Bilder\Artist Cover\$replace(%artist%,/,,?,,*,,",,<,,>,,|,,:,,).jpg
Albumartist is for sampler which have not Various Artists but an Single Artist, like DJ XYZ Presents Mega Hits
Artistgroupheader is for showing the Cover in the Groupheader if no Artist is present. In the Track-Popup the Noartist is still shown (I like it so)
Popup(Track) top
$puts(VA,0),
$puts(VA,1))
$if($findfile(%__PHOTO_PATH_COLLECTED__%),
$puts(artist_path,%__PHOTO_PATH_COLLECTED__%),
$puts(artist_path,$get(foo_path)'images/'$get(config_name)'/cover/noartist.png'))
$puts(albumartist_path,%__PHOTO_PATH_ALBUMARTIST__%)
$puts(artist_groupheader_path,%__PHOTO_PATH_ARTISTGROUPHEADER__%)
$puts(art_path,$get(foo_path)'images/'$get(config_name)'/cover/nocover.png'))
$puts(time_of_year,%__DATENAME__%)
$puts(time_of_day,%__TIME__%)
$puts(Remixed_By,$if2(%remixed by%,$if2(%DISCOGS_TRACK_CREDITS%,)))
$puts(katalog,$if2(%catalog%,$if2(%discogs_catalog%,'N/A')))
Popup(Track)
$ifequal($get(VA),0,$if($findfile($get(artist_groupheader_path)),
$imageabs(12,12,$get(cover_size),$get(cover_size),$get(art_path),,)),
$ifgreater($strstr($upper(%album artist%),'VARIOUS'),0,
$imageabs(12,12,$get(cover_size),$get(cover_size),$get(art_path),,),
$if($findfile($get(albumartist_path)),
$imageabs(12,12,$get(artist_size),$get(artist_size),$get(albumartist_path),,),
$imageabs(12,12,$get(cover_size),$get(cover_size),$get(art_path),,)))
Normal Albums show Artist--->Cover
Sampler show Albumartist--->Cover or Cover if there are Various Artists
The problem ist still if there is no Albumcover, then an empty Group-Popup is shown.
I don't know why Nocover isn't working.
Another strange thing is, that if I replace the "%path%,artreader" with $get(art_path) for the Track-Popup, the Nocover is only shown for Songs which have an embedded cover, but not for Tracks with no cover in the folder.
Hey if anyone could help, that would be great. I wanted to show my Artist photo's in a new way. My current string i'm using
$puts(artist.path,'F:/Artist Images/'$replace(%artist%,/,_,\, ,*, ,?, ,",,<, ,>, ,|, ,:, )'.jpg')
I would like to have the %comment% search first, and then if no %comment%.jpg it would search for %artist%.jpg
$puts(artist.path,$if2($findfile(F:\Artist Images\%comment%.jpg),F:\Artist Images\$replace(%artist%,/,_,\, ,*, ,?, ,",,<, ,>, ,|, ,:, ).jpg))
EDIT:
You does mean showing it in PSS or ELPlaylist, right?
EDIT2:
Tried it now, it could be shorter
$puts(artist.path,F:\Artist Images\$if2(%comment%.jpg,$replace(%artist%,/,_,\, ,*, ,?, ,",,<, ,>, ,|, ,:, ).jpg))
No need for $findfile...
EDIT:
Thanks a lot for your time, tedgo, this works perfect with PSS, i will try and modify it for GB/Graphical Browser, and EL playlist
Edit: I just saw your new edit,
EDIT2:
Don't work for me, the %comment%.jpg shows, but %artist%.jpg don't, First codes works, long but works
Tried it in ELPlaylist and it works, but not in PSS...
Can anyone explain me how to put the musics of an album sorted by album, and not like this..
I wanted all the song of an album under the album, just like in the 1st post by Br3tt...
(http://i39.tinypic.com/9s6ljn.jpg)
Cumpz...
This config works and looks great.
I just have two questions.
What is the best way to tag single tracks for use with this config?
Also, will it always show track numbers as question marks with single tracks?
You could try tagging Album Artist: V.A (or something similar).... Usually it gets sorted by that if the tag is there, and that way the Artist tag is still correct (for example it still gets reported to Last.FM right). I'm actually not at my own PC so I can't check if it works, but I imagine it does...
Hope that helps.
It would be great if the album and artist panels would also display the name of the albums/artists on the images.
I've noticed with Curacao that files with a high bitrate (say, in FLAC format for instance) do not have their bitrates shown correctly in the playlist. It seems as though only three-digit bitrates can be shown, so something with more than 1000kbps bitrate does not show properly, it's cut off. Maybe this can be fixed in the next release?
Maybe you download my tweaked version (http://www.onkelandy.com/curacao_tweaked.zip) and use the Group by Single.. At least you can use the code to start tweaking it by yourself..? It actually totally depends on how you want single tracks to look like... Use %el_item_count% to config the behaviour the way you want to!
@Bubi:
Youhave to change the second if-statement below all the variable configurations on the top to this:
$if($findfile($get(art_path)),$puts(cover_size,$ifequal(%el_item_count%,1,%__ART_SIZE__%,%__ART_SIZE_GROUP__%)),$puts(cover_size,0))
Actually here I have just checked for embedded or cover artwork and don't take the nocover-stuff into consideration. Therefore the size was set to 0
I have implemented your adjustments to my code and updated the files - just download it and put the variable "show_nocover" to 1. Actually this feature lets everyone choose if the nocover/noartist should be shown in the popup or not...
What do you mean by that? Actually my tweaked version (http://www.onkelandy.com/curacao_tweaked.zip) shows the title of the album in the "album"-panel (graphical browser) if there is no cover found. Just look at the code and adapt it to your needs (most of that code was provided by Thuan (http://www.hydrogenaudio.org/forums/index.php?showuser=31716) - thanks go to him!)
Maybe you download my tweaked version (http://www.onkelandy.com/ELPlaylist.zip) and use the Group by Single.. At least you can use the code to start tweaking it by yourself..? It actually totally depends on how you want single tracks to look like... Use %el_item_count% to config the behaviour the way you want to!
I just decided to download your config again and there looks like more changes have been made. Anything cool or new or important?
Cumpz...
So, i don`t know how it makes right, but I changed two boxes below
but sometimes after adding albums in playlist I need to rightclick on elplaylist and change "sort"--->preset default, I don`t know how to make it by default.
anyway, take a look on screenshot, maybe it helps you
(http://img183.imageshack.us/img183/7859/24370096ad0.jpg) (http://img183.imageshack.us/my.php?image=24370096ad0.jpg)
(http://img183.imageshack.us/img183/24370096ad0.jpg/1/w1024.png) (http://g.imageshack.us/img183/24370096ad0.jpg/1/)
What do you mean by that? Actually my tweaked version (http://www.onkelandy.com/ELPlaylist.zip) shows the title of the album in the "album"-panel (graphical browser) if there is no cover found. Just look at the code and adapt it to your needs (most of that code was provided by Thuan (http://www.hydrogenaudio.org/forums/index.php?showuser=31716) - thanks go to him!)
I mean it would be nice if the title is shown on or below the cover. Kind of like Chronflow does. Especially with new albums you might know the name but not the cover. At least that's what sometimes happens to me. Also with the images being so small it is hard to sometimes differentiate some groups if the members look similar.
@Freedom-loving
Go to Preferences-->General-->Sort incoming files by
and set the pattern you want to sort files by default, when added to a playlist
Btw. you have a strange pattern in your ELPlaylist.
With your pattern, some albums wouldn't be sorted correctly, e.g. you have a "Greatest Hits" from 1990 by artist A, and another "Greatest Hits" from 1990 by artist B.
They would be sorted like this:
Track 1 artist A
Track 1 artist B
Track 2 artist A
Track 2 artist B
You probably should change the pattern to:
%album artist% - %date% - %album% - %discnumber% - %tracknumber% - %title%
Has anyone had a problem with minimizing the player to the taskbar and when you go to maximize it, the player won't show itself. The music continues to play, but I have to close and reopen foobar. When I do, the player is small and you have to drag a corner to see the config. Anyone? I've only had this happen a few times.
how can i sort playlist like %artist% - %title%? now it shows only title
(http://img147.imageshack.us/img147/9672/sshot23ht6.jpg)
Use the tweaked version (http://www.onkelandy.com/curacao_tweaked.zip), right-click and choose "Group/Sort by -> Title". You can also define specific playlists where this sorting should happen all the time when you go to the settings of ELPlaylist..
Use the tweaked version (http://www.onkelandy.com/ELPlaylist.zip), right-click and choose "Group/Sort by -> Title". You can also define specific playlists where this sorting should happen all the time when you go to the settings of ELPlaylist..
Great, thanks a lot
I really love Curacao!
One questions though - I used the tweaked file of Uncle Andy cause I read something about embedded cover art support. I tried it but the embedded covers aren't displayed it all. Anyone know if that's possible? EPlaylist should support this feature
I've added that possibility to the new tweaked version (http://www.onkelandy.com/curacao_tweaked.zip).. If you want to use embedded artwork (could lead to performance problems!) set the __EMBEDDED_ART__ under settings/field definition to 1.
I've also filled some other requests so maybe re-downloading (changed the filename!) makes sense. Here is a list of all the changes (maybe not complete..):
CURACAO TWEAKED version features/tweaks (most features are optional, see bottom!):
ELPlaylist:
* Playlist Grouping: Use group/sort by to get different visual styles of your playlist.
* Implementation of History-Plugin: When you use foo_navigator, the "History" grouping is for you. It sorts and displays by "last played" and groups the entries based on the day played. Under "field definition" set __HISTORY__ to the name for the playlist your history is stored in. Do the same in the grouping-tab/Group by History dropdown/playlist filter
* Show Album art for Single- or Soundtrackfiles in the playlist as well as relevant comment-info. (see"setting options" for further info)
* If genre is "Tribute" or a various artist album has "Tribute" in the comment-tag the specific tribute-info is shown in the group header. Additionaly it's sorted by original artist. Means: an AC/DC tribute is listed below the AC/DC albums and not at the end under "Various" - change this behaviour with the __TRIBUTE__ field definition!
* Use of embedded artwork in group header if you want to (see "setting options" below)
* Sorting and grouping with swapprefix(The,Die)
* Re-arranging german umlauts, sorting by release date if available (for greatest hits or own compilation albums)
* trimming special characters from filenames for artist or cover-images
* Lyric-Icon also showing when LRC-File exists, not only tag
* search for artist image in the parent directory and not only in centralized folder
* minor tweaks like 2-digit discnumbers, auto-fill tracknumber, etc.
* POP-UPS: complete redesign with following features for single songs:
- optimized background-image
- automatic resize
- listing of some additional tags, if existing
- special treatment when "Single" in comment-tag is found (for those who tag Single B-Sides with the same album as the original album release and put the info where the sond is really released on in the comment field.. )
- icon for existing lyrics and cover
- showing artist picture if available
- showing embedded cover if available, else cover defined in the "field definition"/__ART_PATH__
* POP-UPS: complete redesign with following features for group headers:
- no popup if no picture found or "nocover.png" shown if you set __SHOW_NOCOVER__ in the field definition to 1
- intelligent display of artist or cover album, depending on whether it's a various artist-album or not
- use of embedded artwork
Graphical Browser:
- Sorting and grouping based on prefix "The", "Die" and german umlauts (same as elPlaylist)
- totally redesigned album/artist-browser based on Thuans great config. Features are:
display info for missing artwork, show play-icon (in images-folder) on playing album/artist
- of course.. popups
- directly jump to the specific artist in the playlist when clicking on letter without waiting for hours Needs the foo_utils plugin though!!!!
SETTING OPTIONS in elPlaylist settings under field definition:
__TRIBUTE__: set to 1 when you want to show the Tribute-info in group header and sort tribute-albums below original artist (needs Tribute-genre or "Tribute" in comment-tag)
__SHOW_NOCOVER: set to 1 when you want to see the nocover/noartist-image in the group-popups. If set to 0 no popup will be shown if no picture for artist or cover is found.
__COMMENTCUT__: cut comments in popups to this amount of characters
__SINGLE_ARTWORK__: show embedded artwork next to the ratings in the playlist, if song has "Single"/"Tribute"/"Soundtrack"/"Bonus" written in the comment field or %original album%-tag. This is useful when you make Rarities-compilation for artists and put the additional info of the original release in the comment-tag
__HISTORY__: name of the playlist that lists all played items (needs foo_navigator plugin). also set that name in the grouping tab!
