Hello there,
So I have Facets downloaded for foobar and I came across and issue that I can't seem to solve no matter how much Google searching or fiddling around myself I do.
My issue is that my music is not being 'sorted' correctly when I use the grouping feature. It seems to be working aside from sorting by the track number. If you see my attached screenshot, it correctly groups by artist and album, but each individual album is not sorted by the correct track number, which can be quite annoying.
Does anyone know how I can fix it? As far as I can tell, it seems to only be a problem when I have an artist with multiple albums.
Screenshot of the issue: http://gyazo.com/1c64120d361d82f4c1f5b8d3337bfd2c (http://gyazo.com/1c64120d361d82f4c1f5b8d3337bfd2c)
I am not sure how the default playlist view sorts by default - I guess by %path_sort% - but according to your picture all your albums are sorted descending by title name. You probably clicked twice at the column "title/track artist". To sort by track number you first have to click at the column "track no" and than at "album" to enable album grouping.
You should also check your tags and file names. If there is something wrong sorting won't work correctly.
Hello there,
If your problem is just that you want it to autosort when you browse by facets, then you can change the facets default sort order.
go to Preferences > Media Library > Facets
in the library section, change the default sort order to something like:
%album artist%|%date%|%album%|%discnumber%|%tracknumber%
you can remove %date% if you prefer albums to be sorted alphabetically rather than by date.
