I have a extensive music collection and i want to adjust autoatically the replaygain in each folder. I'm doing it manually but think i can do it automatically. How do i apply, i'm applying "scan selection as single album" in each album folder, is it correct?. If so, why always get -8, -10, -5db in all the albums?.
Use the "scan selection as Albums by tags" option.
You can also add "Scan Selection as Albums (by directories)" at Preferences, Context Menu.
Which is difference between scan by directories & tags?
how it "groups" albums
Ok, thanks a lot for your replies.
Should i let in 0db in playback preferences with and without reglaygain info?. Why always get negative db (-8, -10, -5db) in all the scans?
http://replaygain.hydrogenaudio.org/faq_quiet.html (http://replaygain.hydrogenaudio.org/faq_quiet.html)
