Topic: foo_beefweb - modern web interface (Read 40453 times) previous topic - next topic
Re: foo_beefweb - modern web interface
Reply #100
When I open beefweb on my browser, it shows all my tracks in 1 HUGE playlist.
Is it possible to group then by genre => album artist or artist => album?
Thanks for the assistance.
Reply #101
Playlist menu > Custom...
%genre% - %album artist% - %date% - %album% - %discnumber% - %tracknumber% -%title%
%genre% - $swapprefix(%album artist%) - $sub(3000,%date%) -%ALBUM% - %DISCNUMBER% - %TRACKNUMBER% - %TITLE%
Green: Playlist select
Click the Playlist icon to update the Playlist.
For convenient use:
foobar2000 menu > Edit > Sort by...
Add some sorting patterns.
Register "Sort by..." to Keyboard Shortcuts.
for example: ctrl + Shift + S
Check Global hotkey.
Choose from sorting patterns.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #102
I'm going to try some small modding ... right now trying to just build the component from the beefweb-0.8 source code ... it keeps failing with these 2 errors. Can someone give me pointer as to what is wrong?
Steps taken:
  • installed all the beefweb-0.8 pre-requisites
  • download beefweb-0.8 source code
  • unzip it into a folder
  • start Visual Studio 2022
  • start VS2022 command prompt
  • issue the build command: msbuild scripts\build.proj /p:Configuration=Release
It runs for quite a while, then throws the following error:
  Performing install step for 'ext_zlib'
  -- ext_zlib install command succeeded.  See also S:/Visual_Studio_Projects/beefweb-
  0.8/cpp/build/Release/extlibs-root/src/ext_zlib-stamp/ext_zlib-install-*.log
  Creating import library for zlib1.dll
  -- ext_zlib make_import_lib command succeeded.  See also S:/Visual_Studio_Projects/
  beefweb-0.8/cpp/build/Release/extlibs-root/src/ext_zlib-stamp/ext_zlib-make_import_
  lib-*.log
  Completed 'ext_zlib'
FinalizeBuildStatus:
  Deleting file "Win32\Release\ext_zlib\ext_zlib.tlog\unsuccessfulbuild".
  Touching "Win32\Release\ext_zlib\ext_zlib.tlog\ext_zlib.lastbuildstate".
Done Building Project "S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\extlib
s\zlib\ext_zlib.vcxproj" (default targets).
s\zlib\ext_zlib.vcxproj.metaproj" (default targets).
Done Building Project "S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\ext_al
l.vcxproj.metaproj" (default targets) -- FAILED.
Done Building Project "S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\server
\core.vcxproj.metaproj" (default targets) -- FAILED.
Done Building Project "S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\beefwe
b.sln" (default targets) -- FAILED.
Done Building Project "S:\Visual_Studio_Projects\beefweb-0.8\scripts\build.proj" (def
Build FAILED.
"S:\Visual_Studio_Projects\beefweb-0.8\scripts\build.proj" (default target) (1) ->
"S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\beefweb.sln" (default target
) (2) ->
"S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\server\core.vcxproj.metaproj
" (default target) (4) ->
"S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\ext_all.vcxproj.metaproj" (d
efault target) (5) ->
"S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\extlibs\foosdk\ext_foosdk.vc
xproj.metaproj" (default target) (8) ->
xproj" (default target) (9) ->
(CustomBuild target) ->
  C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\M
icrosoft.CppCommon.targets(254,5): error MSB8066: Custom build for 'S:\Visual_Studio_
Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\39a10b2bcdfa4bd8961faf62af603ee3\ex
t_foosdk-mkdir.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFile
s\39a10b2bcdfa4bd8961faf62af603ee3\ext_foosdk-download.rule;S:\Visual_Studio_Projects
\beefweb-0.8\cpp\build\Release\CMakeFiles\39a10b2bcdfa4bd8961faf62af603ee3\ext_foosdk
-update.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\39a10
b2bcdfa4bd8961faf62af603ee3\ext_foosdk-patch.rule;S:\Visual_Studio_Projects\beefweb-0
.8\cpp\build\Release\CMakeFiles\39a10b2bcdfa4bd8961faf62af603ee3\ext_foosdk-configure
.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\39a10b2bcdfa
4bd8961faf62af603ee3\ext_foosdk-build.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\
build\Release\CMakeFiles\39a10b2bcdfa4bd8961faf62af603ee3\ext_foosdk-install.rule;S:\
Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\a990d6aed58809e06235a
3d29d51faa2\ext_foosdk-complete.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\
Release\CMakeFiles\baf6f0184f7f380f32d1913cb5728162\ext_foosdk.rule;S:\Visual_Studio_
Projects\beefweb-0.8\cpp\extlibs\foosdk\CMakeLists.txt' exited with code 2. [S:\Visua
l_Studio_Projects\beefweb-0.8\cpp\build\Release\extlibs\foosdk\ext_foosdk.vcxproj]
) (2) ->
"S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\extlibs\stringencoders\ext_s
tringencoders.vcxproj.metaproj" (default target) (12) ->
tringencoders.vcxproj" (default target) (13) ->
Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\7cdbc30f19678a66cf35621c4726fa3b\ex
t_stringencoders-mkdir.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\C
MakeFiles\7cdbc30f19678a66cf35621c4726fa3b\ext_stringencoders-download.rule;S:\Visual
_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\7cdbc30f19678a66cf35621c472
6fa3b\ext_stringencoders-update.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\
Release\CMakeFiles\7cdbc30f19678a66cf35621c4726fa3b\ext_stringencoders-patch.rule;S:\
Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\7cdbc30f19678a66cf356
21c4726fa3b\ext_stringencoders-configure.rule;S:\Visual_Studio_Projects\beefweb-0.8\c
pp\build\Release\CMakeFiles\7cdbc30f19678a66cf35621c4726fa3b\ext_stringencoders-build
.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\7cdbc30f1967
8a66cf35621c4726fa3b\ext_stringencoders-install.rule;S:\Visual_Studio_Projects\beefwe
b-0.8\cpp\build\Release\CMakeFiles\227a5dcaeb306afe9c0bd9c25d325c77\ext_stringencoder
s-complete.rule;S:\Visual_Studio_Projects\beefweb-0.8\cpp\build\Release\CMakeFiles\ab
7a76c9c1c7d9854f4edd6faa3c21ee\ext_stringencoders.rule;S:\Visual_Studio_Projects\beef
web-0.8\cpp\extlibs\stringencoders\CMakeLists.txt' exited with code 2. [S:\Visual_Stu
dio_Projects\beefweb-0.8\cpp\build\Release\extlibs\stringencoders\ext_stringencoders.
vcxproj]
    0 Warning(s)
    2 Error(s)
Time Elapsed 00:11:38.67
All help and guidance would be greatly appreciated...
Reply #103
Nice component, it really gives foobar2000 a great option. Thanks, Hyperblast
There's just one thing I'd wish for to make it perfect for my needs, which would be group by artists and albums.
I got about 200.000 audio files in my library and it really takes a while to scroll all the way down to the bottom. In fb2k itself I group them by artist and then by album and that way I can manage that library. I haven't found a way yet to pass something like group by artists over to this remote interface. I might be stuck to listen to AC/DC and will never go down to ZZ Top that way, it just takes too long:-)
Is there a way to achieve this? Right now it's like mrjayviper says, it shows one huge playlist (or the playlist I chose to play from the foobar2000 application)
