I wasn't sure if I should post this in the "Definitive Custom Buttons Thread", since they are not buttons, strictly...
I'm gonna post my whole config in the new "share your cfg thread", but the layout is not completely finished, and all my codes (except for this one) are a mess, but in the meanwhile I thought maybe someone might want my playback buttons, so here's the code for the Track Info mod
. THANKS TERRESTRIAL![/color]
So. the code:
$imageabs(0,0,images\FOOBOTTOM.png,)
///////PLAY/PAUSE
$button(21,9,0,0,28,30,
$if($or(%ispaused%,$not(%isplaying%)),images\iconsPLAYBACK\PLAY.png,images\iconsPLAYBACK\pause.png),
$if($or(%ispaused%,$not(%isplaying%)),images\iconsPLAYBACK\PLAY_OVER.png,images\iconsPLAYBACK\pause_OVER.png),
$if($or(%ispaused%,$not(%isplaying%)),play,pause)
///////STOP
$button(49,12,0,0,22,24,images\iconsPLAYBACK\STOP.png,images\iconsPLAYBACK\STOP_OVER.png,stop,)
///////PREVIOUS
$button(89,12,0,0,22,24,images\iconsPLAYBACK\PREVIOUS.png,images\iconsPLAYBACK\PREVIOUS_OVER.png,previous,)
///////NEXT
$button(111,12,0,0,22,24,images\iconsPLAYBACK\NEXT.png,images\iconsPLAYBACK\NEXT_OVER.png,next,)
//////////PLAYBACK ORDER
//////DEFAULT//////
$if(
$not($stricmp(%cwb_playback_order%,default))
$button(152,16,0,0,15,15,images\iconsPLAYBACK\dfnot.png,images\iconsPLAYBACK\df_over.png,default,)
$imageabs(152,16,images\iconsPLAYBACK\df.png,)
//////SHUFFLE///
$if(
$xor(
$stricmp(%cwb_playback_order%,default),
$stricmp(%cwb_playback_order%,'repeat (track)'),
$stricmp(%cwb_playback_order%,'repeat (playlist)')
$button(171,16,0,0,15,15,images\iconsPLAYBACK\shnot.png,images\iconsPLAYBACK\shnot_over.png,'Shuffle (tracks)',)
$if($stricmp(%cwb_playback_order%,'Shuffle (tracks)'),images\iconsPLAYBACK\SHTRACKS.png,images\iconsPLAYBACK\SHalbums.png),
$if($stricmp(%cwb_playback_order%,'Shuffle (tracks)'),images\iconsPLAYBACK\SHTRACKS_over.png,images\iconsPLAYBACK\SHalbums_over.png),
$if($stricmp(%cwb_playback_order%,'Shuffle (tracks)'),'Shuffle (albums)','Shuffle (tracks)')
///REPEAT///////
$if(
$xor(
$stricmp(%cwb_playback_order%,'shuffle (tracks)'),
$stricmp(%cwb_playback_order%,'shuffle (albums)')
$button(190,16,0,0,15,15,images\iconsPLAYBACK\rpnot.png,images\iconsPLAYBACK\rpnot_over.png,'repeat (track)',)
$if($stricmp(%cwb_playback_order%,'repeat (track)'),images\iconsPLAYBACK\RPTRACK.png,images\iconsPLAYBACK\RPPLAYLIST.png),
$if($stricmp(%cwb_playback_order%,'repeat (track)'),images\iconsPLAYBACK\RPTRACK_over.png,images\iconsPLAYBACK\RPPLAYLIST_over.png),
$if($stricmp(%cwb_playback_order%,'repeat (track)'),'repeat (playlist)','repeat (track)')
//////////VOLUME
//VOLUME BAR
$alignabs(230,20,100,20,,)
$puts(volume,$substr($num(%cwb_volume%,4),2,4))
$puts(active,$rgb(117,211,255))
$puts(back,$rgb(81,81,77))
$font(arial,10,bold,)
$if($greater(1,$get(volume)),$puts(amp,12),
$if($greater(3,$get(volume)),$puts(amp,11),
$if($greater(6,$get(volume)),$puts(amp,10),
$if($greater(9,$get(volume)),$puts(amp,9),
$if($greater(13,$get(volume)),$puts(amp,8),
$if($greater(16,$get(volume)),$puts(amp,7),
$if($greater(21,$get(volume)),$puts(amp,6),
$if($greater(26,$get(volume)),$puts(amp,5),
$if($greater(33,$get(volume)),$puts(amp,4),
