Topic: Input/Other decoders (special format) 64bit (Read 19299 times) previous topic - next topic
Re: Input/Other decoders (special format) 64bit
Reply #76
Organya ("Cave Story") decoder
Reply #77
There exist no modern reincarnations of foo_input_mdx and foo_input_s98?
Reply #78
PMD Decoder plays PMD files.
Reply #79
Is this a reply to my post above? It seems that PMD decoder can't play *.s98 files, that foo_input_s98 can play. Samples - https://www.dropbox.com/scl/fi/6l3pevu82upzt7gfvdljv/S98.zip?rlkey=qegb97tm5qesd2vo2li2ak7l9&dl=1. foo_input_s98 - http://www.vesta.dti.ne.jp/~tsato/arc/foo_input_s98_090419.7z
Reply #80
You're right. .s98 is a different format. I was too quick to respond. But I'm reading up on those format albeit slowly because of most of it is in Japanese.
Reply #81
One VGM input can play .s98 two geting this error on the plugins from the first post
"Failed to load DLL: foo_input_2sf.dll
Reason: Not a valid Win32 application.
Failed to load DLL: foo_input_usf.dll
Failed to load DLL: foo_input_spu.dll
Failed to load DLL: foo_input_qsf.dll
Reply #82
Supports only 64bit.
32bit
https://foobar2000.xrea.jp/?Input#yd77854d
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #83
I am using the 64 bit build so I confused. Fixed windows .rar suport sucks 7zip fixed it
Reply #84
Oh it's true. Sorry.
Please use 7-Zip etc.
7-Zip
https://7-zip.org/
components
32bit 64bit Support.
Reply #85
VGM input v0.30 beta 3 (foo_input_vgm) x86_32 x86_64 (2023-11-26)
https://ux.getuploader.com/foobar2000/download/240
How to download: A small button above the image 「ダウンロード」click, Next Page > A small button above the image 「Download Now」click
Reply #86
PSF decoder / Mednafen 1.27.0-UNSTABLE v1.3 (foo_input_mdfnpsf) x86_32 x86_64
https://ux.getuploader.com/foobar2000/download/241
Reply #87
foo_sid is a component that plays SID and MUS files.
The old foo_sid component has been archived by kode54. This version:
* Bug fix: MUS and MUS+STR files play again.
URL: https://github.com/stuerp/foo_sid/
Download from the Releases page.
Sorry for the random/necro reply, but I noticed that any config that isn't reSIDfp with the filter 6581 set to 1.0 & the 8580 filter set to 0.0 has a artifacts or does not emulate properly, outputs a different reading on every play.
Don't know if this is a kode64 era bug or introduced in this port, or if it's even an expected result of the other configurations, but it's worth mentioning since i took a while to figure out the non-broken setting.
Reply #88
I'll have a look at it because I have to upgrade to the latest libsidplayfp anyway.
Reply #89
v1.95.0.0, 2024-04-10, foo_sid
* Upgraded libsidplayfp to 2.7.0.
You can download it from the Component repository or from GitHub.
Reply #90
2SF decoder / DeSmuME v0.9.9 0.24 (foo_input_vio2sf) 2024-04-27
https://foobar2000.xrea.jp/up/files/up1957.7z
