QKTune beta 1
This is an (unoptimised) win32 binary of the Vorbis which I tried tuning myself. The tunings are aimed at reducing pre-echo only and that is the only part I modified from the original 1.0.1 source code.
Vendor tag is: Xiph.Org libVorbis I 20030909 (QKTune beta 1) EXPERIMENTAL
This is experimental so the quality of the files produced is uncertain.
The relevant thread is here (http://www.hydrogenaudio.org/forums/index.php?showtopic=17950&view=findpost&p=176753)
QKTune beta 2
This is a better tuned version with further reductions in pre-echo with q 2, 3, 4, and 5. Also, shifted stereo modes down so q 2 and 3 should sound more "stereophonic".
Note that the bitrates produced are slightly higher too because of the above modifications.
Vendor tag: Xiph.Org libVorbis I 20030909 (QKTune beta 2)
Try it and tell me how it goes.
QKTune beta 3 (more like beta 2.1 but oh well) Seems to have a positive effect on the HF boost problem, esp. on nyaochi's 8823.flac sample at q 4. Only change from beta 2 is at q 4.
For testing only. The bitrate goes up quite a lot so I wouldn't recommend this for mainstream use.
Relevant thread (http://www.hydrogenaudio.org/forums/index.php?showtopic=17950&view=findpost&p=185474)
EDIT: Deleted binary. Bitrate is too high for a barely tangible improvement.
QKTune beta 3.1
This is QKTune beta 3.1, a second attempt at reducing HF boost/hiss. Bitrates are now comparable with beta 2 (ie. not skyrocketting like beta 3).
Some radical changes have been made to the stereo coupling mechanisms which are unproven and may very well break quality, so this is for TESTING ONLY!!
Report unwanted and displeasurable distortions HERE (http://www.hydrogenaudio.org/forums/index.php?showtopic=17950&view=findpost&p=187307)
QKTune Beta 3.2 (Final)
Changes:
- Uses less aggressive point stereo compensation
- Implements 'partial point stereo' where some diffuse information (like reverberations) is retained
As usual, report displeasurable quality problems HERE (http://www.hydrogenaudio.org/forums/index.php?showtopic=17950&view=findpost&p=187670)
UPDATE: Final and frozen version of beta 3.2. I've sorted out all the bugs with compiling in VS.NET and some minor pre-echo adjustments.
are you making the libvorbis sources available too?
later
later
Not yet. I'll release the libvorbis sources soon, when I feel I've ironed out most of the problems associated with the changes to the stereo mechanism. There are a lot of question marks in what I'm doing so I want to be sure whether there is a better way of doing it first.
QKTune beta 3.3
Changes:
- replaced angle calculation with something similar to what is done in lossless coupling
This highly experimental release may give worser quality than beta 3.2.
QKTune beta 3.4
Changes:
- we set the angle to 0
QKTune beta 3.5 Classical Edition
This is an experimental tuning to address some noise issues in classical music at q 4 only.
Changes:
- Different point stereo 'hack'
- Tuned to (hopefully) reduce 'graininess/coarseness' in classical instruments
Report any displeasurable artifacts HERE (http://www.hydrogenaudio.org/forums/index.php?showtopic=17950&view=findpost&p=193378).
Thank you.