$if($greater(43,$get(volume)),$puts(amp,3),
$if($greater(58,$get(volume)),$puts(amp,2),
$puts(amp,1))))))))))))
$if($stricmp(100,$get(volume)),$puts(amp,0))
$font(wingdings,6,,)
$get(active)$repeat($char(376),$get(amp))
$get(back)$repeat($char(376),$sub(12,$get(amp)))
///nÂș Db///////
$font(kroeger 05_55,5,,117-211-255)$alignabs(278,19,35,20,right,)-$num($get(volume),1) Db
//BUTTONS
$if($greater(1,$get(volume)),$puts(amp,48),
$if($greater(3,$get(volume)),$puts(amp,44),
$if($greater(6,$get(volume)),$puts(amp,40),
$if($greater(9,$get(volume)),$puts(amp,36),
$if($greater(13,$get(volume)),$puts(amp,32),
$if($greater(16,$get(volume)),$puts(amp,28),
$if($greater(21,$get(volume)),$puts(amp,24),
$if($greater(26,$get(volume)),$puts(amp,20),
$if($greater(33,$get(volume)),$puts(amp,16),
$if($greater(43,$get(volume)),$puts(amp,12),
$if($greater(58,$get(volume)),$puts(amp,8),
$puts(amp,4))))))))))))
$if($not($greater(1,$get(volume))),$button2($add($get(amp),230),20,0,-7,15,20,,'$font(wingdings,6,,250-0-0)$char(376)',volume up,))
$button2($add($get(amp),222),20,-10,-7,15,25,,'$font(wingdings,6,,0-0-250)$char(376)',volume down,)
//VOLUME CONTROLS
$imageabs(331,13,images\iconsPLAYBACK\VOL.png,)
$button(331,13,0,0,12,22,images\iconsPLAYBACK\VOL_DOWN_M.png,images\iconsPLAYBACK\VOL_DOWN_OVER_M.png,Volume DOWN,),
$button(331,13,0,0,12,22,images\iconsPLAYBACK\VOL_DOWN_V.png,images\iconsPLAYBACK\VOL_DOWN_OVER_V.png,Volume DOWN,))
$button(354,13,11,0,11,22,images\iconsPLAYBACK\VOL_UP_M.png,images\iconsPLAYBACK\VOL_UP_OVER_M.png,Volume UP,),
$button(354,13,11,0,11,22,images\iconsPLAYBACK\VOL_UP_V.png,images\iconsPLAYBACK\VOL_UP_OVER_V.png,Volume UP,))
$button(343,13,0,0,22,22,images\iconsPLAYBACK\VOL_MUTE.png,images\iconsPLAYBACK\VOL_MUTE_OVER.png,Volume mute,),
$button(343,13,0,0,22,22,images\iconsPLAYBACK\VOL_ON.png,images\iconsPLAYBACK\VOL_ON_OVER.png,Volume mute,))
The images folder should be inside your foobar dir, (I don't have per-using settings enabled. If you do, maybe they should go in the documents and settings foobar folder too, I'm not sure)
sune
Looks great, I love it. Only thing "missing" is a seekbar. That and the volume thing.
nothing i do matters, the background doesn't show up. all components installed and up2date.
crazy wild bug?
ronny
yeah I already explained that 'bug' in the first post.
when you doubleclick the panel mode changes, from "now playing" to "follow cursor". So, since I've had to use "$if(%isplaying%" several times for the buttons, when the panel mode changes AND the selected track is different from the one that is playing, the buttons don't behave allright (because the target track is actually not playing..).
The next version of track_info_mod will hopefully allow to lock the panel, and this will get fixed. It's pretty annoying for me too, since I'm used now to change the volume from the panel
sune
hallo nice track info, but .....
Really nice, thanks. Can't wait for full config.
You can in theory, but these aren't normal buttons, it's a track info panel. The fofr code would need to be edited to put a track info mod panel where the normal buttons are. It would need to be resized a bit, some regular buttons cut off and this would too.
