Topic: Unplayed Albums (Read 2451 times) previous topic - next topic
Unplayed Albums
Is there a method to display any album that has none of it's tracks played?
Unplayed Albums
It's only possible to show tracks that has not been played yet. unfortunately, you can't query the database albumwide or artistwide.
maybe, if you use columns ui you could use foo_playlist_tree_mod. I didn't use this component, but it's predecessor, foo_playlist_tree could query albumwide/artistwide/genrewide and so on. Actually, it didn't query the database for that, but it's own nested results (query in query).
Unplayed Albums
Add the "Played" statistics column to an album pane in foo_facets
elevatorladylevitateme
Re: Unplayed Albums
Reviving an old question...
I can get the albums displayed in a playlist column or facets (re: Shakey above) but is there currently a way to do this which is autoplaylist compatible?
I tried
Library > album list > filter by %last_played_enhanced% MISSING
but results are still track based and not album grouped.
Re: Unplayed Albums
I tried
"Library Tree" album list can apply filters and maintain album grouping, it already has a 'never played' preset.
Re: Unplayed Albums
Nope. That will always be track based.
I guess facets can't handle %last_played_enhanced% field so trying the Library Tree suggestion above might be your easier route (assuming customising the playcount field is easy and doesn't require editing the script).
foo_uie_sql_tree or the murky world of scripting with Spider Monkey Panel/JScript Panel are the harder ways to do it!
Re: Unplayed Albums
Thanks to you both...
I tried this and it is still track based - results are all albums with the played tracks removed.
I'm trying to remove an album from results if it had any played tracks.
Re: Unplayed Albums
Here's a script for JScript Panel that generates a static playlist containing albums with no plays. Customise the fields at the beginning to suit. It might work with SMP but not tested. just remembered it won't work with SMP
It's a plain white panel and you double click to execute the code. Obviously it's just an example of what is possible, not meant for full time usage.
var group_by = "%album artist%|%album%|%date%";
var filter_by = "album PRESENT";
var playcount = "$if2(%last_played_enhanced%,0)"; // must evaluate to zero for unplayed tracks
var tfo = {
group_by : fb.TitleFormat(group_by),
order_by : fb.TitleFormat(group_by + "|%discnumber%|%tracknumber%"),
playcount : fb.TitleFormat(playcount),
function on_mouse_lbtn_dblclk() {
var items = fb.GetQueryItems(fb.GetLibraryItems(), filter_by);
items.OrderByFormat(tfo.order_by, 1);
var album_list = fb.CreateHandleList();
var to_add = fb.CreateHandleList();
var current = "";
var good = true;
for (var i = 0; i < items.Count; i++) {
var item = items.Item(i);
var tmp = tfo.group_by.EvalWithMetadb(item);
if (tmp != current) {
if (good && album_list.Count) {
to_add.AddRange(album_list);
album_list.RemoveAll();
good = tfo.playcount.EvalWithMetadb(item) == 0;
if (good) album_list.Add(item);
current = tmp;
} else {
if (tfo.playcount.EvalWithMetadb(item) == 0) {
} else {
if (album_list.Count) album_list.RemoveAll();
good = false;
if (to_add.Count) {
var p = plman.CreatePlaylist(plman.PlaylistCount, "Albums with no plays");
plman.ActivePlaylist = p;
plman.InsertPlaylistItems(p, 0, to_add);
Re: Unplayed Albums
Very nice - works well. Is there a mod to generate autoplaylist? ;)
Re: Unplayed Albums
Nope. No amount of scripting trickery can do that. What it is doing is looping over every track in the library and evaluating on a per track basis and keeping track of what the current state is for every track belonging to the same album - something not possible with standard title formatting.
I suppose it is possible to create a fake autoplaylist in the sense it clears and updates itself whenever playcounts change but playing from the playlist would be probematic because the focused/playing track would be lost each time.