__PHOTO_PATH_COLLECTED__: if you collect artist images centrally, set this to that specific folder
__PHOTO_PATH_PARENTDIR__: looking in parent directory for %artist%.jpg, if "collected path" is not found
__PHOTO_PATH_ALBUMARTIST/ARTISTGROUPHEADER__: special treatment of various artist album popups
__ART_SIZE__: cover and artist picture size in single song popup
__ART_SIZE_GOUP__: cover and artist size in group header popup (normally larger as only the picture is shown and no text)
__EMBEDDED_ART__: set to 1 if you want to use embedded artwork. If you experience performance problems just set it to 0!
I got some nice sorting problem... Normally the sorting by "$swapprefix(%album artist%)" is fine... but I just found a release where the artist of some of the songs is identical with the album artist. For example "Faithless Renaissance 3D". It's some sort of remix album with various artists, but actually the album artist is "Faithless". They also contribute some own songs to it, so they are listed first and the other artists are then sorted below by tracknumber.. Any idea?
No more chronflow in this release ?
With tons of albums, it's very hard to use this, how do you make it ?
It's not THAT hard, although performance isn't best with all the covers shown.. If you're talking about difficulties with navigation use these features:
- alphabetical list at the top
- artist-list in upper right
- album / artist graphical browser at the bottom (switch is on lower right).
It mostly makes sense to use "highlight selected item in playlist" on single click what is possible with the foo_utils plugin.
Hmmm yeah, but i was really fond of Chronflow
I was asking also
is there always a search field ?
is it possible that when I re-open foobar that its positionned on the last played album ?
is it possible to put a chronflow instead of the "album / artist graphical browser at the bottom", i got tons of albums, and browsing the covers was really usefull, now it takes me 500 clicks to see my entire collection
Thanks a lot for this release, it's really great !!!!
And also thanks for your reply(ies)
Merry xmas
@ Onkel Andy
Many many thanks for sharing your config! You added some nice touches there
I decided to put every single song in a seperate folder together with an appropiate folder.jpg (besides album-rips!). This works quite well cause now each song has its individual cover which will be displayed in the left album display and also the graphical browser
(Without the folder. jpg's, the embedded covers will only pop up in the playlist, but not on the graphical browser and the big left album side.)
I will still continue to integrate covers into my mp3s, 'cause I'm a Sansa User and I love them to see on my display
Followed your instructions, worked like a charm
Thank you so much for this wonderful Theme
Using Foobar2000 0.9.5.6 version
@ Onkel Andy
Yep it's a pity, that the great graphical browser isn't developed any further and doesn't support embedded art
A question to all here in the thread: where did you get the
pictures of the artists from and would it be possible to share all your pictures here and trade them..?
I was asking also
Actually it's quite easy to implement
coverflow by yourself. Go into the preferences, columnsui/Layout. Right-click on the fourth "Panel Stack Splitter" from the bottom and choose Insert Panels/Panel/Chronflow. That's actually it. By clicking the "..." on the lower right in the skin you see the coverflow. You could use this code to make it work in the quite thin panel a little bit better:
function coverPosition(coverId){
var x, y, z;
x = coverId * 1.1;
y = 0;
z = -1.3 - Math.abs(coverId)/4;
return new Array(x, y, z);
function coverRotation(coverId){
var angle;
// this makes the covers disappera smoothly
if (Math.abs(coverId) >= 8){
var f = Math.abs(coverId) - 2 // this is in [0-1]
// at this angle the covers are not visible
var hideAngle = rad2deg(Math.atan(coverPosition(3)[2] / coverPosition(3)[0]));
angle = hideAngle * f;
if (coverId > 0)
angle *= -1;
} else {
angle = 0;
return new Array(angle,0,1,0);
function rad2deg(angle){
return angle/Math.PI * 180;
function coverSizeLimits(coverId){ return new Array(1, 1) }
function coverAlign(coverId){ return new Array(0, 0) }
function drawCovers(){ return new Array(-9, 9) }
function aspectBehaviour(){ return new Array(0, 1) }
function eyePos(){ return new Array(0, 0, 0) }
function lookAt(){ return new Array(0, 0, -1.5) }
function upVector(){ return new Array(0, 1, 0) }
function showMirrorPlane(){ return false }
As far as the
search field is concerned... I'd also request this for the next update Actually when you go through the code of the config you'll find out how to do it yourself, but, well...
To make the
last played album focus on restart activate "resume playback after restart" in the preferences under "Playback". If you don't want to play it automatically I'm sure there are other plugins that achieve what you want..
Thks a lot, i'll give a try tommorow, it's party time here.
Merry x-mas to all
Br3tt, a small observation I made is that when playing a flac file with a 4 digit bitrate it Curacao does not show it correctly in the playlist. It only displays 3 digits, so a bitrate of 1011 kbps will be displayed as .011 in the playlist.
Also, is it possible to ad a popup field to show the artist name when hovering the mouse pointer over the artist pic in the artist browser. Much like windows does when hovering the mouse pointer over a browser tab.
See example:
(http://img150.imageshack.us/img150/6499/27371376oq2.th.jpg) (http://img150.imageshack.us/my.php?image=27371376oq2.jpg)
In ELPlaylist settings,
Track List and
Per Second tab, replace :
$puts(bitrate_info_width,54)
by
$puts(bitrate_info_width,60)
Thanks dutch109
Is it possible to sync the playback and artist stats with LastFM? I think I saw a component for that once. It would be a nice addition to the next version. That way those of us that use multiple devices to scrobble songs (PC, laptop, iPod...) could get up to date stats in the Curacao stats.
It's me again,
Thanks a lot for the help, i'm getting a perfect impl of foobar, thank u very much !!
I was wondering if it was possible to automatically retrieve artist pics from Last.fm ? Because i don't have any artist pics and they got probably most of them
Thanks for good foobar2k theme.
I like this skin very much, but have problem.
When minimize or retore foobar2k window with this config, Windows is often freezing.
There is no error reporting, no foobar failure log, just system freezing without mouse cursor.
Reset or turn-off are only solution that I can.
I tested minimize and restore with auto clicking program.
It crashed all the time less than 1000 times minimize-restore.
Someone have same problem like me?
my system
E4500, 4G ram
Radeon 3850 (8.12)
Audigy2, ALC888
Windows Vista Ultimate SP1 x64
foobar2000 0.9.6
components only include Curaçao 1.2a
First of all big props for piece of a great job! Awesome theme!
I got some questions about it:
1) How could i understand that path: Z:\_artists_\%artist%.jpg ?? Have no clue how to get that __PHOTO_PATH__ working.. My foo displays album art on the left, and also the same album art as a background of my playlist.. Is that the way it should be done?
2) Can i replace displaying Lyrics with File Properties on the left?
3) I also got album arts in different formats (jpg, gif, png.. all of them named cover.*), so can i anyhow make foo search for more album art formats than only jpg? I found that line: "$replace(%path%,%filename_ext%,)cover.jpg" but dunno if there is any way to get it modified that way..
Sorry if questions were already mentioned, and thanks in advance for any answers.
Really nice
Use something like this in the _ART_PATH_ variable:
$if3($findfile($replace(%path%,%filename_ext%,cover.png)),$findfile($replace(%path%,%filename_ext%,cover.jpg)),$findfile($replace(%path%,%filename_ext%,cover.gif)) )
The PHOTO_PATH is for the artist pictures.. These are only shown when found, otherwise u'll see the cover of the album.
AS far as the "file properties"-question is concerned: yes, you can Easiest way would be to use this in the Formatting String tab of Lyrics Show panel:
$puts(time_of_year,$right($substr(%last_played%,9,10),2)'. '$select($substr(%last_played%,6,7),January,February,March,April,May,June,July,August,September,October,November,December)' '$substr(%last_played%,1,4))
$puts(time_of_day,$substr(%last_played%,12,13)$substr(%last_played%,14,16))
$if(%artist%,FFFFFFArtist: %artist%)
$if(%original artist%,$crlf()C0C0C0Original Artist: %original artist%)
$if(%origartist%,$crlf()C0C0C0Original Artist: %origartist%)
$ifequal($get(comment),2,$crlf()C9B8B8Album: %comment%,$if(%album%,$crlf()C9B8B8Album: %album%))
$if(%title%,$crlf()C9B8B8Title: %title%)
$if(%featuring%,$crlf()C9B8B8Featuring: %featuring%)
$if(%remixed by%,$crlf()C9B8B8Remix: $crlf()%remixed by%)
$if(%date%,$crlf()C9B8B8Year: %date%)
$if($or(%genre%,%publisher%,%bitrate%),$crlf(),)
$if(%genre%,$crlf()C9B8B8Genre: %genre%)
$if(%publisher%,$crlf()C9B8B8Publisher: %publisher%)
// $if(%bitrate%,$crlf()C9B8B8Bitrate: %bitrate% Kbit/s)
$if(%BPM%,$crlf()C9B8B8BPM: %BPM%)
$crlf()
C9B8B8Filesize: $div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2) $get(anno)'MB'
$crlf()
$ifequal($get(comment),1,$crlf()C9B8B8Comment: %comment%,)
$if(%play_counter%,$crlf()C9B8B8Playcount: %play_counter%)
$if(%last_played%,$crlf()C9B8B8Last Played: $get(time_of_year) at $get(time_of_day) )
If you don't want to show lyrics at all just check the other options of the plugin (tag to read from; automatic download)
my system
E4500, 4G ram
Radeon 3850 (8.12)
Audigy2, ALC888
foobar2000 0.9.6
I also have the same problem, and I'm also on Vista 64 bit. I have no idea how to fix the problem though.
The file properties is a very nice addition onkel andy. Just too bad it's either lyrics or file properties and not both at the same time. One advantage is I now can put a total bio of the artist in the comment tag and view it completely when I enlarge the lyrics panel.
(http://img166.imageshack.us/img166/2525/jimmyreedvt6.th.jpg) (http://img166.imageshack.us/my.php?image=jimmyreedvt6.jpg)
This is an amazing theme!! Thank you so much for all your hard work on it...
I do have a question though - the album art string is configured to use folder.jpg... however, in the past I have been able to replace this with a wildcard, like *.jpg so that it shows the first JPG it finds in the folder... this doesn't seem to be working in this theme, however. Does anyone know how to get this working? I did some searching around and found a discussion about this in another theme thread:
http://www.hydrogenaudio.org/forums/index....=33&t=65618 (http://www.hydrogenaudio.org/forums/index.php?act=Print&client=printer&f=33&t=65618)
They mention that the below code can be replaced with the line below it to use wilcards:
$if3($findfile($replace(%path%,%filename_ext%,folder.jpg)),$findfile($replace(%path%,%filename_ext%,*.png))etc.etc
However, when I tried using this in Curacao, everything went black! Of course I removed the etc.etc. from the end and changed *.png to *.jpg... otherwise, I'm not much of a code expert!
Does anyone know how to get wildcards working for album art JPG's in Curacao? Any help would be much appreciated... thanks!
elPlaylist doesn't support wildcards afaik. So you must use the code you mentioned in the elPlaylist definition called __ART_PATH__. The problem with your code is that first of all you'd need at least 3 arguments to make $if3 work (or use $if2 instead) and second you need to close the $if statement with another )! Then it will work.. Actually I'm repeating myself as I've already posted the correct code only 3 posts above!
Thanks - sorry I missed that earlier post... this works great for ELPlaylist, but doesn't seem to work for the large album art display when I replace the below code with yours:
$puts(cover.path,$directory_path(%path%)\folder.jpg)
Also, I am using the original Curacao as opposed to the tweaked version... should I use the tweaked version? Would this be made any easier using Curacao Tweaked? Please let me know, thanks!
Well, the tweaked version has the code for different covers in it in several spaces. You may have to right-click the album picture and adapt the code a little bit, but u'll see how it works immediately.. Give it a try.
I know you have gotten a lot of replies at this point about what a great job you have done with this. Please allow me to add one more. I usually use the default ui but this thing rocks!! It's awesome on a big screen. Thanks!!
Use something like this in the _ART_PATH_ variable [...]
Thank you very much mate! It was what i was lookin' for..
The PHOTO_PATH is for the artist pictures.. These are only shown when found [...]
Found where? On my disk? And what path?
Is it possible to have ELPlaylist show the same part of the playlist upon starting up as it did when you shut foobar off the last time? Kinda like a resume function.
That would be awesome, but I think it may have been requested in the past...
hey, i love this config...the first with panel splitter i love since panels ui...
my problem: is it possible to show the status of "stop after current" in a panel with an icon?
in panels ui i used this for switchable and display status of "stop after current"
$if(%cwb_stopaftercurrent%,$button($add($div(%_width%,2),104),108,0,0,28,28,/images\menue\m_tri_rot.png,/images\menue\m_tri_h.png,stop after current,TOOLTIP:"Stop after Current"),
$button($add($div(%_width%,2),104),108,0,0,28,28,/images\menue\m_tri.png,/images\menue\m_tri_h.png,stop after current,TOOLTIP:"Stop after Current"))
so the button changed from green to red...
thanks
lg frank
thanks
lg frank
%cwb_stopaftercurrent% was brought by cwb_hook component which is no more supported by foobar since 0.9.5.3 (like PanelsUI)
so ... from my knowledge level, it's not possible to detect the status of Stop After Current ...
thanks
lg frank
thanks falstaff,
and a funktion like $if($isvisible_c(Stop After Current) simular to $if($isvisible_c(Playback Order Default) is not possible?
lg frank
Not exact what you want, but after restarting foobar press play and the Activate Now Playing button.
