I don't know if someone is still maintaining of the musepack sources, anyway here's my bug report to anyone for whom it matters.
In tags.c the authors use
char as array index for the codepage conversion, which is very much signed at least in MSVC. I think the official build doesn't work with non-latin tags (cyrillic in my case) because of this error.
int
addtag ( const char* key, // the item key
size_t keylen, // length of item key, or 0 for auto-determine
const char* value, // the item value
size_t valuelen, // the length of the item value (before any possible translation)
int converttoutf8, // convert flags of item value
int flags ) // item flags proposal
unsigned char* p;
unsigned char* q;
char ch; <<---------------- here
size_t i;
Hello,
In tags.c the authors use char as array index for the codepage conversion, which is very much signed at least in MSVC. I think the official build doesn't work with non-latin tags (cyrillic in my case) because of this error.
My inderstanding is that the variable "ch" is used to store the character that will be translated, and not the codepage. The only assigned value is from value
which is a char, so no pb here.
Do you have a case where this function fails ? If yes, please provide the inputs, the current result and the expected result.
Thanks,
Nicolas
Hello, Nicolas.
ch is used as an array index for an array which is used for the codepage conversion (from local to utf8) on the line 776
q = utf8char ( q, CP_ptr [ch] );
for the command
mpcenc --title Песня 01.flac for unaltered sources i have
(http://i60.tinypic.com/25tzxut.jpg)
if i change type of
ch to unsigned char:
(http://i61.tinypic.com/21lj03p.jpg)
Anyway I faced much more significant problem when I tried to convert files with german diaeresis / umlauts in the name, mpcenc just can't open them, because it uses ansi args (
argc,
argv). Therefore I think the only real fix is to use unicode
argv, use
wchar_t in file-handling functions and use
WideCharToMultiByte in
tags.c for converting to utf8. I did some (very) dirty hacks and this actually works.
