Topic: Playlist-Manager-SMP (Read 53584 times) previous topic - next topic
Re: Playlist-Manager-SMP
Reply #350
They are solid but blank, because they are empty. That applies to any type of playlist. Files have a different icon.
I get it at last. To make a standard, one I must select and convert. All others created at the fly are UI-only.
What I can say....I'm dumb.
Accept my humble apologies
Colors work fine
X
Reply #351
It has always been that way. If you want only playlist files, disable tracking UI playlists. Otherwise, create playlist files.
Reply #352
I think I will keep it, maybe I will start to use playlists beyond the library view and some occasional taging.
Reply #353
I'm looking through the latest builds and I see 0.15, but it's dated 2023-03-21. I assume this should be 2024-03-21?
Reply #355
https://github.com/regorxxx/Playlist-Manager-SMP/releases/tag/v0.16.0
0.16.0 - 2024-04-22
Added
    Playlists maintenance tools: ported the Playlist revive functionality from Playlist Tools, available now at Playlist maintenance tools, for the active playlist. Pressing Shift + L. Click on the menu entry will select the dead items instead of replacing them. For more complex usage, check the other script.
    Importing file: feature similar to the one found at Playlist Tools-SMP, lets you find matches on library using a mask against a text list (for ex. ARTIST - TITLE per line). Additionally, not found items may be replaced with YouTube links. It also works directly on a URL as long as the content is only text. There is an array of configurable query filters to tweak how tracks are preferred (for ex. non live tracks first).
    UI: total track's size is now available as sorting method, tooltip info (next to duration) and display column. Value is calculated at startup for playlist files (and never saved at the playlist file nor cached) or after loading any of them. This calculation is done without an additional performance impact in case playlist caching is already enabled due to specific search settings (for ex. enabling query searching); it may also be forced with a new setting at 'Playlist behavior\Update other Playlists...' submenu. For UI-only playlists, is always calculated at startup independently of any other setting.
    UI: added tip at quick help popup ('?' button) about tooltip font settings.
    Configuration: expanded user configurable file at '[FOOBAR PROFILE FOLDER]\js_data\presets\global\globSettings.json' with a new setting for console logging to file. Disabled by default. Now this is a change from the previous behavior, where console was always logged to 'console.log' file at the [FOOBAR PROFILE FOLDER]. It can now be switched, but since it's probably not useful for most users is disabled by default.
Changed
    XSP: smart playlist are now also refreshed when the playlist sources change by drag n' drop, mouse actions, deleted or restored, in addition to changes when they are loaded in UI (introduced at 0.13.0).
    Clone: .xsp playlists and Auto Playlists will now make a copy of the loaded playlist (if possible) when cloning as UI playlist, instead of re-calculating the playlist to create the copy. This ensures the clone has the same sorting than the loaded version.
    UI: changed all builtin tooltips during external drag n' drop to use the native ones (which also span outside the panel).
    UI: all sorting methods now also sort elements by name in case they have the same priority (for ex. all 0-sized playlists sorted alphabetically instead of randomly).
    UI: smoother scroll bar movement when using the mouse and dragging the bar.
    Helpers: most json data files are now saved with Windows EOL for compatibility improvements with Windows text editors.
    Helpers: updated helpers.
Removed
Fixed
    UI: sorting not applying properly to folders when sorting by size or duration.
    UI: wrong offset for first child item within nested folders when the root folder was not shown on the list.
    Drag and drop: conflict drag n' dropping and pressing Ctrl over the "+" button, unintentionally triggering last edited playlist highlighting at the same time (feature introduced at 0.14.0).
