HydrogenAudio
Hydrogenaudio Forum => General Audio => Topic started by: shitdarling on 2024-04-25 19:32:28
Title: Can ALAC/m4a detect file corruption?
Post by: shitdarling on 2024-04-25 19:32:28
I have found amount of article, and know that flac/ape/tak can check audio integrity with inner crc info and outter md5.
ALAC/m4a is also open. But its format is so complicated (so many "box" type with different meta info), and I try to find crc or md5
in the format  structure detail description, and cant find them.
I have tried use an hex editor directly change some random bytes in middle of the alac file.
First time I change 2 position, [foobar 2000 - verify integrity] says it's ok. So the check tool cant detect this change.
Second time I change 2 more position, and this time the tool report :
"Reported length is inaccurate : 4:25.653333 vs 4:25.560454 decoded
Error: Decoding error: Unsupported format or corrupted file, frame: 2112 of 2861".
May there anyone know much about ALAC/m4a structure could tell me :
Can ALAC/m4a detect file corruption? (with inner metadata like crc/md5?or other mechanism?) O:)
Title: Re: Can ALAC/m4a detect file corruption?
Post by: Porcus on 2024-04-25 19:36:32
I tested some of it: https://hydrogenaud.io/index.php/topic,122094
I did get some error reported (Reply #9) - when I destroyed a frame header.
Post by: shitdarling on 2024-04-26 06:27:12
I found this
https://wiki.hydrogenaud.io/index.php?title=Lossless_comparison (which's reference is [2014]this post (https://hydrogenaud.io/index.php/topic,33226.msg862031.html#msg862031)
we can see that ALAC dont support error handling
but in hex chenged test, It indeed can detect some error if you change the metadata.
Post by: Peggyooney on 2024-05-03 07:50:43
I found this
Can you show me the steps to change the data?
Post by: Porcus on 2024-05-03 08:42:26
Simple corruption test: https://hydrogenaud.io/index.php/topic,122094.msg1007969.html#msg1007969
That particular reply was for lossies, but I did similar to ALAC (/TTA, which you don't want to use either).