Uhm care to explain which one the 'Activate Now Playing' button is? Otherwise thanks. I'll try it once I know which button you mean.
hi how can i change the settings that allways the same wallpaper is showed?
Where the Playback Buttons are, the second from the right.
The instructions for this config in the first post of this topic indicates that you should read the tutorials. I'm pointing you in this direction, since your question has been answered by them. Check Br3tt's tutorial here (http://br3tt.online.fr/tutorials/index.htm).
It's not exactly what I want but I can work with that. Thanks again
hi,
when i export the settings i have yet to a new .fcl file and import them again after ive used another skin, are ALL informations restored?
So that everything is stored in the .fcl file?
thx
Hey,
what a wonderful config for foobar !! Thanx alot !!! I really like it - it´s the best one!!
Thanks Br3tt finally I can use new foobarversions.
Two Ideas:
- is it possible to add a "hide titlebar - option" like in the old PANELS_UI config ?
- I wold like a integrated a working coverflow oder chronflow-panel in this great skin - maybe a slime one instead the Covershow-Panel next to AVS...
Thank again to Br3tt !!
Rolf
hi,
thx
A good question.
I would like to know the difference between "Any Foobar2000 Installaiotn" and "This Foobar2000 Installaiotn"for export.
@rolf: you can put chronoflow instead of the graphical browser in the panel, but it's very very small, so it's hard to see something.
Hey,
Two Ideas:
Rolf
You can hide the toolbar in the menu View - show toolbar. Falstaff stated his reason for excluding chronflow earlier in this topic.
Hey Br3tt, again, great config.
I dont know if it was asked already but when i listen to the online radio after 1 minute that message appers -> Could not update tags (Access denied), and then -> Unable to resume decoding at 1:03.242 (Unsupported format or corrupted file).
Any idea?
edit: problem solved, just disable playback statistic update timing or update when track is ended.
I'm having this same problem. Is there a solution for this? Earlier it worked fine but when i re-installed my foobar and loaded config this happened.
i can't reproduce that, all is fine here ... be sure that you have foobar installed in C:\Program Files\foobar200\
like described in the installations notes.
SOMETIMES i have the same problem like Teukka and the others BUT it is 1/60 runs only & it is a lottery. most often when foobar is called from external file like mp3 (it is reminding me problem of ibiza config). One more thing my 9.6.1 portable is installed/extracted? D:\fb2k\ and all is working OK most of the time, so c:\program files\foobar2000\ isn't a must anyway THANX Br3tt for an awesome config. I am voting/asking (if i can...) for the next version to include Onkel Andys tweak.
Hey,
Two Ideas:
Rolf
Sorry - but you don´t understand !
I like to hide the titlebar - not status-bar and not toolbar !!
http://www.pikipimp.com/pp/pimped_photo/s/...bar-preview.JPG (http://www.pikipimp.com/pp/pimped_photo/s/image/40/327/133/titlebar-preview.JPG)?
hidding titlebar not possible in ColumnsUI interface like Curacao (only PUI allow that)
btw an extenal program (autohotkey with an adapted script) that lauch foobar can do the job but not very practical because without the title bar, no way to move the foobar window
@rolf1955 many programs can do it (O&O defrag, Photoshop... many cannot -Opera browser -YET). as a workaround try mine
%artist% - %title% - %_time_elapsed% / %length% $info(tool) <> $info(bitrate)/%bitrate% <> %_foobar2000_version% %replaygain_track_gain%
Hey,
nice to talk with the master himself, aren´t you ... ;+)
First thanx for reply - i have a solution for moving foobar without titlebar --> with "Advanced Controls" ( http://www.niversoft.com/products/fac (http://www.niversoft.com/products/fac) ) you can hide or show foobar - and ( at least at my last conif I had - "FofR config" - similar to Br3tt Curacao --> http://www.fooblog2000.com/category/config (http://www.fooblog2000.com/category/config) ) wich was working with PUI, position move was possibe by moving the dash panel.
..., position move was possibe by moving the dash panel.
which 'dash board' are you talkingabout ? could you explain + screenshot please ?
Thx by advance
Thx by advance
[/quote]
Hey,
Here - that´s what Italkin about:
http://img165.imageshack.us/img165/1619/grabitthereko9.jpg (http://img165.imageshack.us/img165/1619/grabitthereko9.jpg)
Grab it at the dashboard to move the player.
Hey,
i see that you have not tested yet (lol), the zone that you indicate as 'dash board' is no more a anchor because it's a PSS panel. The only way to move a window is to use the titlebar area.
try this : http://br3tt.free.fr/files/foobarrun.7z (http://br3tt.free.fr/files/foobarrun.7z)
extract the 2 files in the foobar2000 folder, then launch foobar with the fobarrun executable, you'll see that there is no dragable area.
[/quote]
[/quote]
Thank you !!
well - interesting. It´s a nice view now, but no real way to move, right! ...but so it´s may be possible to use the player as a kind of desktop-player, you know - instead the wallpaper. Not also so bad....
But - of course - it´s a little pitty - theres nearly no way to move it anymore - but one circumstantially:
you can fit the size on the edges and so you "can manoeuvre" the window across your screen.
focus window, ALT+SPACE / MOVE / ENTER, them vove with arraw keys, or after first move with an arrow key it moves by following the mouse
Hey - cool !
funny thing you freak !!
thanx !!
yep, thanx for the tips! never try the arrow keys to move
notes that after a arrow keypress, then mouse's move works
I'm trying to get this to work with a portable version of foobar2000 (not installed in C:\program files\foobar2000). Does anyone have any tips on how I can make this work, without having installed in the default directory?
nevermind
I've been getting some fatal errors when I try to start foobar recently (with Curaco installed). It was doing fine for awhile, but now just about every time I shut my computer down and start it up again a different time, foobar fatals 2 or 3 times before it will actually load. It has done this with both Br3tt's Curaco version and the tweaked version now. I saved a few copies of the error reports that are created in Notepad when it fatals, so hopefully they will help in solving this problem.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01599BF9h
Access violation, operation: read, address: 01826000h
Call path:
entry
Code bytes (01599BF9h):
01599BB9h: C7 8D 73 1C 8D 50 02 66 8B 08 83 C0 02 66 85 C9
01599BC9h: 75 F5 2B C2 D1 F8 50 8B C7 E8 D9 7A FF FF 8B 5B
01599BD9h: 30 8D 3C 5F 33 C9 66 3B 0F 75 1A 8B 54 24 10 8B
01599BE9h: 44 24 20 03 C2 8B FF 3B F8 73 0A 83 C7 02 33 C9
01599BF9h: 66 3B 0F 74 F2 8B 54 24 14 8B 4A 0C 85 C9 75 04
01599C09h: 33 C0 EB 08 8B 42 14 2B C1 C1 F8 03 8B 5A 10 8B
01599C19h: D3 2B D1 C1 FA 03 3B D0 73 2E C6 44 24 1C 00 8B
01599C29h: 44 24 1C 8B 4C 24 1C 50 51 8D 74 24 30 BA 01 00
Stack (0012F188h):
0012F168h: 00EADCDC 7C9C94F8 77F643DD 7C9C94F8
0012F178h: 00000004 00000000 00EAD1E8 00000000
0012F188h: 0012F308 01825350 00000000 0012F308
0012F198h: 000001C8 015E1458 01824540 0012F200
0012F1A8h: 01825E38 000001C8 01824540 01824610
0012F1B8h: 0049DFB1 0012F218 00000004 0012F22C
0012F1C8h: 015CF690 00000001 01825350 0012F238
0012F1D8h: 015B11D8 0012F204 000001CC 0012F328
0012F1E8h: 00000BFC 01F7660F 0012F358 AA81D745
0012F1F8h: 43A64C62 6920FEAD 39481087 015D7F54
0012F208h: 0012F308 00000000 00000000 015E04CC
0012F218h: 000001CC 00000000 01824F28 013C8A20
0012F228h: 0012F1E8 0012F2DC 015CF11A 00000001
0012F238h: 0012F2E8 015BA70F 0012F308 0012F328
0012F248h: 0041AB95 0012F308 0012F328 0012FD70
0012F258h: 004E72D4 0000027C 0012F2A0 7C90E900
0012F268h: 7C910040 FFFFFFFF 0001003D 0000000D
0012F278h: 0012F1D4 0012F1D8 0012F2C0 7C90E900
0012F288h: 7C910040 FFFFFFFF 7C91003D 01312F55
0012F298h: 01390000 00000000 01312F74 1C299799
Registers:
EAX: 01826000, EBX: 00000041, ECX: 00000000, EDX: 000001C8
ESI: 0182455C, EDI: 01826000, EBP: 0012F1D4, ESP: 0012F188
Crash location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Loaded modules:
foobar2000 loaded at 00400000h - 00539000h
ntdll loaded at 7C900000h - 7C9AF000h
kernel32 loaded at 7C800000h - 7C8F6000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F02000h
Secur32 loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F59000h
USER32 loaded at 7E410000h - 7E4A1000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D7000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 1002A000h
UxTheme loaded at 5AD70000h - 5ADA8000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
LgWndHk loaded at 003D0000h - 003D7000h
MSCTF loaded at 74720000h - 7476C000h
msctfime loaded at 755C0000h - 755EE000h
foo_lyricsgrabber loaded at 00AB0000h - 00B04000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
WINMM loaded at 76B40000h - 76B6D000h
foo_menu_addons loaded at 00BF0000h - 00C4D000h
libmmd loaded at 00C60000h - 00F11000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_uie_panel_splitter loaded at 00F40000h - 00F8F000h
gdiplus loaded at 4EC50000h - 4EDF6000h
foo_ui_columns loaded at 00FC0000h - 010F2000h
foo_playback_custom loaded at 01120000h - 01165000h
WINSPOOL loaded at 73000000h - 73026000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_uie_vis_channel_spectrum loaded at 011B0000h - 011ED000h
MSIMG32 loaded at 76380000h - 76385000h
foo_albumlist loaded at 01210000h - 0127B000h
foo_ui_std loaded at 012A0000h - 01374000h
foo_uie_trackinfo_mod loaded at 013A0000h - 013F6000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
foo_uie_wsh_panel loaded at 01410000h - 0143F000h
foo_uie_lyrics loaded at 01590000h - 015EC000h
WININET loaded at 78050000h - 78120000h
Normaliz loaded at 01600000h - 01609000h
iertutil loaded at 78000000h - 78045000h
foo_input_std loaded at 01830000h - 0196C000h
foo_dsp_std loaded at 01990000h - 019D8000h
foo_skip loaded at 01A00000h - 01A0C000h
MSVCR90 loaded at 78520000h - 785C3000h
foo_uie_graphical_browser loaded at 01A30000h - 01AC4000h
foo_uie_elplaylist loaded at 01AE0000h - 01B47000h
foo_vis_shpeck loaded at 01B70000h - 01B9A000h
foo_converter loaded at 01BB0000h - 01C1C000h
foo_masstag loaded at 01C40000h - 01C83000h
foo_cdda loaded at 01CB0000h - 01CF1000h
foo_uie_albumlist loaded at 01D20000h - 01D5D000h
foo_uie_quicksearch loaded at 01D80000h - 01DC6000h
foo_lastfm_radio loaded at 01DF0000h - 01E36000h
foo_rgscan loaded at 01E60000h - 01EBB000h
foo_run loaded at 01EE0000h - 01F0E000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
VERSION loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 015E1458h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 0049DFB1h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 015CF690h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015B11D8h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015D7F54h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015E04CCh, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 013C8A20h, location: "foo_uie_trackinfo_mod", loaded at 013A0000h - 013F6000h
Address: 015CF11Ah, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015BA70Fh, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 0041AB95h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E72D4h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 01312F55h, location: "foo_ui_std", loaded at 012A0000h - 01374000h
Address: 01312F74h, location: "foo_ui_std", loaded at 012A0000h - 01374000h
Address: 004E8CC4h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C622Bh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 01590000h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015E01F4h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 004DC8A0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DC378h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00417F14h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D8D5Fh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 77E3BEC3h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Address: 77C20621h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "wfullpath" (+00000093h)
Address: 00DF96B1h, location: "libmmd", loaded at 00C60000h - 00F11000h
Symbol: "_csqrtq_f90" (+00196D75h)
Address: 01A6DC95h, location: "foo_uie_graphical_browser", loaded at 01A30000h - 01AC4000h
Address: 01AE79B9h, location: "foo_uie_elplaylist", loaded at 01AE0000h - 01B47000h
Address: 7CB38959h, location: "SHELL32", loaded at 7C9C0000h - 7D1D7000h
Symbol: "Ordinal211" (+0000EF1Ah)
Address: 776067E8h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 00503200h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DD46Ch, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 01000000h, location: "foo_ui_columns", loaded at 00FC0000h - 010F2000h
Address: 00503220h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C9090h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00439CF0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D8DECh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 004B5983h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004B0020h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004B3DD8h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 1000258Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 004DF52Ch, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CA1CAh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 0043A100h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE1B1h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE1ABh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D0B64h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CEED0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE1BFh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CA3A8h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AFC0Ah, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C817067h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AC0h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C817070h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004AFC75h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 00539000h
Version info:
foobar2000 v0.9.6
UNICODE
Windows 5.1
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]
Moderation: Code => codebox. Probably caused by "foo_uie_lyrics", fyi.[/size]
The best! Anyway, is the Avril background is default? Can it be changed?
