HydrogenAudio
Lossy Audio Compression => MP3 => MP3 - Tech => Topic started by: LauraQ on 2014-04-14 21:07:37
Title: audio volume low :(
Post by: LauraQ on 2014-04-14 21:07:37
Hi
I'm converting my CDs using the latest Lame and  using this string
-b 320 --id3v2-only --pad-id3v2 --ta "%artist%" --tt "%title%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr2%" --tg "%genre%" %source%
but the mp3s are often generated with the sound down, What setting I must change to increase the volume? I using EAC
Post by: markanini on 2014-04-14 21:21:04
Should be same levels as input. Did you try a different player?
Post by: pdq on 2014-04-14 21:44:36
If you compare the mp3 against the wav file from which it was encoded, do the volumes match?
Post by: [JAZ] on 2014-04-14 22:08:50
If it still is the case (which i haven't verified), LAME applies a very small attenuation to the signal when encoding in CBR, concretely a multiply of 0.97, which equates to -0.25dB.
I doubt you hear this difference, so I will comment on the most probable reasons:
* You have somehow applied replaygain/R128/whatever (which you didn't say) and the player supports it. AFAIK, neither LAME nor EAC do this automatically.
* If the difference in volume is not constant, it might be that either the player, or Windows is applying a dynamics compressor. If it is based on peak, it is probable that peaks of the MP3 file are higher than those in the CD, causing a reduction in the volume.
* Your player uses different audio paths/equalizers/DSP effects depending on the audio source. For example, old versions of Winamp had a different equalizer for MP3 files than for the rest of the files. I think that there is a similar thing with Windows Media Player, where not all sound types use the DSP effects.
* You use different players to play the files, and they use different audio paths (different sound driver, different volume settings, etc...) This is relevant because in some settings and drivers, the master gain cannot be controlled.
* You compare how the CD sounds played out directly with a hardware player versus the output of your PC/mobile/laptop/tablet/whatever. This wouldn't be a fair comparison.
* You use a (rare?) player that understands replaygain information inside the LAME tag.
* You use the analog output of the CD-ROM  (Does this still exist nowadays?)
Post by: pdq on 2014-04-14 22:16:47
I'm pretty certain that this is only done at lower bitrates, in which case it would not apply to the -b 320 files in question.
Post by: LauraQ on 2014-04-14 22:17:35
No, I have only a player, is a Samsung TSSTcorp CDDVDW SH S222A ATA I think it was a good quality player
Post by: saratoga on 2014-04-14 22:18:29
Thats a CDROM drive, not an a music playing application.
Post by: LauraQ on 2014-04-14 22:23:27
However, the sound is always low with all the CDs that I checked out, I think it's a problem or the player or how I configured EAC.
Is there any setting in EAC that may affect the volume level?
What should I put in place of b-320 to see if the problem is?
for Saratoga:
Yes, I use the cdrom drive for extract the mp3, I have only it
Post by: saratoga on 2014-04-14 22:25:10
This is what you have to tell us.  Try playing the files in a different application.  Try ripping directly to .WAV.  See if either of those fixes the problem.
Post by: LauraQ on 2014-04-14 22:27:19
Can you tell me exactly what I must do, I did not understand
Post by: includemeout on 2014-04-14 23:35:04
Oh lor... I mean, you'll quit calling it a "player" perhaps sooner than you think: as you churn out more CD tracks into MP3, it's your computer who will probably be doing most of your music playing from now on.
Post by: Juha on 2014-04-15 09:55:42
Hi  I'm converting my CDs using the latest Lame and  using this string  -b 320 --id3v2-only --pad-id3v2 --ta "%artist%" --tt "%title%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr2%" --tg "%genre%" %source%  but the mp3s are often generated with the sound down, What setting I must change to increase the volume? I using EAC  Thanks!
I would start by checking the output level of my playback software (you know, knobs pointing to southeast).
Post by: LauraQ on 2014-04-15 18:39:19
in the control panel of my sound card volume level is set to high
Post by: rick.hughes on 2014-04-15 21:57:31
There are potentially many places where volume can be controlled and we are only guessing unless you give us a lot more specific details about your hardware and software.
Post by: nastea on 2014-04-16 04:08:01
Check your volume controls, there's often a master volume, a "wave" output volume, and the appliccation you're using for playback (I just read it's Winamp) also has it's own output volume that may have been put down (accidentally).
Another thing I can think of is: there might be a headphone plugged in while you are thinking you're listening to computer-speakers. I feel a bit stupid to mention this, but you never know.
Hope you find the problem.
Post by: LauraQ on 2014-04-16 07:26:56
motherboard GIGABYTE GA-P55-UD4 with soundcard integrated
Post by: LauraQ on 2014-04-16 07:28:29
thanks but no headphone and all the level are up
Post by: Juha on 2014-04-16 12:13:00
Do you have the software for integrated soundcard installed?
To check the levels you can use software from http://dr.loudness-war.info/ (http://dr.loudness-war.info/)
Behind the Link -button there's a software which you can use for to check the files. Bring the log file data here.
Post by: LauraQ on 2014-04-21 11:21:25
I don't have the software, where I can find it? Thanks
Post by: Juha on 2014-04-21 14:25:57
http://www.gigabyte.com/support-downloads/...-downloads.aspx (http://www.gigabyte.com/support-downloads/support-downloads.aspx)
Post by: LauraQ on 2014-04-21 16:36:04
I have find the page but no software for Win 8.1
http://www.gigabyte.com/products/product-p...161&dl=1#dl (http://www.gigabyte.com/products/product-page.aspx?pid=3161&dl=1#dl)
Post by: fluzzknock on 2014-04-22 02:16:32
There is a page under EAC > EAC Options... called "Normalize."  Make sure "Normalize" setting is OFF (no check-mark).
Which software player are you using to play CD?  Which software player are you using to play mp3 file?
Post by: pdq on 2014-04-22 13:47:04
That would never make the volume softer, only louder.
Post by: DVDdoug on 2014-04-22 23:35:10
Laura,
I'm pretty sure you've misdiagnosed the problem...  For some reason, CDs are playing louder than MP3s (and probably WAVs).  I don't know why...  you haven't told us what player software you are using or if you are using the same application for playing CDs and MP3s.
I don't think you have a problem with ripping or LAME-MP3 encoding.
Post by: rick.hughes on 2014-04-23 13:16:11
Laura,
There are some mp3 samples in this post (http://www.hydrogenaudio.org/forums/index.php?showtopic=105489&st=0&p=863879&#entry863879). Download them and play them the same way you play your own rips. See if the volume is low on them also. That will tell you if you're having a problem with creating mp3 files or (more likely) a problem with playing them.
Post by: Nimos on 2014-04-23 20:03:07
In your sound control panel, check if your particular audio jack ( you are using your headphone or speakers) is assigned as headphones or line out.
Assign it as headphone if not. But it won't affect in case of active speakers.
You may not have that setting available based on your sound card.
I doubt if you are playing the CD directly in your drive. That is your drive sends the audio directly to your sound card instead of a software like EAC reading the CD data.
In older Windows versions there was a CD volume slider available, which handles this type of audio transfer.
Check if such a volume slider is available in your Windows volume control and try playing with it.
