discussion/bug reports here (http://www.hydrogenaud.io/forums/index.php?showtopic=108039)
This plugin convert stereo music to mono without antiphase data lost.
How it works:
In frequency domain (by FFT), this plugin calculate the magnitudes of left, right and mono mix channels for each frequency.
Output signal combined from mix of left and right magnitude and phase from mono mix.
When antiphase mode, the magnutude calculated as difference beetwen mix of left and right, and mono magnitude.
Updated - minor latency bug fixed; output gain parameter added; renamed. Compiled with two versions of SDK for different foobar versions.