I've noticed that I can slightly improve smoothness when scrolling by reducing the size of teh background image (wallpaper.jpg). I think originally it's 300KB, but I used Photoshop to reduce it (save for web and devices option) down to around 48KB!
It's improved smoothness in scrolling in the playlist for me. Could anybody else verify this for me?
ohoh, i'll test that and give you feedback asap, could be a good news to improve curacao a little more
brb
Hi, when i search for lyrics, the field "artist" is empty and i have to fill the artist in manually!
How can i fix it that its automatically?
Preferences-->Lyric Show Panel-->Internet-->Titleformating for lyric search-->Artist: $if2(%artist%,)
still isnt working!
Last thing I would know:
- Filter Artist while download
tested, it's false... i have scrolled down a full playlist of 630 tracks with a background image very huge (~5Mb), it takes 22,6 seconds to reach the bottom with key down pressed. After converting the image to 186 Kb, same result : 22,6 seconds.
I have a problem with this beautiful Design. The "things" on the left side doesnt work. You can see it on the screenshot. What is wrong? Thanks for your help!
(http://img206.imageshack.us/img206/7998/foobarcuracaoyl5.th.jpg) (http://img206.imageshack.us/my.php?image=foobarcuracaoyl5.jpg)
Did you read the instructions?
i think it's because you have not the good version of the component panel stack splitter !!!
grad the last one here : http://foo2k.chottu.net/ (http://foo2k.chottu.net/)
that will fix your pb!
Ah... thanks... simple... That was the problem. Thanks a lot.
Ah, too bad... I guess it just felt faster. Hopefully there's something we can still find to improve scroll speed!
... a recent CPU ?
Hi Br3tt,
I put an additional panel with Playlist Tree Mod and Playlist Tree Mod Search
(http://www.abload.de/thumb/pltmartn.jpg) (http://www.abload.de/image.php?img=pltmartn.jpg)
But the search don't work - I push enter but nothing happens. It only works if I do it with Dockable Panels.
Do you know why?
thx in advance
Is there a way to close the lyrics box by default?
Thanks! That's a wonderful config! Thanks for sharing this one with us.
The only problem for now is that the config does not show the album art. It always shows the default album art picture. Both in the top left pane and the ALB pane with current albums in the list show at the bottom.
The code for the top left pane to display the album art I believe is
$puts(artist.path,'C:/Program Files (x86)/foobar2000/artist/'%artist%'.jpg')
The code for the ALB pane at the bottom is
$puts(cover.path,$replace(%path%,%filename_ext%,folder.jpg))
$puts(artist.path,'C:\Program Files (x86)\foobar2000\artist\'%artist%'.jpg')
Both as I said show the default album art only no matter if I have *.folder*.jpg file in the folder with audio files I play or not.
However, I know that the code for the Popup Plus panel works perfectly. It always shows the album art with the picture that resides in the same folder as the audio file.
The code for the PopUpPlus panel is
$replace(%path%,%filename_ext%,*front.jpg)
$replace(%path%,%filename_ext%,*.jpg)
$replace($replace(%path%,%filename_ext%,),%directoryname%\,*front.jpg)
$replace($replace(%path%,%filename_ext%,),%directoryname%\,*.jpg)
Could you please help me understand how do I change the code for the top left pane Uand the ALB pane to work the same way as the PopUpPlus does?
Could you please provide the proper code to render the album art the same way the PopUpPlus component does? Pleeeaase, it sooo disappointing to see album art not displaying in the foobar window when Popupplus just does it well.
I believe I would just slightly change these lines in config. But how?
Thank you.
Thank you.
i may be worng, but i think if your album arts have completly random names, there is no solution, as *.jpg doesn't work.
if you have different names, two or more different filenames for album arts, like cover.jpg or front.jpg, you can use them both, using $findfile
for example
$if($findfile(folder.jpg),$puts(cover.path,$directory_path(%path%)\cover.jpg),$puts(cover.path,$directory_path(%path%)\folder.jpg))
but your filenames have to be conform to a spefic foramt scheme, otherwise i see no possibilty
but i guess there are effective ways for mass renameing, just google for "batch rename"
sorry, i was wrong.
$findfile works different from what i thought
this code should do it:
$puts(cover.path,$findfile($replace(%path%,%filename_ext%,*.jpg)
it searches your folder for any jpg files and shows you the first found.
thanx for the tips on $findfile()
btw, the right syntax for your example is :
$puts(cover.path,$findfile($replace(%path%,%filename_ext%,*.jpg)))
How can I disable playback statistics?
(http://www.shrani.si/t/l/FG/VHsyhUK/foo.jpg) (http://www.shrani.si/?l/FG/VHsyhUK/foo.jpg)
but still (after 60 seconds)
(http://www.shrani.si/t/N/Jd/4YHteka2/foo.jpg) (http://www.shrani.si/?N/Jd/4YHteka2/foo.jpg)
I tried to remove foo_playback_custom but no luck.
Also another question. VA albums are sorted like this
(http://www.shrani.si/t/3p/hU/1nspNAn3/foo.jpg) (http://www.shrani.si/?3p/hU/1nspNAn3/foo.jpg)
Why cant they be sorted like normal albums?
1. Hmm, do have also official Playback Statistics (foo_playcount)?
2. You need an entry in the %album artist% Tag, eg. Various Artist. Look at ELPSettings-->Grouping-->Group Format there is the query for grouping.
Thanks man.
Thanks for all this info! I do have a couple questions tho...
1) Is there any way I can rate songs without having the file itself updated? That is, I would like to use the rating tool in Curacao (the 5 stars + the "heart") but I don't want the "Date Modified" for my files to change. Can the ratings be redirected to a database instead, such as foo_custominfo? Does the rating have to be updated within the file itself? Also, are there any settings for the rating system? I don't see a component or anything under Preferences to modify the song rating tool. I have both foo_playcount.dll and foo_playback_custom.dll installed, but only see options for Playback Statistics Custom in Preferences, and these all deal with playback stats, not ratings. I do have these set to save their stats in foo_custominfo database, so as long as I don't rate a song, the Date Modified does not change. Once I rate a song, however, the Date Modified updates to that date/time. Should I remove foo_playcount.dll?
2) I am using Curacao Tweaked and have ELPlaylist working with the *.jpg wildcard for album art. However, the "
ALB." album "chronflow" at the bottom and the large album art above the lyrics section still don't work with *.jpg. Has anyone been able to figure out how to get these two working with JPG's named something other than folder.jpg or cover.jpg? Here is what the original Curacao Tweaked has for each:
Large Album Art Splitter above Lyrics:$if($findfile($directory_path(%path%)\$replace(%directoryname%,",,?,,*,.,/,).jpg),
$puts(cover.path,$directory_path(%path%)\$replace(%directoryname%,",,?,,*,.,/,).jpg),
$if($findfile($directory_path(%path%)\folder.jpg),
$puts(cover.path,$directory_path(%path%)\folder.jpg),
$puts(cover.path,$directory_path(%path%)\cover.jpg)))
ALB Album chronflow-type splitter at bottom:$puts(cover.path,$replace(%path%,%filename_ext%,$replace(%directoryname%,",,?,,*,.,/,).jpg))
$puts(cover.path1,$replace(%path%,%filename_ext%,folder.jpg))
$puts(cover.path2,$replace(%path%,%filename_ext%,cover.jpg))
$puts(playIcon,$get(foo_path)'images/play.png')
Any help is much appreciated, thanks!
1. No, you don't have to remove foo_playcount. The following code is for the official Playback Statistics, I don't know how it will interact with Playback Statistics Custom.
Rightclick on the stars at the left--->Settings - look at the code and replace the according part. Ratings are only written in Database then (foo_playcount). But this doesn't work with Skip and Mood cause these can only write tags.
$if(%_isplaying%,
$ifequal($get(rating),5,
$button($get(rate.x),$get(rate.y),0,0,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r5x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,0,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r5.png',5,TOOLTIP:"Average")
$ifequal($get(rating),4,
$button($get(rate.x),$get(rate.y),0,14,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r4x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,14,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r4.png',4,TOOLTIP:"Good")
$ifequal($get(rating),3,
$button($get(rate.x),$get(rate.y),0,28,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r3x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,28,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r3.png',3,TOOLTIP:"Very Good")
$ifequal($get(rating),2,
$button($get(rate.x),$get(rate.y),0,42,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r2x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,42,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r2.png',2,TOOLTIP:"Excellent")
$ifequal($get(rating),1,
$button($get(rate.x),$get(rate.y),0,56,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r1x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,56,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r1.png',1,TOOLTIP:"MegaHit")
$puts(rate.x,2)
$puts(rate.y,$sub(%_height%,70))
$if(%isplaying%,
$button($get(rate.x),$get(rate.y),0,0,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r5.png',5,TOOLTIP:"Average")
$button($get(rate.x),$get(rate.y),0,14,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r4.png',4,TOOLTIP:"Good")
$button($get(rate.x),$get(rate.y),0,28,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r3.png',3,TOOLTIP:"Very Good")
$button($get(rate.x),$get(rate.y),0,42,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r2.png',2,TOOLTIP:"Excellent")
$button($get(rate.x),$get(rate.y),0,56,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r1.png',1,TOOLTIP:"MegaHit")
$imageabs2(0,0,0,0,0,0,$get(rate.x),$get(rate.y),$get(foo_path)'images/'$get(config_name)'/rating/set2/_r0.png',alpha-255)
// .fin --- Rating System
Btw, I have to beg pardon to Br3tt. I'm also using the tags for ratings now. *be ashamed*
2. Have a look at the posts above yours.
I have a similar problem. I set playback statistics to "Update when playback percentage is 50%". After selecting it, it works fine.
But every time foobar is restarted playcount updates after 60 seconds, the setting is the same, though.
Would be glad for any suggestions.
Maybe #1: http://www.hydrogenaudio.org/forums/index....st&p=611538 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=67465&view=findpost&p=611538)
I have some things I want to change on my curacao config. I made a screenie
[a href="http://img142.imageshack.us/my.php?image=ttttcn5.jpg" target="_blank"]
1. Rightclick Scrollbarbutton--->Splittersettings--->look at picture
(http://img443.imageshack.us/img443/9906/29535828cg9.th.jpg) (http://img443.imageshack.us/my.php?image=29535828cg9.jpg)
2. Graphical Browser is only working with playlists, afaik.
3. Like answer #2. It's not possible only showing playlists entries with album tag
That's it. Cheers mate!
false, it's possible to skip the display of singles in graphical browser ,
group order is to set for
example, if singles are files which the tag %album% is empty (my case), set the GROUP by in GB settings like this ...
$if2(%album%,@skip)
You're right of course.
I've forgotten the @skip command, like it is in your group order of GB Artist.
Sorry El Noire.
Thanks for all the help Falstaff and Mr. Jackson
That really helped me! Everything looks really good now
One thing though, my Group-Code for Album-Graphical Browser looks like that:
$if($or($strstr(%genre%,'Tribute'),$and($strstr(%comment%,'Tribute'),stricmp(%album artist%,%artist%))),$swapprefix($replace(%original artist%,'Ä','Ae','ä','ae','Ö','Oe','ö','oe','Ü','Ue','ü','ue'),The,Die),$swapprefix($replace(%album artist%,'Ä','Ae','ä','ae','Ö','Oe','ö','oe','Ü','Ue','ü','ue'),The,Die))- $if2(%album%, Single)
Now I tried to just replace the last fragment... "$if2(%album%, Single)" to "$if2(%album%,@skip)"
but that didn't work (only @skip appeared below each single...) I had to delete all other code to to make it work, so now only "$if2(%album%,@skip)" is there.
Any chance to make it work with the above code too? Oh and now theres one big album @skip displayed which contain all my singles - this isn't a bad thing but I would like to get rid of that album or rename it.
[a href="http://imageshack.us" target="_blank"]
Here's my current code:
$if($or($strstr(%genre%,'Tribute'),$and($strstr(%comment%,'Tribute'),$not($stricmp(%album artist%,%artist%)))),$swapprefix($replace(%original artist%,'Ä','Ae','ä','ae','Ö','Oe','ö','oe','Ü','Ue','ü','ue'),The,Die),$swapprefix($replace(%album artist%,'Ä','Ae','ä','ae','Ö','Oe','ö','oe','Ü','Ue','ü','ue'),The,Die)) - $if($stricmp(%album artist%,%artist%),$if2(%release date%,%date%),) - %album% - %discnumber% - %tracknumber% - %title%
Anyone knows what to change to make it look right?
