Hi. I have been using foobar for years with no issues at all, but now I get the following message when I try to start it:
foobar2000.exe - Application Error
The application was unable to start correctly (0xc0000005). Click OK to close the application.
I am using Windows 7 64, Professional Edition.
Any help would be much appreciated. Thanks.
i had a quick google and it might be a problem with a recent windows update. look under installed updates and try and uninstall kb2859537 and see if that works.
I think you may be right, since I'm getting the same error with other programs too. However, update kb2859537 isn't in my update history and I can't click on "Installed Updates". Is there another way to remove it?
try rolling back with system restore?
failing that you might be better off asking/searching around on the microsoft forums.