    UI: drag and drop and other features requiring a playlist selection did not work properly with selections from other panels which were not using a playlist as source. Issue #81
    Playlist locks: workaround for SMP bug related to playback on locked playlists. It should now work fine, but the 'default action' lock can not be switched anymore. Issue #82
Reply #356
Hi! :) I have 2 errors after updating the scripts :
Error: Spider Monkey Panel v1.6.1-mod (Playlist Manager: Playlist Manager v0.16.0 by regorxxx)
too much recursion
File: helpers_xxx_foobar.js
Line: 25, Column: 17
Stack trace:
  compareVersions@helpers_xxx_foobar.js:25:17
  isCompatible@helpers_xxx_foobar.js:32:9
  _isFile@helpers_xxx_file.js:102:6
  getFilePathsFromPlaylist@helpers_xxx_playlists_files.js:434:6
  getHandlesFromPlaylist@helpers_xxx_playlists_files.js:779:29
  _list/this.getHandleFrom@playlist_manager_list.js:6001:17
  _list/this.getHandleFromPlaylists/<@playlist_manager_list.js:5968:60
  _list/this.getHandleFromPlaylists@playlist_manager_list.js:5968:20
  getHandlesFromPlaylist@helpers_xxx_playlists_files.js:753:12
If I try to reload the panel, it happens again, it takes 1-2 minutes. Everything was fine before updating. The other error is for Playlist tools, I'll post there.
Reply #357
too much recursion
Stack trace:
Without any more info, can't say anything. It seems like you have some kind of circular reference between some smart playlists. It just load a playlist which then tries to load another one, and it goes back and forth indefinitely.
I would need you to check that, and possibly sharing such problematic playlists, if any. While doing that is really stupid, I clearly did not add any kind of safeguard for such usage, so is technically possible to make Playlist A use B as source and viceversa. If that's the case, it's not really a bug but anyway I will forbid such usage.
Reply #358
Ok, so this version should:
- Warn if you try to create a smart playlist with circular references.
- Warn if tries to load somehow such playlist, either internally or in UI (have not tested all cases though).
- New entry at playlist maintenance to check for circular references.
It's a package for testing. It's missing the readme pdf.
Reply #359
Thanks to your tip I managed to solve this, I didn't use the package.
I remembered that I created a smart playlist , probably 2-3 months ago....I removed that smart playlist and everything seems ok now, that error doesn't appear. I'll send you a PM with the details of that smart playlist, just in case it's useful.
But there is one more issue....something that I forgot to mention last time. I also have this error:
unknown format:
File: chroma.min.js
Line: 86, Column: 1596
Stack trace:
  g@chroma.min.js:86:1596
  m@chroma.min.js:86:1908
  getColorName@playlist_manager_menu.js:3218:36
  createMenuRightTop/<@playlist_manager_menu.js:3237:61
  createMenuRightTop@playlist_manager_menu.js:3224:13
  func@playlist_manager_list.js:7174:6
  _list/this.lbtn_up@playlist_manager_list.js:1845:14
  @playlist_manager.js:669:9
  fireEvents/</<@callbacks_xxx.js:149:37
  fireEvents/<@callbacks_xxx.js:145:30
It happens when I try to right click Action button, and also when I try to left click settings button.
Thx for your patience.
Reply #360
unknown format:
File: chroma.min.js
Stack trace:
Your playlist was referencing itself, which is obviously wrong. You made Playlist X with a query using Playlist X as source xd Obviously that should crash. I didn't test that specific case, but I think my latest changes should also warn about it.
About your other error, that seems some error from past versions with some color missing not added at a later update. Will look for it tomorrow. If you post here your properties of the panel (you can skip anything with paths), I will surely find it faster.
Reply #361
I mention this just in case that it matters, I just noticed, it seems the smart playlist had the same name that another playlist present in the query....2 playlists of different types with the same name. So the playlist in the query wasn't referencing itself, I think , no? Pics with the properties panel:
Reply #362
You can not have 2 playlists with same name. There are multiple warnings via popups when that happens. Also if it's "same name/different type", then its referencing itself, since a reference is matched by name.
I need the file, not a screenshot. Text is larger than the window. You can export the properties at that same panel.
Reply #365
Aaand total success, everything seems ok now 👍Thanks a lot
Reply #366
New version should properly handle this cases in the future, along the smart playlist circular references and some other fixes.
https://github.com/regorxxx/Playlist-Manager-SMP/releases/tag/v0.16.1
