Error levels in ADCS used in comparisons
2011-02-25 18:29:06
Hello Chaps, I have been interested in the issue of jitter audibility (or not) for some time. In another place that rhymes with dead-fi there is a discussion which turned to the effect of using reclocking devices to replace a USB----DAC chain with a USB----Reclocker----Toslink-------DAC chain. The proponents of the reclocker device maintain that since the USB mode of digital transfer is so bad jitter wise that taking the alternative route will mean the signal has so much less jitter that the sound will be vastly improved assuming a DAC with normal jitter rejection. My argument was that if lowering jitter in the link to a DAC makes so much difference it would be easily meausurable in the analog output of the ADC which one could route to an ADC bung through a spectral analysis and do the maths on. This is trivial. I have done analyses of samples with differering levels of jitter and the level of jitter does alter the spectra albeit to a small degree. The reclocker camp came back and say that a cheapo USb ADC used to capture such differences cannot do so. To which my response is that any competent ADC has a known level of quantization error which is typically about 1/2 an LSB ? So for a difference in samples to be swamped by the quantization error the difference must be less than 1/2 an LSB or thereabouts i.e any difference of less than about 0.015mV when using a 16 bit system is lost. My question is twofold, am I way off beam, I don't mind being called ignorant and if not is a difference of less than 0.015mV even likely to be audible ?
