Topic: Resurrecting/Preserving the Helix MP3 encoder (Read 70117 times) previous topic - next topic
Re: Resurrecting/Preserving the Helix MP3 encoder
Reply #50
As an aside, on my 8500T based test micro system, a 64 bit build of the C code using LLVM 15.0.5, optimised for AVX2 is roughly 10% faster than the 32 bit ASM build.
Reply #51
Did you specify the "-U2"-flag to use the Pentium III (=SSE) code path for 32-bit?
Reply #52
Actually, no. Using -U2, results in more or less identical times.
Reply #53
Thanks to Peter in the fb2k forums it became clear that the Helix encoder writes a slightly off (by +1) number of total frames into the Xing VBR header. fb2k doesn't decode until the last frame (then discards surplus samples), but uses the number of frames to determine the total number of samples, then subtracts the padding.
Long story short: I pushed changes to GitHub so that encodes should now be sample-accurate-length in fb2k.
Reply #54
I can confirm all is good. Many thanks for your efforts in solving all the issues here. Great work! :)
Reply #55
@maikmerten, I hope you don't mind but I have taken the liberty of providing this on rarewares, attributed to you, in place of the old compile which obviously had issues.
Reply #56
Thanks for your vote of confidence, your testing and providing Windows builds! :-)
Reply #57
You might be amused to know that LameTag 0.4.1 still fails to read the tag. However, I discovered I had version 0.3.1, including the pascal/Delphi source, and that reads the tag perfectly!!
If you're interested, you can d/l from here: https://www.rarewares.org/files/LameTag-0.3.1.zip
Reply #58
Wow! Never thought the gapless implementation will come at all, leave alone that fast. I asked for that several years back already.
Thanks for your time folks :)
Reply #59
Well, I'm pretty sure that many MP3 tools have some built-in assumptions that are based on what LAME in particular is doing.... and who can blame them, with no other implementations choosing to implement the info tag?
You're welcome, it's a fun side-project!
Reply #60
A slight conundrum. According to LameTag 0.4.1, the latest 'lame-svn-r6507-trunk' writes Revision 0 to the lametag. Strangely, LameTag 0.3.1 fails to read the lametag beyond indicating the lame version. Changing the Revision number to 0 in hmp3 results, in my tesfile, in 196 fewer bytes being written which is reflected in the padding being reduced by the number. fb2k appears to be Revision agnostic as it displays the correct information for both files and decodes correctly. Probably of no consequence but just struck me as odd.
Reply #61
I'm not sure I follow. Did you edit xhead.c to simply write "version 0" into the info tag version field and suddenly fewer bytes are emitted?
I used http://gabriel.mp3-tech.org/mp3infotag.html as specification. Sadly, I don't see information on what version that spec describes, so I just assumed it would be the presumably more recent one ("version 1").
Reply #62
Yes, that's all I did. Bizarre, I know, but I can't follow the lame code well enough to understand what's going on.
Reply #63
Ah, so you played around with LAME, not the Helix encoder?
Reply #64
No, I changed the Revision number in xhead.c. I wasn't trying to be contentious, I was just trying to understand the difference between the revisions. ;)
Reply #65
Ah, okay, thanks for confirming. Then I don't see a reason why just changing the version of the info tag in xhead.c would have any effect on the number of bytes being written. The length of the header is determined before the actual encoding loop (line 607 in tomp3.cpp) and there's no code there to switch between version 0 and 1. The actual info header contents (including the version number) are written after the encoding loop (line 777 in tomp3.cpp). At that point the file size should already be final...
Reply #66
Apologies, I think I managed to confuse myself and mixed up what was encoded using the asm build and that which was encoded with the 64 bit C build. I have just confirmed that you are, of course, correct. Sorry about that!
Reply #67
No problem, at least this confirms that the ASM builds follow a different codepath ;-)
Reply #68
I managed to get gapless in CBR by modifying the header in the mp3 file and it works just like in VBR. :)
Reply #69
Interesting, Did they ever release their raac encoder on Helix? Or was it MP3 only?
Reply #70
Hi KrajzegaX, yeah, there's no proper reason why it shouldn't work for CBR - its just that RealNetworks didn't hook up the logic to submit the bitrate to their Xing-Header code. However, I know quite exactly where to hook things in and opened a ticket for that: https://github.com/maikmerten/hmp3/issues/1
(Long story short: For VBR, the header logic can just choose the smallest frame bitrate for the info frame that is big enough to fit all that information - it's VBR, after all, so frames can be of different size. For CBR, the header logic needs to pick exactly the same frame  bitrate as for the audio frames, it wouldn't be CBR otherwise. However, RealNetworks just submits "0" to the header code as bitrate, which means the information will never fit, thus the info frame is skipped)
I hope to get to that pretty soon.
To my knowledge, they never opened their proprietary format encoders.
Reply #71
Okay, took the liberty of enabling the Xing/Info-Header for CBR files now. Also, since yesterday, MPEG-2 files get the Xing/Info-Header as well.
edit: Note that for very low CBR bitrates, the info header may not fit and is then disabled.
Reply #72
Fresh compiles at rarewares. :)
Reply #73
I believe the version number should be bumped to Helix 6.
Thanks to the renovation effort of maikmerten, the new Helix is now very modern, compared to the ancient 2005 version, Helix v5.1.
Easier to recognize if the major version number is higher.
Reply #74
I second that. Gapped playback is such a shortcoming that resurrecting it into a proper gapless-enabled encoder warrants a major-version-bump.
Going for "LAMEH5.11" for now. The "." makes it look better parseable as version number. The "H" behind LAME denotes "Helix" (I really really don't want to steal an actual LAME version string).
LAMELIX6.0 starts with "LAME", is sufficiently close to "HELIX" and ... well is the string too long? To test that, call it LAMELIX6.beta and see how many applications choke on it.
Also, the string now contains "MEH", which is neat.
If testing indicates that this works everywhere, I'd say you have de-meh'ed it successfully.
