Topic: JScript Panel script discussion/help (Read 296644 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #1375
So I've been messing around with a new menu bar script - mainly for CUI since you can't hide the menu in DUI.
This time I've not been so lazy and made a menu for customising the colours....
The buttons will always be black or white based on background colour.
It will be in the next component release but it can be tested now by pasting this in a panel...
https://raw.githubusercontent.com/jscript-panel/component/main/samples/Menu%20%2B%20Playback%20Buttons%20%2B%20Custom%20Colours.txt
Requires component version 3.4.7 or later (the release that ditched FontAwesome and uses Segoe Fluent Icons for all buttons)
Reply #1376
Hey marc2k3 or anyone,
I've been modifying the 'Status Bar' sample to show both selection and playlist totals, and one thing I miss from the built-in status bars is the "Starting playback..." message, which appears in between the stopped and playing states. This is mostly only noticeable when playing a stream, since playback starts more or less immediately from local files.
I know there is on_playback_starting callback (not in the original sample), and the on_paint is using if (fb.IsPlaying) {...} else {...}, but I seem to be missing how to get it to write text only in between the two states when starting. I tried the inverse if (!fb.IsPlaying) to see if that catches it which did not work either. Basically just trying to get the var left_text_status to display "Starting..." when the track / stream is loading.
Look, I'm not competent at this stuff. :D
(No doubt something simple I'm missing - below is the mess I have so far but you may have to avert your eyes there, perhaps an update to the original sample to fix this small issue would clue me in? ;) )
Edit: Fixed code that saving a draft on the forum screwed up...
Spoiler (click to show/hide)
Reply #1377
Interesting. Would it be possible to have an alternative to Text Display with the menu and Playback buttons placed in this way ?
Reply #1378
Updated status bar: https://raw.githubusercontent.com/jscript-panel/component/main/samples/Status%20Bar.txt
And nope, I'm not making any more changes to Text Display. Most of my scripts are flexible with regards to positioning/dimensions. This is not so easy and I can't be bothered.
Reply #1379
How can I check if a certain pattern is in a string?
For instance:
var str = 'Speakers some more text [exclusive]'
How to check that the var str contains 'Speakers ' and/or contains ' [exclusive]'?
Reply #1380
This Status Bar script has been updated: https://raw.githubusercontent.com/jscript-panel/component/main/samples/Status%20Bar.txt
You can now set title formatting via the right click menu and $rgb is supported.
Reply #1381
Is it possible to move the image (Cover Art) a little lower, by a few pixels?
X
Reply #1382
Search this line in text_display.js
_drawImage(gr, albumart.img, albumart.x, albumart.y, albumart.w, albumart.h, image.centre);
add the number of pixels to albumart.y (e.g. + 5) and save the file, but remember, that with every update the file will get overwritten, so better save it somewhere else and replace the path in the config window with your new path (or change the file after every update, that's up to you)
Reply #1384
Yet another Status Bar update: https://raw.githubusercontent.com/jscript-panel/component/main/samples/Status%20Bar.txt
This fixes actual bugz. Ever since the first version, it didn't support the font size being changed so any manual change or DPI increase would have chopped it off. Sorry about that.
Now that it can take up the panel height, multi-line with wrapping is now possible. Use $crlf() in your title formatting.
Reply #1385
^ I never would've figured that out myself. It'll take me some time to integrate the new changes, so I'll just assume it goes smoothly and say thanks now. Thanks :)
Reply #1386
Thanks. I'll try It.
Reply #1387
Nice one Marc2k3... I will try it too....
Reply #1388
I would like to use icons of the font 'Material Icons Round Regular'. How to do it ?
I tried, to use '\uE03D' with char_set[button_set_idx].playlist :
But it does not work. :(  :(
X
Reply #1389
I think, the font is just called 'Material Icons Round' without 'Regular', at least, that's what it's called here in my system
Reply #1391
I tried, but It doesn't work.
[/quote]
A little hard to tell you why without the corresponding code - you just defined some variables...
Reply #1392
[/quote]
Then I use rg_plchars to display the button :
	bpos = btot - 4;		this.buttons.plmanager	= new _button(x + (bs * bpos), y, bs, bs, { char : rg_plchars, colour:colours.white}, null, function () { fb.RunMainMenuCommand('View/Playlist Manager'); }, 'PL Manager');
C'est ce que je veux afficher :
X
Reply #1393
Supposing your standard font is Segoe Fluent Icons, why not just put this line into your code and forget about the rest:
this.buttons.plmanager   = new _button(x + (bs * bpos), y, bs, bs, { char : '\ue90b', colour:colours.white}, null, function () { fb.RunMainMenuCommand('View/Playlist Manager'); }, 'PL Manager');
Reply #1394
X
[/quote]
Like this?
RDIT: Try the attached script
Reply #1395
That's the output of the code you provided - wouldn't look any different with Material Font
You will have to alter the size of the button by adjusting the second bs value:
   this.buttons.plmanager   = new _button(x + (bs * bpos), y, bs, bs + 5...
or whatever value suits your needs
Reply #1397
Thanks for your help.
But if I want to use "Material Icons" for '\ue90b'. What should I write before ?
Reply #1398
Reply #1399
[attach type=image]29696[/attach]
Like this?
[/quote]
It works perfectly. Thanks. 👍👍
The _button_mir function allows, among other things, to assign the "Material Icons Round" font to the plmanager button. 👍
