If I load a WavPack image with an embedded cue sheet into Burrrn and burn it I am actually burning from the cue sheet right?
(ie I'll have an exact 1:1 copy)
Burrrn decodes the WavPack image to WAV and burns from the cue?
I'm not sure if Burrrn supports embedded cue sheets. You can always try burning it once as-is, then extracting the CUE and burning it like that, and see if there's any difference between them.
Yup.
Yup.
