Topic: foo_dsp_soundtouch (Read 153259 times) previous topic - next topic
foo_dsp_soundtouch
Reply #75
Thank you so much!!
foo_dsp_soundtouch
Reply #76
is there any way to change the speed from within foobar's main window and in real time? Kinda like the volume slider, but for playback speed.
foo_dsp_soundtouch
Reply #77
1) Probably not.
2) The closest you'll get to real-time depends on your output buffer size.
foo_dsp_soundtouch
Reply #78
1) Probably not.
I see. Or at least somehow change the settings from the playback interface (even if it won't change in realtime). It's a pain to go through the settings all the time.
foo_dsp_soundtouch
Reply #79
I don't suppose there's any chance of getting an updated version of this plugin that works natively under Windows 7 x64 is there?
I get the following error:
Failed to load DLL: foo_dsp_soundtouch.dll
Reason: This component is not compatible with this version of Windows and needs to be recompiled with a newer version of the foobar2000 SDK; please contact the author of this component to obtain an updated version of this component.
I was able to get around it temporarily by running Foobar2k in Windows XP SP3 mode, but that causes other problems (like you can't drag and drop files into foobar).
foo_dsp_soundtouch
Reply #80
Try to run foobar in compatibility mode (right click on foobar's desktop shortcut, properties, compatibility)
That should do it.
Disregard the constabulary.
foo_dsp_soundtouch
Reply #81
That should do it.
Yes, as I mentioned it does allow the plugin to work, but that causes Foobar to act a little funny.  For example, you can't drop files into Foobar when it's running in compatibility mode.
foo_dsp_soundtouch
Reply #82
I think i ran it in Vista mode if i remember correctly, without any problems..
Maybe some other plugins are causing the problem.
foo_dsp_soundtouch
Reply #83
I doubt it because that's the only one I have installed.  It's a brand new system, so I installed Foobar2k v0.9.6.9 and only the soundtouch plugin.
foo_dsp_soundtouch
Reply #84
It turns out there is a recompiled version on Acropolis's site.  It works great under Win 7 x64.  Unfortunately, for whatever reason I can't link to the site, so if you google for foobar2000 components acropolis blog you should be able to locate it.
