aac-libav-0.8.17-win32:
ffmpeg aac -i input.wav output.aac -quality 00001 cutoff 22050 bitrate 387kbps.
Internal aac encoder in libav still experimental until now, unlike ffmpeg, so you have to add command " -strict -2 " or " -strict experimental " for it to work...
Did i get this? :
Libav (pre-3.0 FFmpeg) AAC encoder.
Anyone?
http://wiki.hydrogenaud.io/index.php?title=AAC_encoders
Yes that is the libav encoder.
Now i only have to learn how to use it.
The reason its marked as experimental is that it doesn't work very well. You probably should not be using it.
