Topic: Pazera Software Lame Front-End (Read 3956 times) previous topic - next topic
We would generally recommend LameDropXPd as a LAME front end, or foobar2000 if you need a player/converter/tagger/etc.
I'm on a horse.
ALL2LAME is good if you just want an easy way to do batch operations with whatever version of LAME you have.
is there any installer version of all2lame & lamedropxpd?
ALL2LAME does not need installing. Extract the zip archive and run ALL2LAME.exe.
then how to remove all2lame leftovers when i want to uninstall? (registry & app date leftovers)
There is no installer for LameDropXPd. Simply unzip and run from any folder/directory. The first time you run it, it will create a .ini file in the same folder. If you wish to uninstall it, just delete the folder, there are no registry entries created.
thanks.
but i want to use command line presets like:
-b 320
-V0 -v1 -v2 & ...
thanks.
-b 320
-V0 -v1 -v2 & ...
Use ALL2LAME, then. It lets you type in the command-line switches that you desire. It too is "uninstalled" simply by deleting the program's folder. No registry entries are written.
