Topic: foo_httpcontrol (Read 949333 times) previous topic - next topic
Re: foo_httpcontrol
Reply #1225
What is Browser?
Doesn't it show up at the end of the download?
Can't you click continue and save?
Direct Link: https://foobar2000.xrea.jp/up/files/up1517.zip
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Re: foo_httpcontrol
Reply #1226
感谢提醒,更换浏览器下载之后就正常了,但是下载安装好新组件(foo_httpcontrol_0_97_28.fb2k组件)之后,发现在手机控制端电源功能(关机、重启)无效,希望下个版本可以修复,其他功能正常。
Please provide English translation in future posts.
TOS 10. All members must post in English. Content in other languages allowed as long as full English translations are provided, or otherwise at the discretion of the staff.
Google translation:
Thanks for reminding, after changing the browser and downloading it will be normal, but after downloading and installing the new component (foo_httpcontrol_0_97_28.fb2k component), I found that the power function (shutdown, restart) of the mobile phone control terminal is invalid, I hope the next version can be repaired, and other functions are normal
Re: foo_httpcontrol
Reply #1227
what are you using?
Device Controller: foobar2000 controller PRO?
Japanese wiki
https://foobar2000.xrea.jp/?General+64bit#h7682466
Re: foo_httpcontrol
Reply #1229
use google translate
HTTP Control component issue
Reply #1230
Hi everyone
I'm using foobar2000 v.2.1.3 [x86] and sometimes I'm using the remote control Pro for Android [Version 0.9.4.0a from July 2016].
Everything works great but recently I've noticed the following message on my Android app:
"Last version of HTTP Control component needed. Please get it on http://tiny.cc/fb2kc" (Please see screenshot attached).
When I open the download link, there's a zip file name: foobar2000 controller [PC-side setup] v2.0.1, and when I starting the installation process, I see that the component's version is: 0.97.14 (screenshot attached), which is older version then the one installed on my foobar2000 software: 0.97.28 (I got it from here.
My questions are:
1. Why do I get this message?
2. Is there any other source or newer version for the HTTP Control component?
Thanks in advance
Re: foo_httpcontrol
Reply #1231
The app in Android uses a different (+outdated) version than this one. BUT the version built for Android does have some extra commands, in particular the one which checks component version, not available on this one.
Therefore... it thinks the component is outdated (even if it is not), because the latest version doesn't output the version number.
All this has been documented here:
https://hydrogenaud.io/index.php/topic,62218.msg1028836.html#msg1028836
In case the developer wants to add the missing commands, which would fix your problem too.
Re: foo_httpcontrol
Reply #1232
Finally have been doing it by myself, and works fine. Added Version, FoobarVersion (which I found to be requested only after adding the previous one) and the GetQueue.
All emulate the functions needed by the controller, and seem to work fine on my side. This is the 32 bit dll. Must be put at
[foobar_profile]\user-components\foo_httpcontrol\
I don't have a bitbucket account and not interested on creating one, attached is the modified source code. For reference:
Spoiler (click to show/hide)
As far as I know, only things missing are the power actions related to shutdown, reboot, etc.
EDIT: updated readme.
Disclaimer: my experience with c++ comes from a lot of years ago, so don't complain if it crashes or whatever. Seems to work fine on my side though. This is just for the developer to merge it.
Re: foo_httpcontrol
Reply #1233
Thank you regor!
And sorry, but where can I get a remote control app for Android without a Google account, please? Do you see any possibility without PlayStore on the phone? Are there any trustworthy sources? Thank you.
Re: foo_httpcontrol
Reply #1234
I download any app from google store using Aurora store; it uses a fake account. Aurora store can be downloaded from github, f-droid, etc.
https://f-droid.org/packages/com.aurora.store/
(direct download of apks are at bottom)
Re: foo_httpcontrol
Reply #1235
Same version than above, but as component file, compatible with both x32 and x64.