Thanks again for all help!
Hi El Noire,
I'm not sure if I understand you properly.
1. Album-Graphical Browser
I don't know how you got the text in the cover display, but with the following code no-album-cover-skipping works.
$if(%album%,$if($or($strstr(%genre%,'Tribute'),$and($strstr(%comment%,'Tribute'),stricmp(%album artist%,%artist%))),$swapprefix($replace(%original artist%,'Ä','Ae','ä','ae','Ö','Oe','ö','oe','Ü','Ue','ü','ue'),The,Die)%album%,$swapprefix($replace(%album artist%,'Ä','Ae','ä','ae','Ö','Oe','ö','oe','Ü','Ue','ü','ue'),The,Die)%album%),@skip)
Grouping scheme: if album--->original artist-album/album artist-album--->else skip cover
2.???
I don't understand for what this code is for, album-gb or artist-gb?
But nevertheless it's clear you'll get separate albums if you are sorting by original artist/album artist and album and you don't have "Various Artist" set to the album artist tag to keep the album together.
Thanks for the info on updating the rating system - worked great!
I took a look at the posts above regarding using wildcards for JPG album art, but each time I add the below code, the entire theme goes black!
I am trying to add the above code to the large album art splitter in Curacao Tweaked, which uses this code:
If I try to replace any/all of those lines, I get a black Foobar theme... I have my theme set to use the same background wallpaper no matter what album art is being used... I also haven't been able to get wildcards working with the album art "chronflow" splitter, which uses:
Where do I need to place the *.jpg line of code to get these two working with my album art that is named something other than folder.jpg or cover.jpg? Sorry if these are dumb questions... Thanks for your help.
Hmmmm, works perfectly for me.
But it didn't work for the Album GB.
Sorry that I couldn't help you.
@ bubi jackson
Wow I didn't know about the %album artist% tag! (It's the BAND-field in Mp3Tag) Problem solved, everything's great and I'm happy! Thanks for all your help, really appreciate it! If I were a girl I would offer you a date lol
"artists information at curacao, instrumentation of the artist next to lyrics"
Hey there,
i wrote in this topic in the wrong subforum:
http://www.hydrogenaudio.org/forums/index....showtopic=69080 (http://www.hydrogenaudio.org/forums/index.php?showtopic=69080)
Thanx for read!!
It's not so simple.
But maybe you wanna try this: http://www.hydrogenaudio.org/forums/index....st&p=602377 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=67465&view=findpost&p=602377)
It's not so simple.
thanx - but it seems not to be easy...
I just want a new tranparent backgrond window for instrumentation, like the one for lyrics or artist-cover and information.
Rolf
No, it's very easy. You have to replace the origin script and only modify it to your needs.
(http://img140.imageshack.us/img140/1917/52008493vl5.th.jpg) (http://img140.imageshack.us/my.php?image=52008493vl5.jpg)
I'm sorry - you are correct... I didn't realize I should have just replaced the entire thing - thanks... working great now... sorry for the dumb response.
sorry, i was wrong.
Thanks, guys! You were quicker to give the working solution faster than I managed to get back to forum. This works for album art in the top left panel!
I had this in the code:
$puts(cover.path,$findfile($replace(%path%,%filename_ext%,folder.jpg)))
And I changed it to as follows:
$puts(cover.path,$findfile($replace(%path%,%filename_ext%,back.jpg)))
//$puts(cover.path,$directory_path(%path%)\folder.jpg)
//$puts(artist.path,'C:/Program Files (x86)/foobar2000/artist/'%artist%'.jpg')
This works! This code displays folder.jpg in the album frame and places back.jpg as a background for the playlist when playing this album.
However,
what if there's no folder.jpg in the album folder?Could you
please help me realize how would I implement the following scheme:
If(folder.jpg) //if folder.jpg file is found in the folder
{ display // display this folder.jpg
elseif cover.jpg //else if cover.jpg is found in the folder
display cover.jpg //display that cover.jpg
else //neither folder.jpg nor cover.jpg is found
display *.jpg //display the first one found
Also, the
line does NOT WORK for the ALB panel at the bottom.The ALB panel now has the following script lines
I commented them out and changed them the same way I did it for album cover:
//$puts(cover.path,$replace(%path%,%filename_ext%,folder.jpg))
//$puts(artist.path,'C:\Program Files (x86)\foobar2000\artist\'%artist%'.jpg')
However,
the ALB panel keeps displaying standard nocover.png as the cover for all the album icons!How do I make the icons show the album cover based on the folder.jpg found in the played folder? Or cover.jpg, or any other found .jpg file?
Thank you all for helping! You make my day.
BTW, what is the intended use of the binary MOOD tag?
Great - the album art panel is working great now - thanks for your help!
One more question - how can I get ELPlaylist to always play the song after the currently playing song in the playlist, rather than playing what is currently selected/highlighted? For example, if I am playing the first track in a playlist of 50 tracks, then add 10 songs to this playlist via Windows Explorer, those 10 new tracks will be highlighted and will start playing after the first track is finished playing. How can I tell ELPlaylist/Foobar to simply play tracks in order, regardless of what track is selected in the playlist (so if Foobar is playing Track 1, and Track 51 is highlighted in ELPlaylist, it will play Track 2 once Track 1 finishes playing)? Any help would be much appreciated, thanks!
read this post
http://www.hydrogenaudio.org/forums/index....st&p=613001 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=62133&view=findpost&p=613001)
uncheck the option Playback follows Cursor
this has nothing to do with el_playlist.
I don't have foobar on the pc i am using right now, but i think this option is to be found under main menu > playback
here you have those 2 options- playback follows cursor ans cursor follows playback.
edit: too slow... :-(
Hi everybody
First of all, thank you Falstaff for this damn fine config
Secondly, I have a small problem. If I understand this code correctly:
// ---> Background cover display
$puts(bg_image_alpha,140)
$if($isvisible_c(_DEFAULT_WALLPAPER),
$puts(bg.path,$get(wallpaper))
$imageabs(0,0,1152,864,$get(wallpaper),nodisplay,,)
$puts(ratio,$div($mul($getimagewidth($get(wallpaper)),10),$getimageheight($get(wallpaper))))
$if(%ps_isplaying%,
// ---> artist ratio
$imageabs(0,0,,,$get(artist.path),nodisplay,,)
$puts(ratio,$div($mul($getimagewidth($get(artist.path)),10),$getimageheight($get(artist.path))))
$puts(ratio.a,$get(ratio))
// ---> album ratio
$ifequal($get(ratio),0,
$imageabs(0,0,,,$get(cover.path),nodisplay,,)
$puts(ratio,$div($mul($getimagewidth($get(cover.path)),10),$getimageheight($get(cover.path))))
$puts(ratio.b,$get(ratio))
$puts(bg.path,$get(cover.path))
$puts(bg.path,$get(artist.path))
then the first background image is artist, if there is no artist image, than cover and than the wallpaper.
Now, artist and cover background work fine, but if there is no cover or artist picture, like for example while listening to radio, the background stays black. Any solution for this?
i know, a little bug not fixed in Curacao... wait for Kameleon http://br3tt.deviantart.com/art/Kameleon-f...EVIEW-111264758 (http://br3tt.deviantart.com/art/Kameleon-foobar-PREVIEW-111264758)
Wow, looks great, you are forgiven
Kameleon looks amazing! When can we expect it? Says end of January................
Thanks for the "Playback Follows Cursor" tip! Works like a charm...
Hi.
There can I change this two settings?
(http://img18.imageshack.us/img18/1020/79808641ig2.jpg)
Preset default:
Right-click on playlist --> Settings --> grouping tab --> "sort format"
Other sort formats:
Right-click on playlist --> Settings --> misc tab --> "additional sort format for context menu"
I love Curacao! Best music player ever
I just integrated internet radiostreams in a seperate Playlist, it looks nice:
[a href="http://img3.imagebanana.com/view/ysf557nm/webradio.jpg" target="_blank"]
So having another strange issue - not sure if it has anything to do with Curacao, but thought I would bring it up since you all have been so helpful...
Since switching to Curacao, my Last.fm scrobbler plugin hasn't been consistently working. It does not scrobble tracks, and when I open the Last.fm application, the "Now Playing" option is grayed out, even though a track is playing in Foobar. I have the latest version of Last.fm (1.5.2.38918) as well as the latest version of audioscrobbler (2.3.1). It looks like it scrobbled a few tracks about 3 or 4 days ago, and hasn't worked since. When I first open Foobar, the Last.fm tray app also opens, so they are cooperating somewhat... just that the scrobbling isn't happening... the playing track in Foobar does not show up in the Last.fm app.
Anyone have any ideas on this one? Thanks for any help you can give me!
You could check out the logs in Help -> Diagnostics in the Last.FM software. Although I think that going to Extras -> Download Plugins is the route that will most likely lead to success.
Yes I tried using
Tools > Get Plugin to re-download/install the plugin which worked fine but still didn't fix the issue... I also tried uninstalling/reinstalling Last.fm & the plugin to no effect either (I also renamed the "
Last.fm" local profile folder under
C:\Users\<username>\AppData\Local\)... Thanks for the tip about
Help > Diagnostics... below is a recent bit of the Scrobbling log. The "Cached Tracks" window was completely empty/blank. It did say that my
Last Successful Connection was just now, although not sure if that is a successful connection to last.fm or to the Foobar scrobbling plugin. Here is some of the log (note that Foobar was playing tracks during this time) and there are some screenshots below:
"090209 04:04:38" - "000003ac" - Handshake::success ( 76 ) - L3
"session=8670ab7c4a4d44a903dfd36d3c653b14
stream_url=http://195.24.233.49:80/last.mp3?Session=8670ab7c4a4d44a903dfd36d3c653b14
subscriber=0
framehack=0..
base_url=ws.audioscrobbler.com
base_path=/radio
info_message=
fingerprint_upload_url=http://ws.audioscrobbler.com/fingerprint/upload.php
permit_bootstrap=0"
090209 04:04:38 - 000003AC - Handshake::success(80) - L3
Handshake response:
subscriber=0
framehack=0..
base_path=/radio
info_message=
permit_bootstrap=0
090209 04:04:38 - 000003AC - Handshake::success(128) - L3
Radio handshake successful. Host: ws.audioscrobbler.com, path: /radio
090209 04:04:38 - 000003AC - Radio::setState(665) - L4
Radio state: State_Handshaken
090209 04:04:38 - 000003AC - LastFmApplication::onRadioStateChanged(723) - L3
Radio streamer handshake successful.
090209 04:04:38 - 000003AC - CUpdateInfoGetter::DownloadInfo(188) - L3
Requesting update info from: ws.audioscrobbler.com/ass/upgrade.xml.php?platform=win&version=1.5.2.38918&lang=en&user=lonkny
"090209 04:04:38" - "000003ac" - Request::onHeaderReceivedPrivate ( 102 ) - L3
"UserPictures" response: 200
"090209 04:04:38" - "000003ac" - Request::onSuccessPrivate ( 182 ) - L3
"UserPictures" request succeeded
"Friends" response: 200
"Friends" request succeeded
"RecentlyLovedTracks" response: 200
"RecentlyLovedTracks" request succeeded
"RecentTracksRequest" response: 200
"RecentTracksRequest" request succeeded
090209 04:04:38 - 000003AC - CPluginInfo::IsPluginInstalled(261) - L3
foo2 wasn't found. Plugin not present.
090209 04:04:38 - 000003AC - CPluginInfo::VersionMatch(292) - L3
Player version to test: 0.9 - 0.9.3.9999
090209 04:04:38 - 000003AC - CPluginInfo::VersionMatch(293) - L3
Version of foobar2000 0.9: 0, 9, 6, 2
090209 04:04:38 - 000003AC - CPluginInfo::IsPluginInstalled(256) - L3
foo3 was found. Plugin present.
090209 04:04:38 - 000003AC - CPluginInfo::IsVersionNewer(121) - L3
foobar2000 0.9.4 plugin installed ver: 2.3.1.2, server ver: 2.3.1.2
itw wasn't found. Plugin not present.
wa2 wasn't found. Plugin not present.
wmp was found. Plugin present.
Windows Media Player plugin installed ver: 2.1.0.6, server ver: 2.1.0.6
090209 04:04:38 - 000003AC - Container::updateCheckDone(891) - L3
Update check said no updates available.
