Topic: ARDFTSRC - Real Discrete Fourier Transform Sample Rate Conversion (Read 12313 times) previous topic - next topic
As available in Librempeg. Latest version have fixed input/output/duration bug.
Output is with minimal aliasing for many values of quality option set:
32000 Hz Sweep 32-bit Float -> 44100 Hz Sweep 32-bit Float
Audio filter ardftsrc, one possible very high quality processing example:
ffmpeg -i sweep.wav -af "aformat=dblp,ardftsrc=44100:quality=4096" -c:a pcm_f32le ardftsrc_4096q.wav
X
For smaller values of option quality and with float input instead of double input samples small aliasing can be seen and very small ringing on very high frequencies but this is only for extremely very low dB levels, much below 120dB.
Speed is on one machine tested consistently faster than SoX for same/similar quality presets.
Drawback is relatively high delay + buffering needed to process audio samples, quality filter option correlates with filtering delay size.
Known bugs:
- for some quality option values and sample ratio conversions combinations output may be invalid due to bug in x86 asm avx2 code path in FFT processing code, workaround is to use different value of quality parameter and/or disable certain/all instruction with "-cpuflags XXX" parameter set.
Re: ARDFTSRC - Real Discrete Fourier Transform Sample Rate Conversion
The taper window was changed from tukey to planck-taper window, this gives much less artifacts for same quality setting value than before.
Now with samplerate conversion from 48000 to 44100.
Why nobody cares?
It's a solution in need of a problem.
I'd care if it was a standalone solution with a nice license. Only thing where resampler is needed in FFmpeg is DSD playback IMO.
Very disappointed.
It's like a reinvention of the wheel to me with a more inferior design or a design that's not well refined.
@mycroft : if you were able to demonstrate by ABX that your DFT resampling is superior to the standard quartic (or whatever) waveform fitting, and provide those comparisons for others to verify, there might be some take-up, but my hunch is that it's no better and potentially worse, while at the same time being much more compute-intense.  Anything subjected to DFT is at risk of spurious artefacts.
You've really not provided any evidence.  A couple of nice smooth plots is not evidence of fidelity.  What I would want is a detailed plot showing the original input samples and the resulting output samples, demonstrating that it is at least a good match.  Then I might consider listening tests.
@mycroft I know that feeling, I'm sorry for you.
