Topic: Low Bit Rate Conversion from WAV vs. Conversion from AAC (Read 1731 times) previous topic - next topic
Posting here as it may get technical.
Is there a way to quantify/assess the reduction of quality in a 128 AAC VBR that was converted from 320 AAC VBR, as compared to a higher quality file, same specs, if converted from an original WAV?
Re: Low Bit Rate Conversion from WAV vs. Conversion from AAC
For each MB of file compressed in mono at 256kbps (more that 320kbps in stereo) you will find about 3kB of difference (0.3%) from the wave file depending on the content.
You will hardly be able to hear the difference but in any case you are not testing the AAC format but a specific encoder and many do not work at 320kbps, with mono input.