"090209 04:05:08" - "000003ac" - Request::get ( 217 ) - L3
"Handshake" initiated: "ws.audioscrobbler.com/radio/handshake.php?version=1.5.2.38918&platform=win32&platformversion=Windows%20Vista&username=lonkny&passwordmd5=3948f921107f72b77a478d6b666d7ef1&language=en&player=foobar2000"
"090209 04:05:08" - "000003ac" - Request::onHeaderReceivedPrivate ( 102 ) - L3
"Handshake" response: 200
"090209 04:05:08" - "000003ac" - Request::onSuccessPrivate ( 182 ) - L3
"Handshake" request succeeded
"090209 04:05:08" - "000003ac" - Handshake::success ( 76 ) - L3
subscriber=0
framehack=0..
base_path=/radio
info_message=
permit_bootstrap=0"
090209 04:05:08 - 000003AC - Handshake::success(80) - L3
Handshake response:
subscriber=0
framehack=0..
base_path=/radio
info_message=
permit_bootstrap=0
090209 04:05:08 - 000003AC - Handshake::success(128) - L3
(http://i385.photobucket.com/albums/oo292/lonkny/Lastfm1.jpg)
(http://i385.photobucket.com/albums/oo292/lonkny/Lastfm2.jpg)
If anyone has any ideas on how I can get Last.fm to scrobble my tracks again that would be great! Thanks again.
Moderation: More codebox.[/size]
Hi Brett,
First of all, awesome skin. But I have a small problem with it in Windows 7, see attached screen.
Basically, the letters above the playlist are cut off half, and I dont see buttons to drop down the media library etc. Any idea how this can be solved?
I had to edit the splitter settings, and change the foo.path variable to the full path, instead of just './'. This fixed it.
Br3tt, i've seen in your Profile on Deviant Art that you are using Win Vista!
What is your Theme for it?
i WAS using Vista, i'm back to XP now
Hey, thanks for a great config. iv had it on my foobar for a while now and been messing around with the layout to suit my tastes.
it currently looks like this:
(http://xs136.xs.to/xs136/09075/artist269.jpg)
@Br3tt,
I set the artist path like this in the artist browser,but it does not work,what should I do?
$puts(artist.path,$replace($replace(%path%,$directory(%path%),),%filename_ext%,artist.jpg))
(http://i280.photobucket.com/albums/kk161/jackschmaltz/MOCKA.jpg)
How did you get the extra tag info like "drum & bass" there? I wanted to have something similar with my custom %sub_genre% tag but could not find out how to do it. Also the middle field (msawdos // headsaw recordings) is that the standard %Genre% tag that is used here or did you find a way to change that and use 2 tags in the same field?
Sorry I can't answer your question.
it took me hours to figure that out but was damn satisfying when i did, just kept messing about with parameters to see what they did. its in the ELPlaylist settings under Group Header, i tweaked this under Album Infos:
// Album infos
$font(uni 05_53,6,bold)
$puts(txt.header.color,210-210-220)
$puts(pos0,$add($get(art_size),$add($get(padding_left),5)))
$puts(lg0,30)
$select($len(%el_item_count%),
$puts(nbtrk,'00'%el_item_count%),
$puts(nbtrk,'0'%el_item_count%),
$puts(nbtrk,%el_item_count%))
$drawroundrect($get(pos0),$sub(%el_height%,18),$get(lg0),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos0),1),$sub(%el_height%,17),$sub($get(lg0),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex($get(nbtrk),$get(pos0),$sub(%el_height%,17),$get(lg0),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex($get(nbtrk),$get(pos0),$sub(%el_height%,18),$get(lg0),%el_row_height%,$get(txt.header.color),hcenter vtop)
[b]$puts(pos1,$add($add($get(pos0),$get(lg0)),4))
$if($stricmp('FOO_LASTFM',$left(%path%,10)),
$puts(lg1,-4)
$puts(lg1,148)[/b]
$if($stricmp('FOO_LASTFM',$left(%path%,10)),,
$drawroundrect($get(pos1),$sub(%el_height%,18),$get(lg1),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos1),1),$sub(%el_height%,17),$sub($get(lg1),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex($if(%genre%,$upper(%genre%),'N/A'),$get(pos1),$sub(%el_height%,17),$get(lg1),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex($if(%genre%,$upper(%genre%),'N/A'),$get(pos1),$sub(%el_height%,18),$get(lg1),%el_row_height%,$get(txt.header.color),hcenter vtop)
[b]$puts(pos2,$add($add($get(pos1),$get(lg1)),4))
$puts(lg2,-4)
$puts(lg2,39)[/b]
$drawroundrect($get(pos2),$sub(%el_height%,18),$get(lg2),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos2),1),$sub(%el_height%,17),$sub($get(lg2),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex($upper($ext(%filename_ext%)),$get(pos2),$sub(%el_height%,17),$get(lg2),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex($upper($ext(%filename_ext%)),$get(pos2),$sub(%el_height%,18),$get(lg2),%el_row_height%,$get(txt.header.color),hcenter vtop)
[b]$puts(pos3,$add($add($get(pos2),$get(lg2)),4))
$puts(lg3,-4)
$puts(lg3,66)[/b]
$drawroundrect($get(pos3),$sub(%el_height%,18),$get(lg3),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos3),1),$sub(%el_height%,17),$sub($get(lg3),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex(%__bitrate%' KBPS',$get(pos3),$sub(%el_height%,17),$get(lg3),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex(%__bitrate%' KBPS',$get(pos3),$sub(%el_height%,18),$get(lg3),%el_row_height%,$get(txt.header.color),hcenter vtop)
//$if(%replaygain_album_gain%,
//$puts(pos4,$add($add($get(pos3),$get(lg3)),4))
//$puts(alb.gain,$if(%replaygain_album_gain%,%replaygain_album_gain%$if($stricmp('fla',$left($upper($ext(%filename_ext%)),3)),,),'0 dB'))
//$puts(lg4,$add($gettextwidth($get(alb.gain)),10))
//$drawroundrect($get(pos4),$sub(%el_height%,18),$get(lg4),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
//$gradientrect($add($get(pos4),1),$sub(%el_height%,17),$sub($get(lg4),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
//$drawtextex($get(alb.gain),$get(pos4),$sub(%el_height%,17),$get(lg4),%el_row_height%,00-00-00,hcenter vtop)
//$drawtextex($get(alb.gain),$get(pos4),$sub(%el_height%,18),$get(lg4),%el_row_height%,$get(txt.header.color),hcenter vtop)
//$puts(pos4,$add($add($get(pos1),$get(lg1)),4))
//$puts(lg4,64)
[b]$puts(pos4,$add($add($get(pos3),$get(lg3)),4))
$puts(lg4,-4)[/b]
its mainly to do with the parameters i've put in bold, i cant remember exactly what does what as it was very late lastnight when i finally figured it out. im sure if you compare it to your code you should be able to see what i have done.
as for the tags, i shifted them around so i have %genre% where it is and the other field is %comment% as i put the cat no. & record label in the comments box for all my files ("eg. MSAW005 // Mindsaw Recordings"). hope this helps, & does anyone have any ideas with my previous question?
Thanks, for the code. It's just what I wanted.
in response to my own previous question about adding the remix credit to the track list iv managed to suss it out after many hours of messing & far to many cups of tea .
it now looks like this:
Nice work, Jack.
I know this very good, too.
Hello Br3tt,
first of all - thanks for your work and this nice plugin
I´m an german user and my english is not so well - sorry.
But now my problem.
I use curacao an the fonts are not right. I must inform you, that I use vista and the dpi is scaled up to 192 dpi.
The product looked like this.
Is it possible to make it looking like usual. When I scale the dpi down ist looked allright. But I use an Sony 40" screen in my livingroom and I can´t read ist when the font ist only normal dpi. (the older or what do say in english....?? an eyeglasses don´t help at this case....)
Sorry- but I can´t fill in the image. Is it possible to send it to your mail-adress - thanks
thank you very much for your time you spend with reading and thinking!
Jörg
Thanks for the great work.
But if I have an sampler the playlist looks really mixed up, because it's grouped by artist and not by album. How can I change this?
EDIT: problem solved^^
%album artist% to fill
Can we use the Wang WSH compiled without SSE?
Also is there a foo_menu_addons compiled without SSE too?
I have an old Celeron that doesn't support SSE.
THANKs
Do you mean SSE2 or really SSE?
WSH w/o SSE2: http://www.hydrogenaudio.org/forums/index....st&p=589236 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=65618&view=findpost&p=589236)
Hi Br3tt,
I had looked for hours but I didn't find an answer.
How will I get the BG Image in the Playlist Panel as sharp and without this litlle colour haze like in Kameleon?
Thanks in advance
(http://img9.imageshack.us/img9/1450/curgx4.th.jpg) (http://img9.imageshack.us/img9/1450/curgx4.jpg) (http://img11.imageshack.us/img11/1334/kamsl6.th.jpg) (http://img11.imageshack.us/img11/1334/kamsl6.jpg)
Hi Br3tt,
Thanks in advance
Curaçao and Kameleon are very different, i can't point you all the lines to fix in Curaçao to obtain the same render as K. sorry, btw you have to find in the code where i use $gradientrect(...) which give this reflection effect in C, on replace it by $drawblurrect(...,250-250-250-30,7), good luck
Thank you.
In the meantime I like it to look at all the code to get a better understanding.
Old and new
[a href="http://img9.imageshack.us/img9/1450/curgx4.jpg" target="_blank"]
But those who helped I think were deactivating background filling in ELP Pannel and in Main Panel and drawing BG Image by $drawimage.
I saw a lot of code like Green/Red/Blue Overlay and drawing scanlines.pngs but I don't know what these are doing, I didn't see a difference by deactivating them.
Old and new
cover reflection is bad now, you have deleted a line to keep
Thank you.
Thank god I work with // instead of deleting.
But I solved the problem by drawing a new black rect.
I have an OLD Celeron that ONLY has MMX, LOL...
Yes I meant without SSE & SSE2...
What about foo_menu_addons compiled without SSE too?
ooops.
Sorry DasFox, but afaik there is no wsh or menu addon without sse.
ooops.
I thought there was WSH by Wang that compiled it with SSE and I'm running it for Ibizia working...
cpuz says I only have MMX so I don't see how the wsh is working then
Very strange.
But then menu_addons should also work.
Another Question.
Is it possible to bind the PSS Panels to shortcuts - eg PANELSHOW:_PLAYLISTS2:0;REFRESH?
I have managed to configure Curacao and it's fantastic.
However I have encountered a visual problem. My layout still has the original Foobar2000 header and status bar visible.
(http://lh6.ggpht.com/_f_0KAiFhnms/SZ2MMsliLXI/AAAAAAAAK9w/2QU7tjQP-bQ/s640/Curacao%20on%20my%20desktop.jpg)
How do I remove them?
upper toobar: Preferences > Columns UI > Main-tab > untic show toolbars
lower statusbar: Preferences > Colums UI > status bar-tab > untic show status bar
tip: I got my "show toolbar" assigned to a hotkey in case i do need the toolbar I have quick acces.
Click on VIEW
Untick SHOW STATUS BAR and SHOW TOOLBARS
Or click the little arrows on the far left top and bottom /\
Maybe a really dumb question:
What do the stars mean in the layout? I thought they indicate the number of plays. But when I played a track 3 times and another twice, the one I played twice has a star and the one I played 3 times not.
Thanks in advance.
It's the rating of the track. You can alter it in the lower left corner.
I wanted to remove the lyrics panel, any pointers on how to do that?
Also the graphical browser doesnt show the album art on startup, it shows the coracao logo, how do i configure it to display otherwise?
1. Replace the Lyric Show Panel in Columns UI Layout - but I woudn't do that, if I don't know what I am doing.
2. Check hide panel on start up and uncheck the one you would like to see.
Kameleon 1.2.0 :
- Playback Order button now remains good image on restart (memory added)
Falstaff, this is possible make in Curacao?
First of all, thank you for this beautiful theme which I am using since december (v.1.2a tweaked). I am currently editing it a little, which brings me to my two questions (which are pretty trite, I am afraid). Here it goes:
1.) I was able to get rid of the date shown in the header, however the album title still get's cut off. Where can I increase the width of the second line (in this case ending with the disc count) in order to use the free space? There is an awful lot of spacing and size related stuff in the "Group Header" script, and honestly I can't make heads and tails of it.
(http://666kb.com/i/b7cn6k3nru7qpwfih.png)
2.) I edited the script for the lyrics viewer (and solved the resulting conflicts with the keywords) to show some general information via the comment tag. It works pretty good so far, but I still need to put a blank line between the date/publisher line and the comment. I tried some stuff with symbols and queries but that is simply discarded instead of generating a blank line. There's got to be a simple code for this.
(http://666kb.com/i/b7cog8f4z3k0t8nt5.png)
Thank you,
Chris
kmk, I use the lyrics panel the same way as you do, to enter a blank line I use:
$crlf()
Thank you, works perfectly
How can I read albumart from id3v2 tags? I think that ELPlaylist is showing images only from specified definition of __ART_PATH__ variable and not from embedded images in files.
In the ELPlaylist settings, change __EMBEDDED_ART__ to 1.
I don't have that variable. I added it, but doesn't work either.
(http://img17.imageshack.us/img17/4470/elplaylist.png)
Sorry, I'm using a tweaked version.
