Hello,
As other people have already noted, the k9 internet filter blocks all connections from foobar (it's the only program that generates problems). Is there a fix (to be made) for this?
I doubt this is foobar's fault... probably some component is trying to connect to a shady server. Please give more details.
Might be related to this (https://hydrogenaud.io/index.php/topic,113883.0.html)
I have done a clean install of foobar and only loaded a wasapi component, then pressed `get updates` and it said `Could not check for updates: Connection error`, so it does not seem to result from a bad component
Is there any indication why K9 is blocking foobar? There may be a false positive.
I wonder if K9 is dinging fb2k because the installer is no longer digitally signed.
@glenngulda Try whitelisting www.foobar2000.org or foobar's exe if k9 supports that.
http://www1.k9webprotection.com/support/kb/K9155.html
Here's a post (https://hydrogenaud.io/index.php/topic,100367.msg899134.html#msg899134) from 2015, so it seems it's not because the installer.
