Hello,
I'm trying to improve the response of the He1000 Stealth headphones with foobar. I have already exhausted the possibilities of the default equalizer present in fb2K, but I would like to connect the curve more precisely, for example by checking the attached graph (blue line) I should increase the 1kHz-3Hkz range by a few decibels, and also the range 20-90hz.
What really working solutions currently exist?
Thank you
Convolver with impulse processed with decent parametric EQ.
I guess MathAudio Headphone EQ (https://hydrogenaud.io/index.php/topic,109674.msg903195.html#msg903195) component might help? (Never used it)
^ Documentation (https://mathaudio.com/headphone-eq.htm)
Thank you guys.
MathAudio look likes fine and easy...
I tried Mathaudio, but my impression best and more rapid solution is the internal foobar equalizer.
Other thing... Mathaudio plugin in my audio-pc works fine without intall VST plugin; Is it possible?
My internal FB2K equalizer setting to compensate Hifiman HE1000 Stealth diagram