See here, http://www.hydrogenaudio.org/forums/index....st&p=604157 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=67465&view=findpost&p=604157)
I installed the tweaked version, now I see the album art on the list, but on the left panel, the cover display shows the default no cover image. Any solution?
hey again, wondering if i can get some help of someone in the know.
im trying to update the rating system so it doesnt write it to file tags & just reads to & from the Playback stats database.
i tried a script from this thread for this but it only semi works, it appears to write to file when you first click a star/rating then when you re-rate it (ie from 5 to 4) it unwrites the tag& reads the database, but then if i go to re-rate again it goes back to writing to tag & continiues to follow this behaviour.
heres the script that i currently have on it:
// Background
$drawrect(0,0,%_width%,%_height%,brushcolor-035-035-040 pencolor-null)
// Global
$puts(config_name,'curacao')
$puts(foo_path,'./')
// PerTrack
// .deb --- Rating System
// drawing RATING info
$puts(rate.x,2)
$imageabs2(0,0,0,0,0,0,$get(rate.x),$get(rate.y),$get(foo_path)'images/'$get(config_name)'/rating/set2/r0.png',alpha-128)
$puts(aa-fp,$year(%first_played%))
$puts(mm-fp,$month(%first_played%))
$puts(jj-fp,$day_of_month(%first_played%))
$puts(aa-lp,$year(%last_played%))
$puts(mm-lp,$month(%last_played%))
$puts(jj-lp,$day_of_month(%last_played%))
$ifgreater(%rating%,0,
$puts(rating,$if2($meta(rating),0))
$puts(no.set,1)
$ifgreater($get(aa-lp),$get(aa-fp),
$ifgreater($get(mm-lp),$get(mm-fp),
$puts(nb.aa,$sub($get(aa-lp),$get(aa-fp)))
$puts(nb.mm,$sub($get(mm-lp),$get(mm-fp)))
$ifgreater($get(jj-lp),$get(jj-fp),
$puts(nb.jj,$sub($get(jj-lp),$get(jj-fp)))
$puts(nb.mm,$sub($get(nb.mm),1))
$puts(nb.jj,$add($sub(30,$get(jj-fp)),$get(jj-lp)))
$puts(nb.aa,$sub($sub($get(aa-lp),$get(aa-fp)),1))
$puts(nb.mm,$add($sub(12,$get(mm-fp)),$get(mm-lp)))
$puts(nb.aa,0)
$puts(nb.mm,0)
$puts(nb.jj,0)
$puts(autorate.add,2)
$puts(autorate.nbdays.sub,30)
$puts(daterange, $add( $add($mul(365,$get(nb.aa)),$mul(30,$get(nb.mm))),$get(nb.jj)) )
$puts(fix,$div($get(daterange),$get(autorate.nbdays.sub)))
$if(%play_counter%,$puts(rating,$div(%play_counter%,$get(autorate.add))),$puts(rating,0))
$puts(rating,$sub($get(rating),$get(fix)))
$if($greater($get(rating),5),$puts(rating,5))
$if($greater(0,$get(rating)),$puts(rating,0))
$puts(no.set,3)
$puts(rate.x,2)
$imageabs2(0,0,0,0,0,0,$get(rate.x),$get(rate.y),$get(foo_path)'/images/'$get(config_name)'/rating/set2/r0.png',alpha-128)
$if(%_isplaying%,
$puts(rate.x,2)
$if(%isplaying%,
// MOOD TAG SET/UNSET to feed automatically auto-playlist for my portable device
$puts(x,1)
$puts(y,$sub(%_height%,86))
$imageabs2(14,14,0,0,0,0,$get(x),$get(y),$get(foo_path)'images/'$get(config_name)'/bt/mood_off.png',nokeepaspect)
$ifgreater(%MOOD%,0,
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/mood_on.png',$get(foo_path)'images/'$get(config_name)'/bt/mood_off.png',TAG:SET:MOOD:0,TOOLTIP:"Unset")
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/mood_off.png',$get(foo_path)'images/'$get(config_name)'/bt/mood_on.png',TAG:SET:MOOD:1,TOOLTIP:"Set")
// SKIP TAG SET/UNSET to skip unwanted tracks using the 'Skip Track' (foo_skip.dll) plugin
$puts(x,1)
$puts(y,$sub(%_height%,102))
$imageabs2(14,14,0,0,0,0,$get(x),$get(y),$get(foo_path)'images/'$get(config_name)'/bt/skip_off.png',nokeepaspect)
$ifgreater(%SKIP%,0,
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/skip_on.png',$get(foo_path)'images/'$get(config_name)'/bt/skip_off.png',TAG:SET:SKIP:0,TOOLTIP:"Unset")
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/skip_off.png',$get(foo_path)'images/'$get(config_name)'/bt/skip_on.png',TAG:SET:SKIP:1,TOOLTIP:"Set")
if anyone can help it will be greatly appreciated
Changing
$puts(no.set,1)
to
$puts(rating,$if2(%rating%,0))
$puts(no.set,1)
should work, I hope
Edit: typo
Changing
$puts(no.set,1)
to
$puts(no.set,1)
should work, I hope
Edit: typo
Thanks for the response bubi, but i tried this & its still behaving as stated before, adding the rating meta then removing on re-rating & so on.
any other ideas anyone? i was pulling my hair out all weekend on this 1 but just cannot figure it out.
any help greatly appreciated
hmmm......
I'm using this and the official Playback Statistics Plugin and it's working fine.
Edit: I compared the two scripts with nozepad+ again, and this is the only difference between yours and mine. I really don't know why it's not working.
hmmm......
how very odd, thanks for having a look for me though.
if its any help im on the latest version of foobar (although i tried this script previous to the update which had the same results) & version 2.1.8 of the official playback stats component.
thanx for your time
Kameleon 1.2.0 :
Falstaff you not planing update old configs?
thanx for your time
Do you have Quick Tagger with a rating script installed? Then a command like "1" in trackinfo will trigger both, the rating to database and the Quick Tagger script.
thanx for your time
qwertz, your an absolute god send haha. exactly the problem, removed the quicktag component & the rating sytem now works like a dream.
it would appear i can now keep my hair haha
thanks to both qwertz & bubi for your time, greatly appreciated
Now I remember, there was something with identical script names.
Thx qwertz for recalling this.
But Jack, you don't have to remove quicktag, just rename the rating scripts to other than 1-5 or delete only them (maybe you still want using QT for some other purpose)
Edit: typo
Can anyone help me please? :]
I want to replace default lyrics panel with last.fm biographies
(http://funkyimg.com/t2/255/763/foobar1.jpg) (http://funkyimg.com/viewer.php?img=/2/255/763/foobar1.jpg)
, but when I right click and choose add panel, it covers up the whole left side
(http://funkyimg.com/t2/471/567/foobar2.jpg) (http://funkyimg.com/viewer.php?img=/2/471/567/foobar2.jpg)
I've managed to do it in the bottom part of the config, everything went well.
(http://funkyimg.com/t2/624/026/foobar3.jpg) (http://funkyimg.com/viewer.php?img=/2/624/026/foobar3.jpg).
Also, I've tried hard to change the sizes of the left panels with lyrics "zoomed in", but something always messes up.
Can I make them a bit bigger and keep cover art bigger than lyrics panel at the same time?
something like this
(http://funkyimg.com/t2/939/160/foobar4.jpg) (http://funkyimg.com/viewer.php?img=/2/939/160/foobar4.jpg)
any tips would be much appreciated
You have to replace the Lyrics Panel at Preferences-->Columns UI-->Layout
Or do it my way
(http://www.abload.de/thumb/bio3en6.jpg) (http://www.abload.de/image.php?img=bio3en6.jpg)
stupid me :\
that was kind of easy, thanks a lot!
im wondering if anyone can help me out.
iv added a few mods to this theme, 1 of which is a filter via the panel stacker as shown here:
(http://i280.photobucket.com/albums/kk161/jackschmaltz/filter-foobar.png)
my question is, how can i adjust the width of the individual filters?
when i hover over them i get the resive icon but im unable to resize & iv tried changing different variables but to no avail.
im not fused if the width i change it too is permanent but would like to be able to adjust the size to my personal preference.
i added it by stacking 3 filters in a panel stacker & adding it to the playlists stack if that helps.
thanks for your time
I think you can define the width by script in the per track tab of the PSS where ELP and the others are - but I don't know exactly how to do it.
Have a look at Br3tt's script and the PSS Readme.
No one who knows how to change the width of the left panel?
thanks for the response Bubi but from what i can gather from that Per Track tab it only lets me define the size of the actual box/panel and wont let me resive the individual panels contained inside.
so im assuming i need to define it somehow in the PSS for the filters, but i could be wrong.
if i recall correctly the xchange config had this with resizable filters so i'll take a look at that & see what i can figure out.
thanx for your time
Curacao still rocks! Just added biography, Scaicha and Wikipedia button
It's the perfect musicplayer for me now! Only one problem left: I noticed that there are no playback statistics displayed under the Library Playback Statistics Button! I changed the settings of playback custom plugin to only allow writing tags in foo_custominfo Database - is this a known problem or I'm missing something here?
EDIT
Found the answer. foo_custominfo Database needs the custominfo.dll plugin which doesn't work for current foobar version. So I added offical playback plugin and changed every %play_counter% into %play_count% and it works now
thanx for your time
i had a look at the Xchange config & found a Horizontal Splitter was placed in the PSS, i tried it & sure enough now it works, resizable filters... result!
i cant help but extend & modify this theme to my own way, its so easy to do so as everything is so clearly laid out & not to tricky to figure out.
now, for my next quest (haha)! iv started adding custom run services with buttons etc. but iv hit a stumbling block.
i have my %comment% tag set up with cat no. & label info, eg. "MSAW005 // MindSaw Recordings".
now, id like to be able to search Discogs with just the label name, so would there be anyway via a syntax command to remove everything to the left of "//" so that it will send just "MindSaw Recordings" to discogs?
im currently working around it by querying the path as i have my collection sorted by label, but the way id like to do it would be more affective to me as some labels contain characters i cannot use in file names.
if anyone could point me in the right direction with this i would be gratefull, cheers.
edit: typo
You still stay with Curacao? Nice
Why don't you use the Discogs-Tags for Catalog and Label instead of writing both in the comment? So do I and it's easy with foo_discogs or Mp3Tag und usung foo_run then.
The Title Formatting String for you is maybe something about $strchr and $left, but I would have to think very very much about it to get a solution.
yes, im still with Curacao, absolutley love it. quick, clean & easily expandable, i dont think i want much else from a theme really haha!
i would retag all my mp3's to an easier standard as you suggested but with over 40k of files to retag, it would stilll take a very long time. i implemented this standard of my own a while before i started using foobar, as if i started it knowing what i know now i cetainly would of made it easier for myself by seperating these tags but nevermind.
i thought $left may be along the lines of what i was after but wasnt sure what to combine it with. i will have to have a play with that & the $strchr command & see if i can figure it out.
thanks again bubi for your wisdom, you've certainly pointed me in the right direction on more than 1 occasion & i appreciate it
Puuuh, you call me a wise guy - I should tell this to my mother.
I hope you'll make some advances with the title formatting, tell me if you have found an answer, please - I'm not so experienced in it.
Edit: typo
(http://fc81.deviantart.com/fs39/i/2008/341/e/b/Curacao_v1_2a_Released_by_Br3tt.png)
(http://img338.imageshack.us/img338/8048/1123200820458pmrq4.jpg)
(http://i3.6.cn/cvbnm/9a/e0/7e/8a7d9c243e34a195bfb02ade04fd5e52.jpg)
How do you make the playlist appear like the last 2 ? I'm currently stuck with the first one and I like the others better.
I've just updated foobar to v0.9.6.7 and lost my default background image. It is still there in the folder...just does not show. Any tips?
Also I noticed that the "rating stars" no longer show either in line with the track info or at the lower left hand corner. However once I rate (right click>playback stats>rating) the rating stars show up for that track.
Previously when I updated to v0.6.6 the rating stars were visible but couldn't rate by clicking on the stars. It seems as though with every new update the rating feature is being cut back. Any solution this?
'Tis a minor thing... just thought I would mention it.
Shamsur
I've been trying to get Curacao v1.1a to work without any luck. I'm new to foobar2000 but I have used skins with it before and I'm pretty good with computers in general.
I downloaded...
Curacao_v1_1a_Released_by_Br3tt
fonts-xchange
components-xchange
I've followed the instructions. I installed the fonts to C:\WINDOWS\Fonts\ I've copied the components to \foobar2000\components\ And the instructions say to extract the Curacao_v1_1a to the \foobar2000\ folder and that it would automatictly creat a new folder called "Skins" and a new sub folder called "xchange" however, when I try to extract it to that folder I just get an error message saying that it can't do it. I can extract the files to my desktop so I did so. Then I created a folder within the foobar2000 folder and named it skins. and I created a folder within the skins folder and named it xchange and I placed the files that I extracted to my desktop into that folder. Now the instructions say to go to "Preferences > Display > ColumnsUI > Main tab and click the 'Import'" I click import and I select the Xchange.fcl file and I get the following message "The layout import was aborted because the following required panels where not installed: Graphical Browser, Track info mod, WSH Panel" This is where I'm at a loss. Any help would be great!
