Hi folks,
I've got a bunch of DTS CDs and I am looking for a decent codec to transcode the stuff. I found some threads about issues like channel coupling and other issues that are important for multi-channel files but I haven't found test comparing different codecs with each other.
Obvious choices are:
- Ogg Vorbis
- (He-)AAC
- WMA
The main purpose I'd like to transcode the stuff is for saving disk space, because I'm a poor student Furthermore, I would like to use foobar2000 for conversion for the sake of simplicity.
I definitly don't consider myself to be an audiophile (lame aps is more than enougth for me for 2channel files) but I wouldn't like to transcode everything, and realizing after a couple of months and properply new equiptment that everything is messed up. Another thing I cannot really assess is the necessity of certain bitrates e.g. ac3 definitly does not need a high bitrate as dts does.
I tried a dts test encode for a file and here are my results:
ogg vorbis -q5: 459kbps
lc-aac (transperant setting): 544kbps
I just consider both setting are still a waste of diskspace for me so any ideas?
Chris
For 5.1 audio I'd go with AAC (not HE) at 320 kbps.
At what setting?
At what setting?
[a href="index.php?act=findpost&pid=316197"][{POST_SNAPBACK}][/a]
Just use 320 kbps CBR (constant bitrate), or find out which VBR (variable bitrate) mode will give you bitrate in the range of 300 to 350 kbps.
5.1 bitrate = STEREO + STEREO + MONO + LFE
For AAC it is believed that the following bitrates produce 'transparent' quality for vast majority of audio samples:
STEREO ~ 128 kbps
MONO ~ 80 kbps
LFE < 10 kbps
so
5.1 bitrate ~ 350 kbps.
Daniel
@dand
it's not that simple
@chris
apart from mp3 surround which is a proprietary codec
aac is at time the only lossy one with channel coupling at multichannel.
you could try he-aac at around 120-170kbit.
personal i don't like the "sbr-sound".
or you go for lc-aac at around 230-320kbit. forget cbr!
at sense of bitrate for me aac is not much better than ac3 for example.
Where did I go wrong?
HE AAC is NOT to be used for transparency. It will never replace AAC, it is its extension for low bitrates only.
How can you fit two stereo pairs and one mono channel into 230 kbps? That won't give you transparency.
Not true. AAC outperformes AC3 at any bitrate.
with your simple equation 128+128+80+10=transparent
chris did not mentioned the word 'transparent' anywhere except for
the preset. i understood the question as a call for low bitrate encodings.
ever monitored a 5.1 recording? not every channel is always peaked out
to the max. or you get the same signal shifted through 4 channels etc...
do you know how good the coupling inside aac works?
test for yourself...i don't consider myself an audiophile.
i can even live with a 140kbit 5.1 he-aac file.
abx tests? or is this your personal opinion?
abx tests? or is this your personal opinion?[a href="index.php?act=findpost&pid=316212"][{POST_SNAPBACK}][/a]
I believe that can be inferred from a math point of view alone. It's well known around here that, from an algorithmic point of view, AC3 is about on par with MP2. So, it isn't (theoretically) even in the same league as MP3, let alone AAC.
that is not the point of this discussion.
it's possible that aac improves on multichannel but in it's current state
of development 320kbit aac is not much less than 448kbit ac3. that's math.
'128+128+80+10=transparent' maybe is a simple equation for you, but there is a huge amount of work done before audio coding got there...
HE AAC should be used for internet radio or your mobile phone, but I don't think that's the case here.
Let's not compare AC3 to AAC, it's not polite.
I never monitored a 5.1 recoding, but I did recently listen to, for example, Beck's Guero as a separate 5.1 album release. Couldn't hear 'same' signal sent to more than 2 channels (and its not the same, only similar, which is a big difference).
Why don't you tell us how AAC handles 6 channels in 5.1 configuration?
at my first trys with he-aac it sounded ok to me at 170kbit transcoded from
a 448kbit ac3. but that are just my ears.
why not? at high bitrate you did not provide any argument against doing this.
i know little about the codec internals but propper coupling of multichannel
is another story than simple stereo.
'you are wrong but I don't know what's right'... With that kind of attitude you will just confuse people around here.
I think, pest impiles that there is no such thing as “two stereo pairs + mono”. It's just five channels, and all of them can be coupled together, without splitting in pairs.
And what is the point? You asked for proof that "AAC outperformes AC3 at any bitrate.". I gave you mathematical hints that such claim is probably true.
[a href="index.php?act=findpost&pid=316214"][{POST_SNAPBACK}][/a]
And what's with 448kbps AC3? What does it matter? The guy is transcoding from DTS, so using AAC at ~300 will be much better than the original bitrate no matter what.
[a href="index.php?act=findpost&pid=316300"][{POST_SNAPBACK}][/a]
Try to find a 5.1 recording that doesn't follow the "two stereo pairs + mono + lfe" rule. I haven't seen one. Of course, you can encode anything with AAC. For example, you can make an encoder that would encode stereo as two mono channels, or also 5.1 as 6 mono channels, or you can pair front left with lfe, but that's something no encoder should do.
2.0 channels = STEREO
5.1 channels = STEREO + STEREO + MONO + LFE
There are 6 channels recordings following the 2+2+2 setting. The german label MDG has some in its catalog:
http://www.mdg.de/dvde.htm (http://www.mdg.de/dvde.htm)
More about 2+2+2:
http://www.mdg.de/222e.htm#Anchor--2+2-63965 (http://www.mdg.de/222e.htm#Anchor--2+2-63965)
http://www.aes.org/events/118/exhibitorsem...on.cfm?code=ES6 (http://www.aes.org/events/118/exhibitorseminars/session.cfm?code=ES6)
From whay I've read (French classical music magazines), 2+2+2 recordings are really convincing, and more suited for music ("classical" at least) than 5.1 (with optimal recording and mastering for both).
More about 2+2+2:
[a href="index.php?act=findpost&pid=316432"][{POST_SNAPBACK}][/a]
Thanks Guru. 2+2+2 is something new (for me) and it seems cool.
However, this still is not a 5.1 recording that doesn't follow "stereo + stereo + mono + lfe" rule. This isn't a 5.1 recording at all, this is 6.0 recording as I understand.
