Hello,
I have a playlist in foobar2000 that have become unmanageable on the smartphone, I have to modify it on the computer. I want to save the playlist to a file (any playlist file format), but I can't find how to do it.
Please advice.
Just create a m3u8 playlist on foobar2000 and send it to Android.
Sorry i forgot, first you have to Edit the m3u8 file with the Path to the files on your Android.
Something like:
/storage/sdcard1/Documents/Music/vivo/05 - Fade Away - Stereo MC's.mp3
and then send m3u8 file to Android.
Sorry but I don't follow...
I already have a playlist in foobar I want to rearrange the tracks but there are too many. If I'm able to save that playlist to a file, then I can transfer the file to my computer to edit the playlist. If I have to create a playlist like a text file using something like Notepad++, that will defy the purpose, that's if I understood you correctly.
Yes thats what i meant. Edit the m3u8 filt with something like Notepad++ and send it to the smartphone.
Ok then, thanks but no thanks.
I had already created the playlist IN Foobar2000 for Android and I need to save that playlist. If I create were I have to manually type the path and the name of the track is like doing the playlist again from scratch. What I need is to save an already created playlist to a file in the smartphone, then take that file and transfer it to the computer. modify it and transfer it back to the smartphone.
By the way I lost all the playlists because I had to roll back from 1.3 to 1.2.30. So under the current circumstances you methodology does apply because I have to create the playlists again but not if I have created a playlist from withing Foobar in the smartphone.
I ask before
How can I import my playlists created on foobar2000 mobile Android to the PC?
But no answer.