Justin
Please understand this is a shot in the dark - I use none of these. BUT are you somehow
combining instructions to two different config?
He has Curacao - which, by the way - is at version 1.2 and Xchange.
AS Curacao came out first, I would wonder why there would be any mention of an xchange sub folder.
good luck
terry
This is where I found it
http://br3tt.deviantart.com/art/Curacao-v1...eased-104617374 (http://br3tt.deviantart.com/art/Curacao-v1-1a-Released-104617374)
and the link on that page leads to the instructions to install it. The same instructions I used
@jesusfreak: you need to extract the image folders to foobar2000/images/curacao (ie. so you have "foobar2000/images/curacao/bg ...etc)
also, the reason you'll be getting error messages is that Vista (which i assume your using) wont allow you to extract archives to the Program folders.
im not sure how you managed to get the 2 config instyuctions confused but what you had was definetly the xchange notes.
EDIT: just had a quick look at the 1.2a archive, if you extract that & just place it directly in your foobar directory you should be good to go
No. That page has instructions for more than one configuration. In the event that you have more than just an error in directory structure, I would suggest to start again with the correct set of instructions and I am sure you will be fine.
terry
Well, where are the correct instructions? It said click here for instructions and i clicked there and was lead to the instructions I used. Can anyone tell me where to find the right instructions for this?
Thanks,
Justin
Well are you here? http://br3tt.online.fr/ (http://br3tt.online.fr/)
Scroll to the config you want...follow the click logo.....follow step one and download instructions.
Terry
thanks everyone for your help! I got it installed and it looks great! Everything looks and acts as it should. BUT it's not playing the audio. I select a song and the album cover comes up and the backgroud of the player changes to an image of the artist selected but I can't get it to play. Any ideas as to why? I followed the right instructions this time to the letter
Justin
never mind, i figured it out
I do have another question lol. How do you change the background image? On the screen shots I've seen it shows a picture of the artist that your playing. Mine just puts the album cover of the album I'm listingint to as the background image. Sometimes this works fine but other times the album cover is not the best image to use for the background. There was nothing in the instructions that told how to change the background image
(http://img140.imageshack.us/img140/7425/23303651.th.jpg) (http://img140.imageshack.us/i/23303651.jpg/)
Thanks for the help! That did change the background image! But the background image is the same all the time. Is there a way to make the background image change by what artist your listening to without just having it be the album cover?
Also, I can't seem to figure out how to get my music to be in alphabetical order of the artists name. All my music is properly tagged and all shows up correctly but when I click on one of the letters at the top to see the artists that start with that letter, I see a big mix of artists, most of them not even starting with the letter I selected
Hmmmm.......
iirc it changes automatically to the artist picture if you have one and the path is right.
I can't imagine.
What's your grouping in El-Playlist and Graphical Browser?
Mine is in ELP
Group format
$swapprefix(%album artist%,The) | $if($not(%album%),%title%,%album% | %discnumber%)
Sort format
$swapprefix(%album artist%,The) | $if($not(%original release date%),%date%,%original release date%) | %album% | %discnumber% | %tracknumber% | %title%
And in GB
Group
$if($stricmp($get(ch),$lower($left($swapprefix(%album artist%,The),1))),
@skip,$puts(ch,$lower($left($swapprefix(%album artist%,The),1)))$if($stricmp($get(ch),'a'),'a',
$if($stricmp($get(ch),'b'),'b',$if($stricmp($get(ch),'c'),'c',$if($stricmp($get(ch),'d'),'d',$if($stricmp($get(ch),'e'),'e',
$if($stricmp($get(ch),'f'),'f',$if($stricmp($get(ch),'g'),'g',$if($stricmp($get(ch),'h'),'h',$if($stricmp($get(ch),'i'),'i',
$if($stricmp($get(ch),'j'),'j',$if($stricmp($get(ch),'k'),'k',$if($stricmp($get(ch),'l'),'l',$if($stricmp($get(ch),'m'),'m',
$if($stricmp($get(ch),'n'),'n',$if($stricmp($get(ch),'o'),'o',$if($stricmp($get(ch),'p'),'p',$if($stricmp($get(ch),'q'),'q',
$if($stricmp($get(ch),'r'),'r',$if($stricmp($get(ch),'s'),'s',$if($stricmp($get(ch),'t'),'t',$if($stricmp($get(ch),'u'),'u',
$if($stricmp($get(ch),'v'),'v',$if($stricmp($get(ch),'w'),'w',$if($stricmp($get(ch),'x'),'x',$if($stricmp($get(ch),'y'),'y',
$if($stricmp($get(ch),'z'),'z',$if($stricmp($get(ch),'0'),'#',$if($stricmp($get(ch),'1'),'#',$if($stricmp($get(ch),'2'),'#',
$if($stricmp($get(ch),'3'),'#',$if($stricmp($get(ch),'4'),'#',$if($stricmp($get(ch),'5'),'#',$if($stricmp($get(ch),'6'),'#',
$if($stricmp($get(ch),'7'),'#',$if($stricmp($get(ch),'8'),'#',$if($stricmp($get(ch),'9'),'#',$if($stricmp($get(ch),'+'),'#',
$if($stricmp($get(ch),'-'),'#',$if($stricmp($get(ch),'/'),'#',$if($stricmp($get(ch),'*'),'#','~')))))))))))))))))))))))))))))))))))))))))
Sort
hth
"it changes automatically to the artist picture if you have one and the path is right."
How do I do this? I know how to change the background pic manually but I need some help it getting it to do it automatically.
As for the other part, the playlist part, I have no idea. That is about a mile above my head lol. I'm not too worried about the playlist part, I just want to get the background pic changing automatically first
Thanks for all the help!
Justin
Nevermind, I figured out the background thing! But if anyone can explain that playlist problem to me in a way that I can understand it that would be great!
Justin
... But if anyone can explain that playlist problem to me in a way that I can understand it that would be great!
if im recalling correctly it hooks to the currently selected playlist & just jumps to the 1st album artist in the playlist, it doesnt single them out in a new playlist.
so, say you have a playlist with every letter in the alphabet album artist wise, if you press C it will set focus to the first album artist beginning with C, similar to how the now playing button works.
i hope this helps
EDIT: on further investigation im half right, it brings the focus to the 1st album artist of the said letter & also highlights all other album artists with the same letter in the playlist, this seems like standard behaviour
@jesusfreak: long time ago. What was the problem, can you tell me please?
and jack is right, but remember only album artists get selected. So artists in a compilation (Various Artist) won't get selected.
If your playlist isn't sorted in a right way (alphabetical order) it looks like GB would select artists in a random order, a little bit.
And for trying out my code for ELP and GB.
ELP: Right click in ELP>>Settings>>Tab Grouping>>Group Format/Sort Format
GB: Right click on the letters>>Settings>>Group/Sort
Btw, you don't have to click on the letters, keyboard is also working very well. eg, type G and the first album artist with G is selected or type the first letters of a band and the cursor jumps to the band.
Turn on the Status Bar and have a lookCtrl-f:the search dialog(%el_group_format%of the search.)
Ctrl-g:jump to the following groups:
Ctrl-b:Before jumping to a group of
Delete:the removal of the track from a playlist
Alt-[Up)/ [Down]:Move the selected track( "hide all items when playlist is changed" to be off)
[Note]:foobar2000 console General-> Keyboard Shortcuts settings will take precedence.
# # [Alt] + Drag & Drop to move,but you can select the track.
¦ incremental key input in the group format(%el_group_format%) and incremental search.(enable incremental search is on only)
Additionally,the following shortcut key is enabled.
Ctrl-e:Reset the search term.
Ctrl-d:Find Next.(Ctrl-s good but if you have a free???)
Ctrl-r:a search before.]
Having trouble talking?
Preferences > Advanced > Tools > Playback Statistics
terry
terry
thanks
You can shorten this to:
$if($strchr(abcdefghijklmnopqrstuvwxyz,$get(ch)),$get(ch),$if($strchr(0123456789+-/*,$get(ch)),#,~))
Thank you
Hey Br3tt, great config you've created here! Huge props!
I'm trying to personalize my config a bit more but I'm going to need some help.
(1) How can I make it so that the Lyrics panel is always collapsed on start up?
(2) How to I change the text color for everything in the playlist view including highlights?
Mainly artist, album, and tracklist titles.
(3) For the controls at the bottom, where are the button images located so that I can alter their color?
(4) How can I make all of the places with images load both PNG or JPG, for "Cover", "Folder" and "Front"?
(5) Where the "SHPECK" and other artist/album images go, can make it slightly transparent so that it blend with the wallpaper image?[/li]
Once again, great job on the interface, I hope you continue to develop on this or at least keep it up to date with any new version releases of foobar2000.
Thanx for enjoying thaht config, but i've stopped developing it since i do not use it.
give a look to my last config which is up to date : http://br3tt.deviantart.com/ (http://br3tt.deviantart.com/)
Regards,
@KeyLogic
1) dont know, sorry
2) change the definitions highlighted in this picture which can be found under elplaylist settings:
4) in the installation instructions where it tells you to define your cover/art path/s, if you replace ".jpg" with ".*" it should (in theory / i think) load up any image extension
5) i dont quite understand what you want here im afraid
Regards,
Aw, I'm so sorry to hear that. I mean no offense to your other design but the Curaçao looks and functions much better in my opinion.
Oh well, I'll keep updating foobar until it breaks compatibility.
@KeyLogic
1) dont know, sorry
Okay I'll keep looking around in the settings, maybe there's something that will do this this.
Thanks again! I should have thought to check there. Question: where are the buttons for the controls like the extension, khz, and channel (bottom-left)?
Ah, will try this. Thanks!
Eh, don't worry about it, I think that it looks fine to me right now, it blends pretty well with the rest of the interface.
I'll post a screenshot once I make the final tweaks.
for duration look for this line under Track List settings:
$drawtextex(%length%' ',$add($sub(%el_width%,$add($get(length_width),$get(padding_right))),1),$add($get(txt.top),1),$get(length_width),%el_row_height%,44-44-44,right vtop end_ellipsis)
$drawtextex(%length%' ',$sub(%el_width%,$add($get(length_width),$get(padding_right))),$get(txt.top),$get(length_width),%el_row_height%,[b]%__ARTIST_COLOR__%[/b],right vtop end_ellipsis)
i cant remember if i set it to %__ARTIST_COLOR__% manually or not but if it isnt that then adjust as you require.
then in Per Second look for the line:
$drawtextex('-'%_time_remaining%' ',$add($sub(%el_width%,$add($get(length_width),$get(padding_right))),1),$add($get(txt.top),1),$get(length_width),%el_row_height%,44-44-44,right vtop end_ellipsis)
$drawtextex('-'%_time_remaining%' ',$sub(%el_width%,$add($get(length_width),$get(padding_right))),$get(txt.top),$get(length_width),%el_row_height%,[b]$get(txt_color)[/b],right vtop end_ellipsis)
same again, adjust the bold text as required
as for the file info in the bottom left, right click on it & select "splitter settings", & its all under the script tab
Sup all.
I've got a few more questions.
1. How do I change the album info font, color and arrangement, the info that's placed over the cover art reflection?
2. How do I change the color of blue that's in the Seekbar?
3. On the top-left corner of the interface, you can choose different layout. Can I make my own (with current interface size) and add it as #3?[/li]
Hey Jack Schmaltz. Unfortunately this didn't work. Is there a way to add all 6 configurations: cover.jpg/folder.jpg/front.jpg, and cover.png/folder.png/front.png?
1, if your referring to the info on the left panel, right click>>splitter Settings>>script>>per second, scroll to the bottom & everythings there
2, right click seekbar>>highlight "WSH SEEKBAR">>configure>>look for lines starting with "gr.FillGradRect(" (should be 5 in a row), cant remember which lines specificaly but the adjustments need to be done there
3, dont know sorry
as for the cover art, really dont know how else it can be done in ELP if the wildcard doesnt work, maybe someone else can enlighten but considering the way its configured prob best to try & standardise your cover names to fit.
Question: is there away to remove the window decoration from around the interface or, if not, can I get foobar to point to a particular visual style that's not currently loaded on my desktop?
do you mean the panels? if you do its coded in the script with drawroundrect's, you could remove them but i wouldnt recomend it as it would make a tremendous mess of the script
I just found this theme and I love it. There is a few things I would like to add but I am not sure of the syntax. Perhaps you guys can help.
1. I would like to add a biography link to the top right set of buttons. I am not sure how to add a new button up by the album list and all.
2. I would like to remove the track number from the track listed under the album art
3. can the stars under the album art be set up to be clickable for rating? Also does the rating in the lower left set the rating in the actual MP3 tag or in the database. I don't want to write to my tags if I can help it.
4. how can I make the got lyrics icon show if there is a .lrc file as well as embedded lyric.
