i can't play some of my mpc files on xmms with this plugin
also the tags are messed-up or don't even show up (this only happens with the files that don't play)
i'm gonna throw out an id3v2 guess here...
i haven't had any problems with a range of files. you can upload the file to me at:
ftp://xmixahlx.dyndns.org:21/incoming/ (http://ftp://xmixahlx.dyndns.org:21/incoming/) if you are unsure of how to handle it
later
later
[a href="index.php?act=findpost&pid=228013"][{POST_SNAPBACK}][/a]
sory for not answering sooner
the file is up on your ftp.
The Clash - London Calling - 13 - Koka Kola.mpc
k
i'm in the process of moving/new job now, so i'll get back to ya
...later
i also tried v1.00 of the plugin and i get this error :
ERROR: function play()
Superframe-size !=1: not suported anymore.
Please decode with command-line tool!
v1.1-alpha6 doesn't output any error
edit:
i also tried: mppdec (Static linked) 1.95e and it played the file fine
the output was:
./mppdec-static ./The\ Clash\ -\ London\ Calling\ \[EAC-MPC\ Q5\ xlevel\]\ \[by\ Panzemeyer\]\ \[www.MPC-Donkey.de\]/The\ Clash\ -\ London\ Calling\ -\ 01\ -\ London\ Calling.mpc
MPC Decoder SV7 1.95e 3DNow/SSE © 1999-2003 Buschmann/Klemm/Piecha/Wolf
decoding of file './The Clash - London Calling [EAC-MPC Q5 xlevel] [by Panzemeyer] [www.MPC-Donkey.de]/The Clash - London Calling - 01 - London Calling.mpc'
to device /dev/audio (Open Sound System)
mppdec: Stream was corrupted by an ID3 Version 2 tagger
, ignore 1086 words and 24 bits ...
The Clash: London Calling (???1979)
[01] London Calling (by Panzemeyer (EAC secure m.)
179.2 kbps, 3:23.83, SV 7.0, Profile 'Standard' (Beta 1.14)
3:23.83 (runtime: 2.99 s speed: 68.17x)
any reason why all the files from this album don't work on the xmms-plugin ?
As xmixahlx already guessed, this file has an ID3v2 tag which is not supported by Musepack. Try to remove the ID3v2 tag and the file should play fine - also with the latest XMMS plugin.
Best regards,
~ Florian
Best regards,
~ Florian
[a href="index.php?act=findpost&pid=230289"][{POST_SNAPBACK}][/a]
how do i remove the tag ?
i've tried easytag and xmms to remove the tag and it doesn't work
- easytag says it removes it but when i reload the file it's still there
- xmms has the option grayed out
hi,
get the id3v2 commandline utility from http://id3v2.sourceforge.net/ (http://id3v2.sourceforge.net/) and run
id3v2 -D file.mpc
it's working now
thank you for your help
